FAH V 8.0.1
Akeron
FAH V 8.0.1
Post by Akeron »
Hey guys just wondering about this v8 installer in the beta section. I used it and it uninstalled the Old software, installed some new stuff but appears to be a web based client..... doesn't seem to connect though. Anyone else tried it or knows what's up with it?
thanks
Ak
Re: FAH V 8.0.1
What is the link to this beta version download? I don't see anything at - https://foldingathome.org/beta/ - to download.
What I can say is that 8.0.1 was an early test client, it was buggy, and was pulled from internal testing after a short period of testing. It shouldn't be available for download at all. Work is being done on V8, but it is not ready for putting out for beta testing. When it is ready for public beta testing there will be an announcement.
At this point there is just a web interface, no separate control app like FAHControl. The actual client software was installed elsewhere on your system. As for the web interface not connecting, that would be over a local network connection on your system so could be blocked by anti-malware or firewall settings.
I recommend uninstalling this version and reinstalling 7.6.21. You may want to keep the older config.xml files around for copying in the settings info, 7.6.21 may nt be able to read that from the 8.0.1 config.
Akeron
Re: FAH V 8.0.1
Post by Akeron »
Hi Joe,
It is here:
https://download.foldingathome.org/rele ... l/release/
sorry for trying so hard to get the newest client :)
thanks for the info
Re: FAH V 8.0.1
It's definitely not ready to be used ... :(
Akeron
Re: FAH V 8.0.1
Post by Akeron »
Yeah, sorry I just got excited. I thought maaaaaaybe it brings GPU computing to the Mac client so my little 2019 Mac Pro can party! (little cause it is almost 2023 :(
Re: FAH V 8.0.1
Post by calxalot »
Definitely No GPU folding on osx at this time.
You should stick with v7.
Your web browser could not connect probably because you were using Safari.
Re: FAH V 8.0.1
Post by calxalot »
Although the downloads url has beta in it, those are all alpha builds.
Akeron
Re: FAH V 8.0.1
Post by Akeron »
I tried Chrome first but same thing. Anyways, like you said... alpha or beta, there's a reason why.
this is why I thought there was GPU support:
Not a U8 is in red :(
21:23:05:I1:Opening Database
21:23:05:I1:Listening for HTTP on 127.0.0.1:7396
21:23:05:I3:id = hfkN/qHYAn4UY+XKlxolARCiDfARnSBKdCILxjUW0Vs=
21:23:05:I3:Loading work unit 4F1creSwEFUn31tRKK5bPxs8NMU4nGsk3RoAHQRoAjU
21:23:05:I3:Loaded 1 wus.
21:23:05:I3:Adding GPU gpu:09:00:00
21:23:05:I3:gpus = {
21:23:05:I3: "gpu:09:00:00": {"type": "amd", "description": "Vega 20"}
21:23:05:I3:}
21:23:05:I1:Downloading https://cores.foldingathome.org/fahcore ... ar.bz2.crt
21:23:05:I1:OUT1:> GET https://cores.foldingathome.org/fahcore ... ar.bz2.crt HTTP/1.1
21:23:05:I3:Connecting to cores.foldingathome.org:443
21:23:05:I1:OUT1:< cores.foldingathome.org:443 HTTP/1.1 200 OK
21:23:05:I1:Downloading https://cores.foldingathome.org/fahcore ... ar.bz2.sig
21:23:05:I1:OUT2:> GET https://cores.foldingathome.org/fahcore ... ar.bz2.sig HTTP/1.1
21:23:05:I1:OUT2:< cores.foldingathome.org:443 HTTP/1.1 200 OK
21:23:05:I1:Downloading https://cores.foldingathome.org/fahcore ... 12.tar.bz2
21:23:05:I1:OUT3:> GET https://cores.foldingathome.org/fahcore ... 12.tar.bz2 HTTP/1.1
21:23:06:I1:OUT3:< cores.foldingathome.org:443 HTTP/1.1 200 OK
21:23:06:E :Exception: Not a U8
Re: FAH V 8.0.1
Post by calxalot »
Alpha builds, by definition, are full of bugs and experimental features.
I encourage you to at least wait for beta.
Akeron
Re: FAH V 8.0.1
Post by Akeron »
That's what I said.... also what I did was download from the "beta" folder a file that was not labeled "alpha" or "a" :twisted:
Re: FAH V 8.0.1
Post by calxalot »
Ah, understood. I don’t disagree.
