Unable to get any work units on 2 machines
MiniMiner
Post by MiniMiner »
Hello all.
I have been folding for about a year but the last week has caused me huge problems. I run two PC's usually with no issues.
About 7 days ago my main PC was no longer able to download a work unit and still was unable to after 248 attempts and 5 days later i decided to turn it off. Then 2 days ago my second PC was unable to download work units but succeeded in uploading the last completed unit. I have tried everything I can think of with reinstalling apps, checking the ports werent being blocked by the router, replaced wireless adapter. Still nothing.
If I open my web browser and try to connect to assign1.foldingathome.org it fails 100% of the time. Then assign2.foldingathome.org is very intermittent, sometimes it loads the webpage correctly but its usually erroring out with "The site cannot be reached - ERR_CONNECTION_RESET" 8/10 times.
My log is pretty much the same on both PC's but here it is. If anyone could help Id really apprechiate it because I dont want to give up on F@H :e(
21:10:39: <!-- Folding Slots -->
21:10:39: <slot id='0' type='CPU'>
21:10:39: <cpus v='3'/>
21:10:39: </slot>
21:10:39:</config>
21:11:05:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:11:05:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:11:24:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:11:24:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:11:44:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:11:44:ERROR:WU00:FS00:Exception: Could not get an assignment
21:11:45:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:12:15:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:12:15:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:12:34:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:12:34:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:12:53:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:12:53:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:13:24:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:13:24:ERROR:WU00:FS00:Exception: Could not get an assignment
21:13:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:13:43:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:13:43:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:14:03:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:14:03:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:14:22:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:14:22:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:14:41:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:14:41:ERROR:WU00:FS00:Exception: Could not get an assignment
21:16:02:WU00:FS00:Connecting to assign1.foldingathome.org:80
21:16:33:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:16:33:WU00:FS00:Connecting to assign2.foldingathome.org:80
21:16:52:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:16:52:WU00:FS00:Connecting to assign3.foldingathome.org:80
21:17:11:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:17:11:WU00:FS00:Connecting to assign4.foldingathome.org:80
21:17:30:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': 10002: Received short response, expected 272 bytes, got 0
21:17:30:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: Unable to get any work units on 2 machines
Messages that you failed to get an assignment with the "Received short response" error message indicates something is blocking network packets from getting back to your PCs. This can be local on the PC from the action of anti-malware or firewalls active on them, or from settings on your router. Between your network and the servers this can also be done by ISP routers or institutional firewalls. One of the more common blockings is HTTP packets for apps not on a recognized list of browsers such as Edge, Firefox, Chrome or Safari. Exceptions can be added to firewall and other settings to allow HTTP packets to go to the FAHClient process.
MiniMiner
Post by MiniMiner »
Strangely after i posted this it started working. I decided to install it on my windows tablet just to see if there was something affecting it. I reset my router and powerline adapters then opened F@H on my tablet (PC 3) .. this immediately downloaded a work unit. Came back to check PC 1 and PC2 a few hours later.. Both PC1 and PC2 are suddernly 50% + through a block. I guess the error was fixed by resetting my network fully by resetting the router and all my powerline adapters. Thank you for the response Joe!
So strange to start working perfectly again once assign1.foldingathome.org came back online but either way I'm happy I can F@H again :)
MiniMiner
Post by MiniMiner »
This was the end result in my log.. it defo seems like it was my router as it went from no response, to unable to find IP address during the reset. Then downloaded immediately upon router fully rebooting, I only tried this since I noticed random 'access denied' logs in my router's system log. After i checked the IP address i realised the router was rejecting one of my powerline adapters data requests (which ofcourse turned out being the powerline adapter both PC's were connected to),
22:36:50:ERROR:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
22:54:47:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:54:47:WU00:FS00:Assigned to work server 129.32.209.204
22:54:47:WU00:FS00:Requesting new work unit for slot 00: cpu:3 from 129.32.209.204
22:54:47:WU00:FS00:Connecting to 129.32.209.204:8080
22:54:48:WU00:FS00:Downloading 458.50KiB
22:54:48:WU00:FS00:Download complete
22:54:48:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16995 run:61 clone:48 gen:151 core:0xa8 unit:0x0000003000000097000042630000003d
22:54:49:WU00:FS00:Starting
22:54:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 6808 -checkpoint 15 -np 3
22:54:49:WU00:FS00:Started FahCore on PID 5624
22:54:49:WU00:FS00:Core PID:1436
22:54:49:WU00:FS00:FahCore 0xa8 started
22:54:49:WU00:FS00:0xa8:*********************** Log Started 2022-10-27T22:54:49Z ***********************
22:54:49:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
22:54:49:WU00:FS00:0xa8: Core: Gromacs
22:54:49:WU00:FS00:0xa8: Type: 0xa8
22:54:49:WU00:FS00:0xa8: Version: 0.0.12
22:54:49:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:54:49:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
22:54:49:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
22:54:49:WU00:FS00:0xa8: Date: Jan 16 2021
22:54:49:WU00:FS00:0xa8: Time: 11:56:07
22:54:49:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
22:54:49:WU00:FS00:0xa8: Branch: master
22:54:49:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
22:54:49:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:54:49:WU00:FS00:0xa8: Platform: win32 10
22:54:49:WU00:FS00:0xa8: Bits: 64
22:54:49:WU00:FS00:0xa8: Mode: Release
22:54:49:WU00:FS00:0xa8: SIMD: avx_256
22:54:49:WU00:FS00:0xa8: OpenMP: ON
22:54:49:WU00:FS00:0xa8: CUDA: OFF
22:54:49:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 5624 -checkpoint 15 -np 3
22:54:49:WU00:FS00:0xa8:************************************ libFAH ************************************
22:54:49:WU00:FS00:0xa8: Time: 11:24:13
22:54:49:WU00:FS00:0xa8:************************************ CBang *************************************
22:54:49:WU00:FS00:0xa8: Time: 11:23:53
22:54:49:WU00:FS00:0xa8:************************************ System ************************************
22:54:49:WU00:FS00:0xa8: CPU: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
22:54:49:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
22:54:49:WU00:FS00:0xa8: CPUs: 4
22:54:49:WU00:FS00:0xa8: Memory: 7.83GiB
22:54:49:WU00:FS00:0xa8:Free Memory: 5.51GiB
22:54:49:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
22:54:49:WU00:FS00:0xa8: OS Version: 6.2
22:54:49:WU00:FS00:0xa8:Has Battery: false
22:54:49:WU00:FS00:0xa8: On Battery: false
22:54:49:WU00:FS00:0xa8: UTC Offset: 1
22:54:49:WU00:FS00:0xa8: PID: 1436
22:54:49:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
22:54:49:WU00:FS00:0xa8:********************************************************************************
22:54:49:WU00:FS00:0xa8:Project: 16995 (Run 61, Clone 48, Gen 151)
22:54:49:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
22:54:49:WU00:FS00:0xa8:Reading tar file core.xml
22:54:49:WU00:FS00:0xa8:Reading tar file frame151.tpr
22:54:49:WU00:FS00:0xa8:Digital signatures verified
22:54:49:WU00:FS00:0xa8:Calling: mdrun -c frame151.gro -s frame151.tpr -x frame151.xtc -cpt 15 -nt 3 -ntmpi 1
22:54:49:WU00:FS00:0xa8:Steps: first=0 total=5000000
22:54:49:WU00:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
22:59:42:WU00:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
23:04:35:WU00:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
23:09:27:WU00:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
23:14:21:WU00:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
23:19:13:WU00:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
23:24:06:WU00:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
23:28:58:WU00:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
23:33:50:WU00:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
23:38:43:WU00:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
23:43:36:WU00:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
23:48:29:WU00:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
23:53:21:WU00:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
23:58:14:WU00:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
00:03:07:WU00:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
00:07:59:WU00:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
00:12:52:WU00:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
00:17:45:WU00:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
00:22:37:WU00:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
00:27:29:WU00:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
00:32:22:WU00:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
00:37:14:WU00:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
00:42:07:WU00:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
00:46:59:WU00:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
00:51:51:WU00:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
00:56:44:WU00:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
01:01:36:WU00:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
01:06:28:WU00:FS00:0xa8:Completed 1350000 out of 5000000 steps (27%)
01:11:21:WU00:FS00:0xa8:Completed 1400000 out of 5000000 steps (28%)
01:16:13:WU00:FS00:0xa8:Completed 1450000 out of 5000000 steps (29%)
01:21:06:WU00:FS00:0xa8:Completed 1500000 out of 5000000 steps (30%)
01:25:59:WU00:FS00:0xa8:Completed 1550000 out of 5000000 steps (31%)
01:30:51:WU00:FS00:0xa8:Completed 1600000 out of 5000000 steps (32%)
01:35:44:WU00:FS00:0xa8:Completed 1650000 out of 5000000 steps (33%)
01:40:37:WU00:FS00:0xa8:Completed 1700000 out of 5000000 steps (34%)
01:45:30:WU00:FS00:0xa8:Completed 1750000 out of 5000000 steps (35%)
01:50:22:WU00:FS00:0xa8:Completed 1800000 out of 5000000 steps (36%)
01:55:15:WU00:FS00:0xa8:Completed 1850000 out of 5000000 steps (37%)
02:00:07:WU00:FS00:0xa8:Completed 1900000 out of 5000000 steps (38%)
02:04:59:WU00:FS00:0xa8:Completed 1950000 out of 5000000 steps (39%)
02:09:52:WU00:FS00:0xa8:Completed 2000000 out of 5000000 steps (40%)
02:14:45:WU00:FS00:0xa8:Completed 2050000 out of 5000000 steps (41%)
02:19:37:WU00:FS00:0xa8:Completed 2100000 out of 5000000 steps (42%)
02:24:29:WU00:FS00:0xa8:Completed 2150000 out of 5000000 steps (43%)
02:29:22:WU00:FS00:0xa8:Completed 2200000 out of 5000000 steps (44%)
02:34:15:WU00:FS00:0xa8:Completed 2250000 out of 5000000 steps (45%)
02:39:07:WU00:FS00:0xa8:Completed 2300000 out of 5000000 steps (46%)
02:44:01:WU00:FS00:0xa8:Completed 2350000 out of 5000000 steps (47%)
02:48:53:WU00:FS00:0xa8:Completed 2400000 out of 5000000 steps (48%)
02:53:45:WU00:FS00:0xa8:Completed 2450000 out of 5000000 steps (49%)
02:58:38:WU00:FS00:0xa8:Completed 2500000 out of 5000000 steps (50%)
03:03:30:WU00:FS00:0xa8:Completed 2550000 out of 5000000 steps (51%)
03:08:26:WU00:FS00:0xa8:Completed 2600000 out of 5000000 steps (52%)
03:14:27:WU00:FS00:0xa8:Completed 2650000 out of 5000000 steps (53%)
