F@H causes my USB devices to disconnect and reconnect randomly
Navic
Post by Navic »
Hello, first time on the forum so if I do something wrong I apologize.
Problem: Only when running F@H (no other programs cause this, like premiere pro, lightroom classic, or gaming) do my USB devices sometimes disconnect and then within a second reconnect. This leads to my external 1TB T7 drive to disconnect (the main thing that tells me my USB devices have disconnected since a notification that the drive isn't working properly shows up, followed by a drive connected notification) as well as my USB-C display (Asus MB16AC) and occasionally my CPU cooler (Corsair H100i Pro XT). Those last two are the main annoyances, as when the USB monitor disconnects both of my other screens go black for a second, and my cooler needs software to control the fans on it properly, and when it gets disconnected I need to restart to get it connected again.
Full system specs: Ryzen 5900x (Curve Optimizer undervolted and power limits increased), Asus Strix B550-i, 32gb 3200MHz CL16 Corsair Vengance RAM, WD SN750 250gb (C: drive), WD Blue 2TB M.2 SATA (storage), EVGA 3080 Ti FTW3 (I also had a 2080 Ti XC Ultra before this, and it happened there too, both were power limited to pull 250-300w only), EVGA 650GM PSU, Windows 10 Home (fully up-to-date, no beta versions, recently reinstalled), 3 different monitors (Acer XB241H (secondary, DP), Asus PG279Q (main, DP), Asus MB16AC (terciary, USB).
I know I can't post URLs since I'm a new user, but here is a PC Part Picker list (add onto the end of the website): user/RickNickHD/saved/rqHqkL
Tried fixes: Updating BIOS, updating Windows (including optional driver updates), resetting BIOS to factory defaults, uninstalling and updating Chipset drivers, updating USB drivers through device manager, reinstalling USB root hubs and host controllers via device manager, disabling USB selective suspend in advanced power options, setting the PCIe link speed to Gen 3 in the BIOS instead of Gen 4, trying different USB ports, reinstalling F@H, disconnecting USB monitor, disconnecting USB hub.
Other notes: I know it is not a PSU over-power-protection or thermal issue, as I have had this happen upon first startup (when everything is cold), and it happens when running only the CPU, only the GPU, and when running CPU and GPU at the same time. I monitor all my main temps on that USB monitor, and everything seemed normal. I have included the log below, and it happened right before I paused it at the very end, but nothing in the log strikes me as a problem. I'm not sure what the problem could be, as it only happens with F@H. I thought it might have been the old USB disconnect problems with Ryzen 5000 and 500 series chipsets, but AMD has since fixed that and I'm running the latest BIOS and drivers, so I don't think it's that, but it still might be. Open to suggestions.
Log:
*********************** Log Started 2023-01-11T19:46:40Z ***********************
19:46:40:******************************* libFAH ********************************
19:46:40:           Date: Oct 20 2020
19:46:40:           Time: 13:36:55
19:46:40:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:46:40:         Branch: master
19:46:40:       Compiler: Visual C++ 2015
19:46:40:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:46:40:       Platform: win32 10
19:46:40:           Bits: 32
19:46:40:           Mode: Release
19:46:40:****************************** FAHClient ******************************
19:46:40:        Version: 7.6.21
19:46:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:46:40:      Copyright: 2020 foldingathome.org
19:46:40:       Homepage: https://foldingathome.org/
19:46:40:           Time: 13:41:04
19:46:40:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:46:40:           Bits: 32
19:46:40:           Args: --open-web-control
19:46:40:******************************** CBang ********************************
19:46:40:           Time: 11:36:18
19:46:40:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:46:40:           Bits: 32
19:46:40:******************************* System ********************************
19:46:40:            CPU: AMD Ryzen 9 5900X 12-Core Processor
19:46:40:         CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
19:46:40:           CPUs: 24
19:46:40:         Memory: 31.91GiB
19:46:40:    Free Memory: 23.42GiB
19:46:40:        Threads: WINDOWS_THREADS
19:46:40:     OS Version: 6.2
19:46:40:    Has Battery: false
19:46:40:     On Battery: false
19:46:40:     UTC Offset: -6
19:46:40:            PID: 22280
19:46:40:            CWD: C:\ProgramData\FAHClient
19:46:40:  Win32 Service: false
19:46:40:             OS: Windows 10 Home
19:46:40:        OS Arch: AMD64
19:46:40:           GPUs: 1
19:46:40:          GPU 0: Bus:7 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080 Ti]
19:46:40:  CUDA Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:8.6 Driver:12.0
19:46:40:OpenCL Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:3.0 Driver:528.2
19:46:40:***********************************************************************
19:46:40:<config>
19:46:40:  <!-- Folding Slots -->
19:46:40:</config>
19:46:40:Trying to access database...
19:46:40:Successfully acquired database lock
19:46:40:FS00:Initialized folding slot 00: cpu:22
19:46:40:FS01:Initialized folding slot 01: gpu:7:0 GA102 [GeForce RTX 3080 Ti]
19:46:41:WARNING:5:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_highlight-soft_75_cccccc_1x100.png
19:46:41:WARNING:9:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_55_fbf9ee_1x400.png
19:46:41:WARNING:10:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_95_fef1ec_1x400.png
19:46:41:WARNING:11:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_222222_256x240.png
19:46:41:15:127.0.0.1:New Web session
19:47:41:Saving configuration to config.xml
19:47:41:<config>
19:47:41:  <!-- Folding Slots -->
19:47:41:  <slot id='0' type='CPU'/>
19:47:41:  <slot id='1' type='GPU'>
19:47:41:    <pci-bus v='7'/>
19:47:41:    <pci-slot v='0'/>
19:47:41:  </slot>
19:47:41:</config>
19:47:41:Set client configured
19:47:41:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:47:41:WU01:FS01:Connecting to assign1.foldingathome.org:80
19:47:42:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:47:42:WU01:FS01:Connecting to assign1.foldingathome.org:80
19:47:42:WU00:FS00:Assigned to work server 66.170.111.50
19:47:42:WU00:FS00:Requesting new work unit for slot 00: cpu:22 from 66.170.111.50
19:47:42:WU00:FS00:Connecting to 66.170.111.50:8080
19:47:42:WU01:FS01:Assigned to work server 206.223.170.146
19:47:42:WU01:FS01:Requesting new work unit for slot 01: gpu:7:0 GA102 [GeForce RTX 3080 Ti] from 206.223.170.146
19:47:42:WU01:FS01:Connecting to 206.223.170.146:8080
19:47:43:WU01:FS01:Downloading 22.06MiB
19:47:43:ERROR:WU00:FS00:Exception: Server did not assign work unit
19:47:43:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:47:43:WU00:FS00:Assigned to work server 129.32.209.203
19:47:43:WU00:FS00:Requesting new work unit for slot 00: cpu:22 from 129.32.209.203
19:47:43:WU00:FS00:Connecting to 129.32.209.203:8080
19:47:44:WU00:FS00:Downloading 745.00KiB
19:47:44:WU00:FS00:Download complete
19:47:44:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16994 run:18 clone:6 gen:94 core:0xa8 unit:0x000000060000005e0000426200000012
19:47:44:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
19:47:44:FS00:Paused
19:47:44:WU00:FS00:Connecting to cores.foldingathome.org:80
19:47:44:FS01:Paused
19:47:44:WU00:FS00:FahCore a8: Downloading 7.72MiB
19:47:45:WU00:FS00:FahCore a8: Download complete
19:47:45:WU00:FS00:Valid core signature
19:47:45:WU00:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
19:47:45:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
19:47:45:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
19:47:45:WU01:FS01:Download complete
19:47:46:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18601 run:4634 clone:4 gen:13 core:0x22 unit:0x000000040000000d000048a90000121a
19:48:29:Saving configuration to config.xml
19:48:29:<config>
19:48:29:  <!-- Network -->
19:48:29:  <proxy v=':8080'/>
19:48:29:
19:48:29:  <!-- Slot Control -->
19:48:29:  <pause-on-start v='true'/>
19:48:29:
19:48:29:  <!-- User Information -->
19:48:29:  <passkey v='*****'/>
19:48:29:  <team v='111065'/>
19:48:29:  <user v='Navic'/>
19:48:29:
19:48:29:  <!-- Folding Slots -->
19:48:29:  <slot id='0' type='CPU'>
19:48:29:    <cpus v='18'/>
19:48:29:    <paused v='True'/>
19:48:29:  </slot>
19:48:29:  <slot id='1' type='GPU'>
19:48:29:    <paused v='true'/>
19:48:29:    <pci-bus v='7'/>
19:48:29:    <pci-slot v='0'/>
19:48:29:  </slot>
19:48:29:</config>
19:48:42:Saving configuration to config.xml
19:48:42:<config>
19:48:42:  <!-- Network -->
19:48:42:  <proxy v=':8080'/>
19:48:42:
19:48:42:  <!-- Slot Control -->
19:48:42:  <pause-on-start v='true'/>
19:48:42:
19:48:42:  <!-- User Information -->
19:48:42:  <passkey v='*****'/>
19:48:42:  <team v='111065'/>
19:48:42:  <user v='Navic'/>
19:48:42:
19:48:42:  <!-- Folding Slots -->
19:48:42:  <slot id='0' type='CPU'>
19:48:42:    <cpus v='18'/>
19:48:42:    <paused v='True'/>
19:48:42:  </slot>
19:48:42:  <slot id='1' type='GPU'>
19:48:42:    <paused v='true'/>
19:48:42:    <pci-bus v='7'/>
19:48:42:    <pci-slot v='0'/>
19:48:42:  </slot>
19:48:42:</config>
19:49:50:26:127.0.0.1:New Web session
19:49:59:FS00:Unpaused
19:49:59:FS00:Finishing
19:49:59:FS01:Unpaused
19:49:59:FS01:Finishing
19:49:59:WU00:FS00:Starting
19:49:59:WARNING:WU00:FS00:Changed SMP threads from 22 to 18 this can cause some work units to fail
19:49:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 22280 -checkpoint 15 -np 18
19:49:59:WU00:FS00:Started FahCore on PID 9364
19:49:59:WU00:FS00:Core PID:1616
19:49:59:WU00:FS00:FahCore 0xa8 started
19:49:59:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah
19:49:59:WU01:FS01:Connecting to cores.foldingathome.org:80
19:49:59:WU01:FS01:FahCore 22: Downloading 156.61MiB
19:50:00:WU00:FS00:0xa8:*********************** Log Started 2023-01-11T19:49:59Z ***********************
19:50:00:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:50:00:WU00:FS00:0xa8:       Core: Gromacs
19:50:00:WU00:FS00:0xa8:       Type: 0xa8
19:50:00:WU00:FS00:0xa8:    Version: 0.0.12
19:50:00:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:50:00:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:50:00:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:50:00:WU00:FS00:0xa8:       Date: Jan 16 2021
19:50:00:WU00:FS00:0xa8:       Time: 12:29:40
19:50:00:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:50:00:WU00:FS00:0xa8:     Branch: master
19:50:00:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:50:00:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:50:00:WU00:FS00:0xa8:   Platform: win32 10
19:50:00:WU00:FS00:0xa8:       Bits: 64
19:50:00:WU00:FS00:0xa8:       Mode: Release
19:50:00:WU00:FS00:0xa8:       SIMD: avx2_256
19:50:00:WU00:FS00:0xa8:     OpenMP: ON
19:50:00:WU00:FS00:0xa8:       CUDA: OFF
19:50:00:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9364 -checkpoint 15 -np
19:50:00:WU00:FS00:0xa8:             18
19:50:00:WU00:FS00:0xa8:************************************ libFAH ************************************
19:50:00:WU00:FS00:0xa8:       Time: 11:24:13
19:50:00:WU00:FS00:0xa8:************************************ CBang *************************************
19:50:00:WU00:FS00:0xa8:       Time: 11:23:53
19:50:00:WU00:FS00:0xa8:************************************ System ************************************
19:50:00:WU00:FS00:0xa8:        CPU: AMD Ryzen 9 5900X 12-Core Processor
19:50:00:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
19:50:00:WU00:FS00:0xa8:       CPUs: 24
19:50:00:WU00:FS00:0xa8:     Memory: 31.91GiB
19:50:00:WU00:FS00:0xa8:Free Memory: 23.56GiB
19:50:00:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:50:00:WU00:FS00:0xa8: OS Version: 6.2
19:50:00:WU00:FS00:0xa8:Has Battery: false
19:50:00:WU00:FS00:0xa8: On Battery: false
19:50:00:WU00:FS00:0xa8: UTC Offset: -6
19:50:00:WU00:FS00:0xa8:        PID: 1616
19:50:00:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
19:50:00:WU00:FS00:0xa8:********************************************************************************
19:50:00:WU00:FS00:0xa8:Project: 16994 (Run 18, Clone 6, Gen 94)
19:50:00:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:50:00:WU00:FS00:0xa8:Reading tar file core.xml
19:50:00:WU00:FS00:0xa8:Reading tar file frame94.tpr
19:50:00:WU00:FS00:0xa8:Digital signatures verified
19:50:00:WU00:FS00:0xa8:Calling: mdrun -c frame94.gro -s frame94.tpr -x frame94.xtc -cpt 15 -nt 18 -ntmpi 1
19:50:00:WU00:FS00:0xa8:Steps: first=940000000 total=950000000
19:50:01:WU00:FS00:0xa8:Completed 1 out of 10000000 steps (0%)
19:50:05:WU01:FS01:FahCore 22: 41.46%
19:50:11:WU01:FS01:FahCore 22: 67.84%
19:50:17:WU01:FS01:FahCore 22: 87.48%
19:50:20:WU01:FS01:FahCore 22: Download complete
19:50:20:WU01:FS01:Valid core signature
19:50:20:WU01:FS01:Unpacked 5.52MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe
19:50:20:WU01:FS01:Unpacked 24.45KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/api-ms-win-crt-runtime-l1-1-0.dll
19:50:20:WU01:FS01:Unpacked 179.58MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/cufft64_10.dll
19:50:20:WU01:FS01:Unpacked 3.25MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/libcrypto-1_1-x64.dll
19:50:20:WU01:FS01:Unpacked 667.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/libssl-1_1-x64.dll
19:50:20:WU01:FS01:Unpacked 552.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140.dll
19:50:20:WU01:FS01:Unpacked 23.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_1.dll
19:50:20:WU01:FS01:Unpacked 181.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_2.dll
19:50:20:WU01:FS01:Unpacked 54.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_atomic_wait.dll
19:50:20:WU01:FS01:Unpacked 19.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_codecvt_ids.dll
19:50:20:WU01:FS01:Unpacked 5.29MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/nvrtc-builtins64_112.dll
19:50:20:WU01:FS01:Unpacked 30.51MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/nvrtc64_112_0.dll
19:50:20:WU01:FS01:Unpacked 2.81MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMM.dll
19:50:20:WU01:FS01:Unpacked 302.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoeba.dll
19:50:20:WU01:FS01:Unpacked 1.04MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaCUDA.dll
19:50:20:WU01:FS01:Unpacked 952.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaOpenCL.dll
19:50:20:WU01:FS01:Unpacked 458.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaReference.dll
19:50:20:WU01:FS01:Unpacked 517.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCPU.dll
19:50:20:WU01:FS01:Unpacked 1.78MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCUDA.dll
19:50:20:WU01:FS01:Unpacked 60.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCudaCompiler.dll
19:50:20:WU01:FS01:Unpacked 99.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrude.dll
19:50:20:WU01:FS01:Unpacked 118.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeCUDA.dll
19:50:20:WU01:FS01:Unpacked 118.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeOpenCL.dll
19:50:20:WU01:FS01:Unpacked 87.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeReference.dll
19:50:20:WU01:FS01:Unpacked 1.81MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMOpenCL.dll
19:50:20:WU01:FS01:Unpacked 61.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMPME.dll
19:50:20:WU01:FS01:Unpacked 57.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMD.dll
19:50:20:WU01:FS01:Unpacked 138.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDCUDA.dll
19:50:20:WU01:FS01:Unpacked 138.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDOpenCL.dll
19:50:20:WU01:FS01:Unpacked 75.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDReference.dll
19:50:20:WU01:FS01:Unpacked 94.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/vcruntime140.dll
19:50:20:WU01:FS01:Unpacked 36.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/vcruntime140_1.dll
19:50:20:WU01:FS01:Starting
19:50:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 22280 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:50:20:WU01:FS01:Started FahCore on PID 10300
19:50:21:WU01:FS01:Core PID:10216
19:50:21:WU01:FS01:FahCore 0x22 started
19:50:21:WU01:FS01:0x22:*********************** Log Started 2023-01-11T19:50:21Z ***********************
19:50:21:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:50:21:WU01:FS01:0x22:       Core: Core22
19:50:21:WU01:FS01:0x22:       Type: 0x22
19:50:21:WU01:FS01:0x22:    Version: 0.0.20
19:50:21:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:50:21:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
19:50:21:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
19:50:21:WU01:FS01:0x22:       Date: Jan 20 2022
19:50:21:WU01:FS01:0x22:       Time: 01:15:36
19:50:21:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
19:50:21:WU01:FS01:0x22:     Branch: HEAD
19:50:21:WU01:FS01:0x22:   Compiler: Visual C++
19:50:21:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:50:21:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
19:50:21:WU01:FS01:0x22:   Platform: win32 10
19:50:21:WU01:FS01:0x22:       Bits: 64
19:50:21:WU01:FS01:0x22:       Mode: Release
19:50:21:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:50:21:WU01:FS01:0x22:             <peastman@stanford.edu>
19:50:21:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10300 -checkpoint 15
19:50:21:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:50:21:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
19:50:21:WU01:FS01:0x22:************************************ libFAH ************************************
19:50:21:WU01:FS01:0x22:       Time: 01:14:17
19:50:21:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
19:50:21:WU01:FS01:0x22:************************************ CBang *************************************
19:50:21:WU01:FS01:0x22:       Time: 01:13:20
19:50:21:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
19:50:21:WU01:FS01:0x22:************************************ System ************************************
19:50:21:WU01:FS01:0x22:        CPU: AMD Ryzen 9 5900X 12-Core Processor
19:50:21:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
19:50:21:WU01:FS01:0x22:       CPUs: 24
19:50:21:WU01:FS01:0x22:     Memory: 31.91GiB
19:50:21:WU01:FS01:0x22:Free Memory: 23.26GiB
19:50:21:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:50:21:WU01:FS01:0x22: OS Version: 6.2
19:50:21:WU01:FS01:0x22:Has Battery: false
19:50:21:WU01:FS01:0x22: On Battery: false
19:50:21:WU01:FS01:0x22: UTC Offset: -6
19:50:21:WU01:FS01:0x22:        PID: 10216
19:50:21:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
19:50:21:WU01:FS01:0x22:************************************ OpenMM ************************************
19:50:21:WU01:FS01:0x22:    Version: 7.7.0
19:50:21:WU01:FS01:0x22:********************************************************************************
19:50:21:WU01:FS01:0x22:Project: 18601 (Run 4634, Clone 4, Gen 13)
19:50:21:WU01:FS01:0x22:Reading tar file core.xml
19:50:21:WU01:FS01:0x22:Reading tar file integrator.xml
19:50:21:WU01:FS01:0x22:Reading tar file state.xml.bz2
19:50:21:WU01:FS01:0x22:Reading tar file system.xml.bz2
19:50:21:WU01:FS01:0x22:Digital signatures verified
19:50:21:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:50:21:WU01:FS01:0x22:Version 0.0.20
19:50:21:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
19:50:21:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:50:21:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
19:50:21:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
19:50:21:WU01:FS01:0x22:There are 4 platforms available.
19:50:21:WU01:FS01:0x22:Platform 0: Reference
19:50:21:WU01:FS01:0x22:Platform 1: CPU
19:50:21:WU01:FS01:0x22:Platform 2: OpenCL
19:50:21:WU01:FS01:0x22:  opencl-device 0 specified
19:50:21:WU01:FS01:0x22:Platform 3: CUDA
19:50:21:WU01:FS01:0x22:  cuda-device 0 specified
19:50:24:FS01:Finishing
19:50:44:Saving configuration to config.xml
19:50:44:<config>
19:50:44:  <!-- Network -->
19:50:44:  <proxy v=':8080'/>
19:50:44:
19:50:44:  <!-- Slot Control -->
19:50:44:  <pause-on-start v='true'/>
19:50:44:
19:50:44:  <!-- User Information -->
19:50:44:  <passkey v='*****'/>
19:50:44:  <team v='111065'/>
19:50:44:  <user v='Navic'/>
19:50:44:
19:50:44:  <!-- Folding Slots -->
19:50:44:  <slot id='0' type='CPU'>
19:50:44:    <cpus v='18'/>
19:50:44:  </slot>
19:50:44:  <slot id='1' type='GPU'>
19:50:44:    <pci-bus v='7'/>
19:50:44:    <pci-slot v='0'/>
19:50:44:  </slot>
19:50:44:</config>
19:50:52:WU01:FS01:0x22:Attempting to create CUDA context:
19:50:52:WU01:FS01:0x22:  Configuring platform CUDA
19:51:04:WU01:FS01:0x22:  Using CUDA and gpu 0
19:51:04:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
19:51:06:WU01:FS01:0x22:Checkpoint completed at step 0
19:51:24:FS00:Paused
19:51:24:FS01:Paused
19:51:24:FS00:Shutting core down
19:51:24:FS01:Shutting core down
19:51:24:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 1616
19:51:24:WU00:FS00:0xa8:Exiting, please wait. . .
19:51:24:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 10216
19:51:24:WU01:FS01:0x22:Exiting, please wait. . .
19:51:24:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
19:51:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:51:25:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:51:45:Saving configuration to config.xml
19:51:45:<config>
19:51:45:  <!-- Network -->
19:51:45:  <proxy v=':8080'/>
19:51:45:
19:51:45:  <!-- Slot Control -->
19:51:45:  <pause-on-start v='true'/>
19:51:45:
19:51:45:  <!-- User Information -->
19:51:45:  <passkey v='*****'/>
19:51:45:  <team v='111065'/>
19:51:45:  <user v='Navic'/>
19:51:45:
19:51:45:  <!-- Folding Slots -->
19:51:45:  <slot id='0' type='CPU'>
19:51:45:    <cpus v='18'/>
19:51:45:    <paused v='true'/>
19:51:45:  </slot>
19:51:45:  <slot id='1' type='GPU'>
19:51:45:    <pci-bus v='7'/>
19:51:45:    <pci-slot v='0'/>
19:51:45:  </slot>
19:51:45:</config>
20:06:58:FS00:Unpaused
20:06:58:FS01:Unpaused
20:06:58:WU00:FS00:Starting
20:06:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 22280 -checkpoint 15 -np 18
20:06:58:WU00:FS00:Started FahCore on PID 1664
20:06:58:WU00:FS00:Core PID:22556
20:06:58:WU00:FS00:FahCore 0xa8 started
20:06:58:WU01:FS01:Starting
20:06:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 22280 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
20:06:58:WU01:FS01:Started FahCore on PID 9680
20:06:58:WU01:FS01:Core PID:17780
20:06:58:WU01:FS01:FahCore 0x22 started
20:06:58:WU00:FS00:0xa8:*********************** Log Started 2023-01-11T20:06:58Z ***********************
20:06:58:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
20:06:58:WU00:FS00:0xa8:       Core: Gromacs
20:06:58:WU00:FS00:0xa8:       Type: 0xa8
20:06:58:WU00:FS00:0xa8:    Version: 0.0.12
20:06:58:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:06:58:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
20:06:58:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
20:06:58:WU00:FS00:0xa8:       Date: Jan 16 2021
20:06:58:WU00:FS00:0xa8:       Time: 12:29:40
20:06:58:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
20:06:58:WU00:FS00:0xa8:     Branch: master
20:06:58:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
20:06:58:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:06:58:WU00:FS00:0xa8:   Platform: win32 10
20:06:58:WU00:FS00:0xa8:       Bits: 64
20:06:58:WU00:FS00:0xa8:       Mode: Release
20:06:58:WU00:FS00:0xa8:       SIMD: avx2_256
20:06:58:WU00:FS00:0xa8:     OpenMP: ON
20:06:58:WU00:FS00:0xa8:       CUDA: OFF
20:06:58:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1664 -checkpoint 15 -np
20:06:58:WU00:FS00:0xa8:             18
20:06:58:WU00:FS00:0xa8:************************************ libFAH ************************************
20:06:58:WU00:FS00:0xa8:       Time: 11:24:13
20:06:58:WU00:FS00:0xa8:************************************ CBang *************************************
20:06:58:WU00:FS00:0xa8:       Time: 11:23:53
20:06:58:WU00:FS00:0xa8:************************************ System ************************************
20:06:58:WU00:FS00:0xa8:        CPU: AMD Ryzen 9 5900X 12-Core Processor
20:06:58:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
20:06:58:WU00:FS00:0xa8:       CPUs: 24
20:06:58:WU00:FS00:0xa8:     Memory: 31.91GiB
20:06:58:WU00:FS00:0xa8:Free Memory: 23.33GiB
20:06:58:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
20:06:58:WU00:FS00:0xa8: OS Version: 6.2
20:06:58:WU00:FS00:0xa8:Has Battery: false
20:06:58:WU00:FS00:0xa8: On Battery: false
20:06:58:WU00:FS00:0xa8: UTC Offset: -6
20:06:58:WU00:FS00:0xa8:        PID: 22556
20:06:58:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
20:06:58:WU00:FS00:0xa8:********************************************************************************
20:06:58:WU00:FS00:0xa8:Project: 16994 (Run 18, Clone 6, Gen 94)
20:06:58:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
20:06:58:WU00:FS00:0xa8:Digital signatures verified
20:06:58:WU00:FS00:0xa8:Calling: mdrun -c frame94.gro -s frame94.tpr -x frame94.xtc -cpi state.cpt -cpt 15 -nt 18 -ntmpi 1
20:06:58:WU00:FS00:0xa8:Steps: first=940000000 total=950000000
20:06:58:WU01:FS01:0x22:*********************** Log Started 2023-01-11T20:06:58Z ***********************
20:06:58:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:06:58:WU01:FS01:0x22:       Core: Core22
20:06:58:WU01:FS01:0x22:       Type: 0x22
20:06:58:WU01:FS01:0x22:    Version: 0.0.20
20:06:58:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:06:58:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
20:06:58:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
20:06:58:WU01:FS01:0x22:       Date: Jan 20 2022
20:06:58:WU01:FS01:0x22:       Time: 01:15:36
20:06:58:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
20:06:58:WU01:FS01:0x22:     Branch: HEAD
20:06:58:WU01:FS01:0x22:   Compiler: Visual C++
20:06:58:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:06:58:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
20:06:58:WU01:FS01:0x22:   Platform: win32 10
20:06:58:WU01:FS01:0x22:       Bits: 64
20:06:58:WU01:FS01:0x22:       Mode: Release
20:06:58:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:06:58:WU01:FS01:0x22:             <peastman@stanford.edu>
20:06:58:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9680 -checkpoint 15
20:06:58:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
20:06:58:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
20:06:58:WU01:FS01:0x22:************************************ libFAH ************************************
20:06:58:WU01:FS01:0x22:       Time: 01:14:17
20:06:58:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
20:06:58:WU01:FS01:0x22:************************************ CBang *************************************
20:06:58:WU01:FS01:0x22:       Time: 01:13:20
20:06:58:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
20:06:58:WU01:FS01:0x22:************************************ System ************************************
20:06:58:WU01:FS01:0x22:        CPU: AMD Ryzen 9 5900X 12-Core Processor
20:06:58:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
20:06:58:WU01:FS01:0x22:       CPUs: 24
20:06:58:WU01:FS01:0x22:     Memory: 31.91GiB
20:06:58:WU01:FS01:0x22:Free Memory: 23.31GiB
20:06:58:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
20:06:58:WU01:FS01:0x22: OS Version: 6.2
20:06:58:WU01:FS01:0x22:Has Battery: false
20:06:58:WU01:FS01:0x22: On Battery: false
20:06:58:WU01:FS01:0x22: UTC Offset: -6
20:06:58:WU01:FS01:0x22:        PID: 17780
20:06:58:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
20:06:58:WU01:FS01:0x22:************************************ OpenMM ************************************
20:06:58:WU01:FS01:0x22:    Version: 7.7.0
20:06:58:WU01:FS01:0x22:********************************************************************************
20:06:58:WU01:FS01:0x22:Project: 18601 (Run 4634, Clone 4, Gen 13)
20:06:58:WU01:FS01:0x22:Digital signatures verified
20:06:58:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:06:58:WU01:FS01:0x22:Version 0.0.20
20:06:58:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
20:06:58:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
20:06:58:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
20:06:58:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
20:06:59:WU01:FS01:0x22:There are 4 platforms available.
20:06:59:WU01:FS01:0x22:Platform 0: Reference
20:06:59:WU01:FS01:0x22:Platform 1: CPU
20:06:59:WU01:FS01:0x22:Platform 2: OpenCL
20:06:59:WU01:FS01:0x22:  opencl-device 0 specified
20:06:59:WU01:FS01:0x22:Platform 3: CUDA
20:06:59:WU01:FS01:0x22:  cuda-device 0 specified
20:06:59:WU00:FS00:0xa8:Completed 23491 out of 10000000 steps (0%)
20:07:00:Saving configuration to config.xml
20:07:00:<config>
20:07:00:  <!-- Network -->
20:07:00:  <proxy v=':8080'/>
20:07:00:
20:07:00:  <!-- Slot Control -->
20:07:00:  <pause-on-start v='true'/>
20:07:00:
20:07:00:  <!-- User Information -->
20:07:00:  <passkey v='*****'/>
20:07:00:  <team v='111065'/>
20:07:00:  <user v='Navic'/>
20:07:00:
20:07:00:  <!-- Folding Slots -->
20:07:00:  <slot id='0' type='CPU'>
20:07:00:    <cpus v='18'/>
20:07:00:  </slot>
20:07:00:  <slot id='1' type='GPU'>
20:07:00:    <pci-bus v='7'/>
20:07:00:    <pci-slot v='0'/>
20:07:00:  </slot>
20:07:00:</config>
20:07:00:FS00:Finishing
20:07:00:FS01:Finishing
20:07:28:WU01:FS01:0x22:Attempting to create CUDA context:
20:07:28:WU01:FS01:0x22:  Configuring platform CUDA
20:07:36:WU01:FS01:0x22:  Using CUDA and gpu 0
20:07:36:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
20:07:38:WU01:FS01:0x22:Checkpoint completed at step 0
20:08:42:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
20:09:49:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
20:09:52:WU01:FS01:0x22:Checkpoint completed at step 25000
20:10:56:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
20:11:22:WU00:FS00:0xa8:Completed 100000 out of 10000000 steps (1%)
20:12:00:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
20:12:02:WU01:FS01:0x22:Checkpoint completed at step 50000
20:13:08:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
20:14:23:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
20:14:26:WU01:FS01:0x22:Checkpoint completed at step 75000
20:15:43:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
20:16:52:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
20:16:55:WU01:FS01:0x22:Checkpoint completed at step 100000
20:17:20:WU00:FS00:0xa8:Completed 200000 out of 10000000 steps (2%)
[deleted completion percent]
21:56:10:WU00:FS00:0xa8:Completed 1900000 out of 10000000 steps (19%)
21:56:35:WU01:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
21:57:43:WU01:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
21:57:45:WU01:FS01:0x22:Checkpoint completed at step 1175000
21:57:54:FS00:Paused
21:57:54:FS01:Paused
21:57:54:FS00:Shutting core down
21:57:54:FS01:Shutting core down
21:57:54:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 22556
21:57:54:WU00:FS00:0xa8:Exiting, please wait. . .
21:57:54:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 17780
21:57:54:WU01:FS01:0x22:Exiting, please wait. . .
21:57:54:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
21:57:54:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:57:55:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:58:50:Saving configuration to config.xml
21:58:50:<config>
21:58:50:  <!-- Network -->
21:58:50:  <proxy v=':8080'/>
21:58:50:
21:58:50:  <!-- Slot Control -->
21:58:50:  <pause-on-start v='true'/>
21:58:50:
21:58:50:  <!-- User Information -->
21:58:50:  <passkey v='*****'/>
21:58:50:  <team v='111065'/>
21:58:50:  <user v='Navic'/>
21:58:50:
21:58:50:  <!-- Folding Slots -->
21:58:50:  <slot id='0' type='CPU'>
21:58:50:    <cpus v='18'/>
21:58:50:    <paused v='true'/>
21:58:50:  </slot>
21:58:50:  <slot id='1' type='GPU'>
21:58:50:    <pci-bus v='7'/>
21:58:50:    <pci-slot v='0'/>
21:58:50:  </slot>
21:58:50:</config>
Vester
Hardware configuration: Gigabyte Aorus Z590 Pro AX, Intel i9-10850K, 32GB Crucial Ballistix DDR4-2600, Samsung NVMe EVO 980 Pro 256GB, CoolerMaster liquid cooler ML360, Nvidia Titan X (Pascal), Dell Nvidia RTX 3080 10GB 4Y12V, Pop!_OS.
Re: F@H causes my USB devices to disconnect and reconnect randomly
Post by Vester »
You certainly have done an excellent job in your attempt to resolve the issue. Here is an AMD Tip to Mitigate USB Disconnect Problems. See the section "Based on user feedback..."
You may find something useful in All my USB devices disconnect for a split second when using Windows 10 at Microsoft.
Navic
Post by Navic »
Vester wrote: Thu Jan 12, 2023 9:57 pm You certainly have done an excellent job in your attempt to resolve the issue. Here is an AMD Tip to Mitigate USB Disconnect Problems. See the section "Based on user feedback..."
Thanks for the links. That article about AMD problems I've already looked into. Couldn't find the setting for global c-state control until today, so I tried that and that didn't fix it.
I also looked at the microsoft forum discussion you linked, went through a lot of those links (most said the same thing as the others) and tried what they suggested, but to no avail.
The later comments in that thread did lead me to thinking it might be an iCue/CPU cooler issue since it's connected with USB 2.0, so I quit iCue and the USB disconnect/reconnect problem has seemingly stopped. The cooler is still connected as I can monitor temps and fan speed via HWiNFO64, but it might have been an iCue problem. My theory is that because I have the RGB on the cooler set to change with different component temperatures, maybe those constant updates to the RGB were sometimes causing problems when running F@H (maybe the cooler got stuck and restarted? idk). If I complete these WUs without having the weird disconnect/reconnect issue, I'll run them again with iCue open, but with static RGB instead of dynamic temperature controlled RGB (or at least less temp controlled layers, because I have 4 different zones of RGB on the cooler controlled by different temp readouts in my system).
EDIT: Right after I posted this, the problem happened again. Looks like it wasn't iCue like I was hoping for.
