F@H Points not being credited properly
beaterhellfire
Post by beaterhellfire »
Hello guys,
i have seen an unusual behavior in the points i receive after i created a new user for F@H with new name and new passcode
here are the outputs from last 4 WUs
20:21:05:WU01:FS01:Upload complete
20:21:05:WU01:FS01:Server responded WORK_ACK (400)
20:21:05:WU01:FS01:Final credit estimate, 226386.00 points
21:54:15:WU02:FS01:Upload complete
21:54:15:WU02:FS01:Server responded WORK_ACK (400)
21:54:15:WU02:FS01:Final credit estimate, 149171.00 points
00:16:50:WU01:FS01:Upload complete
00:16:50:WU01:FS01:Server responded WORK_ACK (400)
00:16:50:WU01:FS01:Final credit estimate, 243054.00 points
02:31:28:WU02:FS01:Upload complete
02:31:28:WU02:FS01:Server responded WORK_ACK (400)
02:31:28:WU02:FS01:Final credit estimate, 222232.00 points
Here is my total of what i made
i can't wrap my head around this please help
fz4z
Re: F@H Points not being credited properly
Post by fz4z »
beaterhellfire wrote: Fri Nov 18, 2022 4:41 am Hello guys,
The bonus is applied for users who use a passkey, have successfully returned at least 10 bonus-eligible WUs, have successfully returned 80% or more of assigned WUs, and returned the unit before its Timeout (formerly Preferred Deadline).
beaterhellfire
fz4z wrote: Fri Nov 18, 2022 5:38 am
[/quote]
Thank you for your assistance all 9 WUs were submitted successfully without any errors and i do use passkey 0 unsubmitted WU or WU with errors
My RTX 2060 Super spends around 2 and half hour max for small WU which returns around 1,80,000-2,50,000 points with bonus and 3 and half hours max for large Work Unit which returns around 3,80,000-4,50,000 points with bonus
As mentioned, 10 WUs need to be returned before you start getting the Quick Return Bonus. So after returning your 10th, the next WU and any after that will get the bonus as long as you maintain the 80% return rate. The client does not have any means of determining if a username & passkey combination have bee qualified for the bonus, so the estimates are only calculated on the basis of whether or not a passkey has been entered.
The webpage apps.foldingathome.org has apps where you can check the return status of any WU, and also check your bonus status.
beaterhellfire
Joe_H wrote: Fri Nov 18, 2022 7:00 am As mentioned, 10 WUs need to be returned before you start getting the Quick Return Bonus. So after returning your 10th, the next WU and any after that will get the bonus as long as you maintain the 80% return rate. The client does not have any means of determining if a username & passkey combination have bee qualified for the bonus, so the estimates are only calculated on the basis of whether or not a passkey has been entered.
Thank You :D
