more and more WU are not finished, stop wasting electricity, stop producing CO2
promeneur
- Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
More and more, WU computing is not finished.
Each time several days FAH computes for nothing.
Are you computing power rich enough to waste it ?
Several days, FAH consumes electricity for nothing.
In many countries electricity is produced by burning coal, oil, gaz. This produced much CO2.
Perhaps it is now necessary to do something. No ?
An example of solution (perhaps there is another solution)
FAH knows the ETA, the time-out date, the expiration date. FAH knows rapidly if "ETA > expiration date". FAH can abort the WU computing and load another WU.
Re: more and more WU are not finished, stop wasting electricity, stop producing CO2
You have given us nothing to go on, so all I can suggest is uninstalling to save energy.
If you wish to continue to fold, read up on items 6 to 8 in this link and send us the first 100 lines in your log. That will tell us much about how your folding is configured now.
viewtopic.php?t=26036
What's the point of your post ? Are you reporting an issue ? Or maybe making a suggestion ?promeneur wrote: ↑Fri Nov 04, 2022 10:49 am More and more, WU computing is not finished.
promeneur
Stopping a WU computing at about 50 % because the time is out is not a software bug. Isn't it ? It is a conception error.
The developer decided that it is not a problem wasting time and energy.
Perhaps it is a good decision, perhaps not.
Today in the world, the energy and CO2 is a growing problem. Perhaps the past decision is not a good decision today.
And you have still provided absolutely no information about your problem, so there is nothing we can do with your report. Which projects are you seeing WUs from that will not complete within the deadlines? What are they being processed on? Your posted hardware configuration lists 3 possible WU processors - CPU (i5-7400), GPU (HD Graphics 630), and GPU (GT 1030).
As for being a "conception error", that is not the case. Due to the serial nature of the WUs for each Run and Clone trajectory, timely receipt of the WU return is expected so the next Gen can be created from the results and sent out to be processed. If the WU has reached the deadline, by then someone else has already been assigned the WU and probably returned it. So further processing by you would be a waste. Creating a major change in coding to cover the occasional exceptionally slow processing WU and dump it earlier for another would be costly in developer time.
In your case it appears some unnamed project or projects are taking longer on your hardware than normal for most other systems. That could be from a misconfiguration on your part, a misclassification of the hardware within F@h, or a combination of both. But since you have just provided a complaint without supporting information, what and where the problem is has no chance of being determined or corrected.
promeneur
How to join a log (400 lines) ?
Use the forum Full Editor, select the Code display - just to the right of the Quote, and copy and paste the section of log between the [code] [/code] tags that will be placed in your post. You can leave out lines that just indicate percent of continuing progress to reduce the size if necessary.
promeneur
*********************** Log Started 2022-11-08T07:26:59Z ***********************
07:26:59:******************************* libFAH ********************************
07:26:59: Date: Oct 20 2020
07:26:59: Time: 20:36:41
07:26:59: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
07:26:59: Branch: master
07:26:59: Compiler: GNU 4.9.4
07:26:59: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
07:26:59: -O3 -funroll-loops
07:26:59: Platform: linux2 5.8.0-1-amd64
07:26:59: Bits: 64
07:26:59: Mode: Release
07:26:59:****************************** FAHClient ******************************
07:26:59: Version: 7.6.21
07:26:59: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:26:59: Copyright: 2020 foldingathome.org
07:26:59: Homepage: https://foldingathome.org/
07:26:59: Time: 20:38:59
07:26:59: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
07:26:59: Bits: 64
07:26:59: Args: /etc/fahclient/config.xml
07:26:59: --pid-file=/run/fahclient/fahclient.pid
07:26:59: Config: /etc/fahclient/config.xml
07:26:59:******************************** CBang ********************************
07:26:59: Time: 18:38:01
07:26:59: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
07:26:59: -O3 -funroll-loops -fPIC
07:26:59: Bits: 64
07:26:59:******************************* System ********************************
07:26:59: CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:26:59: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:26:59: CPUs: 4
07:26:59: Memory: 15.50GiB
07:26:59: Free Memory: 13.91GiB
07:26:59: Threads: POSIX_THREADS
07:26:59: OS Version: 6.0
07:26:59: Has Battery: false
07:26:59: On Battery: false
07:26:59: UTC Offset: 1
07:26:59: PID: 2475
07:26:59: CWD: /var/lib/fahclient
07:26:59: OS: Linux 6.0.7-1-default x86_64
07:26:59: OS Arch: AMD64
07:26:59: GPUs: 2
07:26:59: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
07:26:59: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce GT 1030]
07:26:59: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.7
07:26:59:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:515.76
07:26:59:***********************************************************************
07:26:59:<config>
07:26:59: <!-- Network -->
07:26:59: <proxy v=':8080'/>
07:26:59:
07:26:59: <!-- Slot Control -->
07:26:59: <power v='FULL'/>
07:26:59:
07:26:59: <!-- User Information -->
07:26:59: <passkey v='*****'/>
07:26:59: <team v='51'/>
07:26:59: <user v='philippe_roubach'/>
07:26:59:
07:26:59: <!-- Folding Slots -->
07:26:59: <slot id='0' type='CPU'>
07:26:59: <cpus v='3'/>
07:26:59: </slot>
07:26:59: <slot id='2' type='GPU'>
07:26:59: <pci-bus v='1'/>
07:26:59: <pci-slot v='0'/>
07:26:59: </slot>
07:26:59: <slot id='1' type='GPU'>
07:26:59: <paused v='true'/>
07:26:59: <pci-bus v='0'/>
07:26:59: <pci-slot v='2'/>
07:26:59: </slot>
07:26:59:</config>
07:26:59:Trying to access database...
07:26:59:Successfully acquired database lock
07:26:59:FS00:Initialized folding slot 00: cpu:3
07:26:59:FS02:Initialized folding slot 02: gpu:1:0 GP108 [GeForce GT 1030]
07:26:59:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 KBL GT2 [HD Graphics 630]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
07:26:59:WU01:FS02:Starting
07:26:59:WU01:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 2475 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
07:26:59:WU01:FS02:Started FahCore on PID 2534
07:26:59:WU01:FS02:Core PID:2538
07:26:59:WU01:FS02:FahCore 0x22 started
07:26:59:WU02:FS00:Starting
07:26:59:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 2475 -checkpoint 15 -np 3
07:26:59:WU02:FS00:Started FahCore on PID 2539
07:26:59:WU02:FS00:Core PID:2543
07:26:59:WU02:FS00:FahCore 0xa8 started
07:26:59:WU02:FS00:0xa8:*********************** Log Started 2022-11-08T07:26:59Z ***********************
07:26:59:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
07:26:59:WU02:FS00:0xa8: Core: Gromacs
07:26:59:WU02:FS00:0xa8: Type: 0xa8
07:26:59:WU02:FS00:0xa8: Version: 0.0.12
07:26:59:WU02:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:26:59:WU02:FS00:0xa8: Copyright: 2020 foldingathome.org
07:26:59:WU02:FS00:0xa8: Homepage: https://foldingathome.org/
07:26:59:WU02:FS00:0xa8: Date: Jan 16 2021
07:26:59:WU02:FS00:0xa8: Time: 19:24:44
07:26:59:WU02:FS00:0xa8: Compiler: GNU 8.3.0
07:26:59:WU02:FS00:0xa8: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
07:26:59:WU02:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie
07:26:59:WU02:FS00:0xa8: Platform: linux2 4.15.0-128-generic
07:26:59:WU02:FS00:0xa8: Bits: 64
07:26:59:WU02:FS00:0xa8: Mode: Release
07:26:59:WU02:FS00:0xa8: SIMD: avx2_256
07:26:59:WU02:FS00:0xa8: OpenMP: ON
07:26:59:WU02:FS00:0xa8: CUDA: OFF
07:26:59:WU02:FS00:0xa8: Args: -dir 02 -suffix 01 -version 706 -lifeline 2539 -checkpoint 15 -np 3
07:26:59:WU02:FS00:0xa8:************************************ libFAH ************************************
07:26:59:WU02:FS00:0xa8: Time: 19:21:38
07:26:59:WU02:FS00:0xa8:************************************ CBang *************************************
07:26:59:WU02:FS00:0xa8: Time: 19:21:24
07:26:59:WU02:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:26:59:WU02:FS00:0xa8:************************************ System ************************************
07:26:59:WU02:FS00:0xa8: CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:26:59:WU02:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:26:59:WU02:FS00:0xa8: CPUs: 4
07:26:59:WU02:FS00:0xa8: Memory: 15.50GiB
07:26:59:WU02:FS00:0xa8:Free Memory: 13.77GiB
07:26:59:WU02:FS00:0xa8: Threads: POSIX_THREADS
07:26:59:WU02:FS00:0xa8: OS Version: 6.0
07:26:59:WU02:FS00:0xa8:Has Battery: false
07:26:59:WU02:FS00:0xa8: On Battery: false
07:26:59:WU02:FS00:0xa8: UTC Offset: 1
07:26:59:WU02:FS00:0xa8: PID: 2543
07:26:59:WU02:FS00:0xa8: CWD: /var/lib/fahclient/work
07:26:59:WU02:FS00:0xa8:********************************************************************************
07:26:59:WU02:FS00:0xa8:Project: 16977 (Run 5, Clone 374, Gen 34)
07:26:59:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
07:26:59:WU02:FS00:0xa8:Digital signatures verified
07:26:59:WU02:FS00:0xa8:Calling: mdrun -c frame34.gro -s frame34.tpr -x frame34.xtc -cpi state.cpt -cpt 15 -nt 3 -ntmpi 1
07:26:59:WU02:FS00:0xa8:Steps: first=85000000 total=87500000
07:26:59:WU01:FS02:0x22:*********************** Log Started 2022-11-08T07:26:59Z ***********************
07:26:59:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:26:59:WU01:FS02:0x22: Core: Core22
07:26:59:WU01:FS02:0x22: Type: 0x22
07:26:59:WU01:FS02:0x22: Version: 0.0.20
07:26:59:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:26:59:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
07:26:59:WU01:FS02:0x22: Homepage: https://foldingathome.org/
07:26:59:WU01:FS02:0x22: Date: Jan 20 2022
07:26:59:WU01:FS02:0x22: Time: 00:57:52
07:26:59:WU01:FS02:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:26:59:WU01:FS02:0x22: Branch: HEAD
07:26:59:WU01:FS02:0x22: Compiler: GNU 9.4.0
07:26:59:WU01:FS02:0x22: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
07:26:59:WU01:FS02:0x22: -fdata-sections -O3 -funroll-loops -fno-pie
07:26:59:WU01:FS02:0x22: -DOPENMM_VERSION="\"7.7.0\""
07:26:59:WU01:FS02:0x22: Platform: linux 5.11.0-1025-azure
07:26:59:WU01:FS02:0x22: Bits: 64
07:26:59:WU01:FS02:0x22: Mode: Release
07:26:59:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:26:59:WU01:FS02:0x22: <peastman@stanford.edu>
07:26:59:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 2534 -checkpoint 15
07:26:59:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
07:26:59:WU01:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
07:26:59:WU01:FS02:0x22:************************************ libFAH ************************************
07:26:59:WU01:FS02:0x22: Time: 00:57:22
07:26:59:WU01:FS02:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:26:59:WU01:FS02:0x22:************************************ CBang *************************************
07:26:59:WU01:FS02:0x22: Time: 00:57:00
07:26:59:WU01:FS02:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:26:59:WU01:FS02:0x22: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:26:59:WU01:FS02:0x22:************************************ System ************************************
07:26:59:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:26:59:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:26:59:WU01:FS02:0x22: CPUs: 4
07:26:59:WU01:FS02:0x22: Memory: 15.50GiB
07:26:59:WU01:FS02:0x22:Free Memory: 13.74GiB
07:26:59:WU01:FS02:0x22: Threads: POSIX_THREADS
07:26:59:WU01:FS02:0x22: OS Version: 6.0
07:26:59:WU01:FS02:0x22:Has Battery: false
07:26:59:WU01:FS02:0x22: On Battery: false
07:26:59:WU01:FS02:0x22: UTC Offset: 1
07:26:59:WU01:FS02:0x22: PID: 2538
07:26:59:WU01:FS02:0x22: CWD: /var/lib/fahclient/work
07:26:59:WU01:FS02:0x22:************************************ OpenMM ************************************
07:26:59:WU01:FS02:0x22: Version: 7.7.0
07:26:59:WU01:FS02:0x22:********************************************************************************
07:26:59:WU01:FS02:0x22:Project: 18450 (Run 3, Clone 88, Gen 49)
07:26:59:WU01:FS02:0x22:Digital signatures verified
07:26:59:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:26:59:WU01:FS02:0x22:Version 0.0.20
07:26:59:WU01:FS02:0x22: Checkpoint write interval: 50000 steps (2%) [50 total]
07:26:59:WU01:FS02:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
07:26:59:WU01:FS02:0x22: XTC frame write interval: 2500000 steps (1e+02%) [1 total]
07:26:59:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
07:26:59:WU01:FS02:0x22:There are 4 platforms available.
07:26:59:WU01:FS02:0x22:Platform 0: Reference
07:26:59:WU01:FS02:0x22:Platform 1: CPU
07:26:59:WU01:FS02:0x22:Platform 2: OpenCL
07:26:59:WU01:FS02:0x22: opencl-device 0 specified
07:26:59:WU01:FS02:0x22:Platform 3: CUDA
07:26:59:WU01:FS02:0x22: cuda-device 0 specified
07:27:00:WU02:FS00:0xa8:Completed 2153802 out of 2500000 steps (86%)
07:27:08:WU01:FS02:0x22:Attempting to create CUDA context:
07:27:08:WU01:FS02:0x22: Configuring platform CUDA
07:27:22:WU01:FS02:0x22: Using CUDA and gpu 0
07:27:22:WU01:FS02:0x22:Completed 1250000 out of 2500000 steps (50%)
07:44:12:WU02:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
08:01:29:WU02:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
08:02:58:WU01:FS02:0x22:Completed 1275000 out of 2500000 steps (51%)
08:18:27:WU02:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
08:35:25:WU02:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
08:40:05:WU01:FS02:0x22:Completed 1300000 out of 2500000 steps (52%)
08:40:10:WU01:FS02:0x22:Checkpoint completed at step 1300000
08:52:05:WU02:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
09:09:14:WU02:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
09:16:57:WU01:FS02:0x22:Completed 1325000 out of 2500000 steps (53%)
09:26:18:WU02:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
09:37:46:WARNING:15:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_highlight-soft_75_cccccc_1x100.png
09:37:46:WARNING:20:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_55_fbf9ee_1x400.png
09:37:47:WARNING:23:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_95_fef1ec_1x400.png
09:37:47:WARNING:24:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_222222_256x240.png
09:37:47:WARNING:27:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_2e83ff_256x240.png
09:37:47:WARNING:28:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_cd0a0a_256x240.png
09:37:47:29:127.0.0.1:New Web session
09:43:37:WU02:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
09:46:25:WARNING:WU01:FS02:Past final deadline 2022-11-08T09:46:24Z, dumping
09:46:25:WU01:FS02:Shutting core down
09:46:25:WU01:FS02:0x22:Caught signal SIGINT(2) on PID 2538
09:46:25:WU01:FS02:0x22:Exiting, please wait. . .
09:46:25:WU01:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
09:46:25:WU00:FS02:Connecting to assign1.foldingathome.org:80
09:46:26:WU00:FS02:Assigned to work server 206.223.170.146
09:46:26:WU00:FS02:Requesting new work unit for slot 02: gpu:1:0 GP108 [GeForce GT 1030] from 206.223.170.146
09:46:26:WU00:FS02:Connecting to 206.223.170.146:8080
09:46:26:WU00:FS02:Downloading 22.07MiB
09:46:30:WU00:FS02:Download complete
09:46:30:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18601 run:14521 clone:2 gen:10 core:0x22 unit:0x000000020000000a000048a9000038b9
09:46:30:WU00:FS02:Starting
09:46:30:WU00:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 2475 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
09:46:30:WU00:FS02:Started FahCore on PID 28782
09:46:30:WU00:FS02:Core PID:28786
09:46:30:WU00:FS02:FahCore 0x22 started
09:46:31:WU00:FS02:0x22:*********************** Log Started 2022-11-08T09:46:30Z ***********************
09:46:31:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
09:46:31:WU00:FS02:0x22: Core: Core22
09:46:31:WU00:FS02:0x22: Type: 0x22
09:46:31:WU00:FS02:0x22: Version: 0.0.20
09:46:31:WU00:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:46:31:WU00:FS02:0x22: Copyright: 2020 foldingathome.org
09:46:31:WU00:FS02:0x22: Homepage: https://foldingathome.org/
09:46:31:WU00:FS02:0x22: Date: Jan 20 2022
09:46:31:WU00:FS02:0x22: Time: 00:57:52
09:46:31:WU00:FS02:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
09:46:31:WU00:FS02:0x22: Branch: HEAD
09:46:31:WU00:FS02:0x22: Compiler: GNU 9.4.0
09:46:31:WU00:FS02:0x22: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
09:46:31:WU00:FS02:0x22: -fdata-sections -O3 -funroll-loops -fno-pie
09:46:31:WU00:FS02:0x22: -DOPENMM_VERSION="\"7.7.0\""
09:46:31:WU00:FS02:0x22: Platform: linux 5.11.0-1025-azure
09:46:31:WU00:FS02:0x22: Bits: 64
09:46:31:WU00:FS02:0x22: Mode: Release
09:46:31:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:46:31:WU00:FS02:0x22: <peastman@stanford.edu>
09:46:31:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 28782 -checkpoint 15
09:46:31:WU00:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
09:46:31:WU00:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
09:46:31:WU00:FS02:0x22:************************************ libFAH ************************************
09:46:31:WU00:FS02:0x22: Time: 00:57:22
09:46:31:WU00:FS02:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
09:46:31:WU00:FS02:0x22:************************************ CBang *************************************
09:46:31:WU00:FS02:0x22: Time: 00:57:00
09:46:31:WU00:FS02:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
09:46:31:WU00:FS02:0x22: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
09:46:31:WU00:FS02:0x22:************************************ System ************************************
09:46:31:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
09:46:31:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:46:31:WU00:FS02:0x22: CPUs: 4
09:46:31:WU00:FS02:0x22: Memory: 15.50GiB
09:46:31:WU00:FS02:0x22:Free Memory: 994.05MiB
09:46:31:WU00:FS02:0x22: Threads: POSIX_THREADS
09:46:31:WU00:FS02:0x22: OS Version: 6.0
09:46:31:WU00:FS02:0x22:Has Battery: false
09:46:31:WU00:FS02:0x22: On Battery: false
09:46:31:WU00:FS02:0x22: UTC Offset: 1
09:46:31:WU00:FS02:0x22: PID: 28786
09:46:31:WU00:FS02:0x22: CWD: /var/lib/fahclient/work
09:46:31:WU00:FS02:0x22:************************************ OpenMM ************************************
09:46:31:WU00:FS02:0x22: Version: 7.7.0
09:46:31:WU00:FS02:0x22:********************************************************************************
09:46:31:WU00:FS02:0x22:Project: 18601 (Run 14521, Clone 2, Gen 10)
09:46:31:WU00:FS02:0x22:Reading tar file core.xml
09:46:31:WU00:FS02:0x22:Reading tar file integrator.xml
09:46:31:WU00:FS02:0x22:Reading tar file state.xml.bz2
09:46:31:WU00:FS02:0x22:Reading tar file system.xml.bz2
09:46:31:WU00:FS02:0x22:Digital signatures verified
09:46:31:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
09:46:31:WU00:FS02:0x22:Version 0.0.20
09:46:31:WU00:FS02:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
09:46:31:WU00:FS02:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
09:46:31:WU00:FS02:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
09:46:31:WU00:FS02:0x22: Global context and integrator variables write interval: disabled
09:46:31:WU00:FS02:0x22:There are 4 platforms available.
09:46:31:WU00:FS02:0x22:Platform 0: Reference
09:46:31:WU00:FS02:0x22:Platform 1: CPU
09:46:31:WU00:FS02:0x22:Platform 2: OpenCL
09:46:31:WU00:FS02:0x22: opencl-device 0 specified
09:46:31:WU00:FS02:0x22:Platform 3: CUDA
09:46:31:WU00:FS02:0x22: cuda-device 0 specified
09:47:04:WU00:FS02:0x22:Attempting to create CUDA context:
09:47:04:WU00:FS02:0x22: Configuring platform CUDA
09:47:25:WU01:FS02:Cleaning up
09:47:56:WU00:FS02:0x22: Using CUDA and gpu 0
09:47:56:WU00:FS02:0x22:Completed 0 out of 1250000 steps (0%)
09:48:15:WU00:FS02:0x22:Checkpoint completed at step 0
10:01:43:WU02:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
10:02:25:82:127.0.0.1:New Web session
10:02:26:WARNING:85:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_highlight-soft_75_cccccc_1x100.png
10:02:27:WARNING:95:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_55_fbf9ee_1x400.png
10:02:27:WARNING:96:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-bg_glass_95_fef1ec_1x400.png
10:02:27:WARNING:97:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_222222_256x240.png
10:02:27:WARNING:100:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_2e83ff_256x240.png
10:02:28:WARNING:103:127.0.0.1:404 HTTP NOT FOUND /css/images/ui-icons_cd0a0a_256x240.png
Your GT 1030 appears to have been misclassified, it is in the same group of GPUs such as high end cards like the GTX 980. I have put in a request that its GPUs.txt entry be changed. Once that is done the GT 1030 and similar cards should get smaller sized projects.
promeneur
