[14:45:57] Writing local files
[14:45:57] Completed 495000 out of 500000 steps (99 percent)
[14:58:05] Writing local files
[14:58:05] Completed 500000 out of 500000 steps (100 percent)
M E G A - F L O P S A C C O U N T I N G
Parallel run - timing based on wallclock.
RF=Reaction-Field FE=Free Energy SCFE=Soft-Core/Free Energy
T=Tabulated W3=SPC/TIP3p W4=TIP4p (single or pairs)
NF=No Forces
Computing: M-Number M-Flops % of Flops
----[14:58:05] Writing final coordinates.
VdW(T) 1364641.594393 73690646.097222 16.6
RF Coul 545869.157252 18013682.189316 4.1
RF Coul [W3] 2257.835336 221267.862928 0.0
RF Coul + VdW(T) 617564.629043 40141700.887795 9.0
RF Coul + VdW(T) [W3] 280820.440646 36506657.283980 8.2
RF Coul + VdW(T) [W3-W3] 769776.706149 246328545.967680 55.5
Outer nonbonded loop 237847.898865 2378478.988650 0.5
1,4 nonbonded interactions 1059.002118 95310.190620 0.0
NS-Pairs 501069.584250 10522461.269250 2.4
Reset In Box 3878.527569 34906.748121 0.0
Shift-X 77469.154938 464814.929628 0.1
CG-CoM 1767.035340 51244.024860 0.0
Sum Forces 116353.732707 116353.732707 0.0
Bonds 13273.526547 570761.641521 0.1
Angles 15621.031242 2546228.092446 0.6
Propers 5386.510773 1233510.967017 0.3
Impropers 1008.002016 209664.419328 0.0
RB-Dihedrals 14140.528281 3492710.485407 0.8
Virial 38838.577677 699094.398186 0.2
Update 38784.577569 1202321.904639 0.3
Stop-CM 38784.500000 387845.000000 0.1
P-Coupling 38784.577569 232707.465414 0.1
Calc-Ekin 38784.655138 1047185.688726 0.2
Constraint-V 38784.577569 232707.465414 0.1
Constraint-Vir 25212.050424 605089.210176 0.1
Settle 8404.016808 2714497.428984 0.6
Total 443740394.340015 100.0
NODE (s) Real (s) (%)
Time: 71349.000 71349.000 100.0
19h49:09
(Mnbf/s) (GFlops) (ns/day) (hour/ns)
Performance: 50.189 6.219 1.211 19.819
[14:58:05] Past main M.D. loop
[14:58:05] Will end MPI now
[14:59:05]
[14:59:05] Finished Work Unit:
[14:59:05] - Reading up to 3723552 from "work/wudata_05.arc": Read 3723552
[14:59:05] - Reading up to 1779300 from "work/wudata_05.xtc": Read 1779300
[14:59:05] goefile size: 0
[14:59:05] logfile size: 16925
[14:59:05] Leaving Run
[14:59:08] - Writing 5524177 bytes of core data to disk...
[14:59:08] ... Done.
[14:59:09] - Shutting down core
[14:59:09]
qfix shows:
entry 6, status 0, address 171.64.65.56:8080
entry 7, status 0, address 171.64.65.56:8080
entry 8, status 0, address 171.64.65.56:8080
entry 9, status 0, address 171.64.65.56:8080
entry 0, status 0, address 171.64.65.56:8080
entry 1, status 0, address 171.64.65.56:8080
entry 2, status 0, address 171.64.65.56:8080
entry 3, status 0, address 171.64.65.56:8080
entry 4, status 0, address 171.64.65.56:8080
entry 5, status 1, address 171.64.65.56:8080
Found results <work/wuresults_05.dat>: proj 2605, run 11, clone 497, gen 71
-- queue entry: proj 2605, run 11, clone 497, gen 71
-- queue entry isn't empty
File is OK
Launch directory: /home/mike/Download
Executable: ./fah6
Arguments: -send 5 -verbosity 9
[15:52:05] - Ask before connecting: No
[15:52:05] - User name: Dutchmm (Team 31574)
[15:52:05] - User ID: 2C9583CC4EA765F8
[15:52:05] - Machine ID: 1
[15:52:05]
[15:52:05] Loaded queue successfully.
[15:52:05] Attempting to return result(s) to server...
[15:52:05] - Warning: Asked to send unfinished unit to server
[15:52:05] - Failed to send unit 05 to server
[15:52:05] ***** Got a SIGTERM signal (15)
[15:52:05] Killing all core threads
Folding@Home Client Shutdown.
Executable: ./fah6
Arguments: -smp
[15:53:24] - Ask before connecting: No
[15:53:24] - User name: Dutchmm (Team 31574)
[15:53:24] - User ID: 2C9583CC4EA765F8
[15:53:24] - Machine ID: 1
[15:53:24]
[15:53:24] Loaded queue successfully.
[15:53:24]
[15:53:24] + Processing work unit
[15:53:24] Core required: FahCore_a1.exe
[15:53:24] Core found.
[15:53:24] Working on Unit 05 [July 10 15:53:24]
[15:53:24] + Working ...
[15:53:25]
[15:53:25] *------------------------------*
[15:53:25] Folding@Home Gromacs SMP Core
[15:53:25] Version 1.74 (November 27, 2006)
[15:53:25]
[15:53:25] Preparing to commence simulation
[15:53:25] - Ensuring status. Please wait.
[15:53:42] - Looking at optimizations...
[15:53:42] - Working with standard loops on this execution.
[15:53:42] Examination of work files indicates 8 consecutive improper terminations of core.
[15:53:42] Finalizing output
[15:53:42] - Starting from initial work packet
[15:53:42]
[15:53:42] Project: 0 (Run 0, Clone 0, Gen 0)
[15:53:42]
[15:53:42] Error: Could not write local file. Exiting.
[15:53:42] - Shutting down core
Thx in advance for any advice from Taekwondo blackbelts or folding experts.
Mike
