First Job, complete time way off
ellandrydroid
Post by ellandrydroid »
So the CPU is only @ 1.01% and the GPU is almost 70% but it went from 2.99 days complete to like 26 days. WTH? Also the cpu is 8 core so how is that only at 1%? Plus the points went way way down for the job since i started
https://i.imgur.com/ByiDjmh.jpg
Re: First Job, complete time way off
The picture shows you have two separate things mixed up. The progress bar is for the WU being processed on your GPU. The rest of the information in that picture is for a WU from Project 16998 which is a CPU project and may be at a totally different stage of progress or just started.
Information tat would be useful is from your log file. The Welcome topic includes posts on how to locate and post your log file - viewtopic.php?t=26036. Links are there for doing so from Windows, Linux and macOS. The first 100 lines showing your hardware and software cofiguration of the client plus enough to show a few percent of progress on each WU is enough. The whole log is not required.
ellandrydroid
 *********************** Log Started 2022-12-25T15:12:33Z ***********************
15:12:33:******************************* libFAH ********************************
15:12:33:           Date: Oct 20 2020
15:12:33:           Time: 13:36:55
15:12:33:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:12:33:         Branch: master
15:12:33:       Compiler: Visual C++ 2015
15:12:33:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:12:33:       Platform: win32 10
15:12:33:           Bits: 32
15:12:33:           Mode: Release
15:12:33:****************************** FAHClient ******************************
15:12:33:        Version: 7.6.21
15:12:33:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:12:33:      Copyright: 2020 foldingathome.org
15:12:33:       Homepage: https://foldingathome.org/
15:12:33:           Time: 13:41:04
15:12:33:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:12:33:           Bits: 32
15:12:33:           Args: --open-web-control
15:12:33:******************************** CBang ********************************
15:12:33:           Time: 11:36:18
15:12:33:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:12:33:           Bits: 32
15:12:33:******************************* System ********************************
15:12:33:            CPU: AMD FX(tm)-8350 Eight-Core Processor
15:12:33:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
15:12:33:           CPUs: 8
15:12:33:         Memory: 7.90GiB
15:12:33:    Free Memory: 1.45GiB
15:12:33:        Threads: WINDOWS_THREADS
15:12:33:     OS Version: 6.2
15:12:33:    Has Battery: false
15:12:33:     On Battery: false
15:12:33:     UTC Offset: -6
15:12:33:            PID: 13872
15:12:33:            CWD: C:\ProgramData\FAHClient
15:12:33:  Win32 Service: false
15:12:33:             OS: Windows 10 Home
15:12:33:        OS Arch: AMD64
15:12:33:           GPUs: 1
15:12:33:          GPU 0: Bus:6 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
15:12:33:  CUDA Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:7.5 Driver:12.0
15:12:33:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:3.0 Driver:527.56
15:12:33:***********************************************************************
15:12:33:<config>
15:12:33:  <!-- Folding Slots -->
15:12:33:</config>
15:12:33:Trying to access database...
15:12:33:Successfully acquired database lock
15:12:33:FS00:Initialized folding slot 00: cpu:6
15:12:33:FS01:Initialized folding slot 01: gpu:6:0 TU116 [GeForce GTX 1660 SUPER]
15:12:40:18:127.0.0.1:New Web session
15:13:34:Saving configuration to config.xml
15:13:34:<config>
15:13:34:  <!-- Folding Slots -->
15:13:34:  <slot id='0' type='CPU'/>
15:13:34:  <slot id='1' type='GPU'>
15:13:34:    <pci-bus v='6'/>
15:13:34:    <pci-slot v='0'/>
15:13:34:  </slot>
15:13:34:</config>
15:13:34:Set client configured
15:13:34:WU00:FS00:Connecting to assign1.foldingathome.org:80
15:13:34:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:13:35:WU00:FS00:Connecting to assign1.foldingathome.org:80
15:13:35:WU01:FS01:Connecting to assign1.foldingathome.org:80
15:13:35:WU00:FS00:Assigned to work server 129.32.209.202
15:13:35:WU00:FS00:Requesting new work unit for slot 00: cpu:6 from 129.32.209.202
15:13:35:WU00:FS00:Connecting to 129.32.209.202:8080
15:13:36:WU01:FS01:Assigned to work server 129.32.209.202
15:13:36:WU01:FS01:Requesting new work unit for slot 01: gpu:6:0 TU116 [GeForce GTX 1660 SUPER] from 129.32.209.202
15:13:36:WU01:FS01:Connecting to 129.32.209.202:8080
15:13:36:WU00:FS00:Downloading 835.00KiB
15:13:36:WU01:FS01:Downloading 56.95MiB
15:13:40:WU00:FS00:Download complete
15:13:40:WU01:FS01:Download complete
15:13:40:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16998 run:8 clone:75 gen:210 core:0xa8 unit:0x0000004b000000d20000426600000008
15:13:40:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah
15:13:40:WU00:FS00:Connecting to cores.foldingathome.org:80
15:13:40:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18448 run:8 clone:46 gen:295 core:0x22 unit:0x0000002e000001270000481000000008
15:13:40:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah
15:13:40:WU01:FS01:Connecting to cores.foldingathome.org:80
15:13:40:WU00:FS00:FahCore a8: Downloading 7.72MiB
15:13:40:WU01:FS01:FahCore 22: Downloading 156.61MiB
15:13:42:WU00:FS00:FahCore a8: Download complete
15:13:42:WU00:FS00:Valid core signature
15:13:42:WU00:FS00:Unpacked 21.01MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
15:13:42:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
15:13:42:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
15:13:42:WU00:FS00:Starting
15:13:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -np 6
15:13:42:WU00:FS00:Started FahCore on PID 5144
15:13:44:WU00:FS00:Core PID:2632
15:13:44:WU00:FS00:FahCore 0xa8 started
15:13:44:WU00:FS00:0xa8:*********************** Log Started 2022-12-25T15:13:44Z ***********************
15:13:44:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:13:44:WU00:FS00:0xa8:       Core: Gromacs
15:13:44:WU00:FS00:0xa8:       Type: 0xa8
15:13:44:WU00:FS00:0xa8:    Version: 0.0.12
15:13:44:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:13:44:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
15:13:44:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
15:13:44:WU00:FS00:0xa8:       Date: Jan 16 2021
15:13:44:WU00:FS00:0xa8:       Time: 11:56:07
15:13:44:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:13:44:WU00:FS00:0xa8:     Branch: master
15:13:44:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
15:13:44:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:13:44:WU00:FS00:0xa8:   Platform: win32 10
15:13:44:WU00:FS00:0xa8:       Bits: 64
15:13:44:WU00:FS00:0xa8:       Mode: Release
15:13:44:WU00:FS00:0xa8:       SIMD: avx_256
15:13:44:WU00:FS00:0xa8:     OpenMP: ON
15:13:44:WU00:FS00:0xa8:       CUDA: OFF
15:13:44:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5144 -checkpoint 15 -np 6
15:13:44:WU00:FS00:0xa8:************************************ libFAH ************************************
15:13:44:WU00:FS00:0xa8:       Time: 11:24:13
15:13:44:WU00:FS00:0xa8:************************************ CBang *************************************
15:13:44:WU00:FS00:0xa8:       Time: 11:23:53
15:13:45:WU00:FS00:0xa8:   Platform: win32 10
15:13:45:WU00:FS00:0xa8:       Bits: 64
15:13:45:WU00:FS00:0xa8:       Mode: Release
15:13:45:WU00:FS00:0xa8:************************************ System ************************************
15:13:45:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
15:13:45:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
15:13:45:WU00:FS00:0xa8:       CPUs: 8
15:13:45:WU00:FS00:0xa8:     Memory: 7.90GiB
15:13:45:WU00:FS00:0xa8:Free Memory: 1.32GiB
15:13:45:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
15:13:45:WU00:FS00:0xa8: OS Version: 6.2
15:13:45:WU00:FS00:0xa8:Has Battery: false
15:13:45:WU00:FS00:0xa8: On Battery: false
15:13:45:WU00:FS00:0xa8: UTC Offset: -6
15:13:45:WU00:FS00:0xa8:        PID: 2632
15:13:45:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
15:13:45:WU00:FS00:0xa8:********************************************************************************
15:13:45:WU00:FS00:0xa8:Project: 16998 (Run 8, Clone 75, Gen 210)
15:13:45:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:13:45:WU00:FS00:0xa8:Reading tar file core.xml
15:13:45:WU00:FS00:0xa8:Reading tar file frame210.tpr
15:13:45:WU00:FS00:0xa8:Digital signatures verified
15:13:45:WU00:FS00:0xa8:Calling: mdrun -c frame210.gro -s frame210.tpr -x frame210.xtc -cpt 15 -nt 6 -ntmpi 1
15:13:45:WU00:FS00:0xa8:Steps: first=525000000 total=527500000
15:13:46:WU01:FS01:FahCore 22: 4.39%
15:13:49:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
15:13:52:WU01:FS01:FahCore 22: 18.84%
15:13:58:WU01:FS01:FahCore 22: 52.36%
15:14:04:WU01:FS01:FahCore 22: 86.28%
15:14:07:WU01:FS01:FahCore 22: Download complete
15:14:07:WU01:FS01:Valid core signature
15:14:07:WU01:FS01:Unpacked 5.52MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe
15:14:07:WU01:FS01:Unpacked 24.45KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/api-ms-win-crt-runtime-l1-1-0.dll
15:14:08:WU01:FS01:Unpacked 179.58MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/cufft64_10.dll
15:14:08:WU01:FS01:Unpacked 3.25MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/libcrypto-1_1-x64.dll
15:14:08:WU01:FS01:Unpacked 667.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/libssl-1_1-x64.dll
15:14:08:WU01:FS01:Unpacked 552.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140.dll
15:14:08:WU01:FS01:Unpacked 23.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_1.dll
15:14:08:WU01:FS01:Unpacked 181.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_2.dll
15:14:08:WU01:FS01:Unpacked 54.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_atomic_wait.dll
15:14:08:WU01:FS01:Unpacked 19.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/msvcp140_codecvt_ids.dll
15:14:08:WU01:FS01:Unpacked 5.29MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/nvrtc-builtins64_112.dll
15:14:08:WU01:FS01:Unpacked 30.51MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/nvrtc64_112_0.dll
15:14:08:WU01:FS01:Unpacked 2.81MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMM.dll
15:14:08:WU01:FS01:Unpacked 302.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoeba.dll
15:14:08:WU01:FS01:Unpacked 1.04MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaCUDA.dll
15:14:08:WU01:FS01:Unpacked 952.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaOpenCL.dll
15:14:08:WU01:FS01:Unpacked 458.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMAmoebaReference.dll
15:14:08:WU01:FS01:Unpacked 517.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCPU.dll
15:14:08:WU01:FS01:Unpacked 1.78MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCUDA.dll
15:14:08:WU01:FS01:Unpacked 60.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMCudaCompiler.dll
15:14:08:WU01:FS01:Unpacked 99.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrude.dll
15:14:08:WU01:FS01:Unpacked 118.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeCUDA.dll
15:14:08:WU01:FS01:Unpacked 118.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeOpenCL.dll
15:14:08:WU01:FS01:Unpacked 87.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMDrudeReference.dll
15:14:08:WU01:FS01:Unpacked 1.81MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMOpenCL.dll
15:14:08:WU01:FS01:Unpacked 61.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMPME.dll
15:14:08:WU01:FS01:Unpacked 57.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMD.dll
15:14:08:WU01:FS01:Unpacked 138.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDCUDA.dll
15:14:08:WU01:FS01:Unpacked 138.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDOpenCL.dll
15:14:08:WU01:FS01:Unpacked 75.50KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/OpenMMRPMDReference.dll
15:14:08:WU01:FS01:Unpacked 94.88KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/vcruntime140.dll
15:14:08:WU01:FS01:Unpacked 36.38KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/vcruntime140_1.dll
15:14:08:WU01:FS01:Starting
15:14:08:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
15:14:08:WU01:FS01:Started FahCore on PID 6100
15:14:10:WU01:FS01:Core PID:11072
15:14:10:WU01:FS01:FahCore 0x22 started
15:14:10:WU01:FS01:0x22:*********************** Log Started 2022-12-25T15:14:10Z ***********************
15:14:10:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:14:10:WU01:FS01:0x22:       Core: Core22
15:14:10:WU01:FS01:0x22:       Type: 0x22
15:14:10:WU01:FS01:0x22:    Version: 0.0.20
15:14:10:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:14:10:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
15:14:10:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
15:14:10:WU01:FS01:0x22:       Date: Jan 20 2022
15:14:10:WU01:FS01:0x22:       Time: 01:15:36
15:14:10:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:14:10:WU01:FS01:0x22:     Branch: HEAD
15:14:10:WU01:FS01:0x22:   Compiler: Visual C++
15:14:10:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:14:10:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
15:14:10:WU01:FS01:0x22:   Platform: win32 10
15:14:10:WU01:FS01:0x22:       Bits: 64
15:14:10:WU01:FS01:0x22:       Mode: Release
15:14:10:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:14:10:WU01:FS01:0x22:             <peastman@stanford.edu>
15:14:10:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6100 -checkpoint 15
15:14:10:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:14:10:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
15:14:10:WU01:FS01:0x22:************************************ libFAH ************************************
15:14:10:WU01:FS01:0x22:       Time: 01:14:17
15:14:10:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:14:10:WU01:FS01:0x22:************************************ CBang *************************************
15:14:10:WU01:FS01:0x22:       Time: 01:13:20
15:14:10:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:14:10:WU01:FS01:0x22:************************************ System ************************************
15:14:10:WU01:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
15:14:10:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
15:14:10:WU01:FS01:0x22:       CPUs: 8
15:14:10:WU01:FS01:0x22:     Memory: 7.90GiB
15:14:10:WU01:FS01:0x22:Free Memory: 1.32GiB
15:14:10:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
15:14:10:WU01:FS01:0x22: OS Version: 6.2
15:14:10:WU01:FS01:0x22:Has Battery: false
15:14:10:WU01:FS01:0x22: On Battery: false
15:14:10:WU01:FS01:0x22: UTC Offset: -6
15:14:10:WU01:FS01:0x22:        PID: 11072
15:14:10:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
15:14:10:WU01:FS01:0x22:************************************ OpenMM ************************************
15:14:10:WU01:FS01:0x22:    Version: 7.7.0
15:14:10:WU01:FS01:0x22:********************************************************************************
15:14:10:WU01:FS01:0x22:Project: 18448 (Run 8, Clone 46, Gen 295)
15:14:10:WU01:FS01:0x22:Reading tar file core.xml
15:14:10:WU01:FS01:0x22:Reading tar file integrator.xml
15:14:10:WU01:FS01:0x22:Reading tar file state.xml
15:14:12:WU01:FS01:0x22:Reading tar file system.xml
15:14:13:WU01:FS01:0x22:Digital signatures verified
15:14:13:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:14:13:WU01:FS01:0x22:Version 0.0.20
15:14:13:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
15:14:13:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
15:14:13:WU01:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
15:14:13:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
15:14:14:WU01:FS01:0x22:There are 4 platforms available.
15:14:14:WU01:FS01:0x22:Platform 0: Reference
15:14:14:WU01:FS01:0x22:Platform 1: CPU
15:14:14:WU01:FS01:0x22:Platform 2: OpenCL
15:14:14:WU01:FS01:0x22:  opencl-device 0 specified
15:14:14:WU01:FS01:0x22:Platform 3: CUDA
15:14:14:WU01:FS01:0x22:  cuda-device 0 specified
15:16:00:WU01:FS01:0x22:Attempting to create CUDA context:
15:16:00:WU01:FS01:0x22:  Configuring platform CUDA
15:16:37:Saving configuration to config.xml
15:16:37:<config>
15:16:37:  <!-- Folding Slot Configuration -->
15:16:37:  <cause v='HIGH_PRIORITY'/>
15:16:37:
15:16:37:  <!-- User Information -->
15:16:37:  <passkey v='*****'/>
15:16:37:  <team v='234980'/>
15:16:37:  <user v='rikcvnbo9kw2'/>
15:16:37:
15:16:37:  <!-- Folding Slots -->
15:16:37:  <slot id='0' type='CPU'/>
15:16:37:  <slot id='1' type='GPU'>
15:16:37:    <pci-bus v='6'/>
15:16:37:    <pci-slot v='0'/>
15:16:37:  </slot>
15:16:37:</config>
15:16:58:WU01:FS01:0x22:  Using CUDA and gpu 0
15:16:58:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
15:17:02:WU01:FS01:0x22:Checkpoint completed at step 0
15:19:20:53:127.0.0.1:New Web session
15:23:13:FS00:Shutting core down
15:23:13:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 2632
15:23:13:WU00:FS00:0xa8:Exiting, please wait. . .
15:23:30:WU00:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
15:23:31:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:23:31:WU00:FS00:Starting
15:23:31:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
15:23:31:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
15:23:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -np 6
15:23:31:WU00:FS00:Started FahCore on PID 6944
15:23:31:WU00:FS00:Core PID:4956
15:23:31:WU00:FS00:FahCore 0xa8 started
15:23:32:WU00:FS00:0xa8:*********************** Log Started 2022-12-25T15:23:32Z ***********************
15:23:32:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:23:32:WU00:FS00:0xa8:       Core: Gromacs
15:23:32:WU00:FS00:0xa8:       Type: 0xa8
15:23:32:WU00:FS00:0xa8:    Version: 0.0.12
15:23:32:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:23:32:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
15:23:32:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
15:23:32:WU00:FS00:0xa8:       Date: Jan 16 2021
15:23:32:WU00:FS00:0xa8:       Time: 11:56:07
15:23:32:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:23:32:WU00:FS00:0xa8:     Branch: master
15:23:32:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
15:23:32:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:23:32:WU00:FS00:0xa8:   Platform: win32 10
15:23:32:WU00:FS00:0xa8:       Bits: 64
15:23:32:WU00:FS00:0xa8:       Mode: Release
15:23:32:WU00:FS00:0xa8:       SIMD: avx_256
15:23:32:WU00:FS00:0xa8:     OpenMP: ON
15:23:32:WU00:FS00:0xa8:       CUDA: OFF
15:23:32:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6944 -checkpoint 15 -np 6
15:23:32:WU00:FS00:0xa8:************************************ libFAH ************************************
15:23:32:WU00:FS00:0xa8:       Time: 11:24:13
15:23:32:WU00:FS00:0xa8:************************************ CBang *************************************
15:23:32:WU00:FS00:0xa8:       Time: 11:23:53
15:23:32:WU00:FS00:0xa8:************************************ System ************************************
15:23:32:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
15:23:32:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
15:23:32:WU00:FS00:0xa8:       CPUs: 8
15:23:32:WU00:FS00:0xa8:     Memory: 7.90GiB
15:23:32:WU00:FS00:0xa8:Free Memory: 1.04GiB
15:23:32:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
15:23:32:WU00:FS00:0xa8: OS Version: 6.2
15:23:32:WU00:FS00:0xa8:Has Battery: false
15:23:32:WU00:FS00:0xa8: On Battery: false
15:23:32:WU00:FS00:0xa8: UTC Offset: -6
15:23:32:WU00:FS00:0xa8:        PID: 4956
15:23:32:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
15:23:32:WU00:FS00:0xa8:********************************************************************************
15:23:32:WU00:FS00:0xa8:Project: 16998 (Run 8, Clone 75, Gen 210)
15:23:32:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:23:32:WU00:FS00:0xa8:Digital signatures verified
15:23:32:WU00:FS00:0xa8:Calling: mdrun -c frame210.gro -s frame210.tpr -x frame210.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
15:23:33:WU00:FS00:0xa8:Steps: first=525000000 total=527500000
15:23:38:WU00:FS00:0xa8:Completed 602 out of 2500000 steps (0%)
15:23:44:Saving configuration to config.xml
15:23:44:<config>
15:23:44:  <!-- Folding Slot Configuration -->
15:23:44:  <cause v='HIGH_PRIORITY'/>
15:23:44:
15:23:44:  <!-- Slot Control -->
15:23:44:  <power v='FULL'/>
15:23:44:
15:23:44:  <!-- User Information -->
15:23:44:  <passkey v='*****'/>
15:23:44:  <team v='234980'/>
15:23:44:  <user v='rikcvnbo9kw2'/>
15:23:44:
15:23:44:  <!-- Folding Slots -->
15:23:44:  <slot id='0' type='CPU'/>
15:23:44:  <slot id='1' type='GPU'>
15:23:44:    <pci-bus v='6'/>
15:23:44:    <pci-slot v='0'/>
15:23:44:  </slot>
15:23:44:</config>
15:26:00:FS00:Shutting core down
15:26:00:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 4956
15:26:00:WU00:FS00:0xa8:Exiting, please wait. . .
15:26:22:WU00:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
15:26:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:26:23:WU00:FS00:Starting
15:26:23:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
15:26:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -np 6
15:26:23:WU00:FS00:Started FahCore on PID 17976
15:26:23:WU00:FS00:Core PID:16360
15:26:23:WU00:FS00:FahCore 0xa8 started
15:26:24:WU00:FS00:0xa8:*********************** Log Started 2022-12-25T15:26:23Z ***********************
15:26:24:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:26:24:WU00:FS00:0xa8:       Core: Gromacs
15:26:24:WU00:FS00:0xa8:       Type: 0xa8
15:26:24:WU00:FS00:0xa8:    Version: 0.0.12
15:26:24:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:26:24:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
15:26:24:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
15:26:24:WU00:FS00:0xa8:       Date: Jan 16 2021
15:26:24:WU00:FS00:0xa8:       Time: 11:56:07
15:26:24:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:26:24:WU00:FS00:0xa8:     Branch: master
15:26:24:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
15:26:24:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:26:24:WU00:FS00:0xa8:   Platform: win32 10
15:26:24:WU00:FS00:0xa8:       Bits: 64
15:26:24:WU00:FS00:0xa8:       Mode: Release
15:26:24:WU00:FS00:0xa8:       SIMD: avx_256
15:26:24:WU00:FS00:0xa8:     OpenMP: ON
15:26:24:WU00:FS00:0xa8:       CUDA: OFF
15:26:24:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17976 -checkpoint 15 -np
15:26:24:WU00:FS00:0xa8:             6
15:26:24:WU00:FS00:0xa8:************************************ libFAH ************************************
15:26:24:WU00:FS00:0xa8:       Time: 11:24:13
15:26:24:WU00:FS00:0xa8:************************************ CBang *************************************
15:26:24:WU00:FS00:0xa8:       Time: 11:23:53
15:26:24:WU00:FS00:0xa8:************************************ System ************************************
15:26:24:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
15:26:24:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
15:26:24:WU00:FS00:0xa8:       CPUs: 8
15:26:24:WU00:FS00:0xa8:     Memory: 7.90GiB
15:26:24:WU00:FS00:0xa8:Free Memory: 1.07GiB
15:26:24:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
15:26:24:WU00:FS00:0xa8: OS Version: 6.2
15:26:24:WU00:FS00:0xa8:Has Battery: false
15:26:24:WU00:FS00:0xa8: On Battery: false
15:26:24:WU00:FS00:0xa8: UTC Offset: -6
15:26:24:WU00:FS00:0xa8:        PID: 16360
15:26:24:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
15:26:24:WU00:FS00:0xa8:********************************************************************************
15:26:24:WU00:FS00:0xa8:Project: 16998 (Run 8, Clone 75, Gen 210)
15:26:24:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:26:24:WU00:FS00:0xa8:Digital signatures verified
15:26:24:WU00:FS00:0xa8:Calling: mdrun -c frame210.gro -s frame210.tpr -x frame210.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
15:26:26:WU00:FS00:0xa8:Steps: first=525000000 total=527500000
15:26:31:WU00:FS00:0xa8:Completed 752 out of 2500000 steps (0%)
15:26:47:Saving configuration to config.xml
15:26:47:<config>
15:26:47:  <!-- Folding Slot Configuration -->
15:26:47:  <cause v='HIGH_PRIORITY'/>
15:26:47:
15:26:47:  <!-- Slot Control -->
15:26:47:  <power v='MEDIUM'/>
15:26:47:
15:26:47:  <!-- User Information -->
15:26:47:  <passkey v='*****'/>
15:26:47:  <team v='234980'/>
15:26:47:  <user v='rikcvnbo9kw2'/>
15:26:47:
15:26:47:  <!-- Folding Slots -->
15:26:47:  <slot id='0' type='CPU'/>
15:26:47:  <slot id='1' type='GPU'>
15:26:47:    <pci-bus v='6'/>
15:26:47:    <pci-slot v='0'/>
15:26:47:  </slot>
15:26:47:</config>
15:27:11:WU01:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
15:36:22:WU01:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
15:36:27:WU01:FS01:0x22:Checkpoint completed at step 50000
15:45:21:WU01:FS01:0x22:Completed 75000 out of 2500000 steps (3%)
15:54:07:WU01:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
15:54:11:WU01:FS01:0x22:Checkpoint completed at step 100000
16:02:59:WU01:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
16:11:56:WU01:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
16:12:01:WU01:FS01:0x22:Checkpoint completed at step 150000
16:14:05:FS00:Paused
16:14:05:FS01:Paused
16:14:05:FS00:Shutting core down
16:14:05:FS01:Shutting core down
16:14:05:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 16360
16:14:05:WU00:FS00:0xa8:Exiting, please wait. . .
16:14:05:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 11072
16:14:05:WU01:FS01:0x22:Exiting, please wait. . .
16:14:05:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
16:14:08:FS00:Unpaused
16:14:08:FS01:Unpaused
16:14:11:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
16:14:12:WU01:FS01:Starting
16:14:12:ERROR:WU01:FS01:Failed to start core: Failed to rename 'work/01/logfile_01.txt' to 'work/01/logfile_01-20221225-161412.txt': The process cannot access the file because it is being used by another process.
16:14:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:14:16:WU00:FS00:Starting
16:14:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -np 6
16:14:16:WU00:FS00:Started FahCore on PID 13004
16:14:16:WU00:FS00:Core PID:6552
16:14:16:WU00:FS00:FahCore 0xa8 started
16:14:17:WU00:FS00:0xa8:*********************** Log Started 2022-12-25T16:14:17Z ***********************
16:14:17:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
16:14:17:WU00:FS00:0xa8:       Core: Gromacs
16:14:17:WU00:FS00:0xa8:       Type: 0xa8
16:14:17:WU00:FS00:0xa8:    Version: 0.0.12
16:14:17:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:14:17:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
16:14:17:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
16:14:17:WU00:FS00:0xa8:       Date: Jan 16 2021
16:14:17:WU00:FS00:0xa8:       Time: 11:56:07
16:14:17:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
16:14:17:WU00:FS00:0xa8:     Branch: master
16:14:17:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
16:14:17:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:14:17:WU00:FS00:0xa8:   Platform: win32 10
16:14:17:WU00:FS00:0xa8:       Bits: 64
Reason: fixed code tag
ellandrydroid
16:14:17:WU00:FS00:0xa8:       Mode: Release
16:14:17:WU00:FS00:0xa8:       SIMD: avx_256
16:14:17:WU00:FS00:0xa8:     OpenMP: ON
16:14:17:WU00:FS00:0xa8:       CUDA: OFF
16:14:17:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13004 -checkpoint 15 -np
16:14:17:WU00:FS00:0xa8:             6
16:14:17:WU00:FS00:0xa8:************************************ libFAH ************************************
16:14:17:WU00:FS00:0xa8:       Time: 11:24:13
16:14:17:WU00:FS00:0xa8:************************************ CBang *************************************
16:14:17:WU00:FS00:0xa8:       Time: 11:23:53
16:14:17:WU00:FS00:0xa8:************************************ System ************************************
16:14:17:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
16:14:17:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
16:14:17:WU00:FS00:0xa8:       CPUs: 8
16:14:17:WU00:FS00:0xa8:     Memory: 7.90GiB
16:14:17:WU00:FS00:0xa8:Free Memory: 1.63GiB
16:14:17:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
16:14:17:WU00:FS00:0xa8: OS Version: 6.2
16:14:17:WU00:FS00:0xa8:Has Battery: false
16:14:17:WU00:FS00:0xa8: On Battery: false
16:14:17:WU00:FS00:0xa8: UTC Offset: -6
16:14:17:WU00:FS00:0xa8:        PID: 6552
16:14:17:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
16:14:17:WU00:FS00:0xa8:********************************************************************************
16:14:17:WU00:FS00:0xa8:Project: 16998 (Run 8, Clone 75, Gen 210)
16:14:17:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
16:14:17:WU00:FS00:0xa8:Digital signatures verified
16:14:17:WU00:FS00:0xa8:Calling: mdrun -c frame210.gro -s frame210.tpr -x frame210.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
16:14:17:WU00:FS00:0xa8:Steps: first=525000000 total=527500000
16:14:20:WU00:FS00:0xa8:Completed 3752 out of 2500000 steps (0%)
16:14:34:Saving configuration to config.xml
16:14:34:<config>
16:14:34:  <!-- Slot Control -->
16:14:34:  <power v='MEDIUM'/>
16:14:34:
16:14:34:  <!-- User Information -->
16:14:34:  <passkey v='*****'/>
16:14:34:  <team v='234980'/>
16:14:34:  <user v='rikcvnbo9kw2'/>
16:14:34:
16:14:34:  <!-- Folding Slots -->
16:14:34:  <slot id='0' type='CPU'/>
16:14:34:  <slot id='1' type='GPU'>
16:14:34:    <pci-bus v='6'/>
16:14:34:    <pci-slot v='0'/>
16:14:34:  </slot>
16:14:34:</config>
16:15:49:WU01:FS01:Starting
16:15:49:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
16:15:49:WU01:FS01:Started FahCore on PID 9932
16:15:49:WU01:FS01:Core PID:7188
16:15:49:WU01:FS01:FahCore 0x22 started
16:15:50:WU01:FS01:0x22:*********************** Log Started 2022-12-25T16:15:49Z ***********************
16:15:50:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:15:50:WU01:FS01:0x22:       Core: Core22
16:15:50:WU01:FS01:0x22:       Type: 0x22
16:15:50:WU01:FS01:0x22:    Version: 0.0.20
16:15:50:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:15:50:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
16:15:50:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
16:15:50:WU01:FS01:0x22:       Date: Jan 20 2022
16:15:50:WU01:FS01:0x22:       Time: 01:15:36
16:15:50:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
16:15:50:WU01:FS01:0x22:     Branch: HEAD
16:15:50:WU01:FS01:0x22:   Compiler: Visual C++
16:15:50:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:15:50:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
16:15:50:WU01:FS01:0x22:   Platform: win32 10
16:15:50:WU01:FS01:0x22:       Bits: 64
16:15:50:WU01:FS01:0x22:       Mode: Release
16:15:50:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:15:50:WU01:FS01:0x22:             <peastman@stanford.edu>
16:15:50:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9932 -checkpoint 15
16:15:50:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
16:15:50:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
16:15:50:WU01:FS01:0x22:************************************ libFAH ************************************
16:15:50:WU01:FS01:0x22:       Time: 01:14:17
16:15:50:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
16:15:50:WU01:FS01:0x22:************************************ CBang *************************************
16:15:50:WU01:FS01:0x22:       Time: 01:13:20
16:15:50:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
16:15:50:WU01:FS01:0x22:************************************ System ************************************
16:15:50:WU01:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
16:15:50:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
16:15:50:WU01:FS01:0x22:       CPUs: 8
16:15:50:WU01:FS01:0x22:     Memory: 7.90GiB
16:15:50:WU01:FS01:0x22:Free Memory: 1.54GiB
16:15:50:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
16:15:50:WU01:FS01:0x22: OS Version: 6.2
16:15:50:WU01:FS01:0x22:Has Battery: false
16:15:50:WU01:FS01:0x22: On Battery: false
16:15:50:WU01:FS01:0x22: UTC Offset: -6
16:15:50:WU01:FS01:0x22:        PID: 7188
16:15:50:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
16:15:50:WU01:FS01:0x22:************************************ OpenMM ************************************
16:15:50:WU01:FS01:0x22:    Version: 7.7.0
16:15:50:WU01:FS01:0x22:********************************************************************************
16:15:50:WU01:FS01:0x22:Project: 18448 (Run 8, Clone 46, Gen 295)
16:15:50:WU01:FS01:0x22:Digital signatures verified
16:15:50:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:15:50:WU01:FS01:0x22:Version 0.0.20
16:15:50:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
16:15:50:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
16:15:50:WU01:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
16:15:50:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
16:15:51:WU01:FS01:0x22:There are 4 platforms available.
16:15:51:WU01:FS01:0x22:Platform 0: Reference
16:15:51:WU01:FS01:0x22:Platform 1: CPU
16:15:51:WU01:FS01:0x22:Platform 2: OpenCL
16:15:51:WU01:FS01:0x22:  opencl-device 0 specified
16:15:51:WU01:FS01:0x22:Platform 3: CUDA
16:15:51:WU01:FS01:0x22:  cuda-device 0 specified
16:16:37:WU01:FS01:0x22:Attempting to create CUDA context:
16:16:37:WU01:FS01:0x22:  Configuring platform CUDA
16:16:57:WU01:FS01:0x22:  Using CUDA and gpu 0
16:16:58:WU01:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
16:25:43:WU01:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
16:34:22:WU01:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
16:34:27:WU01:FS01:0x22:Checkpoint completed at step 200000
16:43:10:WU01:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
16:51:56:WU01:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
16:52:01:WU01:FS01:0x22:Checkpoint completed at step 250000
17:00:47:WU01:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
17:09:32:WU01:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
17:09:37:WU01:FS01:0x22:Checkpoint completed at step 300000
17:18:16:WU01:FS01:0x22:Completed 325000 out of 2500000 steps (13%)
17:27:03:WU01:FS01:0x22:Completed 350000 out of 2500000 steps (14%)
17:27:08:WU01:FS01:0x22:Checkpoint completed at step 350000
17:35:55:WU01:FS01:0x22:Completed 375000 out of 2500000 steps (15%)
17:44:36:WU01:FS01:0x22:Completed 400000 out of 2500000 steps (16%)
17:44:41:WU01:FS01:0x22:Checkpoint completed at step 400000
17:53:29:WU01:FS01:0x22:Completed 425000 out of 2500000 steps (17%)
18:02:15:WU01:FS01:0x22:Completed 450000 out of 2500000 steps (18%)
18:02:21:WU01:FS01:0x22:Checkpoint completed at step 450000
18:11:22:WU01:FS01:0x22:Completed 475000 out of 2500000 steps (19%)
18:20:06:WU01:FS01:0x22:Completed 500000 out of 2500000 steps (20%)
18:20:13:WU01:FS01:0x22:Checkpoint completed at step 500000
18:28:50:WU01:FS01:0x22:Completed 525000 out of 2500000 steps (21%)
18:37:31:WU01:FS01:0x22:Completed 550000 out of 2500000 steps (22%)
18:37:36:WU01:FS01:0x22:Checkpoint completed at step 550000
18:46:20:WU01:FS01:0x22:Completed 575000 out of 2500000 steps (23%)
18:54:51:WU01:FS01:0x22:Completed 600000 out of 2500000 steps (24%)
18:54:56:WU01:FS01:0x22:Checkpoint completed at step 600000
19:03:40:WU01:FS01:0x22:Completed 625000 out of 2500000 steps (25%)
19:12:18:WU01:FS01:0x22:Completed 650000 out of 2500000 steps (26%)
19:12:22:WU01:FS01:0x22:Checkpoint completed at step 650000
19:21:06:WU01:FS01:0x22:Completed 675000 out of 2500000 steps (27%)
19:29:43:WU01:FS01:0x22:Completed 700000 out of 2500000 steps (28%)
19:29:48:WU01:FS01:0x22:Checkpoint completed at step 700000
19:38:33:WU01:FS01:0x22:Completed 725000 out of 2500000 steps (29%)
19:47:14:WU01:FS01:0x22:Completed 750000 out of 2500000 steps (30%)
19:47:19:WU01:FS01:0x22:Checkpoint completed at step 750000
19:55:59:WU01:FS01:0x22:Completed 775000 out of 2500000 steps (31%)
20:04:47:WU01:FS01:0x22:Completed 800000 out of 2500000 steps (32%)
20:04:52:WU01:FS01:0x22:Checkpoint completed at step 800000
20:13:29:WU01:FS01:0x22:Completed 825000 out of 2500000 steps (33%)
20:22:12:WU01:FS01:0x22:Completed 850000 out of 2500000 steps (34%)
20:22:17:WU01:FS01:0x22:Checkpoint completed at step 850000
20:30:51:WU01:FS01:0x22:Completed 875000 out of 2500000 steps (35%)
20:39:26:WU01:FS01:0x22:Completed 900000 out of 2500000 steps (36%)
20:39:31:WU01:FS01:0x22:Checkpoint completed at step 900000
20:48:04:WU01:FS01:0x22:Completed 925000 out of 2500000 steps (37%)
20:56:44:WU01:FS01:0x22:Completed 950000 out of 2500000 steps (38%)
20:56:49:WU01:FS01:0x22:Checkpoint completed at step 950000
21:05:34:WU01:FS01:0x22:Completed 975000 out of 2500000 steps (39%)
******************************* Date: 2022-12-25 *******************************
21:14:09:WU01:FS01:0x22:Completed 1000000 out of 2500000 steps (40%)
21:14:14:WU01:FS01:0x22:Checkpoint completed at step 1000000
21:22:50:WU01:FS01:0x22:Completed 1025000 out of 2500000 steps (41%)
21:31:27:WU01:FS01:0x22:Completed 1050000 out of 2500000 steps (42%)
21:31:32:WU01:FS01:0x22:Checkpoint completed at step 1050000
21:40:08:WU01:FS01:0x22:Completed 1075000 out of 2500000 steps (43%)
21:42:30:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
21:48:48:WU01:FS01:0x22:Completed 1100000 out of 2500000 steps (44%)
21:48:53:WU01:FS01:0x22:Checkpoint completed at step 1100000
21:57:41:WU01:FS01:0x22:Completed 1125000 out of 2500000 steps (45%)
22:06:22:WU01:FS01:0x22:Completed 1150000 out of 2500000 steps (46%)
22:06:27:WU01:FS01:0x22:Checkpoint completed at step 1150000
22:15:09:WU01:FS01:0x22:Completed 1175000 out of 2500000 steps (47%)
22:23:46:WU01:FS01:0x22:Completed 1200000 out of 2500000 steps (48%)
22:23:51:WU01:FS01:0x22:Checkpoint completed at step 1200000
22:32:32:WU01:FS01:0x22:Completed 1225000 out of 2500000 steps (49%)
22:41:08:WU01:FS01:0x22:Completed 1250000 out of 2500000 steps (50%)
22:41:13:WU01:FS01:0x22:Checkpoint completed at step 1250000
22:49:46:WU01:FS01:0x22:Completed 1275000 out of 2500000 steps (51%)
22:58:35:WU01:FS01:0x22:Completed 1300000 out of 2500000 steps (52%)
22:58:40:WU01:FS01:0x22:Checkpoint completed at step 1300000
23:07:20:WU01:FS01:0x22:Completed 1325000 out of 2500000 steps (53%)
23:16:02:WU01:FS01:0x22:Completed 1350000 out of 2500000 steps (54%)
23:16:08:WU01:FS01:0x22:Checkpoint completed at step 1350000
23:24:48:WU01:FS01:0x22:Completed 1375000 out of 2500000 steps (55%)
23:33:32:WU01:FS01:0x22:Completed 1400000 out of 2500000 steps (56%)
23:33:36:WU01:FS01:0x22:Checkpoint completed at step 1400000
23:42:20:WU01:FS01:0x22:Completed 1425000 out of 2500000 steps (57%)
23:51:05:WU01:FS01:0x22:Completed 1450000 out of 2500000 steps (58%)
23:51:11:WU01:FS01:0x22:Checkpoint completed at step 1450000
23:59:51:WU01:FS01:0x22:Completed 1475000 out of 2500000 steps (59%)
00:08:28:WU01:FS01:0x22:Completed 1500000 out of 2500000 steps (60%)
00:08:33:WU01:FS01:0x22:Checkpoint completed at step 1500000
00:17:37:WU01:FS01:0x22:Completed 1525000 out of 2500000 steps (61%)
00:26:16:WU01:FS01:0x22:Completed 1550000 out of 2500000 steps (62%)
00:26:21:WU01:FS01:0x22:Checkpoint completed at step 1550000
00:35:03:WU01:FS01:0x22:Completed 1575000 out of 2500000 steps (63%)
00:43:45:WU01:FS01:0x22:Completed 1600000 out of 2500000 steps (64%)
00:43:50:WU01:FS01:0x22:Checkpoint completed at step 1600000
00:52:29:WU01:FS01:0x22:Completed 1625000 out of 2500000 steps (65%)
01:01:09:WU01:FS01:0x22:Completed 1650000 out of 2500000 steps (66%)
01:01:14:WU01:FS01:0x22:Checkpoint completed at step 1650000
01:28:31:WU01:FS01:0x22:Completed 1675000 out of 2500000 steps (67%)
01:43:48:WU01:FS01:0x22:Completed 1700000 out of 2500000 steps (68%)
01:43:54:WU01:FS01:0x22:Checkpoint completed at step 1700000
01:44:40:101:127.0.0.1:New Web session
01:47:25:FS00:Paused
01:47:25:FS01:Paused
01:47:25:FS00:Shutting core down
01:47:25:FS01:Shutting core down
01:47:25:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 6552
01:47:25:WU00:FS00:0xa8:Exiting, please wait. . .
01:47:25:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 7188
01:47:25:WU01:FS01:0x22:Exiting, please wait. . .
01:47:25:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
01:47:29:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
01:47:29:FS00:Unpaused
01:47:29:FS01:Unpaused
01:47:29:WU01:FS01:Starting
01:47:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
01:47:29:WU01:FS01:Started FahCore on PID 2584
01:47:30:WU01:FS01:Core PID:10232
01:47:30:WU01:FS01:FahCore 0x22 started
01:47:30:WU01:FS01:0x22:*********************** Log Started 2022-12-26T01:47:30Z ***********************
01:47:30:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:47:30:WU01:FS01:0x22:       Core: Core22
01:47:30:WU01:FS01:0x22:       Type: 0x22
01:47:30:WU01:FS01:0x22:    Version: 0.0.20
01:47:30:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:47:30:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
01:47:30:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
01:47:30:WU01:FS01:0x22:       Date: Jan 20 2022
01:47:30:WU01:FS01:0x22:       Time: 01:15:36
01:47:30:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
01:47:30:WU01:FS01:0x22:     Branch: HEAD
01:47:30:WU01:FS01:0x22:   Compiler: Visual C++
01:47:30:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:47:30:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
01:47:30:WU01:FS01:0x22:   Platform: win32 10
01:47:30:WU01:FS01:0x22:       Bits: 64
01:47:30:WU01:FS01:0x22:       Mode: Release
01:47:30:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:47:30:WU01:FS01:0x22:             <peastman@stanford.edu>
01:47:30:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2584 -checkpoint 15
01:47:31:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
01:47:31:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
01:47:31:WU01:FS01:0x22:************************************ libFAH ************************************
01:47:31:WU01:FS01:0x22:       Date: Jan 20 2022
01:47:31:WU01:FS01:0x22:       Time: 01:14:17
01:47:31:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
01:47:31:WU01:FS01:0x22:     Branch: HEAD
01:47:31:WU01:FS01:0x22:   Compiler: Visual C++
01:47:31:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:47:31:WU01:FS01:0x22:   Platform: win32 10
01:47:31:WU01:FS01:0x22:       Bits: 64
01:47:31:WU01:FS01:0x22:       Mode: Release
01:47:31:WU01:FS01:0x22:************************************ CBang *************************************
01:47:31:WU01:FS01:0x22:       Time: 01:13:20
01:47:31:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
01:47:31:WU01:FS01:0x22:************************************ System ************************************
01:47:31:WU01:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
01:47:31:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
01:47:31:WU01:FS01:0x22:       CPUs: 8
01:47:31:WU01:FS01:0x22:     Memory: 7.90GiB
01:47:31:WU01:FS01:0x22:Free Memory: 1.31GiB
01:47:31:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
01:47:31:WU01:FS01:0x22: OS Version: 6.2
01:47:31:WU01:FS01:0x22:Has Battery: false
01:47:31:WU01:FS01:0x22: On Battery: false
01:47:31:WU01:FS01:0x22: UTC Offset: -6
01:47:31:WU01:FS01:0x22:        PID: 10232
01:47:31:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
01:47:31:WU01:FS01:0x22:************************************ OpenMM ************************************
01:47:31:WU01:FS01:0x22:    Version: 7.7.0
01:47:31:WU01:FS01:0x22:********************************************************************************
01:47:31:WU01:FS01:0x22:Project: 18448 (Run 8, Clone 46, Gen 295)
01:47:31:WU01:FS01:0x22:Digital signatures verified
01:47:31:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:47:31:WU01:FS01:0x22:Version 0.0.20
01:47:32:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
01:47:32:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
01:47:32:WU01:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
01:47:32:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
01:47:32:WU01:FS01:0x22:There are 4 platforms available.
01:47:32:WU01:FS01:0x22:Platform 0: Reference
01:47:32:WU01:FS01:0x22:Platform 1: CPU
01:47:32:WU01:FS01:0x22:Platform 2: OpenCL
01:47:32:WU01:FS01:0x22:  opencl-device 0 specified
01:47:32:WU01:FS01:0x22:Platform 3: CUDA
01:47:32:WU01:FS01:0x22:  cuda-device 0 specified
01:47:44:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:47:44:WU00:FS00:Starting
01:47:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -np 6
01:47:44:WU00:FS00:Started FahCore on PID 13160
01:47:45:WU00:FS00:Core PID:10016
01:47:45:WU00:FS00:FahCore 0xa8 started
01:47:46:WU00:FS00:0xa8:*********************** Log Started 2022-12-26T01:47:45Z ***********************
01:47:46:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
01:47:46:WU00:FS00:0xa8:       Core: Gromacs
01:47:46:WU00:FS00:0xa8:       Type: 0xa8
01:47:46:WU00:FS00:0xa8:    Version: 0.0.12
01:47:46:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:47:46:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
01:47:46:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
01:47:46:WU00:FS00:0xa8:       Date: Jan 16 2021
01:47:46:WU00:FS00:0xa8:       Time: 11:56:07
01:47:46:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
01:47:46:WU00:FS00:0xa8:     Branch: master
01:47:46:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
01:47:46:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:47:46:WU00:FS00:0xa8:   Platform: win32 10
01:47:46:WU00:FS00:0xa8:       Bits: 64
01:47:46:WU00:FS00:0xa8:       Mode: Release
01:47:46:WU00:FS00:0xa8:       SIMD: avx_256
01:47:46:WU00:FS00:0xa8:     OpenMP: ON
01:47:46:WU00:FS00:0xa8:       CUDA: OFF
01:47:46:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13160 -checkpoint 15 -np
01:47:46:WU00:FS00:0xa8:             6
01:47:46:WU00:FS00:0xa8:************************************ libFAH ************************************
01:47:46:WU00:FS00:0xa8:       Time: 11:24:13
01:47:46:WU00:FS00:0xa8:************************************ CBang *************************************
01:47:46:WU00:FS00:0xa8:       Time: 11:23:53
01:47:46:WU00:FS00:0xa8:************************************ System ************************************
01:47:46:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
01:47:46:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
01:47:46:WU00:FS00:0xa8:       CPUs: 8
01:47:46:WU00:FS00:0xa8:     Memory: 7.90GiB
01:47:46:WU00:FS00:0xa8:Free Memory: 1.10GiB
01:47:46:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
01:47:46:WU00:FS00:0xa8: OS Version: 6.2
01:47:46:WU00:FS00:0xa8:Has Battery: false
01:47:46:WU00:FS00:0xa8: On Battery: false
01:47:46:WU00:FS00:0xa8: UTC Offset: -6
01:47:46:WU00:FS00:0xa8:        PID: 10016
01:47:46:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
01:47:46:WU00:FS00:0xa8:********************************************************************************
01:47:46:WU00:FS00:0xa8:Project: 16998 (Run 8, Clone 75, Gen 210)
01:47:46:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
01:47:46:WU00:FS00:0xa8:Digital signatures verified
01:47:46:WU00:FS00:0xa8:Calling: mdrun -c frame210.gro -s frame210.tpr -x frame210.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
01:47:46:WU00:FS00:0xa8:Steps: first=525000000 total=527500000
01:47:49:WU00:FS00:0xa8:Completed 38852 out of 2500000 steps (1%)
01:48:21:WU01:FS01:0x22:Attempting to create CUDA context:
01:48:21:WU01:FS01:0x22:  Configuring platform CUDA
01:48:40:WU01:FS01:0x22:  Using CUDA and gpu 0
01:48:41:WU01:FS01:0x22:Completed 1700000 out of 2500000 steps (68%)
01:50:40:118:127.0.0.1:New Web session
01:52:22:126:127.0.0.1:New Web session
01:52:24:131:127.0.0.1:New Web session
01:53:05:FS00:Shutting core down
01:53:05:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 10016
01:53:05:WU00:FS00:0xa8:Exiting, please wait. . .
01:53:42:WU00:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
01:53:42:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:53:42:WU00:FS00:Starting
01:53:42:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
01:53:42:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
01:53:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -np 6
01:53:42:WU00:FS00:Started FahCore on PID 13764
01:53:43:WU00:FS00:Core PID:17856
01:53:43:WU00:FS00:FahCore 0xa8 started
01:53:44:WU00:FS00:0xa8:*********************** Log Started 2022-12-26T01:53:43Z ***********************
01:53:44:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
01:53:44:WU00:FS00:0xa8:       Core: Gromacs
01:53:44:WU00:FS00:0xa8:       Type: 0xa8
01:53:44:WU00:FS00:0xa8:    Version: 0.0.12
01:53:44:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:53:44:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
01:53:44:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
01:53:44:WU00:FS00:0xa8:       Date: Jan 16 2021
01:53:44:WU00:FS00:0xa8:       Time: 11:56:07
01:53:44:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
01:53:44:WU00:FS00:0xa8:     Branch: master
01:53:44:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
01:53:44:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:53:44:WU00:FS00:0xa8:   Platform: win32 10
01:53:44:WU00:FS00:0xa8:       Bits: 64
01:53:44:WU00:FS00:0xa8:       Mode: Release
01:53:44:WU00:FS00:0xa8:       SIMD: avx_256
01:53:44:WU00:FS00:0xa8:     OpenMP: ON
01:53:44:WU00:FS00:0xa8:       CUDA: OFF
01:53:44:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13764 -checkpoint 15 -np
01:53:44:WU00:FS00:0xa8:             6
01:53:44:WU00:FS00:0xa8:************************************ libFAH ************************************
01:53:44:WU00:FS00:0xa8:       Time: 11:24:13
01:53:44:WU00:FS00:0xa8:************************************ CBang *************************************
01:53:44:WU00:FS00:0xa8:       Time: 11:23:53
01:53:44:WU00:FS00:0xa8:************************************ System ************************************
01:53:44:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
01:53:44:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
01:53:44:WU00:FS00:0xa8:       CPUs: 8
01:53:44:WU00:FS00:0xa8:     Memory: 7.90GiB
01:53:44:WU00:FS00:0xa8:Free Memory: 1.45GiB
01:53:44:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
01:53:44:WU00:FS00:0xa8: OS Version: 6.2
01:53:44:WU00:FS00:0xa8:Has Battery: false
01:53:44:WU00:FS00:0xa8: On Battery: false
01:53:44:WU00:FS00:0xa8: UTC Offset: -6
01:53:44:WU00:FS00:0xa8:        PID: 17856
01:53:44:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
01:53:44:WU00:FS00:0xa8:********************************************************************************
01:53:44:WU00:FS00:0xa8:Project: 16998 (Run 8, Clone 75, Gen 210)
01:53:44:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
01:53:44:WU00:FS00:0xa8:Digital signatures verified
01:53:44:WU00:FS00:0xa8:Calling: mdrun -c frame210.gro -s frame210.tpr -x frame210.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
01:53:48:WU00:FS00:0xa8:Steps: first=525000000 total=527500000
01:54:04:Saving configuration to config.xml
01:54:04:<config>
01:54:04:  <!-- Slot Control -->
01:54:04:  <power v='FULL'/>
01:54:04:
01:54:04:  <!-- User Information -->
01:54:04:  <passkey v='*****'/>
01:54:04:  <team v='234980'/>
01:54:04:  <user v='rikcvnbo9kw2'/>
01:54:04:
01:54:04:  <!-- Folding Slots -->
01:54:04:  <slot id='0' type='CPU'/>
01:54:04:  <slot id='1' type='GPU'>
01:54:04:    <pci-bus v='6'/>
01:54:04:    <pci-slot v='0'/>
01:54:04:  </slot>
01:54:04:</config>
01:54:05:WU00:FS00:0xa8:Completed 39202 out of 2500000 steps (1%)
01:57:43:FS00:Shutting core down
01:57:43:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 17856
01:57:43:WU00:FS00:0xa8:Exiting, please wait. . .
01:58:05:WU01:FS01:0x22:Completed 1725000 out of 2500000 steps (69%)
01:58:08:Saving configuration to config.xml
01:58:08:<config>
01:58:08:  <!-- Folding Slot Configuration -->
01:58:08:  <cause v='ALZHEIMERS'/>
01:58:08:
01:58:08:  <!-- Slot Control -->
01:58:08:  <power v='FULL'/>
01:58:08:
01:58:08:  <!-- User Information -->
01:58:08:  <passkey v='*****'/>
01:58:08:  <team v='234980'/>
01:58:08:  <user v='rikcvnbo9kw2'/>
01:58:08:
01:58:08:  <!-- Folding Slots -->
01:58:08:  <slot id='0' type='CPU'/>
01:58:08:  <slot id='1' type='GPU'>
01:58:08:    <pci-bus v='6'/>
01:58:08:    <pci-slot v='0'/>
01:58:08:  </slot>
01:58:08:</config>
01:59:09:Saving configuration to config.xml
01:59:09:<config>
01:59:09:  <!-- Slot Control -->
01:59:09:  <power v='FULL'/>
01:59:09:
01:59:09:  <!--
01:59:09:  <passkey v='*****'/>
01:59:09:  <team v='234980'/>
01:59:09:  <user v='rikcvnbo9kw2'/>
01:59:09:
01:59:09:  <!-- Folding Slots -->
01:59:09:  <slot id='0' type='CPU'/>
01:59:09:  <slot id='1' type='GPU'>
01:59:09:    <pci-bus v='6'/>
01:59:09:    <pci-slot v='0'/>
01:59:09:  </slot>
01:59:09:</config>
01:59:13:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:59:14:WU00:FS00:Starting
01:59:14:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
01:59:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 13872 -checkpoint 15 -np 6
01:59:14:WU00:FS00:Started FahCore on PID 15016
01:59:14:WU00:FS00:Core PID:12856
01:59:14:WU00:FS00:FahCore 0xa8 started
01:59:15:WU00:FS00:0xa8:*********************** Log Started 2022-12-26T01:59:14Z ***********************
01:59:15:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
01:59:15:WU00:FS00:0xa8:       Core: Gromacs
01:59:15:WU00:FS00:0xa8:       Type: 0xa8
01:59:15:WU00:FS00:0xa8:    Version: 0.0.12
01:59:15:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:59:15:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
01:59:15:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
01:59:15:WU00:FS00:0xa8:       Date: Jan 16 2021
01:59:15:WU00:FS00:0xa8:       Time: 11:56:07
01:59:15:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
01:59:15:WU00:FS00:0xa8:     Branch: master
01:59:15:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
01:59:15:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:59:15:WU00:FS00:0xa8:   Platform: win32 10
01:59:15:WU00:FS00:0xa8:       Bits: 64
01:59:15:WU00:FS00:0xa8:       Mode: Release
01:59:15:WU00:FS00:0xa8:       SIMD: avx_256
01:59:15:WU00:FS00:0xa8:     OpenMP: ON
01:59:15:WU00:FS00:0xa8:       CUDA: OFF
01:59:15:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15016 -checkpoint 15 -np
01:59:15:WU00:FS00:0xa8:             6
01:59:15:WU00:FS00:0xa8:************************************ libFAH ************************************
01:59:15:WU00:FS00:0xa8:       Time: 11:24:13
01:59:15:WU00:FS00:0xa8:************************************ CBang *************************************
01:59:15:WU00:FS00:0xa8:       Time: 11:23:53
01:59:15:WU00:FS00:0xa8:************************************ System ************************************
01:59:15:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
01:59:15:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
01:59:15:WU00:FS00:0xa8:       CPUs: 8
01:59:15:WU00:FS00:0xa8:     Memory: 7.90GiB
01:59:15:WU00:FS00:0xa8:Free Memory: 1.60GiB
01:59:15:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
01:59:15:WU00:FS00:0xa8: OS Version: 6.2
01:59:15:WU00:FS00:0xa8:Has Battery: false
01:59:15:WU00:FS00:0xa8: On Battery: false
01:59:15:WU00:FS00:0xa8: UTC Offset: -6
01:59:15:WU00:FS00:0xa8:        PID: 12856
01:59:15:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
01:59:15:WU00:FS00:0xa8:********************************************************************************
01:59:15:WU00:FS00:0xa8:Project: 16998 (Run 8, Clone 75, Gen 210)
01:59:15:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
01:59:15:WU00:FS00:0xa8:Digital signatures verified
01:59:15:WU00:FS00:0xa8:Calling: mdrun -c frame210.gro -s frame210.tpr -x frame210.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
01:59:16:WU00:FS00:0xa8:Steps: first=525000000 total=527500000
01:59:27:WU00:FS00:0xa8:Completed 39352 out of 2500000 steps (1%)
02:09:17:WU01:FS01:0x22:Completed 1750000 out of 2500000 steps (70%)
02:09:44:WU01:FS01:0x22:Checkpoint completed at step 1750000
02:53:40:WU01:FS01:0x22:Completed 1775000 out of 2500000 steps (71%)
03:02:20:WU01:FS01:0x22:Completed 1800000 out of 2500000 steps (72%)
03:02:26:WU01:FS01:0x22:Checkpoint completed at step 1800000
03:11:15:WU01:FS01:0x22:Completed 1825000 out of 2500000 steps (73%)
ellandrydroid
Post by ellandrydroid »
I split the log into two different posts I think where I may have messed up is I originally selected high priority and then stopped the folding changed it to any disease and started the folding again and I wonder if that messed the jobs up
Re: First Job, complete time way off
Switching from high priority to any disease only will change selection preferences for the next WUs requested and downloaded. So I have looked further.
The GPU WU for Project 18448 is processing at a reasonable rate. Since this will be your first WUs returned they will not get the bonus. However the client bases its points estimates on the presence of a passkey and does not query the servers to see if the passkey has been qualified for the bonus which requires returning 10 WUs first.
The WU from Project 16998 that is being processed on your CPU may not finish within the deadline. Your FX-8350 while supporting AVX is an older processor that may not be up to some o the larger projects. As a Piledriver architecture processor it has 8 cores that share 4 FPUs so it may not run efficiently on F@h WUs at thread counts over 4. My recommendation would be to use the advanced control - FAHControl - to set the thread count to 4 instead of the default that uses the slider to set that.
ellandrydroid
Okay I'm in the control can you explain how I would change the thread count to four
Click on Configure, then select the tab for Slots. Click on the CPU slot to highlight it and then Edit at the bottom right. In the top section of the screen that opens, change the thread count from the default value of -1 to the number of threads to use. In this case I recommended 4 as that is the number of FPUs available.
You may have to watch and see how the CPU slot works. It does have AVX which helps, but at 10 years old its processing speed is lower than recent processors. It is doable, I still use the 10 year old i7-3520m in my laptop on 2 threads and it can complete the assigments I get. You may find that to get WUs the FX-8350 can complete will require reducing the thread count to less than 4.
ellandrydroid
Thank you for your assistance so what happens when the GPU reaches 100%. Does it move to the next job even though the CPU is not finished
Yes, the two WUs are independent and unless you change a setting another WU will be downloaded. If you do want it to stop processing on the GPU, you can set the slot to Finish. If you use the Finish button it is for all slots, or you can right click in FAHControl on a slot and a menu will pop up that gives your the option to set just that slot to Finish.
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Hard to say if that CPU will be making deadlines with the core counts changed, but the only way to know for sure is to try.
As for your GPU, while it seems to be folding, it's not folding very quickly for what it is. Do you have it on a slow PCI slot by any chance? While I suspect it will still meet the deadlines and such, it seems something is holding it back. Once you start getting your bonus points you will be able to see the true PPD it's running, but based on frame times it's not running at it's full potential.
Fold them if you get them!
ellandrydroid
It's on the fast PCI slot it's a MSI GTX 1660 super 6 gig I have the memory overclocked because some days I use it for crypto mining also
ellandrydroid
I'm assuming the fast PCI slot is the purple one with the clip as opposed to the normal blue ones
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
There is no standard for PCI slot colors, so you might want to take a look at the specs for the motherboard. And for folding, overclocking your memory will generally slow throughput. Many users find faster returns by actually underclocking memory. I also have a 1660 Super, and it returns better PPD with the memory underclocked.
But memory alone shouldn't make that much difference, so I'd check those PCI slots out and make sure you've got it on one quick enough. Your frame times with that project are over 3 times what I get, even when I run the card power limited.
ellandrydroid
So when do the points get converted to banano coin into our wallets? Thanks
