How do i know if my WU's are being sent back?
Subject says it all...Basically i just want to make sure there being sent off so i can help out in this massive project
Re: How do i know if my WU's are being sent back?
Look for lines like this in your FAHlog.txt :
You can also check your stats here with your username : http://fah-web.stanford.edu/cgi-bin/mai ... =userstats
[10:39:39] + Attempting to send results
[10:39:39] - Reading file work/wuresults_04.dat from core
[10:39:39] (Read 3375451 bytes from disk)
[10:39:39] Connecting to http://171.64.65.103:8080/
[10:40:14] Posted data.
[10:40:14] Initial: 0000; - Uploaded at ~94 kB/s
[10:40:14] - Averaged speed for that direction ~91 kB/s
[10:40:14] + Results successfully sent
[10:40:14] Thank you for your contribution to Folding@Home.
[10:40:14] + Number of Units Completed: 593
[13:15:47] Folding@home Core Shutdown: FINISHED_UNIT
[13:15:51] CoreStatus = 64 (100)
[13:15:51] Sending work to server
[13:15:51] + Attempting to send results
[13:16:01] + Results successfully sent
[13:16:01] Thank you for your contribution to Folding@Home.
That seems about right yeah?
