Exception: Core package tar missing cores
jonault
Post by jonault »
Folding stopped this morning with the following error:
*********************** Log Started 2023-02-07T19:00:06Z ***********************
19:00:06:I1:****************************** CBang ******************************
19:00:06:I1: Date: Dec 7 2022
19:00:06:I1: Time: 13:47:39
19:00:06:I1: Compiler: Visual C++
19:00:06:I1: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:00:06:I1: Platform: win32 10
19:00:06:I1: Bits: 64
19:00:06:I1: Mode: Release
19:00:06:I1:***************************** System ******************************
19:00:06:I1: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
19:00:06:I1: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
19:00:06:I1: CPUs: 8
19:00:06:I1: Memory: 15.91GiB
19:00:06:I1:Free Memory: 10.38GiB
19:00:06:I1: Threads: WINDOWS_THREADS
19:00:06:I1: OS Version: 6.2
19:00:06:I1:Has Battery: true
19:00:06:I1: On Battery: false
19:00:06:I1: UTC Offset: -6
19:00:06:I1: PID: 4552
19:00:06:I1: CWD: C:\ProgramData\FAHClient
19:00:06:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
19:00:06:I1:*********************** Folding@home Client ***********************
19:00:06:I1: Version: 8.1.11
19:00:06:I1: Author: Joseph Coffland
19:00:06:I1: Org: foldingathome.org
19:00:06:I1: Copyright: 2023 foldingathome.org
19:00:06:I1: Homepage: https://foldingathome.org/
19:00:06:I1: License: https://www.gnu.org/licenses/gpl-3.0.txt
19:00:06:I1: Date: Jan 16 2023
19:00:06:I1: Time: 16:12:23
19:00:06:I1: Args: --open-web-control
19:00:06:I1: Config: C:\ProgramData\FAHClient\config.xml
19:00:06:I1:*******************************************************************
19:00:06:I2:
19:00:06:I2:
19:00:06:I2:
19:00:06:I2:
19:00:06:I2:
19:00:06:I2:
19:00:06:I2:
19:00:06:I2:
19:00:06:I2:
19:00:06:I1:Opening Database
19:00:06:I1:Listening for HTTP on 127.0.0.1:7396
19:00:06:I3:id = qE8IYDgd28CJ3e9IgGLuaPZzF/5XzHSympicOKfWLbY=
19:00:06:I3:Loading work unit 43 to group '' with ID gsFSv9ZnUPp0hpFjQ5NNm3v63rr2623htukwJfBJFDg
19:00:06:I3:Loaded 1 wus.
19:00:06:I1:Started Windows systray control
19:00:07:I3:Adding GPU gpu:01:00:00
19:00:07:I3:Adding GPU gpu:02:00:00
19:00:07:I3:gpus = {
19:00:07:I3: "gpu:01:00:00": {"type": "nvidia", "description": "TU116 [GeForce GTX 1660 SUPER]"},
19:00:07:I3: "gpu:02:00:00": {"type": "nvidia", "description": "TU102 [GeForce RTX 2080 Ti] M 13448"}
19:00:07:I3:}
19:00:07:I1:Downloading https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.crt
19:00:07:I1:OUT4:> GET https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.crt HTTP/1.1
19:00:07:I3:Connecting to cores.foldingathome.org:443
19:00:07:I1:OUT4:< cores.foldingathome.org:443 HTTP/1.1 200 OK
19:00:07:I1:Downloading https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.sig
19:00:07:I1:OUT5:> GET https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.sig HTTP/1.1
19:00:07:I1:OUT5:< cores.foldingathome.org:443 HTTP/1.1 200 OK
19:00:07:I1:OUT7:> GET https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2 HTTP/1.1
19:00:08:I1:OUT7:< cores.foldingathome.org:443 HTTP/1.1 200 OK
19:00:08:I1:Core signature valid
19:00:08:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/FahCore_a9.exe
19:00:08:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/core-meta.json
19:00:08:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/libfftw3f-3.dll
19:00:08:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/vcomp140.dll
19:00:08:E :Exception: Core package tar missing cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/FahCore_a9
Re: Exception: Core package tar missing cores
I have passed that info on to the developer.
There has been an updated beta released, 8.1.12. That should fix this core download problem.
jonault
Post by jonault »
I'm afraid that just resulted in a different error:
*********************** Log Started 2023-02-07T22:07:44Z ***********************
22:07:44:I1:*********************** Folding@home Client ***********************
22:07:44:I1: Version: 8.1.12
22:07:44:I1: Author: Joseph Coffland
22:07:44:I1: Org: foldingathome.org
22:07:44:I1: Copyright: 2023 foldingathome.org
22:07:44:I1: Homepage: https://foldingathome.org/
22:07:44:I1: License: https://www.gnu.org/licenses/gpl-3.0.txt
22:07:44:I1: Date: Feb 7 2023
22:07:44:I1: Time: 20:34:11
22:07:44:I1: Compiler: Visual C++
22:07:44:I1: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:07:44:I1: Platform: win32 10
22:07:44:I1: Bits: 64
22:07:44:I1: Mode: Release
22:07:44:I1: Args: --open-web-control
22:07:44:I1: Config: C:\ProgramData\FAHClient\config.xml
22:07:44:I1:****************************** CBang ******************************
22:07:44:I1: Version: 1.7.2
22:07:44:I1: Org: Cauldron Development LLC
22:07:44:I1: Copyright: Cauldron Development LLC, 2003-2023
22:07:44:I1: Homepage: https://cauldrondevelopment.com/
22:07:44:I1: License: GPL 2+
22:07:44:I1: Time: 20:33:41
22:07:44:I1:***************************** System ******************************
22:07:44:I1: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
22:07:44:I1: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
22:07:44:I1: CPUs: 8
22:07:44:I1: Memory: 15.91GiB
22:07:44:I1:Free Memory: 10.17GiB
22:07:44:I1: Threads: WINDOWS_THREADS
22:07:44:I1: OS Version: 6.2
22:07:44:I1:Has Battery: true
22:07:44:I1: On Battery: false
22:07:44:I1: UTC Offset: -6
22:07:44:I1: PID: 16648
22:07:44:I1: CWD: C:\ProgramData\FAHClient
22:07:44:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
22:07:44:I1:*******************************************************************
22:07:44:I2:
22:07:44:I2:
22:07:44:I2:
22:07:44:I2:
22:07:44:I2:
22:07:44:I2:
22:07:44:I2:
22:07:44:I2:
22:07:44:I2:
22:07:44:I1:Opening Database
22:07:44:I1:Listening for HTTP on 127.0.0.1:7396
22:07:44:I3:id = qE8IYDgd28CJ3e9IgGLuaPZzF/5XzHSympicOKfWLbY=
22:07:44:I3:Loading work unit 43 to group '' with ID gsFSv9ZnUPp0hpFjQ5NNm3v63rr2623htukwJfBJFDg
22:07:44:I3:Loaded 1 wus.
22:07:44:I1:Started Windows systray control
22:07:44:I3:Adding GPU gpu:01:00:00
22:07:44:I3:Adding GPU gpu:02:00:00
22:07:44:I3:gpus = {
22:07:44:I3: "gpu:01:00:00": {"type": "nvidia", "description": "TU116 [GeForce GTX 1660 SUPER]"},
22:07:44:I3: "gpu:02:00:00": {"type": "nvidia", "description": "TU102 [GeForce RTX 2080 Ti] M 13448"}
22:07:44:I3:}
22:07:44:I1:Downloading https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.crt
22:07:44:I1:OUT1:> GET https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.crt HTTP/1.1
22:07:44:I3:Connecting to cores.foldingathome.org:443
22:07:44:I1:OUT1:< cores.foldingathome.org:443 HTTP/1.1 200 OK
22:07:44:I1:Downloading https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.sig
22:07:44:I1:OUT3:> GET https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2.sig HTTP/1.1
22:07:44:I1:OUT3:< cores.foldingathome.org:443 HTTP/1.1 200 OK
22:07:44:I1:OUT4:> GET https://cores.foldingathome.org/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12.tar.bz2 HTTP/1.1
22:07:45:I1:OUT4:< cores.foldingathome.org:443 HTTP/1.1 200 OK
22:07:45:I1:Core signature valid
22:07:45:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/FahCore_a9.exe
22:07:46:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/core-meta.json
22:07:46:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/libfftw3f-3.dll
22:07:46:I1:Extracting cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/vcomp140.dll
22:07:46:E :Exception: Failed to rename 'cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/FahCore_a9' to 'cores/gromacs-core-a9/windows-10-64bit/cpu-avx2_256-release/fahcore-a9-windows-10-64bit-cpu-avx2_256-release-0.0.12/FahCore_a9.exe': The system cannot find the file specified.
The file doesn't need to be renamed, it already has the ".exe" extension.
Could you try the next version, 8.1.13 has been posted.
jonault
Post by jonault »
8.1.13 works, I'm up & running again. Thanks!
