CPU: 13th Gen Intel(R) Core(TM) i9-13900K
So far I am seeing 200K PPD @5.4MHz out of the box. No tweaking yet.
Motherboard: MSI Z790 Carbon WiFi
RAM: 16G DDR5 Kingston Fury Beast
GPU: RTX4090
Cooler: MSI Coreliquid 280R
PSU: MSI MPG A1000G
Raptor Lake folding - i9-13900K
Re: Raptor Lake folding - i9-13900K
If it is a single folding slot using all available threads, it's definitely not good ... limit the slot thread number to the number of performance threads.
red454
- Hardware configuration: MSI Z790 ACE | 12700K | Cooler Master Cosmos | TeamGroup 32GB | RTX 4080/4090 | Win10 Pro
I spent a little time with it. When set to -1, the cpu:30. I experimented with setting the cpu to 8, 16 and 20 and didn't see any real difference in performance. Project 16969.
n1np
- Hardware configuration: HP DL380g8 x12
That sounds either problematic or disappointing.
My ~8-year-old e5-2690v0 @ 2.9GHz (turbo boost OFF, DL380g8) running CPU:30 gets ~270k PPD on p16969.
FWIW I have found that v0 (32nm) cpus far outperform v1 and v2 (22nm) cpus for F@H. I have only worked with the Xeons of this generation, not the consumer level chips.
Ben N1NP
Ben N1NP
Antonomasia Productions
New Release 2022: Re-Entrant
You should see most performance when limiting the number of threads to fit your P-cores only. As FaH overall performance is capped by the performance of your slowest CPU core, you don't want to share work between P-cores and E-cores.
Things are complicated by Windows 11 dumb scheduler which doesn't understand complications like this, which might get into its head to put work on E-cores if you run FaH on more than 8 threads. Try setting 16 threads (assuming no GPU folding!) and disable E-cores altogether and see what happens...
