Running a GPU WU on a Mac Studio
My apologies in advance if this is a stupid question, but is it possible to run an FAH slot using the GPU on a Mac Studio? I have tried to add a slot for a GPU, and although the client allows me to do so, it never executes a WU. My Mac Studio has an M1 Max SoC, with a 32-core GPU, but, obviously, not a separate/dedicated GPU card.
Best regards,
Mike Potter
Best regards,
Mike Potter
Re: Running a GPU WU on a Mac Studio
Welcome to Folding@Home!
For a long time the MacOS had a driver bug preventing OpenCL from working.
Shortly after they fixed it, they depreciated OpenCL in favor of metal.
Currently, only AMD and Nvidia have written GPU code for F@H, but if Apple wrote a Core for folding, I bet F@H would issue Work Units for it.
That said, Linux does not have the OpenCL issues, so a Mac with an AMD or Nvidia GPU wanted to fold, Linux might be the answer.
That OpenCL bug was the beginning of a string of obstacles towards getting a working GPU folding solution for Mac's. Apple took 2-3 years before fixing the bug in their OpenCL implementation and releasing it in a software update. The bug also affected other software development doing number crunching on GPUs under the macOS besides F@h. By the time the fix was out, almost no Mac's were sold with suitable GPUs for folding, and almost all older GPUs were no longer usable. F@h ended up not expending developer time to create a GPU folding core for use by a small number of systems out there such as Mac Pros upgraded with third party AMD or Nvidia cards.
There is still some interest in getting GPU folding on macOS. Either support for Metal would need to be added to GROMACS or OpenMM, or a core would have to be created using the available OpenCL support. While deprecated, Apple still supports OpenCL including for GPU processing on M1 and M2 Mac's. I don't have any information though on progress towards that happening.
Thank you both for your replies, I greatly appreciate it!
I also appreciate the background history leading to no gpu support for Macs. My Mac Pro (2019) has a Radeon Pro Vega II with a lot of processing power which often just sits, and I have wondered why fah does not use it. I am pleased to hear there is still interest in getting f@h running on Mac gpus.
randoPrime
Is it possible to utilize the GPUs on an M1 Mac if I was to install Linux or Windows? Is it the MacOS software specifically that is keeping the GPU cores from folding?
The macOS is not the only thing keeping GPU cores from folding. They would still need to create a folding core to utilize the M1 integrated GPU. An obstacle that came up for someone investigating utilizing the M1 iGPU was that the normal client method of identifying a GPU being present - checking for a PCI ID - doesn't work.randoPrime wrote: ↑Fri Jan 06, 2023 4:44 pm Is it possible to utilize the GPUs on an M1 Mac if I was to install Linux or Windows? Is it the MacOS software specifically that is keeping the GPU cores from folding?
I also haven't been keeping in touch with the progress of creating an Apple Silicon port of Linux to run on recent Mac hardware. At this point all I can say is that some investigation into using the newer hardware from Apple is being done, no idea if it will make it to a release that will also include the GPU. They did compile a native code version of the CPU folding core, that replaced the version that was Intel code running in Rosetta2.
MaineDPCdoc
For what it's worth, the BOINC project PrimeGrid now can use Mac M1 and M2 GPUs for distributed computing.
I'm trying it on my M2 MBA and it seems to work well. Based on the task names, it appears they are using OpenCL, not Metal. I imagine a Mac Studio would scream through GPU tasks compared to my fanless MBA.
https://www.primegrid.com/forum_thread. ... 207#161570
https://developer.apple.com/forums/thread/694866
https://www.reddit.com/r/BOINC/comments ... wto_guide/
Just a note that the responses in the Apple forum that Apple doesn't have anything posted on OpenCL are not correct. There are several places where Apple has posted variations of the following:
This still applies to macOS Ventura, though a few months ago I did come across a post claiming one of the updates broke OpenCL usage. Didn't have anything to test that out with, so consider that claim as unverified.OpenGL is deprecated, but is available on Apple silicon.
OpenCL is deprecated, but is available on Apple silicon when targeting the GPU. The OpenCL CPU device is not available to arm64 apps.
What user does PrimeGrid GPU run as? Does it need to run as the logged in user, or can an unprivileged daemon access the GPU?
MaineDPCdoc
Any updates to native Apple Silicon Support for CPU folding? Is the new client still being worked on? M2 Mac Studio on Rosetta 2 pumping out 500k PPD currently...
If you meant GPU folding which this topic is about, no updates. As for CPU folding the current CPU folding core is Apple native code, not Intel running under Rosetta 2. Development on the v7 client has ended, it never received an Apple native release. But the client uses little CPU time, so that is not an issue. The v8 public Beta client is native and uses the same CPU folding cores as v7. So on your system if you check in Activity Monitor you should see the CPU folding core is listed as "Apple", not "Intel", for kind of processing. That is where almost all of the CPU usage by F@h will be.
I have a M1 Max Mac Studio putting out about 260K for PPD using 6 cores, keep the rest available for my usage in other apps.
Thank you very much for your kind reply, @Joe_H!
As I'm new on Mac, I still have to learn how things work in detail. However, it at least seams to me as if FahCore_a8 uses x86-Code (Intel/AMD), which has to be translated via Rosetta 2 for macOS on Apple Silicon. Here a snippet from the process analysis:
Do I look at the wrong process, maybe I misunderstood you?
Here is a screenshot from the process explorer:
https://www.dropbox.com/scl/fi/uazkbps0 ... jjvk6&dl=0
Analysis of sampling FahCore_a8 (pid 4760) every 1 millisecond
Process: FahCore_a8 [4760]
Path: /Library/Application Support/FAHClient/*/FahCore_a8
Load Address: 0x1028a7000
Identifier: FahCore_a8
Version: ???
Code Type: X86-64 (translated)
Platform: macOS
Parent Process: FAHCoreWrapper [4759]Here is a screenshot from the process explorer:
It looks like you are sampling the correct process, it is possible the WU specified an older version of Core_A8 than is running on my Mac Studio at the moment. Here is the same section from a sample report I just did:
Looking at the log for the running WU, it shows version 0.0.12 of the Core_A8. The other possibility is that the client and server misidentified which core was needed for the newer M2 processor and downloaded the Intel version for macOS instead go the ARM64 one.
Analysis of sampling FahCore_a8 (pid 25594) every 1 millisecond
Process: FahCore_a8 [25594]
Load Address: 0x100a90000
Version: 0
Code Type: ARM64
Platform: macOS
Parent Process: fah-client [337]
