206.223.170.146 (fah1) down
jjmiller
Scientist
Post by jjmiller »
This morning we lost cooling services for 206.223.170.146 (fah1) and had to urgently shut it down to prevent overheating. We'll have it back up again as soon as possible.
pyrocyborg
Hardware configuration: 3060 12GB, 3060 Ti, 3070, 3080, 3090, 6700 XT, 6800 XT, 6900 XT
Re: 206.223.170.146 (fah1) down
Post by pyrocyborg »
Hi!
It seems like 206.223.170.146 is still down currently. None of our PC can connect to it, and F@H keeps trying over and over again to no avail.
Edit : It's been resolved or it was a connection issue. It seems like it does send new work units from time to time. It may take up to 20-30 minutes to do so, but it's working.
pyrocyborg wrote: Wed Feb 08, 2023 4:08 pm Hi!
The server may be having issues with temporary overloads. Currently GPU projects are in short supply, the other server with an active GPU project recently completed its runs and they are being checked to see if enough data was collected. There are some GPU projects in the pipeline, but not ready to be released. So it should improve in the near future, but not sure if that is days or a couple weeks.
Breach
Post by Breach »
Posted and then saw this. Same story, come on my 4090 is sad ;-)
12:31:55:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:31:56:WU01:FS01:Assigned to work server 206.223.170.146
12:31:56:WU01:FS01:Requesting new work unit for slot 01: gpu:6:0 AD102 [GeForce RTX 4090] from 206.223.170.146
12:31:56:WU01:FS01:Connecting to 206.223.170.146:8080
12:32:17:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:32:17:WU01:FS01:Connecting to 206.223.170.146:80
12:32:38:ERROR:WU01:FS01:Exception: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
They should be looking at the server, it is currently listed as down.
pyrocyborg
Thanks for the heads up Joe_H. Is there any way to temporarily remove a work server from our list so that it stops requesting from it when it's down and try another server instead?
Thanks!
The AS shouldn't be sending any requests to the server when it is down. If you have any examples of that still happening now I can forward them to the person in charge of the assignment servers to see what is going wrong.
pyrocyborg
You are right. The client paused itself after 10 minutes or so of tries. After that, it simply unpaused as soon as the server was ready.
Thanks!
pyrocyborg
Hi! It seems like it's down again, or acting up somehow. I guess it's going to happen sometimes. :wink:
22:10:25:WU00:FS01:Connecting to assign1.foldingathome.org:80
22:10:26:WU00:FS01:Assigned to work server 206.223.170.146
22:10:26:WU00:FS01:Requesting new work unit for slot 01: gpu:4:0 GA104 [GeForce RTX 3070] from 206.223.170.146
22:10:26:WU00:FS01:Connecting to 206.223.170.146:8080
22:10:47:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
22:10:47:WU00:FS01:Connecting to 206.223.170.146:80
22:11:08:ERROR:WU00:FS01:Exception: Failed to connect to 206.223.170.146:80: Une tentative de connexion a échoué car le parti connecté na pas répondu convenablement au-delà dune certaine durée ou une connexion établie a échoué car lhôte de connexion na pas répondu.
Not sure what is going on there, I have sent a message to the person who looks after it. Its uptime is listed as 11 days, but sometimes can not connect to the server and at times it shows as down.
pyrocyborg
Allright. Thanks Joe_H. We eventually get assigned to another server after 30 minutes or so since the "last contact" (according to the server stats), so it's not too bad.
Have a nice day and thanks for your help!
Researcher was recovering space by compressing older completed projects. That finished by yesterday evening so should no longer be effecting the server.
