Only getting bad work units.
btyrellb125
Post by btyrellb125 »
I took about a 2 month break from folding but now I only get bad work units. Nothing has changed hardware wise. I have tried reinstalling F@H, gpu drivers, and even tried reseating the gpu. I have a rtx 3060 on driver version 512.77. I have attched my log if that helps.
*********************** Log Started 2022-12-13T21:39:06Z ***********************
21:39:06:******************************* libFAH ********************************
21:39:06:           Date: Oct 20 2020
21:39:06:           Time: 13:36:55
21:39:06:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
21:39:06:         Branch: master
21:39:06:       Compiler: Visual C++ 2015
21:39:06:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:39:06:       Platform: win32 10
21:39:06:           Bits: 32
21:39:06:           Mode: Release
21:39:06:****************************** FAHClient ******************************
21:39:06:        Version: 7.6.21
21:39:06:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:39:06:      Copyright: 2020 foldingathome.org
21:39:06:       Homepage: https://foldingathome.org/
21:39:06:           Time: 13:41:04
21:39:06:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
21:39:06:           Bits: 32
21:39:06:         Config: C:\ProgramData\FAHClient\config.xml
21:39:06:******************************** CBang ********************************
21:39:06:           Time: 11:36:18
21:39:06:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
21:39:06:           Bits: 32
21:39:06:******************************* System ********************************
21:39:06:            CPU: AMD Ryzen 7 3800X 8-Core Processor
21:39:06:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:39:06:           CPUs: 16
21:39:06:         Memory: 31.93GiB
21:39:06:    Free Memory: 25.82GiB
21:39:06:        Threads: WINDOWS_THREADS
21:39:06:     OS Version: 6.2
21:39:06:    Has Battery: false
21:39:06:     On Battery: false
21:39:06:     UTC Offset: -5
21:39:06:            PID: 6432
21:39:06:            CWD: C:\ProgramData\FAHClient
21:39:06:  Win32 Service: false
21:39:06:             OS: Windows 10 Enterprise
21:39:06:        OS Arch: AMD64
21:39:06:           GPUs: 1
21:39:06:          GPU 0: Bus:6 Slot:0 Func:0 NVIDIA:8 GA106 [GeForce RTX 3060 Lite Hash
21:39:06:                 Rate]
21:39:06:  CUDA Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:8.6 Driver:11.6
21:39:06:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:3.0 Driver:512.77
21:39:06:***********************************************************************
21:39:07:<config>
21:39:07:  <!-- Folding Core -->
21:39:07:  <checkpoint v='30'/>
21:39:07:
21:39:07:  <!-- Folding Slot Configuration -->
21:39:07:  <max-packet-size v='SMALL'/>
21:39:07:
21:39:07:  <!-- Network -->
21:39:07:  <proxy v=':8080'/>
21:39:07:
21:39:07:  <!-- Slot Control -->
21:39:07:  <pause-on-start v='true'/>
21:39:07:  <power v='full'/>
21:39:07:
21:39:07:  <!-- User Information -->
21:39:07:  <team v='234980'/>
21:39:07:  <user v='test'/>
21:39:07:
21:39:07:  <!-- Folding Slots -->
21:39:07:  <slot id='1' type='GPU'>
21:39:07:    <pci-bus v='6'/>
21:39:07:    <pci-slot v='0'/>
21:39:07:  </slot>
21:39:07:</config>
21:39:07:Trying to access database...
21:39:07:Successfully acquired database lock
21:39:07:FS01:Initialized folding slot 01: gpu:6:0 GA106 [GeForce RTX 3060 Lite Hash Rate]
21:39:31:FS01:Unpaused
21:39:31:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:39:31:WU00:FS01:Assigned to work server 128.174.73.78
21:39:31:WU00:FS01:Requesting new work unit for slot 01: gpu:6:0 GA106 [GeForce RTX 3060 Lite Hash Rate] from 128.174.73.78
21:39:31:WU00:FS01:Connecting to 128.174.73.78:8080
21:39:37:WU00:FS01:Downloading 13.54MiB
21:39:38:WU00:FS01:Download complete
21:39:38:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14942 run:0 clone:74 gen:67 core:0x22 unit:0x0000004a0000004300003a5e00000000
21:39:38:WU00:FS01:Starting
21:39:38:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 6432 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:39:38:WU00:FS01:Started FahCore on PID 10180
21:39:38:WU00:FS01:Core PID:13500
21:39:38:WU00:FS01:FahCore 0x22 started
21:39:39:WU00:FS01:0x22:*********************** Log Started 2022-12-13T21:39:38Z ***********************
21:39:39:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:39:39:WU00:FS01:0x22:       Core: Core22
21:39:39:WU00:FS01:0x22:       Type: 0x22
21:39:39:WU00:FS01:0x22:    Version: 0.0.20
21:39:39:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:39:39:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
21:39:39:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
21:39:39:WU00:FS01:0x22:       Date: Jan 20 2022
21:39:39:WU00:FS01:0x22:       Time: 01:15:36
21:39:39:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:39:39:WU00:FS01:0x22:     Branch: HEAD
21:39:39:WU00:FS01:0x22:   Compiler: Visual C++
21:39:39:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:39:39:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
21:39:39:WU00:FS01:0x22:   Platform: win32 10
21:39:39:WU00:FS01:0x22:       Bits: 64
21:39:39:WU00:FS01:0x22:       Mode: Release
21:39:39:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:39:39:WU00:FS01:0x22:             <peastman@stanford.edu>
21:39:39:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10180 -checkpoint 30
21:39:39:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:39:39:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
21:39:39:WU00:FS01:0x22:************************************ libFAH ************************************
21:39:39:WU00:FS01:0x22:       Time: 01:14:17
21:39:39:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:39:39:WU00:FS01:0x22:************************************ CBang *************************************
21:39:39:WU00:FS01:0x22:       Time: 01:13:20
21:39:39:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:39:39:WU00:FS01:0x22:************************************ System ************************************
21:39:39:WU00:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
21:39:39:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:39:39:WU00:FS01:0x22:       CPUs: 16
21:39:39:WU00:FS01:0x22:     Memory: 31.93GiB
21:39:39:WU00:FS01:0x22:Free Memory: 24.46GiB
21:39:39:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:39:39:WU00:FS01:0x22: OS Version: 6.2
21:39:39:WU00:FS01:0x22:Has Battery: false
21:39:39:WU00:FS01:0x22: On Battery: false
21:39:39:WU00:FS01:0x22: UTC Offset: -5
21:39:39:WU00:FS01:0x22:        PID: 13500
21:39:39:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
21:39:39:WU00:FS01:0x22:************************************ OpenMM ************************************
21:39:39:WU00:FS01:0x22:    Version: 7.7.0
21:39:39:WU00:FS01:0x22:********************************************************************************
21:39:39:WU00:FS01:0x22:Project: 14942 (Run 0, Clone 74, Gen 67)
21:39:39:WU00:FS01:0x22:Reading tar file core.xml
21:39:39:WU00:FS01:0x22:Reading tar file integrator.xml
21:39:39:WU00:FS01:0x22:Reading tar file state.xml
21:39:39:WU00:FS01:0x22:Reading tar file system.xml
21:39:39:WU00:FS01:0x22:Digital signatures verified
21:39:39:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:39:39:WU00:FS01:0x22:Version 0.0.20
21:39:39:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
21:39:39:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
21:39:39:WU00:FS01:0x22:  XTC frame write interval: 25000 steps (2.5%) [40 total]
21:39:39:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
21:39:39:WU00:FS01:0x22:There are 4 platforms available.
21:39:39:WU00:FS01:0x22:Platform 0: Reference
21:39:39:WU00:FS01:0x22:Platform 1: CPU
21:39:39:WU00:FS01:0x22:Platform 2: OpenCL
21:39:39:WU00:FS01:0x22:  opencl-device 0 specified
21:39:39:WU00:FS01:0x22:Platform 3: CUDA
21:39:39:WU00:FS01:0x22:  cuda-device 0 specified
21:39:53:WU00:FS01:0x22:Attempting to create CUDA context:
21:39:53:WU00:FS01:0x22:  Configuring platform CUDA
21:39:53:WU00:FS01:0x22:ERROR:Win32: 0xc0000005: Exception access violation
21:39:53:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
21:39:53:WU00:FS01:0x22:Saving result file science.log
21:39:53:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:39:54:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:39:54:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14942 run:0 clone:74 gen:67 core:0x22 unit:0x0000004a0000004300003a5e00000000
21:39:54:WU00:FS01:Uploading 2.54KiB to 128.174.73.78
21:39:54:WU00:FS01:Connecting to 128.174.73.78:8080
21:39:54:WU00:FS01:Upload complete
21:39:54:WU00:FS01:Server responded WORK_ACK (400)
21:39:54:WU00:FS01:Cleaning up
21:39:54:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:39:54:WU01:FS01:Assigned to work server 206.223.170.146
21:39:54:WU01:FS01:Requesting new work unit for slot 01: gpu:6:0 GA106 [GeForce RTX 3060 Lite Hash Rate] from 206.223.170.146
21:39:54:WU01:FS01:Connecting to 206.223.170.146:8080
21:39:55:WU01:FS01:Downloading 22.06MiB
21:39:58:WU01:FS01:Download complete
21:39:58:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18601 run:7191 clone:3 gen:13 core:0x22 unit:0x000000030000000d000048a900001c17
21:39:58:WU01:FS01:Starting
21:39:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 6432 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:39:58:WU01:FS01:Started FahCore on PID 21076
21:39:58:WU01:FS01:Core PID:9280
21:39:58:WU01:FS01:FahCore 0x22 started
21:39:59:WU01:FS01:0x22:*********************** Log Started 2022-12-13T21:39:58Z ***********************
21:39:59:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:39:59:WU01:FS01:0x22:       Core: Core22
21:39:59:WU01:FS01:0x22:       Type: 0x22
21:39:59:WU01:FS01:0x22:    Version: 0.0.20
21:39:59:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:39:59:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
21:39:59:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
21:39:59:WU01:FS01:0x22:       Date: Jan 20 2022
21:39:59:WU01:FS01:0x22:       Time: 01:15:36
21:39:59:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:39:59:WU01:FS01:0x22:     Branch: HEAD
21:39:59:WU01:FS01:0x22:   Compiler: Visual C++
21:39:59:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:39:59:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
21:39:59:WU01:FS01:0x22:   Platform: win32 10
21:39:59:WU01:FS01:0x22:       Bits: 64
21:39:59:WU01:FS01:0x22:       Mode: Release
21:39:59:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:39:59:WU01:FS01:0x22:             <peastman@stanford.edu>
21:39:59:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 21076 -checkpoint 30
21:39:59:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:39:59:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
21:39:59:WU01:FS01:0x22:************************************ libFAH ************************************
21:39:59:WU01:FS01:0x22:       Time: 01:14:17
21:39:59:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:39:59:WU01:FS01:0x22:************************************ CBang *************************************
21:39:59:WU01:FS01:0x22:       Time: 01:13:20
21:39:59:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:39:59:WU01:FS01:0x22:************************************ System ************************************
21:39:59:WU01:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
21:39:59:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:39:59:WU01:FS01:0x22:       CPUs: 16
21:39:59:WU01:FS01:0x22:     Memory: 31.93GiB
21:39:59:WU01:FS01:0x22:Free Memory: 24.46GiB
21:39:59:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:39:59:WU01:FS01:0x22: OS Version: 6.2
21:39:59:WU01:FS01:0x22:Has Battery: false
21:39:59:WU01:FS01:0x22: On Battery: false
21:39:59:WU01:FS01:0x22: UTC Offset: -5
21:39:59:WU01:FS01:0x22:        PID: 9280
21:39:59:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
21:39:59:WU01:FS01:0x22:************************************ OpenMM ************************************
21:39:59:WU01:FS01:0x22:    Version: 7.7.0
21:39:59:WU01:FS01:0x22:********************************************************************************
21:39:59:WU01:FS01:0x22:Project: 18601 (Run 7191, Clone 3, Gen 13)
21:39:59:WU01:FS01:0x22:Reading tar file core.xml
21:39:59:WU01:FS01:0x22:Reading tar file integrator.xml
21:39:59:WU01:FS01:0x22:Reading tar file state.xml.bz2
21:39:59:WU01:FS01:0x22:Reading tar file system.xml.bz2
21:39:59:WU01:FS01:0x22:Digital signatures verified
21:39:59:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:39:59:WU01:FS01:0x22:Version 0.0.20
21:39:59:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
21:39:59:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
21:39:59:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
21:39:59:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
21:39:59:WU01:FS01:0x22:There are 4 platforms available.
21:39:59:WU01:FS01:0x22:Platform 0: Reference
21:39:59:WU01:FS01:0x22:Platform 1: CPU
21:39:59:WU01:FS01:0x22:Platform 2: OpenCL
21:39:59:WU01:FS01:0x22:  opencl-device 0 specified
21:39:59:WU01:FS01:0x22:Platform 3: CUDA
21:39:59:WU01:FS01:0x22:  cuda-device 0 specified
21:40:21:WU01:FS01:0x22:Attempting to create CUDA context:
21:40:21:WU01:FS01:0x22:  Configuring platform CUDA
21:40:21:WU01:FS01:0x22:ERROR:Win32: 0xc0000005: Exception access violation
21:40:21:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:40:21:WU01:FS01:0x22:Saving result file science.log
21:40:21:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:40:21:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:40:21:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18601 run:7191 clone:3 gen:13 core:0x22 unit:0x000000030000000d000048a900001c17
21:40:21:WU01:FS01:Uploading 11.00KiB to 206.223.170.146
21:40:21:WU01:FS01:Connecting to 206.223.170.146:8080
21:40:22:WU01:FS01:Upload complete
21:40:22:WU01:FS01:Server responded WORK_ACK (400)
21:40:22:WU01:FS01:Cleaning up
21:40:22:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:40:22:WU00:FS01:Assigned to work server 129.32.209.202
21:40:22:WU00:FS01:Requesting new work unit for slot 01: gpu:6:0 GA106 [GeForce RTX 3060 Lite Hash Rate] from 129.32.209.202
21:40:22:WU00:FS01:Connecting to 129.32.209.202:8080
21:40:23:WU00:FS01:Downloading 94.24MiB
21:40:26:WU00:FS01:Download complete
21:40:26:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18450 run:1 clone:332 gen:191 core:0x22 unit:0x0000014c000000bf0000481200000001
21:40:26:WU00:FS01:Starting
21:40:26:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 6432 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:40:26:WU00:FS01:Started FahCore on PID 19792
21:40:26:WU00:FS01:Core PID:5472
21:40:26:WU00:FS01:FahCore 0x22 started
21:40:27:WU00:FS01:0x22:*********************** Log Started 2022-12-13T21:40:26Z ***********************
21:40:27:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:40:27:WU00:FS01:0x22:       Core: Core22
21:40:27:WU00:FS01:0x22:       Type: 0x22
21:40:27:WU00:FS01:0x22:    Version: 0.0.20
21:40:27:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:40:27:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
21:40:27:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
21:40:27:WU00:FS01:0x22:       Date: Jan 20 2022
21:40:27:WU00:FS01:0x22:       Time: 01:15:36
21:40:27:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:40:27:WU00:FS01:0x22:     Branch: HEAD
21:40:27:WU00:FS01:0x22:   Compiler: Visual C++
21:40:27:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:40:27:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
21:40:27:WU00:FS01:0x22:   Platform: win32 10
21:40:27:WU00:FS01:0x22:       Bits: 64
21:40:27:WU00:FS01:0x22:       Mode: Release
21:40:27:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:40:27:WU00:FS01:0x22:             <peastman@stanford.edu>
21:40:27:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 19792 -checkpoint 30
21:40:27:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:40:27:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
21:40:27:WU00:FS01:0x22:************************************ libFAH ************************************
21:40:27:WU00:FS01:0x22:       Time: 01:14:17
21:40:27:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:40:27:WU00:FS01:0x22:************************************ CBang *************************************
21:40:27:WU00:FS01:0x22:       Time: 01:13:20
21:40:27:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:40:27:WU00:FS01:0x22:************************************ System ************************************
21:40:27:WU00:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
21:40:27:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:40:27:WU00:FS01:0x22:       CPUs: 16
21:40:27:WU00:FS01:0x22:     Memory: 31.93GiB
21:40:27:WU00:FS01:0x22:Free Memory: 24.01GiB
21:40:27:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:40:27:WU00:FS01:0x22: OS Version: 6.2
21:40:27:WU00:FS01:0x22:Has Battery: false
21:40:27:WU00:FS01:0x22: On Battery: false
21:40:27:WU00:FS01:0x22: UTC Offset: -5
21:40:27:WU00:FS01:0x22:        PID: 5472
21:40:27:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
21:40:27:WU00:FS01:0x22:************************************ OpenMM ************************************
21:40:27:WU00:FS01:0x22:    Version: 7.7.0
21:40:27:WU00:FS01:0x22:********************************************************************************
21:40:27:WU00:FS01:0x22:Project: 18450 (Run 1, Clone 332, Gen 191)
21:40:27:WU00:FS01:0x22:Reading tar file core.xml
21:40:27:WU00:FS01:0x22:Reading tar file integrator.xml
21:40:27:WU00:FS01:0x22:Reading tar file state.xml
21:40:27:WU00:FS01:0x22:Reading tar file system.xml
21:40:27:WU00:FS01:0x22:Digital signatures verified
21:40:27:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:40:27:WU00:FS01:0x22:Version 0.0.20
21:40:27:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
21:40:27:WU00:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
21:40:27:WU00:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
21:40:27:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
21:40:27:WU00:FS01:0x22:There are 4 platforms available.
21:40:27:WU00:FS01:0x22:Platform 0: Reference
21:40:27:WU00:FS01:0x22:Platform 1: CPU
21:40:27:WU00:FS01:0x22:Platform 2: OpenCL
21:40:27:WU00:FS01:0x22:  opencl-device 0 specified
21:40:27:WU00:FS01:0x22:Platform 3: CUDA
21:40:27:WU00:FS01:0x22:  cuda-device 0 specified
21:40:39:WU00:FS01:0x22:Attempting to create CUDA context:
21:40:39:WU00:FS01:0x22:  Configuring platform CUDA
21:40:39:WU00:FS01:0x22:ERROR:Win32: 0xc0000005: Exception access violation
21:40:39:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
21:40:39:WU00:FS01:0x22:Saving result file science.log
21:40:39:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:40:39:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:40:39:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18450 run:1 clone:332 gen:191 core:0x22 unit:0x0000014c000000bf0000481200000001
21:40:39:WU00:FS01:Uploading 11.00KiB to 129.32.209.202
21:40:39:WU00:FS01:Connecting to 129.32.209.202:8080
21:40:40:WU00:FS01:Upload complete
21:40:40:WU00:FS01:Server responded WORK_ACK (400)
21:40:40:WU00:FS01:Cleaning up
21:40:40:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:40:40:WU01:FS01:Assigned to work server 129.32.209.202
21:40:40:WU01:FS01:Requesting new work unit for slot 01: gpu:6:0 GA106 [GeForce RTX 3060 Lite Hash Rate] from 129.32.209.202
21:40:40:WU01:FS01:Connecting to 129.32.209.202:8080
21:40:41:WU01:FS01:Downloading 41.74MiB
21:40:42:WU01:FS01:Download complete
21:40:42:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18447 run:0 clone:54 gen:579 core:0x22 unit:0x00000036000002430000480f00000000
21:40:42:WU01:FS01:Starting
21:40:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 6432 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:40:42:WU01:FS01:Started FahCore on PID 15432
21:40:42:WU01:FS01:Core PID:18168
21:40:42:WU01:FS01:FahCore 0x22 started
21:40:43:WU01:FS01:0x22:*********************** Log Started 2022-12-13T21:40:42Z ***********************
21:40:43:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:40:43:WU01:FS01:0x22:       Core: Core22
21:40:43:WU01:FS01:0x22:       Type: 0x22
21:40:43:WU01:FS01:0x22:    Version: 0.0.20
21:40:43:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:40:43:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
21:40:43:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
21:40:43:WU01:FS01:0x22:       Date: Jan 20 2022
21:40:43:WU01:FS01:0x22:       Time: 01:15:36
21:40:43:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:40:43:WU01:FS01:0x22:     Branch: HEAD
21:40:43:WU01:FS01:0x22:   Compiler: Visual C++
21:40:43:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:40:43:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
21:40:43:WU01:FS01:0x22:   Platform: win32 10
21:40:43:WU01:FS01:0x22:       Bits: 64
21:40:43:WU01:FS01:0x22:       Mode: Release
21:40:43:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:40:43:WU01:FS01:0x22:             <peastman@stanford.edu>
21:40:43:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 15432 -checkpoint 30
21:40:43:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:40:43:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
21:40:43:WU01:FS01:0x22:************************************ libFAH ************************************
21:40:43:WU01:FS01:0x22:       Time: 01:14:17
21:40:43:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:40:43:WU01:FS01:0x22:************************************ CBang *************************************
21:40:43:WU01:FS01:0x22:       Time: 01:13:20
21:40:43:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:40:43:WU01:FS01:0x22:************************************ System ************************************
21:40:43:WU01:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
21:40:43:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:40:43:WU01:FS01:0x22:       CPUs: 16
21:40:43:WU01:FS01:0x22:     Memory: 31.93GiB
21:40:43:WU01:FS01:0x22:Free Memory: 24.01GiB
21:40:43:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:40:43:WU01:FS01:0x22: OS Version: 6.2
21:40:43:WU01:FS01:0x22:Has Battery: false
21:40:43:WU01:FS01:0x22: On Battery: false
21:40:43:WU01:FS01:0x22: UTC Offset: -5
21:40:43:WU01:FS01:0x22:        PID: 18168
21:40:43:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
21:40:43:WU01:FS01:0x22:************************************ OpenMM ************************************
21:40:43:WU01:FS01:0x22:    Version: 7.7.0
21:40:43:WU01:FS01:0x22:********************************************************************************
21:40:43:WU01:FS01:0x22:Project: 18447 (Run 0, Clone 54, Gen 579)
21:40:43:WU01:FS01:0x22:Reading tar file core.xml
21:40:43:WU01:FS01:0x22:Reading tar file integrator.xml
21:40:43:WU01:FS01:0x22:Reading tar file state.xml
21:40:43:WU01:FS01:0x22:Reading tar file system.xml
21:40:43:WU01:FS01:0x22:Digital signatures verified
21:40:43:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:40:43:WU01:FS01:0x22:Version 0.0.20
21:40:43:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
21:40:43:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
21:40:43:WU01:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
21:40:43:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
21:40:43:WU01:FS01:0x22:There are 4 platforms available.
21:40:43:WU01:FS01:0x22:Platform 0: Reference
21:40:43:WU01:FS01:0x22:Platform 1: CPU
21:40:43:WU01:FS01:0x22:Platform 2: OpenCL
21:40:43:WU01:FS01:0x22:  opencl-device 0 specified
21:40:43:WU01:FS01:0x22:Platform 3: CUDA
21:40:43:WU01:FS01:0x22:  cuda-device 0 specified
21:40:48:WU01:FS01:0x22:Attempting to create CUDA context:
21:40:48:WU01:FS01:0x22:  Configuring platform CUDA
21:40:48:WU01:FS01:0x22:ERROR:Win32: 0xc0000005: Exception access violation
21:40:48:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:40:48:WU01:FS01:0x22:Saving result file science.log
21:40:48:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:40:48:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:40:48:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:18447 run:0 clone:54 gen:579 core:0x22 unit:0x00000036000002430000480f00000000
21:40:48:WU01:FS01:Uploading 11.00KiB to 129.32.209.202
21:40:48:WU01:FS01:Connecting to 129.32.209.202:8080
21:40:48:WU01:FS01:Upload complete
21:40:48:WU01:FS01:Server responded WORK_ACK (400)
21:40:48:WU01:FS01:Cleaning up
21:40:48:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:40:49:WU00:FS01:Assigned to work server 128.174.73.78
21:40:49:WU00:FS01:Requesting new work unit for slot 01: gpu:6:0 GA106 [GeForce RTX 3060 Lite Hash Rate] from 128.174.73.78
21:40:49:WU00:FS01:Connecting to 128.174.73.78:8080
21:40:54:FS01:Finishing
21:40:54:WU00:FS01:Downloading 14.07MiB
21:40:56:WU00:FS01:Download complete
21:40:56:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:19325 run:0 clone:62 gen:178 core:0x22 unit:0x0000003e000000b200004b7d00000000
21:40:56:WU00:FS01:Starting
21:40:56:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 6432 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:40:56:WU00:FS01:Started FahCore on PID 9580
21:40:56:WU00:FS01:Core PID:16940
21:40:56:WU00:FS01:FahCore 0x22 started
21:40:57:WU00:FS01:0x22:*********************** Log Started 2022-12-13T21:40:56Z ***********************
21:40:57:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:40:57:WU00:FS01:0x22:       Core: Core22
21:40:57:WU00:FS01:0x22:       Type: 0x22
21:40:57:WU00:FS01:0x22:    Version: 0.0.20
21:40:57:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:40:57:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
21:40:57:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
21:40:57:WU00:FS01:0x22:       Date: Jan 20 2022
21:40:57:WU00:FS01:0x22:       Time: 01:15:36
21:40:57:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:40:57:WU00:FS01:0x22:     Branch: HEAD
21:40:57:WU00:FS01:0x22:   Compiler: Visual C++
21:40:57:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:40:57:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
21:40:57:WU00:FS01:0x22:   Platform: win32 10
21:40:57:WU00:FS01:0x22:       Bits: 64
21:40:57:WU00:FS01:0x22:       Mode: Release
21:40:57:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:40:57:WU00:FS01:0x22:             <peastman@stanford.edu>
21:40:57:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9580 -checkpoint 30
21:40:57:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:40:57:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
21:40:57:WU00:FS01:0x22:************************************ libFAH ************************************
21:40:57:WU00:FS01:0x22:       Time: 01:14:17
21:40:57:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:40:57:WU00:FS01:0x22:************************************ CBang *************************************
21:40:57:WU00:FS01:0x22:       Time: 01:13:20
21:40:57:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:40:57:WU00:FS01:0x22:************************************ System ************************************
21:40:57:WU00:FS01:0x22:        CPU: AMD Ryzen 7 3800X 8-Core Processor
21:40:57:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:40:57:WU00:FS01:0x22:       CPUs: 16
21:40:57:WU00:FS01:0x22:     Memory: 31.93GiB
21:40:57:WU00:FS01:0x22:Free Memory: 23.86GiB
21:40:57:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:40:57:WU00:FS01:0x22: OS Version: 6.2
21:40:57:WU00:FS01:0x22:Has Battery: false
21:40:57:WU00:FS01:0x22: On Battery: false
21:40:57:WU00:FS01:0x22: UTC Offset: -5
21:40:57:WU00:FS01:0x22:        PID: 16940
21:40:57:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
21:40:57:WU00:FS01:0x22:************************************ OpenMM ************************************
21:40:57:WU00:FS01:0x22:    Version: 7.7.0
21:40:57:WU00:FS01:0x22:********************************************************************************
21:40:57:WU00:FS01:0x22:Project: 19325 (Run 0, Clone 62, Gen 178)
21:40:57:WU00:FS01:0x22:Reading tar file core.xml
21:40:57:WU00:FS01:0x22:Reading tar file integrator.xml
21:40:57:WU00:FS01:0x22:Reading tar file state.xml
21:40:57:WU00:FS01:0x22:Reading tar file system.xml
21:40:57:WU00:FS01:0x22:Digital signatures verified
21:40:57:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:40:57:WU00:FS01:0x22:Version 0.0.20
21:40:57:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
21:40:57:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
21:40:57:WU00:FS01:0x22:  XTC frame write interval: 25000 steps (2.5%) [40 total]
21:40:57:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
21:40:57:WU00:FS01:0x22:There are 4 platforms available.
21:40:57:WU00:FS01:0x22:Platform 0: Reference
21:40:57:WU00:FS01:0x22:Platform 1: CPU
21:40:57:WU00:FS01:0x22:Platform 2: OpenCL
21:40:57:WU00:FS01:0x22:  opencl-device 0 specified
21:40:57:WU00:FS01:0x22:Platform 3: CUDA
21:40:57:WU00:FS01:0x22:  cuda-device 0 specified
21:41:07:WU00:FS01:0x22:Attempting to create CUDA context:
21:41:07:WU00:FS01:0x22:  Configuring platform CUDA
21:41:08:WU00:FS01:0x22:ERROR:Win32: 0xc0000005: Exception access violation
21:41:08:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
21:41:08:WU00:FS01:0x22:Saving result file science.log
21:41:08:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:41:08:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:41:08:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:19325 run:0 clone:62 gen:178 core:0x22 unit:0x0000003e000000b200004b7d00000000
21:41:08:WU00:FS01:Uploading 2.55KiB to 128.174.73.78
21:41:08:WU00:FS01:Connecting to 128.174.73.78:8080
21:41:08:WU00:FS01:Upload complete
21:41:08:WU00:FS01:Server responded WORK_ACK (400)
21:41:08:WU00:FS01:Cleaning up
Reason: Added code tags to log
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Only getting bad work units.
Post by BobWilliams757 »
Being you are getting the same error, I suspect it's a Windows related issue, possibly triggered by updates since you last folded.
A quick search shows multiple possible causes for such an error code.
Fold them if you get them!
It could be either hardware or software ... :(
pyrocyborg
Hardware configuration: 3060 12GB, 3060 Ti, 3070, 3080, 3090, 6700 XT, 6800 XT, 6900 XT
Post by pyrocyborg »
HI there! I think that we discussed together on Discord a day or two ago. You might have to reinstall Windows, and even there, it doesn't guarantee it's going to work as there might be some hardware issue somewhere.
I know there is a way to uninstall a particular Windows update, but you have to pinpoint the issue first, which might be problematic.
However, without reinstalling anything, if it's system file related, you could try this (this "tip" is taken from the Windows community forums) :
To run System File Checker (SFC), follow these steps:
  • In the search box on the taskbar, type command prompt, press and hold (or right-click) Command Prompt, then select Run as administrator > Yes.
  • At the command prompt, type sfc /scannow (note the space between sfc and the /). Scanning will take a few minutes.
  • If SFC finds corrupted files and replaces them, restart your PC and check if the issue persists.
btyrellb125
If i can not fix this without reinstalling windows, i am going to be done with folding, it is too much of a hassle for me.
You can check for hardware stability first (StressCPU v2, Furmark, OCCT, Memtest86+, ...).
btyrellb125
I used OCCT to test, i ran each test for a few minutes, and everything seems fine.
btyrellb125
I recently got a 3070, and it is also getting bad work units so i dont think it is a hardware issue.
btyrellb125
Still Have this issue if someone can help.
HayesK
Hardware configuration: hardware folding: 24 GPUs (8-GTX980Ti, 2-GTX1060, 2-GTX1070, 6-1080Ti, 2-1660Ti, 4-2070 Super)
hardware idle: 7-2600K, 1-i7-950, 2-i7-930, 2-i7-920, 3-i7-860, 2-Q9450, 4-L5640, 1-Q9550, 2-GTS450, 2-GTX550Ti, 3-GTX560Ti, 3-GTX650Ti, 11-GTX650Ti-Boost, 4-GTX660Ti, 2-GTX670, 6-GTX750Ti, 7-GTX970
Post by HayesK »
Windows update may have upgraded nvidia driver without providing all the components required for folding.
Have you tried installing the most recent nvidia driver directly from nvidia web site?
Looks like nvidia just released an update on 2/28.
GeForce Game Ready Driver
Version: 531.18 WHQL
Release Date: 2023.2.28
Operating System: Windows 10 64-bit, Windows 11
https://www.nvidia.com/download/driverR ... 990/en-us/
folding for OCF T32
<= 10-GPU ( 8-GTX980Ti, 2-RTX2070Super ) as HayesK =>
<= 24-GPU ( 3-650TiBoost, 1-660Ti, 3-750Ti, 1-960m, 4-970, 2-1060, 2-1070, 6-1080Ti, 2-1660Ti, 2-2070Super )
as HayesK_ALL_18SjyNbF8VdXaNAFCVfG4rAHUyvtdmoFvX =>
