Please add NVIDIA CMP 50HX
daratmp
Post by daratmp »
The CMP 170HX and CMP 90HX is in the GPUs.txt
0x10de:0x20c2:2:8:GA100 [CMP 170HX]
0x10de:0x220d:2:8:GA102 [CMP 90HX]
Could you add CMP 50HX please?
https://www.techpowerup.com/gpu-specs/cmp-50hx.c3782
Re: Please add NVIDIA CMP 50HX
DO you have the PCI device ID for this card? That will be needed to add it to the list. This post has information on how to obtain the ID - viewtopic.php?p=262894#p262894
daratmp
Post by daratmp »
Joe_H wrote: Thu Oct 13, 2022 2:22 pm DO you have the PCI device ID for this card? That will be needed to add it to the list. This post has information on how to obtain the ID - viewtopic.php?p=262894#p262894
Cpu: AMD Ryzen 3 2200G with Radeon Vega Graphic(2G)
Gpu: NVIDIA CMP 50HX
fahclient --lspci
C:\Program Files (x86)\FAHClient>fahclient --lspci
0x1022:0x15e3:7:0:6:Advanced Micro Devices, Inc. [AMD]:High Definition Audio 控制器
0x1022:0x15db:0:8:1:Advanced Micro Devices, Inc. [AMD]:PCI Express 根端口
0x1022:0x15ef:0:24:7:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x1452:0:1:0:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x1452:0:8:0:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x10de:0x1e09:1:0:0:NVIDIA Corporation:NVIDIA CMP 50HX
0x1022:0x43b4:3:4:0:Advanced Micro Devices, Inc. [AMD]:PCI Express 下游交换机端口
0x1022:0x15ec:0:24:4:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x15e0:7:0:3:Advanced Micro Devices, Inc. [AMD]:符合 USB xHCI 的主机控制器
0x1022:0x790b:0:20:0:Advanced Micro Devices, Inc. [AMD]:AMD SMBus
0x1022:0x15e8:0:24:0:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x43bc:2:0:0:Advanced Micro Devices, Inc. [AMD]:符合 USB xHCI 的主机控制器
0x1022:0x43b8:2:0:1:Advanced Micro Devices, Inc. [AMD]:标准 SATA AHCI 控制器
0x1002:0x15de:7:0:1:Advanced Micro Devices, Inc. [AMD/ATI]:High Definition Audio 控制器
0x1022:0x15ee:0:24:6:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x7901:8:0:0:Advanced Micro Devices, Inc. [AMD]:标准 SATA AHCI 控制器
0x1022:0x43b4:3:6:0:Advanced Micro Devices, Inc. [AMD]:PCI Express 下游交换机端口
0x1022:0x15eb:0:24:3:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x15d3:0:1:1:Advanced Micro Devices, Inc. [AMD]:PCI Express 根端口
0x1022:0x15d3:0:1:2:Advanced Micro Devices, Inc. [AMD]:PCI Express 根端口
0x1022:0x43b4:3:7:0:Advanced Micro Devices, Inc. [AMD]:PCI Express 下游交换机端口
0x1022:0x15dc:0:8:2:Advanced Micro Devices, Inc. [AMD]:PCI Express 根端口
0x1022:0x43b3:2:0:2:Advanced Micro Devices, Inc. [AMD]:PCI Express 上游交换机端口
0x1022:0x790e:0:20:3:Advanced Micro Devices, Inc. [AMD]:PCI 标准 ISA 桥
0x1022:0x15ed:0:24:5:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x10ec:0x8168:6:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe GbE Family Controller
0x1022:0x15e9:0:24:1:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1002:0x15dd:7:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:AMD Radeon(TM) Vega 8 Graphics
0x1022:0x15e1:7:0:4:Advanced Micro Devices, Inc. [AMD]:符合 USB xHCI 的主机控制器
0x1022:0x15ea:0:24:2:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x15d0:0:0:0:Advanced Micro Devices, Inc. [AMD]:PCI 标准主机 CPU 桥
0x1022:0x15df:7:0:2:Advanced Micro Devices, Inc. [AMD]:AMD PSP 10.0 Device
log
*********************** Log Started 2022-10-13T14:37:53Z ***********************
14:37:53:******************************* libFAH ********************************
14:37:53:           Date: Oct 20 2020
14:37:53:           Time: 13:36:55
14:37:53:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:37:53:         Branch: master
14:37:53:       Compiler: Visual C++ 2015
14:37:53:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:37:53:       Platform: win32 10
14:37:53:           Bits: 32
14:37:53:           Mode: Release
14:37:53:****************************** FAHClient ******************************
14:37:53:        Version: 7.6.21
14:37:53:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:37:53:      Copyright: 2020 foldingathome.org
14:37:53:       Homepage: https://foldingathome.org/
14:37:53:           Time: 13:41:04
14:37:53:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:37:53:           Bits: 32
14:37:53:           Args: --open-web-control
14:37:53:         Config: C:\ProgramData\FAHClient\config.xml
14:37:53:******************************** CBang ********************************
14:37:53:           Time: 11:36:18
14:37:53:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:37:53:           Bits: 32
14:37:53:******************************* System ********************************
14:37:53:            CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
14:37:53:         CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
14:37:53:           CPUs: 4
14:37:53:         Memory: 5.93GiB
14:37:53:    Free Memory: 2.88GiB
14:37:53:        Threads: WINDOWS_THREADS
14:37:53:     OS Version: 6.2
14:37:53:    Has Battery: false
14:37:53:     On Battery: false
14:37:53:     UTC Offset: 8
14:37:53:            PID: 2676
14:37:53:            CWD: C:\ProgramData\FAHClient
14:37:53:  Win32 Service: false
14:37:53:             OS: Windows 10 Enterprise
14:37:53:        OS Arch: AMD64
14:37:53:           GPUs: 1
14:37:53:          GPU 0: Bus:7 Slot:0 Func:0 AMD:5 Raven Ridge [Radeon Vega Series /
14:37:53:                 Radeon Vega Mobile Series]
14:37:53:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.4
14:37:53:OpenCL Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:1.2 Driver:2580.6
14:37:53:***********************************************************************
14:37:53:<config>
14:37:53:  <!-- Network -->
14:37:53:  <proxy v=':8080'/>
14:37:53:
14:37:53:  <!-- User Information -->
14:37:53:  <passkey v='*****'/>
14:37:53:  <team v='*****'/>
14:37:53:  <user v='*****'/>
14:37:53:
14:37:53:  <!-- Folding Slots -->
14:37:53:</config>
14:37:53:Trying to access database...
14:37:53:Successfully acquired database lock
14:37:53:FS00:Initialized folding slot 00: cpu:2
14:37:53:FS01:Initialized folding slot 01: gpu:7:0 Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
14:37:55:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:37:55:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:37:56:WU00:FS00:Assigned to work server 129.32.209.202
14:37:56:WU00:FS00:Requesting new work unit for slot 00: cpu:2 from 129.32.209.202
14:37:56:WU00:FS00:Connecting to 129.32.209.202:8080
14:37:57:WU01:FS01:Assigned to work server 129.32.209.202
14:37:57:WU01:FS01:Requesting new work unit for slot 01: gpu:7:0 Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] from 129.32.209.202
14:37:57:WU01:FS01:Connecting to 129.32.209.202:8080
14:38:03:WU01:FS01:Downloading 95.56MiB
14:38:05:WU00:FS00:Downloading 808.50KiB
14:38:37:WU00:FS00:Download 7.92%
14:38:42:WU01:FS01:Download 0.07%
14:38:54:Saving configuration to config.xml
14:38:54:<config>
14:38:54:  <!-- Network -->
14:38:54:  <proxy v=':8080'/>
14:38:54:
14:38:54:  <!-- User Information -->
14:38:54:  <passkey v='*****'/>
14:38:54:  <team v='*****'/>
14:38:54:  <user v='*****'/>
14:38:54:
14:38:54:  <!-- Folding Slots -->
14:38:54:  <slot id='0' type='CPU'/>
14:38:54:  <slot id='1' type='GPU'>
14:38:54:    <pci-bus v='7'/>
14:38:54:    <pci-slot v='0'/>
14:38:54:  </slot>
14:38:54:</config>
14:39:02:WU00:FS00:Download 15.83%
14:39:08:WU01:FS01:Download 0.13%
14:39:26:WU00:FS00:Download 23.75%
14:39:36:WU01:FS01:Download 0.20%
I just added 0x1e09 / TU102 [CMP 50HX] ...
daratmp
Post by daratmp »
toTOW wrote: Sat Oct 15, 2022 1:44 pm I just added 0x1e09 / TU102 [CMP 50HX] ...
Thanks
