RTX 4080 PPD numbers
red454
- Hardware configuration: MSI Z790 ACE | 12700K | Cooler Master Cosmos | TeamGroup 32GB | RTX 4080/4090 | Win10 Pro
I have been testing the RTX 4080 and it seems to hit between 10 and 16 million PPD consistently, however I have seen it briefly hit 52 million PPD on project 18601.
Re: RTX 4080 PPD numbers
52m ppd must be a short fluke. There is no way a 4080 could actually run an entire job on 52m ppd. A 4090 does about half that, after all. Up to 16 mil does sound reasonable given the diff in compute power of those cards, with jobs that properly utilize that number of cuda cores.
red454
@PaulTV: Correct - it stayed at the high level for about 20 minutes, then ramped down to the 15 mil level. I have two of the 4080 cards, one from Nvidia and one from MSI and as expected, the performance is similar between the two.
