Hello, all. I've been running FAH for a few weeks now, and I'm really enjoying it. It runs on my work PC, and I seem to be making good progress.
I'm wondering, though, if it continues to run if I haven't yet logged into Windows. I can't find anything in the FAQs that mentions this, and a forum search didn't turn up anything either.
I'm basically asking, if I'm leaving for the weekend, if I can reboot the PC and leave it not logged in, or if I need to log into Windows in order for FAH to run while I'm gone.
Thanks in advance for your help!
Best practice for long idle times: Reboot? Login?
Re: Best practice for long idle times: Reboot? Login?
On Windows, the folding client only runs while you are logged in.
It will continue to run if you just lock screen instead of log out.
