GT 1030 Disabled
Meki01
Hardware configuration: WIN7 HP / Intel i7-4790 CPU @ 3.60 GHz / 16 GB RAM / AMD RX-570P8DFD6
WIN10 pro / AMD RYZEN 7 2700 / 16 GB RAM / NVIDIA GeForce GTX 1050 Ti
Folding since 03 2020 - not always, always more often
GT 1030 Disabled
Post by Meki01 »
Hi! Is the NVIDIA GT 1030 no longer supported? It is now disabled for me... Thanks for the help!
07:36:06:******************************* System ********************************
07:36:06:            CPU: AMD Ryzen 7 3700X 8-Core Processor
07:36:06:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:36:06:           CPUs: 16
07:36:06:         Memory: 15.91GiB
07:36:06:    Free Memory: 6.07GiB
07:36:06:        Threads: WINDOWS_THREADS
07:36:06:     OS Version: 6.2
07:36:06:    Has Battery: false
07:36:06:     On Battery: false
07:36:06:     UTC Offset: 1
07:36:06:            PID: 3912
07:36:06:            CWD: C:\ProgramData\FAHClient
07:36:06:  Win32 Service: false
07:36:06:             OS: Windows 10 Enterprise
07:36:06:        OS Arch: AMD64
07:36:06:           GPUs: 2
07:36:06:          GPU 0: Bus:9 Slot:0 Func:0 NVIDIA:1
07:36:06:          GPU 1: Bus:10 Slot:0 Func:0 NVIDIA:1
07:36:06:  CUDA Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:6.1 Driver:11.1
07:36:06:  CUDA Device 1: Platform:0 Device:1 Bus:10 Slot:0 Compute:6.1 Driver:11.1
07:36:06:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:456.71
07:36:06:OpenCL Device 1: Platform:0 Device:1 Bus:10 Slot:0 Compute:1.2 Driver:456.71
07:36:06:***********************************************************************
07:36:06:<config>
07:36:06:  <!-- Folding Slots -->
07:36:06:</config>
07:36:06:Trying to access database...
07:36:07:Successfully acquired database lock
07:36:07:FS00:Initialized folding slot 00: cpu:13
07:36:07:WARNING:FS01:Disabling beta GPU slot 01: gpu:9:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
07:36:07:WARNING:FS02:Disabling beta GPU slot 02: gpu:10:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
Sorry for my bad english - google translator says hello :-)
Re: GT 1030 Disabled
There are two different GT 1030 GPUs listed and enabled in the GPUs.txt file. What probably happened was that after a restart of your PC the FAHClient process started before your PC had an internet connection established. About once a month the client updates the GPUs.txt file by downloading from the servers, if there is no internet connection that fails and your GPU gets disabled.
There is further discussion on this here - viewtopic.php?t=38807
Meki01
Post by Meki01 »
I have installed two GT 1030 in my system. Somehow I managed to get them online again. It's working again at the moment. Let's see how long...
