HOWTO: Local v8 Web Control
Post by calxalot »
HOWTO: Local v8 Web Control v8.5
What?
Use a local Web Control served by the client.
Why?
  • Want partial control of local client when internet is down
  • Want to use Safari to direct connect to local client
  • Have problems accessing https://v8-5.foldingathome.org
Why not?
  • Must be manually updated
  • May still access servers at foldingathome.org. This is not an offline solution.
Prerequisites
  • Administrator account so you can use sudo
  • Comfortable using the command line in Terminal
Download and install pre-built Web Control
https://master.foldingathome.org/builds ... se/latest/
Note that this is from bleeding edge builds.
These builds may occasionally be broken and can have an incorrect version number in file name.
Unarchive and rename extracted directory to just "fah-web-control".
Move it into the fah data directory.
On macOS, the data directory is
/Library/Application Support/FAHClient/
On Linux it is
/var/lib/fah-client/
Note: fah-web-control.zip is being built on only one worker, but the files are identical for all platforms.
Restart client
macOS
sudo /bin/launchctl stop org.foldingathome.fahclient
sudo /bin/launchctl start org.foldingathome.fahclient
Linux
sudo /usr/bin/systemctl restart fah-client
Windows
Use sys tray fah client icon menu to quit. Then relaunch via Start menu > Folding@home.
Enjoy
To access local Web Control, open
http://localhost:7396/
Use http://localhost:7396/machines if you get redirected to the public web site.
Edited for v8.5 on 2024-01-15
daiko
Hardware configuration: Mac Studio M1 Max
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Re: HOWTO: Local v8 Web Control
Post by daiko »
Thanks, calxalot. I appreciate the option to run local on MacOS (Ventura 13.2.1). I’m back to using Safari for folding control.
I downloaded and installed the latest beta from the given link, and it picked up where the previous version left off, no problems. 👍
Post by calxalot »
I have recently been asked for terminal commands to install the local web control.
You are encouraged to use your desktop GUI instead.
But if you must, this works on ubuntu 22.04 for the release version:
Edit 2025-01-15: this has been updated for 8.5.7 and is untested.
cd /tmp
wget -O latest.zip \
  https://master.foldingathome.org/builds/fah-web-control/debian-13-64bit/release/latest/fah-web-control_8.5.7.zip
unzip latest.zip
rm latest.zip
mv fah-web-control_* fah-web-control
sudo /usr/bin/rm -r /var/lib/fah-client/fah-web-control/
sudo /usr/bin/mv fah-web-control /var/lib/fah-client/.
Untested gets latest:
cd /tmp
base="https://master.foldingathome.org/builds/fah-web-control/debian-13-64bit/release/latest/"
# Download last zip file on page; extract, rename fah-web-control dir
zipfile=$(wget -q -O - "$base" | awk -F'"' '/href=.*\.zip/{print $2}' | tail -1)
wget -q "${base}${zipfile}" && unzip -q "$zipfile" && rm "$zipfile"
mv -v fah-web-control_8*/ fah-web-control
sudo /usr/bin/mv -f fah-web-control /var/lib/fah-client/.
Open http://localhost:7396/machines
If it won't load, restart the client and reload the web page.
JoeDaCabbie
Post by JoeDaCabbie »
Hola! I just tried re-installing 8.3.18 again because v7 was causing my machine to restart too frequently and am getting the 'DNS lookup failed for cores2.foldingathome.org' message again. On a whim, I ran cores2 through the RDAP.ORG Validator tool and got an Error 404 message. Are you all sure you've got that domain set up correctly?
Results
ℹ️ Version is 0.0.1.
ℹ️ Punycode.js version is 2.3.1.
ℹ️ Testing URL is 'cores2.foldingathome.org.
ℹ️ Response type is 'domain'.
ℹ️ Server type is 'vanilla'.
ℹ️ Sending request...
ℹ️ Received a response from the server.
❌ HTTP status 404 MUST be less than 400. 📖
cores2.foldingathome.org won't let you access anything unless you know the full link to the file.
