Mining rigs put to good use Good then bad
Driver issues associated with the Windows 10 roll-out
trkr75
Post by trkr75 »
Good afternoon,
Not sure what is going on, but recently I noticed my Crypto miners that I switched over to Folding@Home went from running great to under performing by a lot. For a few months I was getting almost 400million a month now last month I was at like 80 million. I even have a RTX 4090 and it is only pulling in around 10million a day. Really not sure what is going on. Drivers are all up to date and I am running F@H ver. 7.6.21 according to the web interface "SLOT PROJECT PERFORMANCE 69.46% BELOW AVERAGE" Any thoughts or suggestions of settings I should check?
Regards,
Ken
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Mining rigs put to good use Good then bad
Post by BobWilliams757 »
Loads of questions here beyond drivers....
How many GPU's are you using? What specs?
Are all GPU's getting work units, and if so what is the average PPD of each card?
What type of system(s) are they running in?
More information is always better. Though some variation in performance is normal, long term variations of several hundred percent are not.
Fold them if you get them!
trkr75
Post by trkr75 »
Rig #1:
GeForce RTX 4090 AVG PPD 8,743,228
Others with the same GPU AVG PPD 26,674,394
F@H IN THE DARK: Boot Settings
F@H In The Dark Extension: v2.0.6
Folding@Home Client Backend: v7.6.21
Timer & Auto Finish Support: true
User Session ID Type: api/session
Operating System: Windows 11 Pro
Rig #2
INFLUENZA Project #18447
GeForce RTX 3070 AVG PPD 971,211
Others with the same GPU AVG PPD 3,508,654
INFLUENZA Project #18450
GeForce RTX 3070 AVG PPD 1,312,339
Others with the same GPU AVG PPD 3,987,948
ALZHEIMERS Project #18601
GeForce RTX 3070 AVG PPD 1,664,926
Others with the same GPU AVG PPD 4,069,857
INFLUENZA Project #18448
GeForce RTX 3070 AVG PPD 1,204,681
Others with the same GPU AVG PPD 3,723,270
Operating System: Windows 10 Pro
Rig #3
GeForce GTX 1080 AVG PPD 382,815
Others with the same GPU AVG PPD 1,031,984
GeForce RTX 3090 AVG PPD 4,790,001
Others with the same GPU AVG PPD 7,176,896
GeForce GTX 1060 3GB AVG PPD 444,130
Others with the same GPU AVG PPD 451,237
Rig #4
AAA-PROTEIN-SUPERFAMILY Project #19321
GeForce GTX 1080 Ti AVG PPD 1,307,983
Others with the same GPU AVG PPD 1,991,037
INFLUENZA Project #18449
GeForce RTX 3090 AVG PPD 2,322,671
Others with the same GPU AVG PPD 5,971,065
GeForce GTX 1080 Ti AVG PPD 1,495,195
Operating System: Windows 10 Enterprise
I went back and checked and made sure that my passcode was installed and correct.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
What are you using for input on your PPD averages? The reason I ask is due to the numbers being low across several systems, and indicative that something might simply be using the incorrect metric for the calculation.
Seeing that all rigs use the Timer and Auto Finish Support, I'm wondering if maybe you are only folding at night, yet your PPD is being calculated as if you are running 24/7? Though I didn't look at them all, it seems your GPU's are returning about 1/3 of the expected PPD. If you only fold somewhere around 8 hours a night this is expected, but how it's calculated can tell different stories.
Are you using HFM or another program to monitor actual throughput and returns per work unit?
I'm not familiar with the metrics the LAR Systems use to report PPD returns and such, as I haven't used the extension. But it seems to me somehow you might be seeing the actual 24 hour average on your GPU throughput, but not folding on them 24 hours a day. As such a 1 million PPD GPU that runs 8 hours a day is still a 1 million PPD GPU. But if that GPU is only actually run for 8 hours a day then the actual points for that 8 hour period would be 333,3333, not 1 million.
trkr75
Post by trkr75 »
I did check the timers and that seemed to be part of the issue so I turned them off so it should be folding 24/7, I may have a PSU issue as they seem to be rebooting randomly through out the day. I have a tester and new PSU on the way so I can rule that out as well. As far as "What are you using for input on your PPD averages?" I am not sure what you mean. I just took the information form the LAR System page. I have never used HFM before just going by https://folding.extremeoverclocking.com/ for my stats and now the LAR Systems extension.
The mix of projects is always changing, and with wide GPUs like RTX 4090, it is very prone to huge variations in PPD ...
Also, make sure that you don't get GPU driver resets which might leave your GPUs into conservative clocks until you reboot the system.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
trkr75 wrote: Tue Dec 06, 2022 4:15 pm I did check the timers and that seemed to be part of the issue so I turned them off so it should be folding 24/7, I may have a PSU issue as they seem to be rebooting randomly through out the day. I have a tester and new PSU on the way so I can rule that out as well. As far as "What are you using for input on your PPD averages?" I am not sure what you mean. I just took the information form the LAR System page. I have never used HFM before just going by https://folding.extremeoverclocking.com/ for my stats and now the LAR Systems extension.
The question regarding PPD was what you are basing your PPD return on, but pointing out that if only part of a day you can't expect that PPD to reflect an entire day.
As for the power supply issues, how often are things rebooting? Every time that happens your system has to start at the last checkpoint at best, and might lose work units at worst. If this is happening a number of times a day you are doing duplicate work at times, and losing work units at other times. In either case something you should sort out before folding.
Mxyzptlk
Hardware configuration: Lots... Look at my website: www.mxyzptlk.us
Post by Mxyzptlk »
What MOBO, cpu and riser cables are you using?
trkr75
Post by trkr75 »
Mxyzptlk wrote: Wed Dec 07, 2022 3:03 am What MOBO, cpu and riser cables are you using?
MOBO -Gigabyte Z390
CPU -Intel I5 94000f
No riser installed on the MOBO
RAM -32GB
M.2 -2TB
SSD -2TB X2
PSU -850watt have a 1000 on the way for another build but could swap it in if that may be the problem.
GPU -RTX 4090 ZOTAC
On a side note, I see your a HAM as well. KJ4OQW here
Mxyzptlk
Post by Mxyzptlk »
Very odd indeed. When your label said mining rigs, the riser cables were the forst thing that i thought of. But I assumed...so... :)
Check your folding number here: https://apps.foldingathome.org/bonus
looks like maybe you are getting failed WU's possibly so you aren't getting a bonus?
I use the Lars extension and the timers in it and neverf had a problem.
73
