Missing GPU in list
murre
Missing GPU in list
Post by murre »
Pleas add this new modell of: NVIDIA GeForce RTX 3060 Ti GDDR6X to the white list.
Device ID: 10DE 24C9 - 1043 88AC
*********************** Log Started 2022-12-27T17:15:49Z ***********************
17:15:49:******************************* libFAH ********************************
17:15:49:           Date: Oct 20 2020
17:15:49:           Time: 13:36:55
17:15:49:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
17:15:49:         Branch: master
17:15:49:       Compiler: Visual C++ 2015
17:15:49:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:15:49:       Platform: win32 10
17:15:49:           Bits: 32
17:15:49:           Mode: Release
17:15:49:****************************** FAHClient ******************************
17:15:49:        Version: 7.6.21
17:15:49:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:15:49:      Copyright: 2020 foldingathome.org
17:15:49:       Homepage: https://foldingathome.org/
17:15:49:           Time: 13:41:04
17:15:49:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
17:15:49:           Bits: 32
17:15:49:         Config: D:\ProgramData\FAHClient\config.xml
17:15:49:******************************** CBang ********************************
17:15:49:           Time: 11:36:18
17:15:49:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
17:15:49:           Bits: 32
17:15:49:******************************* System ********************************
17:15:49:            CPU: AMD Ryzen 5 5600X 6-Core Processor
17:15:49:         CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
17:15:49:           CPUs: 12
17:15:49:         Memory: 15.91GiB
17:15:49:    Free Memory: 12.31GiB
17:15:49:        Threads: WINDOWS_THREADS
17:15:49:     OS Version: 6.2
17:15:49:    Has Battery: true
17:15:49:     On Battery: false
17:15:49:     UTC Offset: 1
17:15:49:            PID: 6280
17:15:49:            CWD: D:\ProgramData\FAHClient
17:15:49:  Win32 Service: false
17:15:49:             OS: Windows 10 Enterprise
17:15:49:        OS Arch: AMD64
17:15:49:           GPUs: 1
17:15:49:          GPU 0: Bus:8 Slot:0 Func:0 NVIDIA:1
17:15:49:  CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:8.6 Driver:12.0
17:15:49:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:3.0 Driver:527.56
17:15:49:***********************************************************************
17:15:49:<config>
17:15:49:  <!-- Folding Core -->
17:15:49:  <checkpoint v='4'/>
17:15:49:
17:15:49:  <!-- HTTP Server -->
17:15:49:  <allow v='127.0.0.1 192.168.10.0/24'/>
17:15:49:
17:15:49:  <!-- Network -->
17:15:49:  <proxy v=':8080'/>
17:15:49:
17:15:49:  <!-- Remote Command Server -->
17:15:49:  <command-allow-no-pass v='127.0.0.1 192.168.10.0/24'/>
17:15:49:
17:15:49:  <!-- Slot Control -->
17:15:49:  <power v='full'/>
17:15:49:
17:15:49:  <!-- User Information -->
17:15:49:  <passkey v='*****'/>
17:15:49:  <team v='37451'/>
17:15:49:  <user v='murre'/>
17:15:49:
17:15:49:  <!-- Folding Slots -->
17:15:49:  <slot id='2' type='GPU'>
17:15:49:    <client-type v='advanced'/>
17:15:49:    <max-packet-size v='big'/>
17:15:49:    <paused v='true'/>
17:15:49:    <pci-bus v='8'/>
17:15:49:    <pci-slot v='0'/>
17:15:49:  </slot>
17:15:49:</config>
17:15:49:Trying to access database...
17:15:49:Successfully acquired database lock
17:15:49:WARNING:FS02:Disabling beta GPU slot 02: gpu:8:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
17:15:49:ERROR:No valid folding configuration
17:15:49:WARNING:WU00:No longer matches Slot 2's configuration and there are no other matching slots, dumping
17:15:49:WU00:FS02:Sending unit results: id:00 state:SEND error:DUMPED project:16977 run:10 clone:1768 gen:151 core:0xa8 unit:0x000006e800000097000042510000000a
17:15:49:WU00:FS02:Connecting to 129.32.209.202:8080
17:15:50:WU00:FS02:Server responded WORK_ACK (400)
17:15:50:WU00:FS02:Cleaning up
Reason: added code tags to log
Re: Missing GPU in list
Added 0x24c9 / GA104 [GeForce RTX 3060 Ti].
murre
Post by murre »
Thanks, that was fast! Now it`s working!
