Web control disagrees with website on what the project subject is.
Peter_Hucker
Post by Peter_Hucker »
I'm running Project 18213, which web control says is cancer research by Dylan Novack (in the projects area just under the work units). But if I click on the project number under work units, it says it's alzheimers research by Justin Miller. I have my preferences set to do "any" research. In fact of the 5 projects I'm running, 4 of them have the researcher and/or the subject incorrect.
If it means anything, I had all my computers set to get cancer in preference, then changed it a couple of days ago to any.
Dayle Diamond
Re: Web control disagrees with website on what the project subject is.
Post by Dayle Diamond »
I'm getting the same issue.
