Can't get a new work unit
m_vokhm
Hardware configuration: CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz (4 kernels)
Memory: 16 GiB
No GPU
Post by m_vokhm »
For about 3 days, my F@H client can't connect to work servers to receive a new work unit.
The log is filled with records like the following :
07:45:03:WU00:FS00:Connecting to assign1.foldingathome.org:80
07:45:04:WU00:FS00:Assigned to work server 129.32.209.202
07:45:05:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 129.32.209.202
07:45:05:WU00:FS00:Connecting to 129.32.209.202:8080
07:45:26:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
07:45:26:WU00:FS00:Connecting to 129.32.209.202:80
07:45:47:ERROR:WU00:FS00:Exception: Failed to connect to 129.32.209.202:80: >?KB:0 CAB0=>28BL A>548=5=85 1K;0 157CA?5H=>9, B.:. >B 4@C3>3> :><?LNB5@0 70 B@51C5<>5 2@5<O =5 ?>;CG5= =C6=K9 >B:;8:, 8;8 1K;> @07>@20=> C65 CAB0=>2;5==>5 A>548=5=85 87-70 =525@=>3> >B:;8:0 C65 ?>4:;NG5==>3> :><?LNB5@0.
work servers IPs vary: 129.32.209.202 and 129.32.209.204.
What can be the matter? Is it something wrong at my side?
My computer and the internet connection seem to be all right, I don't see any other unusual signs.
TheDevil
Re: Can't get a new work unit
Post by TheDevil »
I am also having an issue:
17:42:00:WU04:FS04:Downloading core from http://cores.foldingathome.org/lin/64bi ... ore_00.fah
17:42:00:WU04:FS04:Connecting to cores.foldingathome.org:80
17:42:01:ERROR:WU04:FS04:Exception: Failed reading core package header.
When I browse to this I am getting a 404 error too (where as if i got ot https://cores.foldingathome.org/lin/64bit/22-0.0.20/ I get a 403 error.)
TheDevil wrote: Fri Oct 14, 2022 6:21 pm I am also having an issue:
Yours is a different problem, you can download a WU, just not the folding core designated by the WS and the WU.
There are already 3 places where this core download problem hs been posted. I will be merging the two other topics, resolution to the problem and how to remove the WU are going to be posted there.
m_vokhm wrote: Fri Oct 14, 2022 8:29 am For about 3 days, my F@H client can't connect to work servers to receive a new work unit.
Please see this topic - viewtopic.php?t=38104. It appears the IT department at Temple University has set its firewall to deny access to IP addresses on some blocklist. Due to high spam counts and DOS attacks from some sites in Russia, it is possible your IP is in a range that has been blocked.
I have not received confirmation of this, but I can attest to the volume of spam and other invalid connections I see here on the forum. You may be able to connect through a VPN, but I am seeing heavy abuse of VPN connections provided through some firms by spammers as well.
m_vokhm
Memory: 16 GiB
No GPU
Post by m_vokhm »
Joe_H wrote: Fri Oct 14, 2022 7:03 pm Due to high spam counts and DOS attacks from some sites in Russia, it is possible your IP is in a range that has been blocked.
I have not received confirmation of this...
Yes, it seems to be true. Either my IP is blacklisted or our russian authorities are blocking access to the work servers (less probably). Now I've configured my computer to route the connection via a VPN and everything works fine now.
merlock
Hardware configuration: i7-8700K, 32GB RAM
Radeon RX 550 640SP / RX 560/560X
Post by merlock »
Having a similar problem; but I haven't been able to get a GPU WU for almost 24 hours now. Latest log:
02:19:27:WU00:FS01:Connecting to assign1.foldingathome.org:80
02:19:27:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
02:19:27:WU00:FS01:Connecting to assign2.foldingathome.org:80
02:19:27:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
02:19:27:WU00:FS01:Connecting to assign3.foldingathome.org:80
02:19:27:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
02:19:27:WU00:FS01:Connecting to assign4.foldingathome.org:80
02:19:28:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
02:19:28:ERROR:WU00:FS01:Exception: Could not get an assignment
GPU is listed in CPUs.txt file: 0x1002:0x67ff:1:5:Baffin [Polaris11]
and
FAHClient --lspci
0x1002:0x67ff:1:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:
Ideas/help?
merlock wrote: Thu Oct 27, 2022 3:26 am Having a similar problem; but I haven't been able to get a GPU WU for almost 24 hours now.
Similar in that you are not getting a WU, but for a different reason and with a totally different message in the log file. The other problems reported were due to not being able to make a network connection to specific servers, your client is connecting but not finding any suitable work available.
That is
vs.
Th problem comes from the entries for AMD GPUs being updated over the last 24-36 hours. That has changed the groups the GPUs are part of and they still need to update the servers to match. The current entry for your GPU is as follows:
 0x1002:0x67ff:1:3:Baffin [RX 550 640SP/RX 560/560X]
Your GPU has moved from species 5 to species 3. As species 5 it would have occasionally been assigned too large WUs, once the servers get updated there should be assignments more consistent in size. It ay take a few days to get everything propagated. In the meantime to get the updated GPUs.txt file just delete it and restart your folding client or the machine it is running on.
merlock
Post by merlock »
Joe_H wrote: Thu Oct 27, 2022 4:52 am Your GPU has moved from species 5 to species 3. As species 5 it would have occasionally been assigned too large WUs, once the servers get updated there should be assignments more consistent in size. It ay take a few days to get everything propagated. In the meantime to get the updated GPUs.txt file just delete it and restart your folding client or the machine it is running on.
Appreciate the quick reply. Updated the GPUs.txt file, now I'll just wait it out. :)
Thanks again!
KalixtShawxo
Post by KalixtShawxo »
Hi, I have been folding a short time, had it going on a Pine64 board and a Dell Laptop. Then I added another Pine and all three were chugging away just fine. I dedicated them to folding for cancer. I recently a few days ago added another RPi to the group and it would not get any assignments, the others were working but it did not. I uninstalled F@H and reinstalled thinking there was a problem, I am running all of them on DietPi.
anyway, I found this thread, and looking at my logs my connection is being refused. I am coming from an IP in the US, so I hope it isn't being blocked. IP is 143.59.86.xxx under WideOpenWest (WOW) as my internet provider.
Here's what my logs say:
Oct 27 22:51:04 Pine64-1GB FAHClient[3321]: WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': Failed to connect to assign1.foldingathome.org:80: Connection refused
Oct 27 22:51:04 Pine64-1GB FAHClient[3321]: WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': Failed to connect to assign2.foldingathome.org:80: Connection refused
Oct 27 22:51:04 Pine64-1GB FAHClient[3321]: WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': Failed to connect to assign3.foldingathome.org:80: Connection refused
Oct 27 22:51:04 Pine64-1GB FAHClient[3321]: WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': Failed to connect to assign4.foldingathome.org:80: Connection refused
Oct 27 22:51:04 Pine64-1GB FAHClient[3321]: ERROR:WU00:FS00:Exception: Could not get an assignment
Any idea why i'm being refused? Thanks in advance for any help or insight.
also edit to add that all systems are now not getting WUs at all after finishing what they had started last.
Starduster
Hardware configuration: Dell Optiplex 3020 SFF; Intel Core i7-4790, 16 GB mem, 512 Gb SSD; AMD Radeon Pro WX-2100, 2 GB.
Post by Starduster »
I have the same issue with my AMD Radeon Pro WX-2100, for what is now 2-3 days. But if the mentioned "reranking" process means I won't be assigned a job that my GPU cannot possibly do by deadline (which is a waste of time, effort, and energy for us and F@H), I shall be patient. CPU's still humming along at flank speed.
Thursday Nov 3 update: Is there progress on the reranking?
KalixtShawxo wrote: Thu Oct 27, 2022 9:54 pm Hi, I have been folding a short time, had it going on a Pine64 board and a Dell Laptop. Then I added another Pine and all three were chugging away just fine. I dedicated them to folding for cancer. I recently a few days ago added another RPi to the group and it would not get any assignments, the others were working but it did not. I uninstalled F@H and reinstalled thinking there was a problem, I am running all of them on DietPi.
This is a different issue ...
Something is blocking your connection to the assignment servers ... Can you access http://assign1.foldingathome.org or http://assign2.foldingathome.org from a browser on the same machine ?
psaam0001
Post by psaam0001 »
I have also been having trouble getting WU's for my Ryzen 3's (3200G/Picasso Core) iGPU for the past week or so. Is there going to be a classification downgrade for this iGPU?
Paul
Most of the low end GPUs moved to species 3 or 4. Once the servers are updated to reflect that change for the smaller projects, you should start receiving WUs again. The new categories are mostly organized by processing power.
psaam0001
Post by psaam0001 »
Joe_H wrote: Mon Oct 31, 2022 1:59 am Most of the low end GPUs moved to species 3 or 4. Once the servers are updated to reflect that change for the smaller projects, you should start receiving WUs again. The new categories are mostly organized by processing power.
Sounds like a plan! :D
Paul
Starduster
Update: My AMD GPU has its first work in 2 weeks. All is good now. Thanks all!
