folding with CPU only; GPU added but was disabled
MisterEd
Post by MisterEd »
When I started folding it only showed CPU being used. I added GPU (GTX560) in configuration but it showed disabled. How can I enable the GPU it so I can be used it for folding.
*********************** Log Started 2023-02-07T21:10:14Z ***********************
21:10:14:******************************* libFAH ********************************
21:10:14:           Date: Oct 20 2020
21:10:14:           Time: 13:36:55
21:10:14:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
21:10:14:         Branch: master
21:10:14:       Compiler: Visual C++ 2015
21:10:14:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:10:14:       Platform: win32 10
21:10:14:           Bits: 32
21:10:14:           Mode: Release
21:10:14:****************************** FAHClient ******************************
21:10:14:        Version: 7.6.21
21:10:14:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:10:14:      Copyright: 2020 foldingathome.org
21:10:14:       Homepage: https://foldingathome.org/
21:10:14:           Time: 13:41:04
21:10:14:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
21:10:14:           Bits: 32
21:10:14:           Args: --open-web-control
21:10:14:         Config: C:\ProgramData\FAHClient\config.xml
21:10:14:******************************** CBang ********************************
21:10:14:           Time: 11:36:18
21:10:14:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
21:10:14:           Bits: 32
21:10:14:******************************* System ********************************
21:10:14:            CPU: AMD Phenom(tm) II X4 960T Processor
21:10:14:         CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
21:10:14:           CPUs: 4
21:10:14:         Memory: 8.00GiB
21:10:14:    Free Memory: 5.88GiB
21:10:14:        Threads: WINDOWS_THREADS
21:10:14:     OS Version: 6.2
21:10:14:    Has Battery: false
21:10:14:     On Battery: false
21:10:14:     UTC Offset: -6
21:10:14:            PID: 6776
21:10:14:            CWD: C:\ProgramData\FAHClient
21:10:14:  Win32 Service: false
21:10:14:             OS: Windows 10 Home
21:10:14:        OS Arch: AMD64
21:10:14:           GPUs: 0
21:10:14:  CUDA Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:2.1 Driver:9.1
21:10:14:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.1 Driver:391.35
21:10:14:***********************************************************************
21:10:14:<config>
21:10:14:  <!-- Network -->
21:10:14:  <proxy v=':8080'/>
21:10:14:
21:10:14:  <!-- User Information -->
21:10:14:  <passkey v='*****'/>
21:10:14:  <team v='32'/>
21:10:14:  <user v='MisterEd'/>
21:10:14:
21:10:14:  <!-- Folding Slots -->
21:10:14:  <slot id='0' type='CPU'/>
21:10:14:</config>
21:10:14:Trying to access database...
21:10:14:Successfully acquired database lock
21:10:14:FS00:Initialized folding slot 00: cpu:3
21:10:14:WU00:FS00:Starting
21:10:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 6776 -checkpoint 15 -np 3
21:10:14:WU00:FS00:Started FahCore on PID 1096
21:10:14:WU00:FS00:Core PID:6924
21:10:14:WU00:FS00:FahCore 0xa8 started
21:10:15:WU00:FS00:0xa8:*********************** Log Started 2023-02-07T21:10:14Z ***********************
21:10:15:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
21:10:15:WU00:FS00:0xa8:       Core: Gromacs
21:10:15:WU00:FS00:0xa8:       Type: 0xa8
21:10:15:WU00:FS00:0xa8:    Version: 0.0.12
21:10:15:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:10:15:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
21:10:15:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
21:10:15:WU00:FS00:0xa8:       Date: Jan 16 2021
21:10:15:WU00:FS00:0xa8:       Time: 11:25:04
21:10:15:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
21:10:15:WU00:FS00:0xa8:     Branch: master
21:10:15:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
21:10:15:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:10:15:WU00:FS00:0xa8:   Platform: win32 10
21:10:15:WU00:FS00:0xa8:       Bits: 64
21:10:15:WU00:FS00:0xa8:       Mode: Release
21:10:15:WU00:FS00:0xa8:       SIMD: sse2
21:10:15:WU00:FS00:0xa8:     OpenMP: ON
21:10:15:WU00:FS00:0xa8:       CUDA: OFF
21:10:15:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1096 -checkpoint 15 -np 3
21:10:15:WU00:FS00:0xa8:************************************ libFAH ************************************
21:10:15:WU00:FS00:0xa8:       Time: 11:24:13
21:10:15:WU00:FS00:0xa8:************************************ CBang *************************************
21:10:15:WU00:FS00:0xa8:       Time: 11:23:53
21:10:15:WU00:FS00:0xa8:************************************ System ************************************
21:10:15:WU00:FS00:0xa8:        CPU: AMD Phenom(tm) II X4 960T Processor
21:10:15:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
21:10:15:WU00:FS00:0xa8:       CPUs: 4
21:10:15:WU00:FS00:0xa8:     Memory: 8.00GiB
21:10:15:WU00:FS00:0xa8:Free Memory: 5.87GiB
21:10:15:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
21:10:15:WU00:FS00:0xa8: OS Version: 6.2
21:10:15:WU00:FS00:0xa8:Has Battery: false
21:10:15:WU00:FS00:0xa8: On Battery: false
21:10:15:WU00:FS00:0xa8: UTC Offset: -6
21:10:15:WU00:FS00:0xa8:        PID: 6924
21:10:15:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
21:10:15:WU00:FS00:0xa8:********************************************************************************
21:10:15:WU00:FS00:0xa8:Project: 16977 (Run 46, Clone 475, Gen 289)
21:10:15:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
21:10:15:WU00:FS00:0xa8:Digital signatures verified
21:10:15:WU00:FS00:0xa8:Calling: mdrun -c frame289.gro -s frame289.tpr -x frame289.xtc -cpi state.cpt -cpt 15 -nt 3 -ntmpi 1
21:10:15:WU00:FS00:0xa8:Steps: first=722500000 total=725000000
21:10:18:WU00:FS00:0xa8:Completed 19052 out of 2500000 steps (0%)
21:10:27:17:127.0.0.1:New Web session
21:12:04:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:-1:-1.  Disabling.
21:12:04:Adding folding slot 01: gpu:-1:-1
21:12:04:Saving configuration to config.xml
21:12:04:<config>
21:12:04:  <!-- Network -->
21:12:04:  <proxy v=':8080'/>
21:12:04:
21:12:04:  <!-- User Information -->
21:12:04:  <passkey v='*****'/>
21:12:04:  <team v='32'/>
21:12:04:  <user v='MisterEd'/>
21:12:04:
21:12:04:  <!-- Folding Slots -->
21:12:04:  <slot id='0' type='CPU'/>
21:12:04:  <slot id='1' type='GPU'/>
21:12:04:</config>
21:12:04:FS00:Shutting core down
21:12:04:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 6924
21:12:04:WU00:FS00:0xa8:Exiting, please wait. . .
21:12:05:WU00:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
21:12:05:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:12:06:WU00:FS00:Starting
21:12:06:WARNING:WU00:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
21:12:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 6776 -checkpoint 15 -np 2
21:12:06:WU00:FS00:Started FahCore on PID 9356
21:12:06:WU00:FS00:Core PID:9392
21:12:06:WU00:FS00:FahCore 0xa8 started
21:12:06:WU00:FS00:0xa8:*********************** Log Started 2023-02-07T21:12:06Z ***********************
21:12:06:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
21:12:06:WU00:FS00:0xa8:       Core: Gromacs
21:12:06:WU00:FS00:0xa8:       Type: 0xa8
21:12:06:WU00:FS00:0xa8:    Version: 0.0.12
21:12:06:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:12:06:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
21:12:06:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
21:12:06:WU00:FS00:0xa8:       Date: Jan 16 2021
21:12:06:WU00:FS00:0xa8:       Time: 11:25:04
21:12:06:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
21:12:06:WU00:FS00:0xa8:     Branch: master
21:12:06:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
21:12:06:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:12:06:WU00:FS00:0xa8:   Platform: win32 10
21:12:06:WU00:FS00:0xa8:       Bits: 64
21:12:06:WU00:FS00:0xa8:       Mode: Release
21:12:06:WU00:FS00:0xa8:       SIMD: sse2
21:12:06:WU00:FS00:0xa8:     OpenMP: ON
21:12:06:WU00:FS00:0xa8:       CUDA: OFF
21:12:06:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9356 -checkpoint 15 -np 2
21:12:06:WU00:FS00:0xa8:************************************ libFAH ************************************
21:12:06:WU00:FS00:0xa8:       Time: 11:24:13
21:12:06:WU00:FS00:0xa8:************************************ CBang *************************************
21:12:06:WU00:FS00:0xa8:       Time: 11:23:53
21:12:06:WU00:FS00:0xa8:************************************ System ************************************
21:12:06:WU00:FS00:0xa8:        CPU: AMD Phenom(tm) II X4 960T Processor
21:12:06:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
21:12:06:WU00:FS00:0xa8:       CPUs: 4
21:12:06:WU00:FS00:0xa8:     Memory: 8.00GiB
21:12:06:WU00:FS00:0xa8:Free Memory: 5.48GiB
21:12:06:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
21:12:06:WU00:FS00:0xa8: OS Version: 6.2
21:12:06:WU00:FS00:0xa8:Has Battery: false
21:12:06:WU00:FS00:0xa8: On Battery: false
21:12:06:WU00:FS00:0xa8: UTC Offset: -6
21:12:06:WU00:FS00:0xa8:        PID: 9392
21:12:06:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
21:12:06:WU00:FS00:0xa8:********************************************************************************
21:12:06:WU00:FS00:0xa8:Project: 16977 (Run 46, Clone 475, Gen 289)
21:12:06:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
21:12:06:WU00:FS00:0xa8:Digital signatures verified
21:12:06:WU00:FS00:0xa8:Calling: mdrun -c frame289.gro -s frame289.tpr -x frame289.xtc -cpi state.cpt -cpt 15 -nt 2 -ntmpi 1
21:12:06:WU00:FS00:0xa8:Steps: first=722500000 total=725000000
21:12:09:WU00:FS00:0xa8:Completed 22402 out of 2500000 steps (0%)
21:12:16:Saving configuration to config.xml
21:12:16:<config>
21:12:16:  <!-- Network -->
21:12:16:  <proxy v=':8080'/>
21:12:16:
21:12:16:  <!-- User Information -->
21:12:16:  <passkey v='*****'/>
21:12:16:  <team v='32'/>
21:12:16:  <user v='MisterEd'/>
21:12:16:
21:12:16:  <!-- Folding Slots -->
21:12:16:  <slot id='0' type='CPU'/>
21:12:16:  <slot id='1' type='GPU'/>
21:12:16:</config>
21:12:58:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
21:13:53:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
Re: folding with CPU only; GPU added but was disabled
The GTX 560 is no longer supported for folding. It is based on the Fermi microarchitecture that does not fully support OpenCL 1.2 and was removed from the supported list over a year ago. The oldest Nvidia cards supported are based on Kepler, and will use OpenCL. Maxwell based and newer cards can use CUDA for F@h GPU processing.
MisterEd
Post by MisterEd »
Thanks for letting me know. That means it is only using its AMD Phenom II X4 960T CPU for folding. If you think it best I will stop that computer from folding.
BTW, the amount of points it will contribute is not much since my other computers combined are averaging over 4 million points per day.
Welcome to Folding@Home!
https://www.techpowerup.com/cpu-specs/p ... -9650.c499
Unless you do not pay for electricity, you may find it cheaper to buy a more modern CPU.
Your 2008 CPU only supports 128 bit math and some current CPUs support 512 bits at a time. (F@H only supports 256 bits currently)
MisterEd
Post by MisterEd »
Actually this is my CPU: https://www.techpowerup.com/cpu-specs/p ... 0t-be.c745
It really doesn't matter since it's not much better than the CPU you gave a link to. I am going to at least have it finish the unit it started.
My other computers have the following GPU's that are folding OK: GTX1060, RTX3060, RTX3060-Ti.
BTW, I am not totally new to Folding@home because over 10 years ago I folded for team DevFolding (12912). I am currently using the same user name I used back then.
