a8 Core too slow
okaits#7534
Hardware configuration: AMD Ryzen 5 3500X x 6, NVIDIA GeForce GTX 1660 SUPER
a8 Core too slow
Post by okaits#7534 »
My a8 core is too slow to meet the final report deadline.
CPU usage has been going back and forth between 35~60% all the time and is not at 100%. If I run the a8 core in that state, it is too slow and will miss the final report deadline.
I have been running Folding@home for a little while now, but this has suddenly happened recently. should I abandon the CPU slot and dump the WU that is running now?
(Now I'm running project 16996)
Log file (/var/lib/fahclient/log.txt):
*********************** Log Started 2022-12-04T07:29:02Z ***********************
07:29:02:******************************* libFAH ********************************
07:29:02:           Date: Oct 20 2020
07:29:02:           Time: 20:36:39
07:29:02:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
07:29:02:         Branch: master
07:29:02:       Compiler: GNU 8.3.0
07:29:02:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:29:02:                 -fdata-sections -O3 -funroll-loops -fno-pie
07:29:02:       Platform: linux2 5.8.0-1-amd64
07:29:02:           Bits: 64
07:29:02:           Mode: Release
07:29:02:****************************** FAHClient ******************************
07:29:02:        Version: 7.6.21
07:29:02:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:29:02:      Copyright: 2020 foldingathome.org
07:29:02:       Homepage: https://foldingathome.org/
07:29:02:           Time: 20:39:00
07:29:02:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
07:29:02:           Bits: 64
07:29:02:           Args: --child /etc/fahclient/config.xml --run-as fahclient
07:29:02:                 --pid-file=/var/run/fahclient.pid --daemon
07:29:02:         Config: /etc/fahclient/config.xml
07:29:02:******************************** CBang ********************************
07:29:02:           Time: 18:37:59
07:29:02:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
07:29:02:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:29:02:           Bits: 64
07:29:02:******************************* System ********************************
07:29:02:            CPU: AMD Ryzen 5 3500X 6-Core Processor
07:29:02:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:29:02:           CPUs: 6
07:29:02:         Memory: 15.55GiB
07:29:02:    Free Memory: 10.95GiB
07:29:02:        Threads: POSIX_THREADS
07:29:02:     OS Version: 6.1
07:29:02:    Has Battery: false
07:29:02:     On Battery: false
07:29:02:     UTC Offset: 9
07:29:02:            PID: 3503
07:29:02:            CWD: /var/lib/fahclient
07:29:02:             OS: Linux 6.1.0-rc7+ x86_64
07:29:02:        OS Arch: AMD64
07:29:02:           GPUs: 1
07:29:02:          GPU 0: Bus:8 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
07:29:02:  CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:7.5 Driver:11.8
07:29:02:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:3.0 Driver:520.56
07:29:02:***********************************************************************
07:29:02:<config>
07:29:02:  <!-- Client Control -->
07:29:02:  <fold-anon v='true'/>
07:29:02:
07:29:02:  <!-- Folding Core -->
07:29:02:  <checkpoint v='3'/>
07:29:02:  <core-priority v='low'/>
07:29:02:
07:29:02:  <!-- Folding Slot Configuration -->
07:29:02:  <cause v='COVID_19'/>
07:29:02:
07:29:02:  <!-- HTTP Server -->
07:29:02:  <allow v='127.0.0.1 192.168.1.0/24'/>
07:29:02:
07:29:02:  <!-- Network -->
07:29:02:  <proxy v=':8080'/>
07:29:02:
07:29:02:  <!-- Slot Control -->
07:29:02:  <pause-on-battery v='false'/>
07:29:02:
07:29:02:  <!-- User Information -->
07:29:02:  <passkey v='*****'/>
07:29:02:  <team v='162'/>
07:29:02:  <user v='okaits#7534'/>
07:29:02:
07:29:02:  <!-- Web Server -->
07:29:02:  <web-allow v='127.0.0.1 192.168.1.0/24'/>
07:29:02:
07:29:02:  <!-- Folding Slots -->
07:29:02:  <slot id='0' type='CPU'>
07:29:02:    <next-unit-percentage v='100'/>
07:29:02:  </slot>
07:29:02:  <slot id='1' type='GPU'>
07:29:02:    <pci-bus v='8'/>
07:29:02:    <pci-slot v='0'/>
07:29:02:  </slot>
07:29:02:</config>
07:29:02:Trying to access database...
07:29:02:Successfully acquired database lock
07:29:02:FS00:Initialized folding slot 00: cpu:4
07:29:02:FS01:Initialized folding slot 01: gpu:8:0 TU116 [GeForce GTX 1660 SUPER]
07:29:02:WU01:FS01:Starting
07:29:02:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 3503 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
07:29:02:WU01:FS01:Started FahCore on PID 3528
07:29:02:WU01:FS01:Core PID:3534
07:29:02:WU01:FS01:FahCore 0x22 started
07:29:02:WU02:FS00:Starting
07:29:02:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 3503 -checkpoint 3 -np 4
07:29:02:WU02:FS00:Started FahCore on PID 3657
07:29:02:WU02:FS00:Core PID:3661
07:29:02:WU02:FS00:FahCore 0xa8 started
07:29:02:WU01:FS01:0x22:*********************** Log Started 2022-12-04T07:29:02Z ***********************
07:29:02:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:29:02:WU01:FS01:0x22:       Core: Core22
07:29:02:WU01:FS01:0x22:       Type: 0x22
07:29:02:WU01:FS01:0x22:    Version: 0.0.20
07:29:02:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:29:02:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
07:29:02:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
07:29:02:WU01:FS01:0x22:       Date: Jan 20 2022
07:29:02:WU01:FS01:0x22:       Time: 00:57:52
07:29:02:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:29:02:WU01:FS01:0x22:     Branch: HEAD
07:29:02:WU01:FS01:0x22:   Compiler: GNU 9.4.0
07:29:02:WU01:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:29:02:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
07:29:02:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
07:29:02:WU01:FS01:0x22:   Platform: linux 5.11.0-1025-azure
07:29:02:WU01:FS01:0x22:       Bits: 64
07:29:02:WU01:FS01:0x22:       Mode: Release
07:29:02:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:29:02:WU01:FS01:0x22:             <peastman@stanford.edu>
07:29:02:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3528 -checkpoint 3
07:29:02:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
07:29:02:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
07:29:02:WU01:FS01:0x22:************************************ libFAH ************************************
07:29:02:WU01:FS01:0x22:       Time: 00:57:22
07:29:02:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:29:02:WU01:FS01:0x22:************************************ CBang *************************************
07:29:02:WU01:FS01:0x22:       Time: 00:57:00
07:29:02:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:29:02:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:29:02:WU01:FS01:0x22:************************************ System ************************************
07:29:02:WU01:FS01:0x22:        CPU: AMD Ryzen 5 3500X 6-Core Processor
07:29:02:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:29:02:WU01:FS01:0x22:       CPUs: 6
07:29:02:WU01:FS01:0x22:     Memory: 15.55GiB
07:29:02:WU01:FS01:0x22:Free Memory: 10.90GiB
07:29:02:WU01:FS01:0x22:    Threads: POSIX_THREADS
07:29:02:WU01:FS01:0x22: OS Version: 6.1
07:29:02:WU01:FS01:0x22:Has Battery: false
07:29:02:WU01:FS01:0x22: On Battery: false
07:29:02:WU01:FS01:0x22: UTC Offset: 9
07:29:02:WU01:FS01:0x22:        PID: 3534
07:29:02:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
07:29:02:WU01:FS01:0x22:************************************ OpenMM ************************************
07:29:02:WU01:FS01:0x22:    Version: 7.7.0
07:29:02:WU01:FS01:0x22:********************************************************************************
07:29:02:WU01:FS01:0x22:Project: 18601 (Run 12061, Clone 3, Gen 0)
07:29:02:WU01:FS01:0x22:Digital signatures verified
07:29:02:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:29:02:WU01:FS01:0x22:Version 0.0.20
07:29:02:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
07:29:02:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
07:29:02:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
07:29:02:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
07:29:02:WU01:FS01:0x22:There are 4 platforms available.
07:29:02:WU01:FS01:0x22:Platform 0: Reference
07:29:02:WU01:FS01:0x22:Platform 1: CPU
07:29:02:WU01:FS01:0x22:Platform 2: OpenCL
07:29:02:WU01:FS01:0x22:  opencl-device 0 specified
07:29:02:WU01:FS01:0x22:Platform 3: CUDA
07:29:02:WU01:FS01:0x22:  cuda-device 0 specified
07:29:03:WU02:FS00:0xa8:*********************** Log Started 2022-12-04T07:29:02Z ***********************
07:29:03:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
07:29:03:WU02:FS00:0xa8:       Core: Gromacs
07:29:03:WU02:FS00:0xa8:       Type: 0xa8
07:29:03:WU02:FS00:0xa8:    Version: 0.0.12
07:29:03:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:29:03:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
07:29:03:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
07:29:03:WU02:FS00:0xa8:       Date: Jan 16 2021
07:29:03:WU02:FS00:0xa8:       Time: 19:24:44
07:29:03:WU02:FS00:0xa8:   Compiler: GNU 8.3.0
07:29:03:WU02:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
07:29:03:WU02:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
07:29:03:WU02:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
07:29:03:WU02:FS00:0xa8:       Bits: 64
07:29:03:WU02:FS00:0xa8:       Mode: Release
07:29:03:WU02:FS00:0xa8:       SIMD: avx2_256
07:29:03:WU02:FS00:0xa8:     OpenMP: ON
07:29:03:WU02:FS00:0xa8:       CUDA: OFF
07:29:03:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3657 -checkpoint 3 -np 4
07:29:03:WU02:FS00:0xa8:************************************ libFAH ************************************
07:29:03:WU02:FS00:0xa8:       Time: 19:21:38
07:29:03:WU02:FS00:0xa8:************************************ CBang *************************************
07:29:03:WU02:FS00:0xa8:       Time: 19:21:24
07:29:03:WU02:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:29:03:WU02:FS00:0xa8:************************************ System ************************************
07:29:03:WU02:FS00:0xa8:        CPU: AMD Ryzen 5 3500X 6-Core Processor
07:29:03:WU02:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:29:03:WU02:FS00:0xa8:       CPUs: 6
07:29:03:WU02:FS00:0xa8:     Memory: 15.55GiB
07:29:03:WU02:FS00:0xa8:Free Memory: 10.83GiB
07:29:03:WU02:FS00:0xa8:    Threads: POSIX_THREADS
07:29:03:WU02:FS00:0xa8: OS Version: 6.1
07:29:03:WU02:FS00:0xa8:Has Battery: false
07:29:03:WU02:FS00:0xa8: On Battery: false
07:29:03:WU02:FS00:0xa8: UTC Offset: 9
07:29:03:WU02:FS00:0xa8:        PID: 3661
07:29:03:WU02:FS00:0xa8:        CWD: /var/lib/fahclient/work
07:29:03:WU02:FS00:0xa8:********************************************************************************
07:29:03:WU02:FS00:0xa8:Project: 16996 (Run 18, Clone 6, Gen 108)
07:29:03:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
07:29:03:WU02:FS00:0xa8:Digital signatures verified
07:29:03:WU02:FS00:0xa8:Calling: mdrun -c frame108.gro -s frame108.tpr -x frame108.xtc -cpi state.cpt -cpt 3 -nt 4 -ntmpi 1
07:29:03:WU02:FS00:0xa8:Steps: first=270000000 total=272500000
07:29:04:WU02:FS00:0xa8:Completed 100602 out of 2500000 steps (4%)
07:29:15:WU01:FS01:0x22:Attempting to create CUDA context:
07:29:15:WU01:FS01:0x22:  Configuring platform CUDA
07:29:29:WU01:FS01:0x22:  Using CUDA and gpu 0
07:29:29:WU01:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
07:29:42:1:127.0.0.1:New Web session
07:29:43:6:127.0.0.1:New Web session
07:29:44:15:127.0.0.1:New Web session
07:29:45:19:127.0.0.1:New Web session
07:29:47:23:127.0.0.1:New Web session
07:30:29:48:127.0.0.1:New Web session
07:30:30:49:127.0.0.1:New Web session
07:33:48:WU01:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
07:38:13:WU01:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
07:38:16:WU01:FS01:0x22:Checkpoint completed at step 525000
07:42:34:WU01:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
Image Image
I may be using strange English, but please take it with a grain of salt.
Re: a8 Core too slow
Why else are you running on that system besides folding? In addition, setting the checkpoint frequency to the minimum of 3 minutes is not gaining you much and will slow down processing on the CPU A8 core. Also if you hav not recently cleaned out the interior of this system, check that and clear out any accumulated dust and lint. The Ryzen 5 3500X is thermally limited to 65 W so often is configured with the minimum cooling required.
okaits#7534
Oh, sorry, I forgot to change the settings, there are no processes other than FAH that require the CPU often. I also measured the CPU temperature using lm-sensors and it was 65.8C. I also changed Checkpointing frequency back to the default of 15 minutes, but the ETA is still the same.
Image Image
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
What position is the slider in, and have you changed any settings in your configuration? It appears to me that you're only using 1/3 of your available cores currently.
And, are you folding around the clock 24/7? Even running on reduced cores you should be able to finish that work unit with time to spare. Even running on reduced cores I have finished one on my slower system in less than a day, and the deadline is 3 days.
If you are running on full CPU power you should be able to generate 50K + PPD. Is there any chance you are looking at the initial prediction and not letting the work unit run for a couple of frames?
Fold them if you get them!
okaits#7534
I checked the slider to make sure and to my surprise it was set to Medium. I just made sure it was changed to Full and then tried a reboot and it only changed a little.
No, I don't use my PC for 24 hours, but I think it's too slow because I could finish the CPU tasks before.
Here is my log file:
*********************** Log Started 2022-12-06T06:59:55Z ***********************
06:59:55:******************************* libFAH ********************************
06:59:55:           Date: Oct 20 2020
06:59:55:           Time: 20:36:39
06:59:55:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
06:59:55:         Branch: master
06:59:55:       Compiler: GNU 8.3.0
06:59:55:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
06:59:55:                 -fdata-sections -O3 -funroll-loops -fno-pie
06:59:55:       Platform: linux2 5.8.0-1-amd64
06:59:55:           Bits: 64
06:59:55:           Mode: Release
06:59:55:****************************** FAHClient ******************************
06:59:55:        Version: 7.6.21
06:59:55:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:55:      Copyright: 2020 foldingathome.org
06:59:55:       Homepage: https://foldingathome.org/
06:59:55:           Time: 20:39:00
06:59:55:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
06:59:55:           Bits: 64
06:59:55:           Args: --child /etc/fahclient/config.xml --run-as fahclient
06:59:55:                 --pid-file=/var/run/fahclient.pid --daemon
06:59:55:         Config: /etc/fahclient/config.xml
06:59:55:******************************** CBang ********************************
06:59:55:           Time: 18:37:59
06:59:55:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
06:59:55:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:59:55:           Bits: 64
06:59:55:******************************* System ********************************
06:59:55:            CPU: AMD Ryzen 5 3500X 6-Core Processor
06:59:55:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
06:59:55:           CPUs: 6
06:59:55:         Memory: 15.55GiB
06:59:55:    Free Memory: 11.37GiB
06:59:55:        Threads: POSIX_THREADS
06:59:55:     OS Version: 6.1
06:59:55:    Has Battery: false
06:59:55:     On Battery: false
06:59:55:     UTC Offset: 9
06:59:55:            PID: 2999
06:59:55:            CWD: /var/lib/fahclient
06:59:55:             OS: Linux 6.1.0-rc7+ x86_64
06:59:55:        OS Arch: AMD64
06:59:55:           GPUs: 1
06:59:55:          GPU 0: Bus:8 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
06:59:55:  CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:7.5 Driver:11.8
06:59:55:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:3.0 Driver:520.56
06:59:55:***********************************************************************
06:59:55:<config>
06:59:55:  <!-- Client Control -->
06:59:55:  <fold-anon v='true'/>
06:59:55:
06:59:55:  <!-- Folding Slot Configuration -->
06:59:55:  <cause v='COVID_19'/>
06:59:55:
06:59:55:  <!-- HTTP Server -->
06:59:55:  <allow v='127.0.0.1 192.168.1.0/24'/>
06:59:55:
06:59:55:  <!-- Network -->
06:59:55:  <proxy v=':8080'/>
06:59:55:
06:59:55:  <!-- Slot Control -->
06:59:55:  <pause-on-battery v='false'/>
06:59:55:  <power v='full'/>
06:59:55:
06:59:55:  <!-- User Information -->
06:59:55:  <passkey v='*****'/>
06:59:55:  <team v='162'/>
06:59:55:  <user v='okaits#7534'/>
06:59:55:
06:59:55:  <!-- Web Server -->
06:59:55:  <web-allow v='127.0.0.1 192.168.1.0/24'/>
06:59:55:
06:59:55:  <!-- Folding Slots -->
06:59:55:  <slot id='0' type='CPU'>
06:59:55:    <next-unit-percentage v='100'/>
06:59:55:  </slot>
06:59:55:  <slot id='1' type='GPU'>
06:59:55:    <pci-bus v='8'/>
06:59:55:    <pci-slot v='0'/>
06:59:55:  </slot>
06:59:55:</config>
06:59:55:Trying to access database...
06:59:55:Successfully acquired database lock
06:59:55:FS00:Initialized folding slot 00: cpu:5
06:59:55:FS01:Initialized folding slot 01: gpu:8:0 TU116 [GeForce GTX 1660 SUPER]
06:59:55:WU01:FS01:Starting
06:59:55:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 2999 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
06:59:55:WU01:FS01:Started FahCore on PID 3015
06:59:55:WU01:FS01:Core PID:3027
06:59:55:WU01:FS01:FahCore 0x22 started
06:59:56:WU01:FS01:0x22:*********************** Log Started 2022-12-06T06:59:56Z ***********************
06:59:56:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
06:59:56:WU01:FS01:0x22:       Core: Core22
06:59:56:WU01:FS01:0x22:       Type: 0x22
06:59:56:WU01:FS01:0x22:    Version: 0.0.20
06:59:56:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:56:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
06:59:56:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
06:59:56:WU01:FS01:0x22:       Date: Jan 20 2022
06:59:56:WU01:FS01:0x22:       Time: 00:57:52
06:59:56:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
06:59:56:WU01:FS01:0x22:     Branch: HEAD
06:59:56:WU01:FS01:0x22:   Compiler: GNU 9.4.0
06:59:56:WU01:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
06:59:56:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
06:59:56:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
06:59:56:WU01:FS01:0x22:   Platform: linux 5.11.0-1025-azure
06:59:56:WU01:FS01:0x22:       Bits: 64
06:59:56:WU01:FS01:0x22:       Mode: Release
06:59:56:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:59:56:WU01:FS01:0x22:             <peastman@stanford.edu>
06:59:56:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3015 -checkpoint 15
06:59:56:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
06:59:56:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
06:59:56:WU01:FS01:0x22:************************************ libFAH ************************************
06:59:56:WU01:FS01:0x22:       Time: 00:57:22
06:59:56:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
06:59:56:WU01:FS01:0x22:************************************ CBang *************************************
06:59:56:WU01:FS01:0x22:       Time: 00:57:00
06:59:56:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
06:59:56:WU01:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:59:56:WU01:FS01:0x22:************************************ System ************************************
06:59:56:WU01:FS01:0x22:        CPU: AMD Ryzen 5 3500X 6-Core Processor
06:59:56:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
06:59:56:WU01:FS01:0x22:       CPUs: 6
06:59:56:WU01:FS01:0x22:     Memory: 15.55GiB
06:59:56:WU01:FS01:0x22:Free Memory: 11.32GiB
06:59:56:WU01:FS01:0x22:    Threads: POSIX_THREADS
06:59:56:WU01:FS01:0x22: OS Version: 6.1
06:59:56:WU01:FS01:0x22:Has Battery: false
06:59:56:WU01:FS01:0x22: On Battery: false
06:59:56:WU01:FS01:0x22: UTC Offset: 9
06:59:56:WU01:FS01:0x22:        PID: 3027
06:59:56:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
06:59:56:WU01:FS01:0x22:************************************ OpenMM ************************************
06:59:56:WU01:FS01:0x22:    Version: 7.7.0
06:59:56:WU01:FS01:0x22:********************************************************************************
06:59:56:WU01:FS01:0x22:Project: 18601 (Run 13268, Clone 3, Gen 5)
06:59:56:WU01:FS01:0x22:Digital signatures verified
06:59:56:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
06:59:56:WU01:FS01:0x22:Version 0.0.20
06:59:56:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
06:59:56:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
06:59:56:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
06:59:56:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
06:59:56:WU02:FS00:Starting
06:59:56:WARNING:WU02:FS00:AS lowered CPUs from 5 to 4
06:59:56:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 2999 -checkpoint 15 -np 4
06:59:56:WU02:FS00:Started FahCore on PID 3291
06:59:56:WU02:FS00:Core PID:3307
06:59:56:WU02:FS00:FahCore 0xa8 started
06:59:56:WU01:FS01:0x22:There are 4 platforms available.
06:59:56:WU01:FS01:0x22:Platform 0: Reference
06:59:56:WU01:FS01:0x22:Platform 1: CPU
06:59:56:WU01:FS01:0x22:Platform 2: OpenCL
06:59:56:WU01:FS01:0x22:  opencl-device 0 specified
06:59:56:WU01:FS01:0x22:Platform 3: CUDA
06:59:56:WU01:FS01:0x22:  cuda-device 0 specified
06:59:57:WU02:FS00:0xa8:*********************** Log Started 2022-12-06T06:59:56Z ***********************
06:59:57:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
06:59:57:WU02:FS00:0xa8:       Core: Gromacs
06:59:57:WU02:FS00:0xa8:       Type: 0xa8
06:59:57:WU02:FS00:0xa8:    Version: 0.0.12
06:59:57:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:57:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
06:59:57:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
06:59:57:WU02:FS00:0xa8:       Date: Jan 16 2021
06:59:57:WU02:FS00:0xa8:       Time: 19:24:44
06:59:57:WU02:FS00:0xa8:   Compiler: GNU 8.3.0
06:59:57:WU02:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
06:59:57:WU02:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
06:59:57:WU02:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
06:59:57:WU02:FS00:0xa8:       Bits: 64
06:59:57:WU02:FS00:0xa8:       Mode: Release
06:59:57:WU02:FS00:0xa8:       SIMD: avx2_256
06:59:57:WU02:FS00:0xa8:     OpenMP: ON
06:59:57:WU02:FS00:0xa8:       CUDA: OFF
06:59:57:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3291 -checkpoint 15 -np 4
06:59:57:WU02:FS00:0xa8:************************************ libFAH ************************************
06:59:57:WU02:FS00:0xa8:       Time: 19:21:38
06:59:57:WU02:FS00:0xa8:************************************ CBang *************************************
06:59:57:WU02:FS00:0xa8:       Time: 19:21:24
06:59:57:WU02:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:59:57:WU02:FS00:0xa8:************************************ System ************************************
06:59:57:WU02:FS00:0xa8:        CPU: AMD Ryzen 5 3500X 6-Core Processor
06:59:57:WU02:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
06:59:57:WU02:FS00:0xa8:       CPUs: 6
06:59:57:WU02:FS00:0xa8:     Memory: 15.55GiB
06:59:57:WU02:FS00:0xa8:Free Memory: 11.00GiB
06:59:57:WU02:FS00:0xa8:    Threads: POSIX_THREADS
06:59:57:WU02:FS00:0xa8: OS Version: 6.1
06:59:57:WU02:FS00:0xa8:Has Battery: false
06:59:57:WU02:FS00:0xa8: On Battery: false
06:59:57:WU02:FS00:0xa8: UTC Offset: 9
06:59:57:WU02:FS00:0xa8:        PID: 3307
06:59:57:WU02:FS00:0xa8:        CWD: /var/lib/fahclient/work
06:59:57:WU02:FS00:0xa8:********************************************************************************
06:59:57:WU02:FS00:0xa8:Project: 16996 (Run 18, Clone 6, Gen 108)
06:59:57:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
06:59:57:WU02:FS00:0xa8:Digital signatures verified
06:59:57:WU02:FS00:0xa8:Calling: mdrun -c frame108.gro -s frame108.tpr -x frame108.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
06:59:57:WU02:FS00:0xa8:Steps: first=270000000 total=272500000
06:59:59:WU02:FS00:0xa8:Completed 225352 out of 2500000 steps (9%)
07:00:09:WU01:FS01:0x22:Attempting to create CUDA context:
07:00:09:WU01:FS01:0x22:  Configuring platform CUDA
07:00:22:WU01:FS01:0x22:  Using CUDA and gpu 0
07:00:22:WU01:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
07:00:26:3:127.0.0.1:New Web session
07:00:27:9:127.0.0.1:New Web session
07:00:27:10:127.0.0.1:New Web session
07:04:44:WU01:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
07:09:05:WU01:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
07:09:08:WU01:FS01:0x22:Checkpoint completed at step 750000
07:13:36:WU01:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
07:17:56:WU01:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
07:17:59:WU01:FS01:0x22:Checkpoint completed at step 775000
07:22:19:WU01:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
07:26:30:WU01:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
07:26:33:WU01:FS01:0x22:Checkpoint completed at step 800000
07:30:44:WU01:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
07:35:05:WU01:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
07:35:08:WU01:FS01:0x22:Checkpoint completed at step 825000
07:39:27:WU01:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
07:43:39:WU01:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
07:43:42:WU01:FS01:0x22:Checkpoint completed at step 850000
07:47:55:WU01:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
07:52:06:WU01:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
07:52:09:WU01:FS01:0x22:Checkpoint completed at step 875000
07:56:21:WU01:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
08:00:21:WU01:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
08:00:24:WU01:FS01:0x22:Checkpoint completed at step 900000
08:04:24:WU01:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
08:08:28:WU01:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
08:08:31:WU01:FS01:0x22:Checkpoint completed at step 925000
08:12:44:WU01:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
08:17:01:WU01:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
08:17:04:WU01:FS01:0x22:Checkpoint completed at step 950000
08:21:22:WU01:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
08:25:47:WU01:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
08:25:50:WU01:FS01:0x22:Checkpoint completed at step 975000
08:30:18:WU01:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
08:34:39:WU01:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
08:34:42:WU01:FS01:0x22:Checkpoint completed at step 1000000
08:39:02:WU01:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
08:43:23:WU01:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
08:43:26:WU01:FS01:0x22:Checkpoint completed at step 1025000
08:47:55:WU01:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
08:52:17:WU01:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
08:52:20:WU01:FS01:0x22:Checkpoint completed at step 1050000
08:56:45:WU01:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
09:01:02:WU01:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
09:01:05:WU01:FS01:0x22:Checkpoint completed at step 1075000
09:05:28:WU01:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
09:09:39:WU01:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
09:09:41:WU01:FS01:0x22:Checkpoint completed at step 1100000
09:13:49:WU01:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
09:17:56:WU01:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
09:17:59:WU01:FS01:0x22:Checkpoint completed at step 1125000
09:22:17:WU01:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
09:26:34:WU01:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
09:26:37:WU01:FS01:0x22:Checkpoint completed at step 1150000
09:30:46:WU01:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
09:34:56:WU01:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
09:34:59:WU01:FS01:0x22:Checkpoint completed at step 1175000
09:39:13:WU01:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
09:43:22:WU01:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
09:43:25:WU01:FS01:0x22:Checkpoint completed at step 1200000
09:47:37:WU01:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
09:51:56:WU01:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
09:51:59:WU01:FS01:0x22:Checkpoint completed at step 1225000
09:56:10:WU01:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
10:00:32:WU01:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
10:00:32:WU01:FS01:0x22:Average performance: 8.42105 ns/day
10:00:35:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:00:35:WU01:FS01:0x22:Checkpoint completed at step 1250000
10:00:36:WU00:FS01:Assigned to work server 129.32.209.202
10:00:36:WU00:FS01:Requesting new work unit for slot 01: gpu:8:0 TU116 [GeForce GTX 1660 SUPER] from 129.32.209.202
10:00:36:WU00:FS01:Connecting to 129.32.209.202:8080
10:00:37:WU00:FS01:Downloading 94.24MiB
10:00:43:WU00:FS01:Download 7.56%
10:00:43:WU01:FS01:0x22:Saving result file ../logfile_01.txt
10:00:43:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
10:00:43:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
10:00:43:WU01:FS01:0x22:Saving result file positions.xtc
10:00:43:WU01:FS01:0x22:Saving result file science.log
10:00:43:WU01:FS01:0x22:Saving result file xtcAtoms.csv.bz2
10:00:43:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
10:00:44:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:00:44:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18601 run:13268 clone:3 gen:5 core:0x22 unit:0x0000000300000005000048a9000033d4
10:00:44:WU01:FS01:Uploading 22.94MiB to 206.223.170.146
10:00:44:WU01:FS01:Connecting to 206.223.170.146:8080
10:00:47:WU01:FS01:Upload complete
10:00:47:WU01:FS01:Server responded WORK_ACK (400)
10:00:47:WU01:FS01:Final credit estimate, 167820.00 points
10:00:47:WU01:FS01:Cleaning up
10:00:49:WU00:FS01:Download 18.11%
10:00:55:WU00:FS01:Download 27.06%
10:01:01:WU00:FS01:Download 36.34%
10:01:07:WU00:FS01:Download 46.23%
10:01:13:WU00:FS01:Download 55.58%
10:01:19:WU00:FS01:Download 65.39%
10:01:25:WU00:FS01:Download 74.48%
10:01:31:WU00:FS01:Download 84.23%
10:01:37:WU00:FS01:Download 93.45%
10:01:40:WU00:FS01:Download complete
10:01:40:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18450 run:1 clone:27 gen:402 core:0x22 unit:0x0000001b000001920000481200000001
10:01:40:WU00:FS01:Starting
10:01:40:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 2999 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
10:01:40:WU00:FS01:Started FahCore on PID 21475
10:01:40:WU00:FS01:Core PID:21479
10:01:40:WU00:FS01:FahCore 0x22 started
10:01:41:WU00:FS01:0x22:*********************** Log Started 2022-12-06T10:01:40Z ***********************
10:01:41:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:01:41:WU00:FS01:0x22:       Core: Core22
10:01:41:WU00:FS01:0x22:       Type: 0x22
10:01:41:WU00:FS01:0x22:    Version: 0.0.20
10:01:41:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:01:41:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
10:01:41:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
10:01:41:WU00:FS01:0x22:       Date: Jan 20 2022
10:01:41:WU00:FS01:0x22:       Time: 00:57:52
10:01:41:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
10:01:41:WU00:FS01:0x22:     Branch: HEAD
10:01:41:WU00:FS01:0x22:   Compiler: GNU 9.4.0
10:01:41:WU00:FS01:0x22:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
10:01:41:WU00:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie
10:01:41:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
10:01:41:WU00:FS01:0x22:   Platform: linux 5.11.0-1025-azure
10:01:41:WU00:FS01:0x22:       Bits: 64
10:01:41:WU00:FS01:0x22:       Mode: Release
10:01:41:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
10:01:41:WU00:FS01:0x22:             <peastman@stanford.edu>
10:01:41:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 21475 -checkpoint 15
10:01:41:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
10:01:41:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
10:01:41:WU00:FS01:0x22:************************************ libFAH ************************************
10:01:41:WU00:FS01:0x22:       Time: 00:57:22
10:01:41:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
10:01:41:WU00:FS01:0x22:************************************ CBang *************************************
10:01:41:WU00:FS01:0x22:       Time: 00:57:00
10:01:41:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
10:01:41:WU00:FS01:0x22:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
10:01:41:WU00:FS01:0x22:************************************ System ************************************
10:01:41:WU00:FS01:0x22:        CPU: AMD Ryzen 5 3500X 6-Core Processor
10:01:41:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
10:01:41:WU00:FS01:0x22:       CPUs: 6
10:01:41:WU00:FS01:0x22:     Memory: 15.55GiB
10:01:41:WU00:FS01:0x22:Free Memory: 3.57GiB
10:01:41:WU00:FS01:0x22:    Threads: POSIX_THREADS
10:01:41:WU00:FS01:0x22: OS Version: 6.1
10:01:41:WU00:FS01:0x22:Has Battery: false
10:01:41:WU00:FS01:0x22: On Battery: false
10:01:41:WU00:FS01:0x22: UTC Offset: 9
10:01:41:WU00:FS01:0x22:        PID: 21479
10:01:41:WU00:FS01:0x22:        CWD: /var/lib/fahclient/work
10:01:41:WU00:FS01:0x22:************************************ OpenMM ************************************
10:01:41:WU00:FS01:0x22:    Version: 7.7.0
10:01:41:WU00:FS01:0x22:********************************************************************************
10:01:41:WU00:FS01:0x22:Project: 18450 (Run 1, Clone 27, Gen 402)
10:01:41:WU00:FS01:0x22:Reading tar file core.xml
10:01:41:WU00:FS01:0x22:Reading tar file integrator.xml
10:01:41:WU00:FS01:0x22:Reading tar file state.xml
10:01:41:WU00:FS01:0x22:Reading tar file system.xml
10:01:41:WU00:FS01:0x22:Digital signatures verified
10:01:41:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:01:41:WU00:FS01:0x22:Version 0.0.20
10:01:41:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
10:01:41:WU00:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
10:01:41:WU00:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
10:01:41:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
10:01:41:WU00:FS01:0x22:There are 4 platforms available.
10:01:41:WU00:FS01:0x22:Platform 0: Reference
10:01:41:WU00:FS01:0x22:Platform 1: CPU
10:01:41:WU00:FS01:0x22:Platform 2: OpenCL
10:01:41:WU00:FS01:0x22:  opencl-device 0 specified
10:01:41:WU00:FS01:0x22:Platform 3: CUDA
10:01:41:WU00:FS01:0x22:  cuda-device 0 specified
10:01:45:WU00:FS01:0x22:Attempting to create CUDA context:
10:01:45:WU00:FS01:0x22:  Configuring platform CUDA
10:01:50:WU00:FS01:0x22:  Using CUDA and gpu 0
10:01:50:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
10:01:51:WU00:FS01:0x22:Checkpoint completed at step 0
10:06:48:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
10:11:46:WU00:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
10:11:47:WU00:FS01:0x22:Checkpoint completed at step 50000
10:16:43:WU00:FS01:0x22:Completed 75000 out of 2500000 steps (3%)
10:21:40:WU00:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
10:21:41:WU00:FS01:0x22:Checkpoint completed at step 100000
10:26:37:WU00:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
10:31:32:WU00:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
10:31:33:WU00:FS01:0x22:Checkpoint completed at step 150000
10:36:29:WU00:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
10:41:24:WU00:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
10:41:25:WU00:FS01:0x22:Checkpoint completed at step 200000
10:46:20:WU00:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
10:47:35:WU02:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
10:51:15:WU00:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
10:51:16:WU00:FS01:0x22:Checkpoint completed at step 250000
10:56:11:WU00:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
11:01:05:WU00:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
11:01:06:WU00:FS01:0x22:Checkpoint completed at step 300000
11:06:01:WU00:FS01:0x22:Completed 325000 out of 2500000 steps (13%)
11:10:57:WU00:FS01:0x22:Completed 350000 out of 2500000 steps (14%)
11:10:57:WU00:FS01:0x22:Checkpoint completed at step 350000
11:15:53:WU00:FS01:0x22:Completed 375000 out of 2500000 steps (15%)
Image Image
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
Moving the slider to full won't change the number of cores until you pick up a new work unit. But in any case if you are not folding 24/7 then you can add a great deal of time to the work unit completion time.
I'm not sure what is going on here but this is a huge time chunk for a single percentage change. Is your CPU operating at normal speeds, not limited in BIOS or other settings, etc?
okaits#7534
No, I have never configured it that way. I also ran another project (BOINC, etc.) as an experiment and it worked fine.
I just received a new WU because I missed the final report deadline for WU and nothing changed.
Image Image
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
There are only a couple possibilities really.
Either you are just getting larger work units than you had been getting before and your amount of time folding isn't sufficient, or your CPU isn't operating at full speed. Unless I missed something in your last log those times for a single frame are very slow. It might be wise to use some benchmarks or such and see what speeds your CPU is running at, or if there is some type of software related issue slowing it down.
As a comparison example, I just unpaused my CPU slot and picked up the work unit you initially mentioned, 16996. I have a Ryzen 2400G, which has the same base clocks as your CPU. I also have the same graphics card which is folding. In my case I have performance boost on the CPU turned off for fan/noise level reasons. Folding at 4 cores (out of 8 available) that work unit is now estimating right around 21 hours total time and producing about 21.4K PPD. If anything your system should be folding faster than mine, unless it is somehow being limited more than mine.
As for CPU use, I'm not sure what you are using, but currently my Windows Task Manager puts CPU use at about 60%.
That CPU should be more than capable unless you are only folding a few hours a day. If you are only folding a few hours a day it's probably not worth CPU folding as those dumped work units will slow down the science.
