scripted Silent uninstall
mveras1972
Is there a silent uninstall option for FAH Client? I am trying to create an automated script to push it to a group of machines where we want to uninstall the client silently. Please advise. Thanks!
Re: scripted Silent uninstall
Not that I am aware of. The package for all three OSs include an uninstaller, but as privileges are required to install they are also required to uninstall.
My assumption is that you are following the F@h terms of use which include only installing on machines you own or have permission to use the folding client on. If you don't ownership or permission, then please do not install the client. The F@h project does not need negative perceptions that come from misuse of the software.
The uninstaller pkg is at
https://github.com/FoldingAtHome/fah-cl ... r/releases
You can uninstall via script with
sudo installer -target / -pkg fah-uninstaller_0.1.5_all.pkg
mveras1972
What can I tell you. The same people that asked me to install it to their department PCs is now asking me to uninstall it. I only support them and do what they ask.Joe_H wrote: ↑Mon Nov 21, 2022 8:37 pm Not that I am aware of. The package for all three OSs include an uninstaller, but as privileges are required to install they are also required to uninstall.
mveras1972
Is there one for Windows?calxalot wrote: ↑Tue Nov 22, 2022 1:54 am The uninstaller pkg is at
You can uninstall via script withCode: Select all
There is an uninstall created when installed on Windows. I don’t know how to use it from command line. I expect it’s easy to run from MS remote management tools.
