Way to use same WUs via Win10/Gentoo Dual boot?
sanik
Post by sanik »
Is this possible? I set up f@h on Windows, but I would like to be able to continue where it left off whenever I reboot into Linux.
Re: Way to use same WUs via Win10/Gentoo Dual boot?
I remember seeing this question already, but I don't remember the answer ... you'll have to search on the forums for similar topics.
sanik
Post by sanik »
found this after a more comprehensive search: "FAH's data in the work files is not the same format in Windows and in Linux. You can''t start a WU on on and then continue it on the other."
oh well.
