random reboot, weird time at start of log
Knish
Post by Knish »
new rtx 2060 been folding fine as stock for the past 6mo. Not sure what caused the sudden reboot while on the web (maybe power surge as other pc seems to be offline). I had to reboot a couple more times for FAHControl to see the Fahclient, but looking at the new logs, the initial 100 lines always seems to be about an hr into the future, then the log starts using the correct time. weird?
*********************** Log Started 2022-12-24T22:58:47Z ***********************
22:58:47:******************************* libFAH ********************************
22:58:47:           Date: Oct 20 2020
22:58:47:           Time: 20:36:39
22:58:47:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:58:47:         Branch: master
22:58:47:       Compiler: GNU 8.3.0
22:58:47:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
22:58:47:                 -fdata-sections -O3 -funroll-loops -fno-pie
22:58:47:       Platform: linux2 5.8.0-1-amd64
22:58:47:           Bits: 64
22:58:47:           Mode: Release
22:58:47:****************************** FAHClient ******************************
22:58:47:        Version: 7.6.21
22:58:47:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:58:47:      Copyright: 2020 foldingathome.org
22:58:47:       Homepage: https://foldingathome.org/
22:58:47:           Time: 20:39:00
22:58:47:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:58:47:           Bits: 64
22:58:47:           Args: --child /etc/fahclient/config.xml --run-as fahclient
22:58:47:                 --pid-file=/var/run/fahclient.pid --daemon
22:58:47:         Config: /etc/fahclient/config.xml
22:58:47:******************************** CBang ********************************
22:58:47:           Time: 18:37:59
22:58:47:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:58:47:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
22:58:47:           Bits: 64
22:58:47:******************************* System ********************************
22:58:47:            CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
22:58:47:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
22:58:47:           CPUs: 4
22:58:47:         Memory: 15.51GiB
22:58:47:    Free Memory: 14.88GiB
22:58:47:        Threads: POSIX_THREADS
22:58:47:     OS Version: 5.10
22:58:47:    Has Battery: false
22:58:47:     On Battery: false
22:58:47:     UTC Offset: -8
22:58:47:            PID: 875
22:58:47:            CWD: /var/lib/fahclient
22:58:47:             OS: Linux 5.10.0-20-amd64 x86_64
22:58:47:        OS Arch: AMD64
22:58:47:           GPUs: 1
22:58:47:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
22:58:47:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:12.0
22:58:47:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:525.60
22:58:47:***********************************************************************
22:58:47:<config>
22:58:47:  <!-- Client Control -->
22:58:47:  <fold-anon v='true'/>
22:58:47:
22:58:47:  <!-- Folding Slot Configuration -->
22:58:47:  <cause v='PARKINSONS'/>
22:58:47:
22:58:47:  <!-- HTTP Server -->
22:58:47:  <allow v='127.0.0.1 192.168.2.183'/>
22:58:47:
22:58:47:  <!-- Network -->
22:58:47:  <proxy v=':8080'/>
22:58:47:
22:58:47:  <!-- Remote Command Server -->
22:58:47:  <command-allow-no-pass v='127.0.0.1 192.168.2.183'/>
22:58:47:
22:58:47:  <!-- Slot Control -->
22:58:47:  <pause-on-start v='true'/>
22:58:47:  <power v='full'/>
22:58:47:
22:58:47:  <!-- User Information -->
22:58:47:  <passkey v='*****'/>
22:58:47:  <team v='31659'/>
22:58:47:  <user v='TofuHunden@mail.com'/>
22:58:47:
22:58:47:  <!-- Work Unit Control -->
22:58:47:  <next-unit-percentage v='100'/>
22:58:47:
22:58:47:  <!-- Folding Slots -->
22:58:47:  <slot id='0' type='CPU'/>
22:58:47:  <slot id='1' type='GPU'>
22:58:47:    <pci-bus v='1'/>
22:58:47:    <pci-slot v='0'/>
22:58:47:  </slot>
22:58:47:</config>
22:58:47:Trying to access database...
22:58:47:Successfully acquired database lock
22:58:47:FS00:Initialized folding slot 00: cpu:3
22:58:47:FS01:Initialized folding slot 01: gpu:1:0 TU106 [Geforce RTX 2060]
22:03:37:FS01:Unpaused
22:03:37:WU01:FS01:Starting
22:03:37:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 875 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:03:37:WU01:FS01:Started FahCore on PID 2716
22:03:38:WU01:FS01:Core PID:2720
22:03:38:WU01:FS01:FahCore 0x22 started
22:03:38:WU01:FS01:0x22:*********************** Log Started 2022-12-24T22:03:38Z ***********************
22:03:38:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:03:38:WU01:FS01:0x22:       Core: Core22
22:03:38:WU01:FS01:0x22:       Type: 0x22
22:03:38:WU01:FS01:0x22:    Version: 0.0.20
22:03:38:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:03:38:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
22:03:38:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
22:03:38:WU01:FS01:0x22:       Date: Jan 20 2022
22:03:38:WU01:FS01:0x22:       Time: 00:57:52
22:03:38:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
22:03:38:WU01:FS01:0x22:     Branch: HEAD
22:03:38:WU01:FS01:0x22:   Compiler: GNU 9.4.0
22:03:38:WU01:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
22:03:38:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
22:03:38:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
22:03:38:WU01:FS01:0x22:   Platform: linux 5.11.0-1025-azure
22:03:38:WU01:FS01:0x22:       Bits: 64
22:03:38:WU01:FS01:0x22:       Mode: Release
22:03:38:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:03:38:WU01:FS01:0x22:             <peastman@stanford.edu>
22:03:38:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2716 -checkpoint 15
22:03:38:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
22:03:38:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
22:03:38:WU01:FS01:0x22:************************************ libFAH ************************************
22:03:38:WU01:FS01:0x22:       Time: 00:57:22
22:03:38:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
22:03:38:WU01:FS01:0x22:************************************ CBang *************************************
22:03:38:WU01:FS01:0x22:       Time: 00:57:00
22:03:38:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
22:03:38:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
22:03:38:WU01:FS01:0x22:************************************ System ************************************
22:03:38:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
22:03:38:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
22:03:38:WU01:FS01:0x22:       CPUs: 4
22:03:38:WU01:FS01:0x22:     Memory: 15.51GiB
22:03:38:WU01:FS01:0x22:Free Memory: 11.94GiB
22:03:38:WU01:FS01:0x22:    Threads: POSIX_THREADS
22:03:38:WU01:FS01:0x22: OS Version: 5.10
22:03:38:WU01:FS01:0x22:Has Battery: false
22:03:38:WU01:FS01:0x22: On Battery: false
22:03:38:WU01:FS01:0x22: UTC Offset: -8
22:03:38:WU01:FS01:0x22:        PID: 2720
22:03:38:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
22:03:38:WU01:FS01:0x22:************************************ OpenMM ************************************
22:03:38:WU01:FS01:0x22:    Version: 7.7.0
22:03:38:WU01:FS01:0x22:********************************************************************************
22:03:38:WU01:FS01:0x22:Project: 18601 (Run 7875, Clone 3, Gen 26)
22:03:38:WU01:FS01:0x22:Digital signatures verified
22:03:38:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:03:38:WU01:FS01:0x22:Version 0.0.20
22:03:38:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
22:03:38:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
22:03:38:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
22:03:38:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
22:03:38:WU01:FS01:0x22:There are 4 platforms available.
22:03:38:WU01:FS01:0x22:Platform 0: Reference
22:03:38:WU01:FS01:0x22:Platform 1: CPU
22:03:38:WU01:FS01:0x22:Platform 2: OpenCL
22:03:38:WU01:FS01:0x22:  opencl-device 0 specified
22:03:38:WU01:FS01:0x22:Platform 3: CUDA
22:03:38:WU01:FS01:0x22:  cuda-device 0 specified
22:03:48:WU01:FS01:0x22:Attempting to create CUDA context:
22:03:48:WU01:FS01:0x22:  Configuring platform CUDA
Re: random reboot, weird time at start of log
I have seen those kind of oddities when the motherboard clock battery has died and time settings get messed up. After the system has booted eventually it queries a time server and resets the clock to the correct time. The one hour off sounds like a setting that was made during daylight savings time.
