AMD Cards Failing out
TheDevil
Post by TheDevil »
So I have a used Eth mining rig that I am moving to FAH, its got 4 580s 8gb and 2 5700XT. With a clean install of windows and and only the AMD drivers and FAH installed I am getting cards that fail to do anything, they just download over and over, saying bad work unit.
13:18:22:WU00:FS01:0x22:*********************** Log Started 2022-09-27T13:18:21Z ***********************
13:18:22:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:18:22:WU00:FS01:0x22:       Core: Core22
13:18:22:WU00:FS01:0x22:       Type: 0x22
13:18:22:WU00:FS01:0x22:    Version: 0.0.20
13:18:22:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:18:22:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
13:18:22:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
13:18:22:WU00:FS01:0x22:       Date: Jan 20 2022
13:18:22:WU00:FS01:0x22:       Time: 01:15:36
13:18:22:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
13:18:22:WU00:FS01:0x22:     Branch: HEAD
13:18:22:WU00:FS01:0x22:   Compiler: Visual C++
13:18:22:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:18:22:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
13:18:22:WU00:FS01:0x22:   Platform: win32 10
13:18:22:WU00:FS01:0x22:       Bits: 64
13:18:22:WU00:FS01:0x22:       Mode: Release
13:18:22:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:18:22:WU00:FS01:0x22:             <peastman@stanford.edu>
13:18:22:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9928 -checkpoint 15
13:18:22:WU00:FS01:0x22:             -opencl-platform 1 -opencl-device 4 -gpu-vendor amd -gpu 4
13:18:22:WU00:FS01:0x22:             -gpu-usage 100
13:18:22:WU00:FS01:0x22:************************************ libFAH ************************************
13:18:22:WU00:FS01:0x22:       Time: 01:14:17
13:18:22:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
13:18:22:WU00:FS01:0x22:************************************ CBang *************************************
13:18:22:WU00:FS01:0x22:       Time: 01:13:20
13:18:22:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
13:18:22:WU00:FS01:0x22:************************************ System ************************************
13:18:22:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
13:18:22:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
13:18:22:WU00:FS01:0x22:       CPUs: 4
13:18:22:WU00:FS01:0x22:     Memory: 31.70GiB
13:18:22:WU00:FS01:0x22:Free Memory: 26.17GiB
13:18:22:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
13:18:22:WU00:FS01:0x22: OS Version: 6.2
13:18:22:WU00:FS01:0x22:Has Battery: false
13:18:22:WU00:FS01:0x22: On Battery: false
13:18:22:WU00:FS01:0x22: UTC Offset: -7
13:18:22:WU00:FS01:0x22:        PID: 7624
13:18:22:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
13:18:22:WU00:FS01:0x22:************************************ OpenMM ************************************
13:18:22:WU00:FS01:0x22:    Version: 7.7.0
13:18:22:WU00:FS01:0x22:********************************************************************************
13:18:22:WU00:FS01:0x22:Project: 18450 (Run 1, Clone 59, Gen 118)
13:18:22:WU00:FS01:0x22:Reading tar file core.xml
13:18:22:WU00:FS01:0x22:Reading tar file integrator.xml
13:18:22:WU00:FS01:0x22:Reading tar file state.xml
13:18:22:WU00:FS01:0x22:Reading tar file system.xml
13:18:22:WU00:FS01:0x22:Digital signatures verified
13:18:22:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:18:22:WU00:FS01:0x22:Version 0.0.20
13:18:44:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
13:18:44:WU00:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
13:18:44:WU00:FS01:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
13:18:44:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
13:18:44:WU00:FS01:0x22:There are 3 platforms available.
13:18:44:WU00:FS01:0x22:Platform 0: Reference
13:18:44:WU00:FS01:0x22:Platform 1: CPU
13:18:44:WU00:FS01:0x22:Platform 2: OpenCL
13:18:44:WU00:FS01:0x22:  opencl-device 4 specified
13:19:03:WU00:FS01:0x22:Attempting to create OpenCL context:
13:19:03:WU00:FS01:0x22:  Configuring platform OpenCL
13:19:03:WU00:FS01:0x22:Failed to create OpenCL context:
13:19:03:WU00:FS01:0x22:Illegal value for DeviceIndex: 4
13:19:03:WU00:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
13:19:03:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
13:19:03:WU00:FS01:0x22:Saving result file science.log
13:19:03:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:19:16:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:19:16:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18450 run:1 clone:59 gen:118 core:0x22 unit:0x0000003b000000760000481200000001
13:19:16:WU00:FS01:Uploading 13.50KiB to 129.32.209.202
13:19:16:WU00:FS01:Connecting to 129.32.209.202:8080
13:19:16:WU00:FS01:Upload complete
13:19:16:WU00:FS01:Server responded WORK_ACK (400)
13:19:16:WU00:FS01:Cleaning up
13:19:16:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:19:17:WU00:FS01:Assigned to work server 34.72.228.44
13:19:17:WU00:FS01:Requesting new work unit for slot 01: gpu:10:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 34.72.228.44
13:19:17:WU00:FS01:Connecting to 34.72.228.44:8080
13:19:17:ERROR:WU00:FS01:Exception: Server did not assign work unit
13:19:17:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:19:18:WU00:FS01:Assigned to work server 129.32.209.202
13:19:18:WU00:FS01:Requesting new work unit for slot 01: gpu:10:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 129.32.209.202
13:19:18:WU00:FS01:Connecting to 129.32.209.202:8080
13:19:19:WU00:FS01:Downloading 28.02MiB
13:19:24:WU00:FS01:Download complete
13:19:24:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18445 run:7 clone:7 gen:124 core:0x22 unit:0x000000070000007c0000480d00000007
13:19:24:WU00:FS01:Starting
13:19:24:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10156 -checkpoint 15 -opencl-platform 1 -opencl-device 4 -gpu-vendor amd -gpu 4 -gpu-usage 100
13:19:24:WU00:FS01:Started FahCore on PID 9848
13:19:24:WU00:FS01:Core PID:9164
13:19:24:WU00:FS01:FahCore 0x22 started
Re: AMD Cards Failing out
Welcome to Folding@Home!
If you could show us the first 100 lines of your log, it would show us much of the configuration of your PC.
TheDevil
Post by TheDevil »
*********************** Log Started 2022-09-27T23:53:12Z ***********************
23:53:12:******************************* libFAH ********************************
23:53:12:           Date: Oct 20 2020
23:53:12:           Time: 13:36:55
23:53:12:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
23:53:12:         Branch: master
23:53:12:       Compiler: Visual C++ 2015
23:53:12:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:53:12:       Platform: win32 10
23:53:12:           Bits: 32
23:53:12:           Mode: Release
23:53:12:****************************** FAHClient ******************************
23:53:12:        Version: 7.6.21
23:53:12:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:12:      Copyright: 2020 foldingathome.org
23:53:12:       Homepage: https://foldingathome.org/
23:53:12:           Time: 13:41:04
23:53:12:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
23:53:12:           Bits: 32
23:53:12:           Args: --open-web-control
23:53:12:         Config: C:\ProgramData\FAHClient\config.xml
23:53:12:******************************** CBang ********************************
23:53:12:           Time: 11:36:18
23:53:12:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
23:53:12:           Bits: 32
23:53:12:******************************* System ********************************
23:53:12:            CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:53:12:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:53:12:           CPUs: 4
23:53:12:         Memory: 31.70GiB
23:53:12:    Free Memory: 28.22GiB
23:53:12:        Threads: WINDOWS_THREADS
23:53:12:     OS Version: 6.2
23:53:12:    Has Battery: false
23:53:12:     On Battery: false
23:53:12:     UTC Offset: -7
23:53:12:            PID: 11148
23:53:12:            CWD: C:\ProgramData\FAHClient
23:53:12:  Win32 Service: false
23:53:12:             OS: Windows 10 Enterprise
23:53:12:        OS Arch: AMD64
23:53:12:           GPUs: 7
23:53:12:          GPU 0: Bus:10 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:53:12:                 470/480/570/580/590]
23:53:12:          GPU 1: Bus:8 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:53:12:          GPU 2: Bus:6 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600
23:53:12:                 XT/5700/5700 XT]
23:53:12:          GPU 3: Bus:7 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:53:12:          GPU 4: Bus:9 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:53:12:          GPU 5: Bus:3 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600
23:53:12:          GPU 6: Bus:0 Slot:2 Func:0 INTEL:1 SKL GT2 [HD Graphics 530]
23:53:12:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:53:12:                 specified module could not be found.
23:53:12:
23:53:12:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:30.0
23:53:12:OpenCL Device 1: Platform:1 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3444.0
23:53:12:OpenCL Device 2: Platform:1 Device:1 Bus:6 Slot:0 Compute:1.2 Driver:3444.0
23:53:12:OpenCL Device 3: Platform:1 Device:2 Bus:7 Slot:0 Compute:1.2 Driver:3444.0
23:53:12:OpenCL Device 4: Platform:1 Device:3 Bus:9 Slot:0 Compute:1.2 Driver:3444.0
23:53:12:OpenCL Device 5: Platform:1 Device:4 Bus:10 Slot:0 Compute:1.2 Driver:3444.0
23:53:12:OpenCL Device 6: Platform:1 Device:5 Bus:8 Slot:0 Compute:1.2 Driver:3444.0
23:53:12:***********************************************************************
23:53:12:<config>
23:53:12:  <!-- Folding Slot Configuration -->
23:53:12:  <cause v='HIGH_PRIORITY'/>
23:53:12:
23:53:12:  <!-- Network -->
23:53:12:  <proxy v=':8080'/>
23:53:12:
23:53:12:  <!-- Slot Control -->
23:53:12:  <power v='MEDIUM'/>
23:53:12:
23:53:12:  <!-- User Information -->
23:53:12:  <passkey v='*****'/>
23:53:12:  <team v='238663'/>
23:53:12:  <user v='combasemain'/>
23:53:12:
23:53:12:  <!-- Folding Slots -->
23:53:12:  <slot id='1' type='GPU'>
23:53:12:    <pci-bus v='10'/>
23:53:12:    <pci-slot v='0'/>
23:53:12:  </slot>
23:53:12:  <slot id='2' type='GPU'>
23:53:12:    <pci-bus v='8'/>
23:53:12:  </slot>
23:53:12:  <slot id='3' type='GPU'>
23:53:12:    <pci-bus v='6'/>
23:53:12:  </slot>
23:53:12:  <slot id='4' type='GPU'>
23:53:12:    <pci-bus v='7'/>
23:53:12:  </slot>
23:53:12:  <slot id='5' type='GPU'>
23:53:12:    <pci-bus v='9'/>
23:53:12:  </slot>
23:53:12:  <slot id='6' type='GPU'>
23:53:12:    <pci-bus v='3'/>
23:53:12:  </slot>
23:53:12:  <slot id='0' type='GPU'>
23:53:12:    <pci-bus v='0'/>
23:53:12:    <pci-slot v='2'/>
23:53:12:  </slot>
23:53:12:</config>
23:53:12:Trying to access database...
23:53:12:Successfully acquired database lock
23:53:12:FS01:Initialized folding slot 01: gpu:10:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
23:53:12:FS02:Initialized folding slot 02: gpu:8:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
23:53:12:FS03:Initialized folding slot 03: gpu:6:0 Navi 10 [Radeon RX 5600 OEM/5600 XT/5700/5700 XT]
23:53:12:FS04:Initialized folding slot 04: gpu:7:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
23:53:12:FS05:Initialized folding slot 05: gpu:9:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
23:53:12:FS06:Initialized folding slot 06: gpu:3:0 Navi 10 [Radeon RX 5600 OEM/5600 XT/5700/5700 XT]
23:53:12:WARNING:FS00:Guessing ambiguous GPU to OpenCL device mapping for 00: gpu:0:2 SKL GT2 [HD Graphics 530].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
23:53:12:WARNING:FS00:Disabling beta GPU slot 00: gpu:0:2 SKL GT2 [HD Graphics 530].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
23:53:12:WU05:FS06:Starting
23:53:12:WU05:FS06:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 05 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
23:53:12:WU05:FS06:Started FahCore on PID 5152
23:53:12:WU05:FS06:Core PID:11012
23:53:12:WU05:FS06:FahCore 0x22 started
23:53:12:WU00:FS01:Starting
23:53:12:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 4 -gpu-vendor amd -gpu 4 -gpu-usage 100
23:53:12:WU00:FS01:Started FahCore on PID 9048
23:53:13:WU00:FS01:Core PID:10292
23:53:13:WU00:FS01:FahCore 0x22 started
23:53:13:WU02:FS05:Starting
23:53:13:WU02:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 3 -gpu-vendor amd -gpu 3 -gpu-usage 100
23:53:13:WU02:FS05:Started FahCore on PID 8348
23:53:13:WU02:FS05:Core PID:3644
23:53:13:WU02:FS05:FahCore 0x22 started
23:53:13:WU04:FS02:Starting
23:53:13:WU04:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 04 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 5 -gpu-vendor amd -gpu 5 -gpu-usage 100
23:53:13:WU05:FS06:0x22:*********************** Log Started 2022-09-27T23:53:12Z ***********************
23:53:13:WU05:FS06:0x22:*************************** Core22 Folding@home Core ***************************
23:53:13:WU05:FS06:0x22:       Core: Core22
23:53:13:WU05:FS06:0x22:       Type: 0x22
23:53:13:WU05:FS06:0x22:    Version: 0.0.20
23:53:13:WU05:FS06:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:13:WU05:FS06:0x22:  Copyright: 2020 foldingathome.org
23:53:13:WU05:FS06:0x22:   Homepage: https://foldingathome.org/
23:53:13:WU05:FS06:0x22:       Date: Jan 20 2022
23:53:13:WU05:FS06:0x22:       Time: 01:15:36
23:53:13:WU05:FS06:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:53:13:WU05:FS06:0x22:     Branch: HEAD
23:53:13:WU05:FS06:0x22:   Compiler: Visual C++
23:53:13:WU05:FS06:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:53:13:WU05:FS06:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:53:13:WU05:FS06:0x22:   Platform: win32 10
23:53:13:WU05:FS06:0x22:       Bits: 64
23:53:13:WU05:FS06:0x22:       Mode: Release
23:53:13:WU05:FS06:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:53:13:WU05:FS06:0x22:             <peastman@stanford.edu>
23:53:13:WU05:FS06:0x22:       Args: -dir 05 -suffix 01 -version 706 -lifeline 5152 -checkpoint 15
23:53:13:WU05:FS06:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
23:53:13:WU05:FS06:0x22:             -gpu-usage 100
23:53:13:WU05:FS06:0x22:************************************ libFAH ************************************
23:53:13:WU05:FS06:0x22:       Time: 01:14:17
23:53:13:WU05:FS06:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:53:13:WU05:FS06:0x22:************************************ CBang *************************************
23:53:13:WU05:FS06:0x22:       Time: 01:13:20
23:53:13:WU05:FS06:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:53:13:WU05:FS06:0x22:************************************ System ************************************
23:53:13:WU05:FS06:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:53:13:WU05:FS06:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:53:13:WU05:FS06:0x22:       CPUs: 4
23:53:13:WU05:FS06:0x22:     Memory: 31.70GiB
23:53:13:WU05:FS06:0x22:Free Memory: 28.03GiB
23:53:13:WU05:FS06:0x22:    Threads: WINDOWS_THREADS
23:53:13:WU05:FS06:0x22: OS Version: 6.2
23:53:13:WU05:FS06:0x22:Has Battery: false
23:53:13:WU05:FS06:0x22: On Battery: false
23:53:13:WU05:FS06:0x22: UTC Offset: -7
23:53:13:WU05:FS06:0x22:        PID: 11012
23:53:13:WU05:FS06:0x22:        CWD: C:\ProgramData\FAHClient\work
23:53:13:WU05:FS06:0x22:************************************ OpenMM ************************************
23:53:13:WU05:FS06:0x22:    Version: 7.7.0
23:53:13:WU05:FS06:0x22:********************************************************************************
23:53:13:WU05:FS06:0x22:Project: 18213 (Run 24576, Clone 0, Gen 38)
23:53:13:WU00:FS01:0x22:*********************** Log Started 2022-09-27T23:53:13Z ***********************
23:53:13:WU05:FS06:0x22:Digital signatures verified
23:53:13:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:53:13:WU05:FS06:0x22:Folding@home GPU Core22 Folding@home Core
23:53:13:WU00:FS01:0x22:       Core: Core22
23:53:13:WU05:FS06:0x22:Version 0.0.20
23:53:13:WU00:FS01:0x22:       Type: 0x22
23:53:13:WU00:FS01:0x22:    Version: 0.0.20
23:53:13:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:13:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
23:53:13:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
23:53:13:WU00:FS01:0x22:       Date: Jan 20 2022
23:53:13:WU00:FS01:0x22:       Time: 01:15:36
23:53:13:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:53:13:WU00:FS01:0x22:     Branch: HEAD
23:53:13:WU00:FS01:0x22:   Compiler: Visual C++
23:53:13:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:53:13:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:53:13:WU00:FS01:0x22:   Platform: win32 10
23:53:13:WU00:FS01:0x22:       Bits: 64
23:53:13:WU00:FS01:0x22:       Mode: Release
23:53:13:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:53:13:WU00:FS01:0x22:             <peastman@stanford.edu>
23:53:13:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9048 -checkpoint 15
23:53:13:WU00:FS01:0x22:             -opencl-platform 1 -opencl-device 4 -gpu-vendor amd -gpu 4
23:53:13:WU00:FS01:0x22:             -gpu-usage 100
23:53:13:WU00:FS01:0x22:************************************ libFAH ************************************
23:53:13:WU00:FS01:0x22:       Time: 01:14:17
23:53:13:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:53:13:WU00:FS01:0x22:************************************ CBang *************************************
23:53:13:WU00:FS01:0x22:       Time: 01:13:20
23:53:13:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:53:13:WU02:FS05:0x22:*********************** Log Started 2022-09-27T23:53:13Z ***********************
23:53:13:WU00:FS01:0x22:************************************ System ************************************
23:53:13:WU02:FS05:0x22:*************************** Core22 Folding@home Core ***************************
23:53:13:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:53:13:WU02:FS05:0x22:       Core: Core22
23:53:13:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:53:13:WU02:FS05:0x22:       Type: 0x22
23:53:13:WU00:FS01:0x22:       CPUs: 4
23:53:13:WU02:FS05:0x22:    Version: 0.0.20
23:53:13:WU00:FS01:0x22:     Memory: 31.70GiB
23:53:13:WU02:FS05:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:13:WU00:FS01:0x22:Free Memory: 28.02GiB
23:53:13:WU02:FS05:0x22:  Copyright: 2020 foldingathome.org
23:53:13:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
23:53:13:WU02:FS05:0x22:   Homepage: https://foldingathome.org/
23:53:13:WU00:FS01:0x22: OS Version: 6.2
23:53:13:WU02:FS05:0x22:       Date: Jan 20 2022
23:53:13:WU00:FS01:0x22:Has Battery: false
23:53:13:WU02:FS05:0x22:       Time: 01:15:36
23:53:13:WU00:FS01:0x22: On Battery: false
23:53:13:WU02:FS05:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:53:13:WU00:FS01:0x22: UTC Offset: -7
23:53:13:WU02:FS05:0x22:     Branch: HEAD
23:53:13:WU00:FS01:0x22:        PID: 10292
23:53:13:WU02:FS05:0x22:   Compiler: Visual C++
23:53:13:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
23:53:13:WU02:FS05:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:53:13:WU00:FS01:0x22:************************************ OpenMM ************************************
23:53:13:WU02:FS05:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:53:13:WU00:FS01:0x22:    Version: 7.7.0
23:53:13:WU02:FS05:0x22:   Platform: win32 10
23:53:13:WU00:FS01:0x22:********************************************************************************
23:53:13:WU02:FS05:0x22:       Bits: 64
23:53:13:WU00:FS01:0x22:Project: 18706 (Run 0, Clone 242, Gen 126)
23:53:13:WU02:FS05:0x22:       Mode: Release
23:53:13:WU00:FS01:0x22:Reading tar file core.xml
23:53:13:WU02:FS05:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:53:13:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
23:53:13:WU02:FS05:0x22:             <peastman@stanford.edu>
23:53:13:WU00:FS01:0x22:Reading tar file state.xml.bz2
23:53:13:WU02:FS05:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8348 -checkpoint 15
23:53:13:WU00:FS01:0x22:Reading tar file system.xml.bz2
23:53:13:WU02:FS05:0x22:             -opencl-platform 1 -opencl-device 3 -gpu-vendor amd -gpu 3
23:53:13:WU00:FS01:0x22:Digital signatures verified
23:53:13:WU02:FS05:0x22:             -gpu-usage 100
23:53:13:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:53:13:WU02:FS05:0x22:************************************ libFAH ************************************
23:53:13:WU00:FS01:0x22:Version 0.0.20
23:53:13:WU02:FS05:0x22:       Time: 01:14:17
23:53:13:WU02:FS05:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:53:13:WU02:FS05:0x22:************************************ CBang *************************************
23:53:13:WU02:FS05:0x22:       Time: 01:13:20
23:53:13:WU02:FS05:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:53:13:WU02:FS05:0x22:************************************ System ************************************
23:53:13:WU02:FS05:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:53:13:WU02:FS05:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:53:13:WU02:FS05:0x22:       CPUs: 4
23:53:13:WU02:FS05:0x22:     Memory: 31.70GiB
23:53:13:WU02:FS05:0x22:Free Memory: 28.02GiB
23:53:13:WU02:FS05:0x22:    Threads: WINDOWS_THREADS
23:53:13:WU02:FS05:0x22: OS Version: 6.2
23:53:13:WU02:FS05:0x22:Has Battery: false
23:53:13:WU02:FS05:0x22: On Battery: false
23:53:13:WU02:FS05:0x22: UTC Offset: -7
23:53:13:WU02:FS05:0x22:        PID: 3644
23:53:13:WU02:FS05:0x22:        CWD: C:\ProgramData\FAHClient\work
23:53:13:WU02:FS05:0x22:************************************ OpenMM ************************************
23:53:13:WU02:FS05:0x22:    Version: 7.7.0
23:53:13:WU02:FS05:0x22:********************************************************************************
23:53:13:WU02:FS05:0x22:Project: 18706 (Run 0, Clone 172, Gen 137)
23:53:13:WU02:FS05:0x22:Digital signatures verified
23:53:13:WU02:FS05:0x22:Folding@home GPU Core22 Folding@home Core
23:53:13:WU02:FS05:0x22:Version 0.0.20
23:53:13:WU04:FS02:Started FahCore on PID 9824
23:53:14:WU04:FS02:Core PID:10540
23:53:14:WU04:FS02:FahCore 0x22 started
23:53:14:WU04:FS02:0x22:*********************** Log Started 2022-09-27T23:53:14Z ***********************
23:53:14:WU04:FS02:0x22:*************************** Core22 Folding@home Core ***************************
23:53:14:WU04:FS02:0x22:       Core: Core22
23:53:14:WU04:FS02:0x22:       Type: 0x22
23:53:14:WU04:FS02:0x22:    Version: 0.0.20
23:53:14:WU04:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:14:WU04:FS02:0x22:  Copyright: 2020 foldingathome.org
23:53:14:WU04:FS02:0x22:   Homepage: https://foldingathome.org/
23:53:14:WU04:FS02:0x22:       Date: Jan 20 2022
23:53:14:WU04:FS02:0x22:       Time: 01:15:36
23:53:14:WU04:FS02:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:53:14:WU04:FS02:0x22:     Branch: HEAD
23:53:14:WU04:FS02:0x22:   Compiler: Visual C++
23:53:14:WU04:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:53:14:WU04:FS02:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:53:14:WU04:FS02:0x22:   Platform: win32 10
23:53:14:WU04:FS02:0x22:       Bits: 64
23:53:14:WU04:FS02:0x22:       Mode: Release
23:53:14:WU04:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:53:14:WU04:FS02:0x22:             <peastman@stanford.edu>
23:53:14:WU04:FS02:0x22:       Args: -dir 04 -suffix 01 -version 706 -lifeline 9824 -checkpoint 15
23:53:14:WU04:FS02:0x22:             -opencl-platform 1 -opencl-device 5 -gpu-vendor amd -gpu 5
23:53:14:WU04:FS02:0x22:             -gpu-usage 100
23:53:14:WU04:FS02:0x22:************************************ libFAH ************************************
23:53:14:WU04:FS02:0x22:       Time: 01:14:17
23:53:14:WU04:FS02:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:53:14:WU04:FS02:0x22:************************************ CBang *************************************
23:53:14:WU04:FS02:0x22:       Time: 01:13:20
23:53:14:WU04:FS02:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:53:14:WU04:FS02:0x22:************************************ System ************************************
23:53:14:WU04:FS02:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:53:14:WU04:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:53:14:WU04:FS02:0x22:       CPUs: 4
23:53:14:WU04:FS02:0x22:     Memory: 31.70GiB
23:53:14:WU04:FS02:0x22:Free Memory: 27.94GiB
23:53:14:WU04:FS02:0x22:    Threads: WINDOWS_THREADS
23:53:14:WU04:FS02:0x22: OS Version: 6.2
23:53:14:WU04:FS02:0x22:Has Battery: false
23:53:14:WU04:FS02:0x22: On Battery: false
23:53:14:WU04:FS02:0x22: UTC Offset: -7
23:53:14:WU04:FS02:0x22:        PID: 10540
23:53:14:WU04:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
23:53:14:WU04:FS02:0x22:************************************ OpenMM ************************************
23:53:14:WU04:FS02:0x22:    Version: 7.7.0
23:53:14:WU04:FS02:0x22:********************************************************************************
23:53:14:WU04:FS02:0x22:Project: 18500 (Run 1, Clone 147, Gen 221)
23:53:14:WU04:FS02:0x22:Digital signatures verified
23:53:14:WU04:FS02:0x22:Folding@home GPU Core22 Folding@home Core
23:53:14:WU04:FS02:0x22:Version 0.0.20
23:53:14:WU01:FS03:Connecting to assign1.foldingathome.org:80
23:53:14:WU03:FS04:Connecting to assign1.foldingathome.org:80
23:53:15:4:127.0.0.1:New Web session
23:53:15:WU03:FS04:Assigned to work server 206.223.170.146
23:53:15:WU03:FS04:Requesting new work unit for slot 04: gpu:7:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 206.223.170.146
23:53:15:WU01:FS03:Assigned to work server 129.32.209.202
23:53:15:WU03:FS04:Connecting to 206.223.170.146:8080
23:53:15:WU01:FS03:Requesting new work unit for slot 03: gpu:6:0 Navi 10 [Radeon RX 5600 OEM/5600 XT/5700/5700 XT] from 129.32.209.202
23:53:15:WU01:FS03:Connecting to 129.32.209.202:8080
23:53:16:WU01:FS03:Downloading 41.74MiB
23:53:21:WU02:FS05:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
23:53:21:WU02:FS05:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
23:53:21:WU02:FS05:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
23:53:21:WU02:FS05:0x22:  Global context and integrator variables write interval: disabled
23:53:21:WU02:FS05:0x22:There are 3 platforms available.
23:53:21:WU02:FS05:0x22:Platform 0: Reference
23:53:21:WU02:FS05:0x22:Platform 1: CPU
23:53:21:WU02:FS05:0x22:Platform 2: OpenCL
23:53:21:WU02:FS05:0x22:  opencl-device 3 specified
23:53:21:WU05:FS06:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
23:53:21:WU05:FS06:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
23:53:21:WU05:FS06:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
23:53:21:WU05:FS06:0x22:  Global context and integrator variables write interval: disabled
23:53:21:WU05:FS06:0x22:There are 3 platforms available.
23:53:21:WU05:FS06:0x22:Platform 0: Reference
23:53:21:WU05:FS06:0x22:Platform 1: CPU
23:53:21:WU05:FS06:0x22:Platform 2: OpenCL
23:53:21:WU05:FS06:0x22:  opencl-device 0 specified
23:53:21:WU00:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
23:53:21:WU00:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
23:53:21:WU00:FS01:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
23:53:21:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
23:53:21:WU00:FS01:0x22:There are 3 platforms available.
23:53:21:WU00:FS01:0x22:Platform 0: Reference
23:53:21:WU00:FS01:0x22:Platform 1: CPU
23:53:21:WU00:FS01:0x22:Platform 2: OpenCL
23:53:21:WU00:FS01:0x22:  opencl-device 4 specified
23:53:22:WU01:FS03:Download 91.20%
23:53:22:WU01:FS03:Download complete
23:53:22:WU01:FS03:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18447 run:0 clone:81 gen:373 core:0x22 unit:0x00000051000001750000480f00000000
23:53:22:WU01:FS03:Starting
23:53:22:WU01:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 1 -gpu-vendor amd -gpu 1 -gpu-usage 100
23:53:22:WU01:FS03:Started FahCore on PID 6600
23:53:22:WU01:FS03:Core PID:9868
23:53:22:WU01:FS03:FahCore 0x22 started
23:53:23:WU01:FS03:0x22:*********************** Log Started 2022-09-27T23:53:22Z ***********************
23:53:23:WU01:FS03:0x22:*************************** Core22 Folding@home Core ***************************
23:53:23:WU01:FS03:0x22:       Core: Core22
23:53:23:WU01:FS03:0x22:       Type: 0x22
23:53:23:WU01:FS03:0x22:    Version: 0.0.20
23:53:23:WU01:FS03:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:23:WU01:FS03:0x22:  Copyright: 2020 foldingathome.org
23:53:23:WU01:FS03:0x22:   Homepage: https://foldingathome.org/
23:53:23:WU01:FS03:0x22:       Date: Jan 20 2022
23:53:23:WU01:FS03:0x22:       Time: 01:15:36
23:53:23:WU01:FS03:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:53:23:WU01:FS03:0x22:     Branch: HEAD
23:53:23:WU01:FS03:0x22:   Compiler: Visual C++
23:53:23:WU01:FS03:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:53:23:WU01:FS03:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:53:23:WU01:FS03:0x22:   Platform: win32 10
23:53:23:WU01:FS03:0x22:       Bits: 64
23:53:23:WU01:FS03:0x22:       Mode: Release
23:53:23:WU01:FS03:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:53:23:WU01:FS03:0x22:             <peastman@stanford.edu>
23:53:23:WU01:FS03:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6600 -checkpoint 15
23:53:23:WU01:FS03:0x22:             -opencl-platform 1 -opencl-device 1 -gpu-vendor amd -gpu 1
23:53:23:WU01:FS03:0x22:             -gpu-usage 100
23:53:23:WU01:FS03:0x22:************************************ libFAH ************************************
23:53:23:WU01:FS03:0x22:       Time: 01:14:17
23:53:23:WU01:FS03:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:53:23:WU01:FS03:0x22:************************************ CBang *************************************
23:53:23:WU01:FS03:0x22:       Time: 01:13:20
23:53:23:WU01:FS03:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:53:23:WU01:FS03:0x22:************************************ System ************************************
23:53:23:WU01:FS03:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:53:23:WU01:FS03:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:53:23:WU01:FS03:0x22:       CPUs: 4
23:53:23:WU01:FS03:0x22:     Memory: 31.70GiB
23:53:23:WU01:FS03:0x22:Free Memory: 27.58GiB
23:53:23:WU01:FS03:0x22:    Threads: WINDOWS_THREADS
23:53:23:WU01:FS03:0x22: OS Version: 6.2
23:53:23:WU01:FS03:0x22:Has Battery: false
23:53:23:WU01:FS03:0x22: On Battery: false
23:53:23:WU01:FS03:0x22: UTC Offset: -7
23:53:23:WU01:FS03:0x22:        PID: 9868
23:53:23:WU01:FS03:0x22:        CWD: C:\ProgramData\FAHClient\work
23:53:23:WU01:FS03:0x22:************************************ OpenMM ************************************
23:53:23:WU01:FS03:0x22:    Version: 7.7.0
23:53:23:WU01:FS03:0x22:********************************************************************************
23:53:23:WU01:FS03:0x22:Project: 18447 (Run 0, Clone 81, Gen 373)
23:53:23:WU01:FS03:0x22:Reading tar file core.xml
23:53:23:WU01:FS03:0x22:Reading tar file integrator.xml
23:53:23:WU01:FS03:0x22:Reading tar file state.xml
23:53:23:WU01:FS03:0x22:Reading tar file system.xml
23:53:23:WU01:FS03:0x22:Digital signatures verified
23:53:23:WU01:FS03:0x22:Folding@home GPU Core22 Folding@home Core
23:53:23:WU01:FS03:0x22:Version 0.0.20
23:53:26:WU04:FS02:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
23:53:26:WU04:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
23:53:26:WU04:FS02:0x22:  XTC frame write interval: 250000 steps (10%) [10 total]
23:53:26:WU04:FS02:0x22:  Global context and integrator variables write interval: disabled
23:53:26:WU04:FS02:0x22:There are 3 platforms available.
23:53:26:WU04:FS02:0x22:Platform 0: Reference
23:53:26:WU04:FS02:0x22:Platform 1: CPU
23:53:26:WU04:FS02:0x22:Platform 2: OpenCL
23:53:26:WU04:FS02:0x22:  opencl-device 5 specified
23:53:26:WU03:FS04:Downloading 26.58MiB
23:53:30:WU03:FS04:Download complete
23:53:30:WU03:FS04:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:18213 run:24596 clone:0 gen:38 core:0x22 unit:0x00000000000000260000472500006014
23:53:30:WU03:FS04:Starting
23:53:30:WU03:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 2 -gpu-vendor amd -gpu 2 -gpu-usage 100
23:53:30:WU03:FS04:Started FahCore on PID 456
23:53:30:WU03:FS04:Core PID:10656
23:53:30:WU03:FS04:FahCore 0x22 started
23:53:31:WU03:FS04:0x22:*********************** Log Started 2022-09-27T23:53:30Z ***********************
23:53:31:WU03:FS04:0x22:*************************** Core22 Folding@home Core ***************************
23:53:31:WU03:FS04:0x22:       Core: Core22
23:53:31:WU03:FS04:0x22:       Type: 0x22
23:53:31:WU03:FS04:0x22:    Version: 0.0.20
23:53:31:WU03:FS04:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:31:WU03:FS04:0x22:  Copyright: 2020 foldingathome.org
23:53:31:WU03:FS04:0x22:   Homepage: https://foldingathome.org/
23:53:31:WU03:FS04:0x22:       Date: Jan 20 2022
23:53:31:WU03:FS04:0x22:       Time: 01:15:36
23:53:31:WU03:FS04:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:53:31:WU03:FS04:0x22:     Branch: HEAD
23:53:31:WU03:FS04:0x22:   Compiler: Visual C++
23:53:31:WU03:FS04:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:53:31:WU03:FS04:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:53:31:WU03:FS04:0x22:   Platform: win32 10
23:53:31:WU03:FS04:0x22:       Bits: 64
23:53:31:WU03:FS04:0x22:       Mode: Release
23:53:31:WU03:FS04:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:53:31:WU03:FS04:0x22:             <peastman@stanford.edu>
23:53:31:WU03:FS04:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 456 -checkpoint 15
23:53:31:WU03:FS04:0x22:             -opencl-platform 1 -opencl-device 2 -gpu-vendor amd -gpu 2
23:53:31:WU03:FS04:0x22:             -gpu-usage 100
23:53:31:WU03:FS04:0x22:************************************ libFAH ************************************
23:53:31:WU03:FS04:0x22:       Time: 01:14:17
23:53:31:WU03:FS04:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:53:31:WU03:FS04:0x22:************************************ CBang *************************************
23:53:31:WU03:FS04:0x22:       Time: 01:13:20
23:53:31:WU03:FS04:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:53:31:WU03:FS04:0x22:************************************ System ************************************
23:53:31:WU03:FS04:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:53:31:WU03:FS04:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:53:31:WU03:FS04:0x22:       CPUs: 4
23:53:31:WU03:FS04:0x22:     Memory: 31.70GiB
23:53:31:WU03:FS04:0x22:Free Memory: 25.38GiB
23:53:31:WU03:FS04:0x22:    Threads: WINDOWS_THREADS
23:53:31:WU03:FS04:0x22: OS Version: 6.2
23:53:31:WU03:FS04:0x22:Has Battery: false
23:53:31:WU03:FS04:0x22: On Battery: false
23:53:31:WU03:FS04:0x22: UTC Offset: -7
23:53:31:WU03:FS04:0x22:        PID: 10656
23:53:31:WU03:FS04:0x22:        CWD: C:\ProgramData\FAHClient\work
23:53:31:WU03:FS04:0x22:************************************ OpenMM ************************************
23:53:31:WU03:FS04:0x22:    Version: 7.7.0
23:53:31:WU03:FS04:0x22:********************************************************************************
23:53:31:WU03:FS04:0x22:Project: 18213 (Run 24596, Clone 0, Gen 38)
23:53:31:WU03:FS04:0x22:Reading tar file core.xml
23:53:31:WU03:FS04:0x22:Reading tar file integrator.xml
23:53:31:WU03:FS04:0x22:Reading tar file state.xml
23:53:32:WU03:FS04:0x22:Reading tar file system.xml
23:53:33:WU01:FS03:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
23:53:33:WU01:FS03:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
23:53:33:WU01:FS03:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
23:53:33:WU01:FS03:0x22:  Global context and integrator variables write interval: disabled
23:53:33:WU01:FS03:0x22:There are 3 platforms available.
23:53:33:WU01:FS03:0x22:Platform 0: Reference
23:53:33:WU01:FS03:0x22:Platform 1: CPU
23:53:33:WU01:FS03:0x22:Platform 2: OpenCL
23:53:33:WU01:FS03:0x22:  opencl-device 1 specified
23:53:33:WU03:FS04:0x22:Digital signatures verified
23:53:33:WU03:FS04:0x22:Folding@home GPU Core22 Folding@home Core
23:53:33:WU03:FS04:0x22:Version 0.0.20
23:53:43:WU01:FS03:0x22:Attempting to create OpenCL context:
23:53:43:WU01:FS03:0x22:  Configuring platform OpenCL
23:53:43:WU01:FS03:0x22:Failed to create OpenCL context:
23:53:43:WU01:FS03:0x22:Illegal value for DeviceIndex: 1
23:53:43:WU01:FS03:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
23:53:43:WU01:FS03:0x22:Saving result file ..\logfile_01.txt
23:53:43:WU01:FS03:0x22:Saving result file science.log
23:53:43:WU01:FS03:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
23:53:46:WU03:FS04:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
23:53:46:WU03:FS04:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
23:53:46:WU03:FS04:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
23:53:46:WU03:FS04:0x22:  Global context and integrator variables write interval: disabled
23:53:46:WU03:FS04:0x22:There are 3 platforms available.
23:53:46:WU03:FS04:0x22:Platform 0: Reference
23:53:46:WU03:FS04:0x22:Platform 1: CPU
23:53:46:WU03:FS04:0x22:Platform 2: OpenCL
23:53:46:WU03:FS04:0x22:  opencl-device 2 specified
23:53:48:WU00:FS01:0x22:Attempting to create OpenCL context:
23:53:48:WU00:FS01:0x22:  Configuring platform OpenCL
23:53:48:WU00:FS01:0x22:Failed to create OpenCL context:
23:53:48:WU00:FS01:0x22:Illegal value for DeviceIndex: 4
23:53:48:WU00:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
23:53:48:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
23:53:48:WU02:FS05:0x22:Attempting to create OpenCL context:
23:53:48:WU02:FS05:0x22:  Configuring platform OpenCL
23:53:48:WU02:FS05:0x22:Failed to create OpenCL context:
23:53:48:WU02:FS05:0x22:Illegal value for DeviceIndex: 3
23:53:48:WU02:FS05:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
23:53:48:WU02:FS05:0x22:Saving result file ..\logfile_01.txt
23:53:48:WU02:FS05:0x22:Saving result file science.log
23:53:48:WU02:FS05:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
23:53:48:WU00:FS01:0x22:Saving result file science.log
23:53:48:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
23:53:49:WU05:FS06:0x22:Attempting to create OpenCL context:
23:53:49:WU05:FS06:0x22:  Configuring platform OpenCL
23:53:50:WARNING:WU01:FS03:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:53:50:WU01:FS03:Sending unit results: id:01 state:SEND error:FAULTY project:18447 run:0 clone:81 gen:373 core:0x22 unit:0x00000051000001750000480f00000000
23:53:50:WU01:FS03:Uploading 12.00KiB to 129.32.209.202
23:53:50:WU01:FS03:Connecting to 129.32.209.202:8080
23:53:50:WU01:FS03:Upload complete
23:53:50:WU01:FS03:Server responded WORK_ACK (400)
23:53:50:WU01:FS03:Cleaning up
23:53:50:WU06:FS03:Connecting to assign1.foldingathome.org:80
23:53:51:WARNING:WU02:FS05:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:53:51:WU02:FS05:Sending unit results: id:02 state:SEND error:FAULTY project:18706 run:0 clone:172 gen:137 core:0x22 unit:0x000000ac000000890000491200000000
23:53:51:WU02:FS05:Uploading 17.50KiB to 34.72.228.44
23:53:51:WU02:FS05:Connecting to 34.72.228.44:8080
23:53:51:WU02:FS05:Upload complete
23:53:51:WU02:FS05:Server responded WORK_ACK (400)
23:53:51:WU02:FS05:Cleaning up
23:53:51:WU01:FS05:Connecting to assign1.foldingathome.org:80
23:53:51:WU06:FS03:Assigned to work server 206.223.170.146
23:53:51:WU06:FS03:Requesting new work unit for slot 03: gpu:6:0 Navi 10 [Radeon RX 5600 OEM/5600 XT/5700/5700 XT] from 206.223.170.146
23:53:51:WU06:FS03:Connecting to 206.223.170.146:8080
23:53:52:WU01:FS05:Assigned to work server 129.32.209.202
23:53:52:WU01:FS05:Requesting new work unit for slot 05: gpu:9:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 129.32.209.202
23:53:52:WU01:FS05:Connecting to 129.32.209.202:8080
23:53:52:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:53:52:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:18706 run:0 clone:242 gen:126 core:0x22 unit:0x000000f20000007e0000491200000000
23:53:52:WU00:FS01:Uploading 12.50KiB to 34.72.228.44
23:53:52:WU00:FS01:Connecting to 34.72.228.44:8080
23:53:52:WU01:FS05:Downloading 61.42MiB
23:53:52:WU00:FS01:Upload complete
23:53:52:WU00:FS01:Server responded WORK_ACK (400)
23:53:52:WU00:FS01:Cleaning up
23:53:52:WU02:FS01:Connecting to assign1.foldingathome.org:80
23:53:53:WU02:FS01:Assigned to work server 206.223.170.146
23:53:53:WU02:FS01:Requesting new work unit for slot 01: gpu:10:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 206.223.170.146
23:53:53:WU02:FS01:Connecting to 206.223.170.146:8080
23:53:58:WU01:FS05:Download 51.28%
23:54:02:WU06:FS03:Downloading 26.58MiB
23:54:03:WU01:FS05:Download complete
23:54:03:WU01:FS05:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18449 run:2 clone:34 gen:273 core:0x22 unit:0x00000022000001110000481100000002
23:54:03:WU01:FS05:Starting
23:54:03:WU01:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 3 -gpu-vendor amd -gpu 3 -gpu-usage 100
23:54:03:WU01:FS05:Started FahCore on PID 3088
23:54:03:WU01:FS05:Core PID:9888
23:54:03:WU01:FS05:FahCore 0x22 started
23:54:04:WU01:FS05:0x22:*********************** Log Started 2022-09-27T23:54:03Z ***********************
23:54:04:WU01:FS05:0x22:*************************** Core22 Folding@home Core ***************************
23:54:04:WU01:FS05:0x22:       Core: Core22
23:54:04:WU01:FS05:0x22:       Type: 0x22
23:54:04:WU01:FS05:0x22:    Version: 0.0.20
23:54:04:WU01:FS05:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:54:04:WU01:FS05:0x22:  Copyright: 2020 foldingathome.org
23:54:04:WU01:FS05:0x22:   Homepage: https://foldingathome.org/
23:54:04:WU01:FS05:0x22:       Date: Jan 20 2022
23:54:04:WU01:FS05:0x22:       Time: 01:15:36
23:54:04:WU01:FS05:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:54:04:WU01:FS05:0x22:     Branch: HEAD
23:54:04:WU01:FS05:0x22:   Compiler: Visual C++
23:54:04:WU01:FS05:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:54:04:WU01:FS05:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:54:04:WU01:FS05:0x22:   Platform: win32 10
23:54:04:WU01:FS05:0x22:       Bits: 64
23:54:04:WU01:FS05:0x22:       Mode: Release
23:54:04:WU01:FS05:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:54:04:WU01:FS05:0x22:             <peastman@stanford.edu>
23:54:04:WU01:FS05:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3088 -checkpoint 15
23:54:04:WU01:FS05:0x22:             -opencl-platform 1 -opencl-device 3 -gpu-vendor amd -gpu 3
23:54:04:WU01:FS05:0x22:             -gpu-usage 100
23:54:04:WU01:FS05:0x22:************************************ libFAH ************************************
23:54:04:WU01:FS05:0x22:       Time: 01:14:17
23:54:04:WU01:FS05:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:54:04:WU01:FS05:0x22:************************************ CBang *************************************
23:54:04:WU01:FS05:0x22:       Time: 01:13:20
23:54:04:WU01:FS05:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:54:04:WU01:FS05:0x22:************************************ System ************************************
23:54:04:WU01:FS05:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:54:04:WU01:FS05:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:54:04:WU01:FS05:0x22:       CPUs: 4
23:54:04:WU01:FS05:0x22:     Memory: 31.70GiB
23:54:04:WU01:FS05:0x22:Free Memory: 27.20GiB
23:54:04:WU01:FS05:0x22:    Threads: WINDOWS_THREADS
23:54:04:WU01:FS05:0x22: OS Version: 6.2
23:54:04:WU01:FS05:0x22:Has Battery: false
23:54:04:WU01:FS05:0x22: On Battery: false
23:54:04:WU01:FS05:0x22: UTC Offset: -7
23:54:04:WU01:FS05:0x22:        PID: 9888
23:54:04:WU01:FS05:0x22:        CWD: C:\ProgramData\FAHClient\work
23:54:04:WU01:FS05:0x22:************************************ OpenMM ************************************
23:54:04:WU01:FS05:0x22:    Version: 7.7.0
23:54:04:WU01:FS05:0x22:********************************************************************************
23:54:04:WU01:FS05:0x22:Project: 18449 (Run 2, Clone 34, Gen 273)
23:54:04:WU01:FS05:0x22:Reading tar file core.xml
23:54:04:WU01:FS05:0x22:Reading tar file integrator.xml
23:54:04:WU01:FS05:0x22:Reading tar file state.xml
23:54:04:WU01:FS05:0x22:Reading tar file system.xml
23:54:04:WU01:FS05:0x22:Digital signatures verified
23:54:04:WU01:FS05:0x22:Folding@home GPU Core22 Folding@home Core
23:54:04:WU01:FS05:0x22:Version 0.0.20
23:54:04:WU02:FS01:Downloading 26.57MiB
23:54:07:WU06:FS03:Download complete
23:54:07:WU06:FS03:Received Unit: id:06 state:DOWNLOAD error:NO_ERROR project:18213 run:8937 clone:0 gen:38 core:0x22 unit:0x000000000000002600004725000022e9
23:54:07:WU06:FS03:Starting
23:54:07:WU06:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 06 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 1 -gpu-vendor amd -gpu 1 -gpu-usage 100
23:54:07:WU06:FS03:Started FahCore on PID 10672
23:54:07:WU06:FS03:Core PID:10224
23:54:07:WU06:FS03:FahCore 0x22 started
23:54:07:WU06:FS03:0x22:*********************** Log Started 2022-09-27T23:54:07Z ***********************
23:54:07:WU06:FS03:0x22:*************************** Core22 Folding@home Core ***************************
23:54:07:WU06:FS03:0x22:       Core: Core22
23:54:07:WU06:FS03:0x22:       Type: 0x22
23:54:07:WU06:FS03:0x22:    Version: 0.0.20
23:54:07:WU06:FS03:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:54:07:WU06:FS03:0x22:  Copyright: 2020 foldingathome.org
23:54:07:WU06:FS03:0x22:   Homepage: https://foldingathome.org/
23:54:07:WU06:FS03:0x22:       Date: Jan 20 2022
23:54:07:WU06:FS03:0x22:       Time: 01:15:36
23:54:07:WU06:FS03:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:54:07:WU06:FS03:0x22:     Branch: HEAD
23:54:07:WU06:FS03:0x22:   Compiler: Visual C++
23:54:07:WU06:FS03:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:54:07:WU06:FS03:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:54:07:WU06:FS03:0x22:   Platform: win32 10
23:54:07:WU06:FS03:0x22:       Bits: 64
23:54:07:WU06:FS03:0x22:       Mode: Release
23:54:07:WU06:FS03:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:54:07:WU06:FS03:0x22:             <peastman@stanford.edu>
23:54:07:WU06:FS03:0x22:       Args: -dir 06 -suffix 01 -version 706 -lifeline 10672 -checkpoint 15
23:54:07:WU06:FS03:0x22:             -opencl-platform 1 -opencl-device 1 -gpu-vendor amd -gpu 1
23:54:07:WU06:FS03:0x22:             -gpu-usage 100
23:54:07:WU06:FS03:0x22:************************************ libFAH ************************************
23:54:07:WU06:FS03:0x22:       Time: 01:14:17
23:54:07:WU06:FS03:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:54:07:WU06:FS03:0x22:************************************ CBang *************************************
23:54:07:WU06:FS03:0x22:       Time: 01:13:20
23:54:07:WU06:FS03:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:54:07:WU06:FS03:0x22:************************************ System ************************************
23:54:07:WU06:FS03:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:54:07:WU06:FS03:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:54:07:WU06:FS03:0x22:       CPUs: 4
23:54:07:WU06:FS03:0x22:     Memory: 31.70GiB
23:54:07:WU06:FS03:0x22:Free Memory: 26.22GiB
23:54:07:WU06:FS03:0x22:    Threads: WINDOWS_THREADS
23:54:07:WU06:FS03:0x22: OS Version: 6.2
23:54:07:WU06:FS03:0x22:Has Battery: false
23:54:07:WU06:FS03:0x22: On Battery: false
23:54:07:WU06:FS03:0x22: UTC Offset: -7
23:54:07:WU06:FS03:0x22:        PID: 10224
23:54:07:WU06:FS03:0x22:        CWD: C:\ProgramData\FAHClient\work
23:54:07:WU06:FS03:0x22:************************************ OpenMM ************************************
23:54:07:WU06:FS03:0x22:    Version: 7.7.0
23:54:07:WU06:FS03:0x22:********************************************************************************
23:54:07:WU06:FS03:0x22:Project: 18213 (Run 8937, Clone 0, Gen 38)
23:54:07:WU06:FS03:0x22:Reading tar file core.xml
23:54:07:WU06:FS03:0x22:Reading tar file integrator.xml
23:54:07:WU06:FS03:0x22:Reading tar file state.xml
23:54:09:WU06:FS03:0x22:Reading tar file system.xml
23:54:10:WU02:FS01:Download 64.92%
23:54:10:WU06:FS03:0x22:Digital signatures verified
23:54:10:WU06:FS03:0x22:Folding@home GPU Core22 Folding@home Core
23:54:10:WU06:FS03:0x22:Version 0.0.20
23:54:10:WU04:FS02:0x22:Attempting to create OpenCL context:
23:54:10:WU04:FS02:0x22:  Configuring platform OpenCL
23:54:10:WU04:FS02:0x22:Failed to create OpenCL context:
23:54:10:WU04:FS02:0x22:Illegal value for DeviceIndex: 5
23:54:10:WU04:FS02:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
23:54:10:WU04:FS02:0x22:Saving result file ..\logfile_01.txt
23:54:10:WU04:FS02:0x22:Saving result file science.log
23:54:10:WU04:FS02:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
23:54:11:WU02:FS01:Download complete
23:54:11:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:18213 run:8942 clone:0 gen:38 core:0x22 unit:0x000000000000002600004725000022ee
23:54:11:WU02:FS01:Starting
23:54:11:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 11148 -checkpoint 15 -opencl-platform 1 -opencl-device 4 -gpu-vendor amd -gpu 4 -gpu-usage 100
23:54:11:WU02:FS01:Started FahCore on PID 10968
23:54:11:WU02:FS01:Core PID:4968
23:54:11:WU02:FS01:FahCore 0x22 started
23:54:12:WU02:FS01:0x22:*********************** Log Started 2022-09-27T23:54:11Z ***********************
23:54:12:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:54:12:WU02:FS01:0x22:       Core: Core22
23:54:12:WU02:FS01:0x22:       Type: 0x22
23:54:12:WU02:FS01:0x22:    Version: 0.0.20
23:54:12:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:54:12:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
23:54:12:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
23:54:12:WU02:FS01:0x22:       Date: Jan 20 2022
23:54:12:WU02:FS01:0x22:       Time: 01:15:36
23:54:12:WU02:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
23:54:12:WU02:FS01:0x22:     Branch: HEAD
23:54:12:WU02:FS01:0x22:   Compiler: Visual C++
23:54:12:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:54:12:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
23:54:12:WU02:FS01:0x22:   Platform: win32 10
23:54:12:WU02:FS01:0x22:       Bits: 64
23:54:12:WU02:FS01:0x22:       Mode: Release
23:54:12:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:54:12:WU02:FS01:0x22:             <peastman@stanford.edu>
23:54:12:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 10968 -checkpoint 15
23:54:12:WU02:FS01:0x22:             -opencl-platform 1 -opencl-device 4 -gpu-vendor amd -gpu 4
23:54:12:WU02:FS01:0x22:             -gpu-usage 100
23:54:12:WU02:FS01:0x22:************************************ libFAH ************************************
23:54:12:WU02:FS01:0x22:       Time: 01:14:17
23:54:12:WU02:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
23:54:12:WU02:FS01:0x22:************************************ CBang *************************************
23:54:12:WU02:FS01:0x22:       Time: 01:13:20
23:54:12:WU02:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
23:54:12:WU02:FS01:0x22:************************************ System ************************************
23:54:12:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
23:54:12:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:54:12:WU02:FS01:0x22:       CPUs: 4
23:54:12:WU02:FS01:0x22:     Memory: 31.70GiB
23:54:12:WU02:FS01:0x22:Free Memory: 26.33GiB
23:54:12:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
23:54:12:WU02:FS01:0x22: OS Version: 6.2
23:54:12:WU02:FS01:0x22:Has Battery: false
23:54:12:WU02:FS01:0x22: On Battery: false
23:54:12:WU02:FS01:0x22: UTC Offset: -7
23:54:12:WU02:FS01:0x22:        PID: 4968
23:54:12:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
23:54:12:WU02:FS01:0x22:************************************ OpenMM ************************************
23:54:12:WU02:FS01:0x22:    Version: 7.7.0
23:54:12:WU02:FS01:0x22:********************************************************************************
23:54:12:WU02:FS01:0x22:Project: 18213 (Run 8942, Clone 0, Gen 38)
23:54:12:WU02:FS01:0x22:Reading tar file core.xml
23:54:12:WU02:FS01:0x22:Reading tar file integrator.xml
23:54:12:WU02:FS01:0x22:Reading tar file state.xml
23:54:12:WU03:FS04:0x22:Attempting to create OpenCL context:
23:54:12:WU03:FS04:0x22:  Configuring platform OpenCL
23:54:12:WU03:FS04:0x22:Failed to create OpenCL context:
23:54:12:WU03:FS04:0x22:Illegal value for DeviceIndex: 2
23:54:12:WU03:FS04:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
23:54:12:WU03:FS04:0x22:Saving result file ..\logfile_01.txt
23:54:12:WU03:FS04:0x22:Saving result file science.log
23:54:12:WU03:FS04:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
23:54:12:WU02:FS01:0x22:Reading tar file system.xml
23:54:13:WU01:FS05:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
23:54:13:WU01:FS05:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
23:54:13:WU01:FS05:0x22:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
23:54:13:WU01:FS05:0x22:  Global context and integrator variables write interval: disabled
23:54:13:WU01:FS05:0x22:There are 3 platforms available.
23:54:13:WU01:FS05:0x22:Platform 0: Reference
23:54:13:WU01:FS05:0x22:Platform 1: CPU
23:54:13:WU01:FS05:0x22:Platform 2: OpenCL
23:54:13:WU01:FS05:0x22:  opencl-device 3 specified
23:54:13:WU02:FS01:0x22:Digital signatures verified
23:54:13:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:54:13:WU02:FS01:0x22:Version 0.0.20
23:54:14:WARNING:WU04:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:54:14:WU04:FS02:Sending unit results: id:04 state:SEND error:FAULTY project:18500 run:1 clone:147 gen:221 core:0x22 unit:0x00000093000000dd0000484400000001
23:54:14:WU04:FS02:Uploading 17.50KiB to 140.163.4.200
23:54:14:WU04:FS02:Connecting to 140.163.4.200:8080
23:54:15:WARNING:WU03:FS04:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:54:15:WU03:FS04:Sending unit results: id:03 state:SEND error:FAULTY project:18213 run:24596 clone:0 gen:38 core:0x22 unit:0x00000000000000260000472500006014
23:54:15:WU03:FS04:Uploading 2.69KiB to 206.223.170.146
23:54:15:WU03:FS04:Connecting to 206.223.170.146:8080
23:54:15:WU04:FS02:Upload complete
23:54:15:WU04:FS02:Server responded WORK_ACK (400)
23:54:15:WU04:FS02:Cleaning up
23:54:15:WU03:FS04:Upload complete
23:54:15:WU00:FS02:Connecting to assign1.foldingathome.org:80
23:54:16:WU04:FS04:Connecting to assign1.foldingathome.org:80
23:54:16:WU03:FS04:Server responded WORK_ACK (400)
In F@H, one CPU thread is reserved for the OS and one core is reserved for each GPU. Since you have 4 cores, you can run 3 GPUs.
TheDevil
Post by TheDevil »
I am confused, as a computer engineer that makes no sense that an application like this would need exclusive controll over a whole core.
TheDevil
Post by TheDevil »
JimboPalmer wrote: Tue Sep 27, 2022 9:19 pm In F@H, one CPU thread is reserved for the OS and one core is reserved for each GPU. Since you have 4 cores, you can run 3 GPUs.
I believe you are wrong. My other machine is a 7400t (4 cores, 4 threads) is HAPPILY running 9 gpus right nw.
TheDevil
Post by TheDevil »
This is my other rig, that is working fine with only 4 cores.
*********************** Log Started 2022-09-27T13:21:00Z ***********************
13:21:00:******************************* libFAH ********************************
13:21:00:            Date: Oct 20 2020
13:21:00:            Time: 13:36:55
13:21:00:        Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:21:00:          Branch: master
13:21:00:        Compiler: Visual C++ 2015
13:21:00:         Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:21:00:        Platform: win32 10
13:21:00:            Bits: 32
13:21:00:            Mode: Release
13:21:00:****************************** FAHClient ******************************
13:21:00:         Version: 7.6.21
13:21:00:          Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:21:00:       Copyright: 2020 foldingathome.org
13:21:00:        Homepage: https://foldingathome.org/
13:21:00:            Time: 13:41:04
13:21:00:        Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:21:00:            Bits: 32
13:21:00:            Args: --open-web-control
13:21:00:          Config: C:\ProgramData\FAHClient\config.xml
13:21:00:******************************** CBang ********************************
13:21:00:            Time: 11:36:18
13:21:00:        Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:21:00:            Bits: 32
13:21:00:******************************* System ********************************
13:21:00:             CPU: Intel(R) Core(TM) i5-7400T CPU @ 2.40GHz
13:21:00:          CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
13:21:00:            CPUs: 4
13:21:00:          Memory: 15.93GiB
13:21:00:     Free Memory: 13.57GiB
13:21:00:         Threads: WINDOWS_THREADS
13:21:00:      OS Version: 6.2
13:21:00:     Has Battery: false
13:21:00:      On Battery: false
13:21:00:      UTC Offset: -4
13:21:00:             PID: 7968
13:21:00:             CWD: C:\ProgramData\FAHClient
13:21:00:   Win32 Service: false
13:21:00:              OS: Windows 10 Enterprise
13:21:00:         OS Arch: AMD64
13:21:00:            GPUs: 10
13:21:00:           GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
13:21:00:           GPU 1: Bus:10 Slot:0 Func:0 NVIDIA:7 GP102 [GeForce GTX 1080 Ti]
13:21:00:                  11380
13:21:00:           GPU 2: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
13:21:00:           GPU 3: Bus:8 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
13:21:00:           GPU 4: Bus:5 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
13:21:00:           GPU 5: Bus:3 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
13:21:00:           GPU 6: Bus:9 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
13:21:00:           GPU 7: Bus:4 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
13:21:00:           GPU 8: Bus:2 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070 Ti] 8186
13:21:00:           GPU 9: Bus:7 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
13:21:00:   CUDA Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 2: Platform:0 Device:2 Bus:1 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 3: Platform:0 Device:3 Bus:3 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 4: Platform:0 Device:4 Bus:4 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 5: Platform:0 Device:5 Bus:5 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 6: Platform:0 Device:6 Bus:7 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 7: Platform:0 Device:7 Bus:8 Slot:0 Compute:6.1 Driver:11.6
13:21:00:   CUDA Device 8: Platform:0 Device:8 Bus:9 Slot:0 Compute:6.1 Driver:11.6
13:21:00: OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
13:21:00: OpenCL Device 2: Platform:1 Device:0 Bus:10 Slot:0 Compute:3.0 Driver:512.15
13:21:00: OpenCL Device 3: Platform:1 Device:1 Bus:2 Slot:0 Compute:3.0 Driver:512.15
13:21:00: OpenCL Device 4: Platform:1 Device:2 Bus:1 Slot:0 Compute:3.0 Driver:512.15
13:21:00: OpenCL Device 5: Platform:1 Device:3 Bus:3 Slot:0 Compute:3.0 Driver:512.15
13:21:00: OpenCL Device 6: Platform:1 Device:4 Bus:4 Slot:0 Compute:3.0 Driver:512.15
13:21:00: OpenCL Device 7: Platform:1 Device:5 Bus:5 Slot:0 Compute:3.0 Driver:512.15
13:21:00: OpenCL Device 8: Platform:1 Device:6 Bus:7 Slot:0 Compute:3.0 Driver:512.15
13:21:00: OpenCL Device 9: Platform:1 Device:7 Bus:8 Slot:0 Compute:3.0 Driver:512.15
13:21:00:OpenCL Device 10: Platform:1 Device:8 Bus:9 Slot:0 Compute:3.0 Driver:512.15
13:21:00:***********************************************************************
13:21:00:<config>
You can oversubscribe the CPU threads, and folding will still run with some reduction in performance as the GPUs will need to wait at times for the CPU to prepare the next packet of data to be processed on the GPU. In the past it was less of an issue with AMD GPUs running OpenCL than with Nvidia GPUs running OpenCL due to differences in how the drivers implemented I/O waits.
I can see a couple potential sources of problems. First is that the iGPU on your Intel processor is being detected as being available for OpenCL processing. In the past this sometimes caused problems by having the wrong OpenCL DLL be used. If you are not using it for a video connection to a monitor, try disabling it. Or install just the video driver support w/o the OpenCL support if you need it for a monitor.
The other potential issue is running GPUs from two different series of the architecture. Your RX 580s are GCN 4th Gen cards and the RX 5700s are NAVI 10 RDNA based cards. They will need different drivers installed even if they are from the same version driver installer. That can run into conflicts with the wrong code being generated for GPUs to process. If disabling the Intel iGPU doesn't help, try running with just the RX 5700s installed.
TheDevil
Post by TheDevil »
Joe_H wrote: Tue Sep 27, 2022 11:13 pm You can oversubscribe the CPU threads, and folding will still run with some reduction in performance as the GPUs will need to wait at times for the CPU to prepare the next packet of data to be processed on the GPU. In the past it was less of an issue with AMD GPUs running OpenCL than with Nvidia GPUs running OpenCL due to differences in how the drivers implemented I/O waits.
Okay i am upgrade these both to an i7 that would give each at least 8 threads, that's fine. now my question is would it be better to use virtual box and pass the gpus into a VM then?
Master991
Post by Master991 »
Hello! I've ran into similar problem I guess. PC fails to download WU's and it happened suddenly.
I reinstalled F@H, cleaned work directoty, reinstalled Windows and still can't start folding again.
If someone could help I'd appreciate it alot
Log:
*********************** Log Started 2022-11-07T18:48:30Z ***********************
18:48:30:****************************** FAHClient ******************************
18:48:30: Version: 7.6.9
18:48:30: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:48:30: Copyright: 2020 foldingathome.org
18:48:30: Homepage: https://foldingathome.org/
18:48:30: Date: Apr 17 2020
18:48:30: Time: 11:13:06
18:48:30: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
18:48:30: Branch: master
18:48:30: Compiler: Visual C++ 2008
18:48:30: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:48:30: Platform: win32 10
18:48:30: Bits: 32
18:48:30: Mode: Release
18:48:30: Args: --open-web-control
18:48:30: Config: C:\Program Files (x86)\FAHClient\Data\config.xml
18:48:30:******************************** CBang ********************************
18:48:30: Time: 11:10:09
18:48:30: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
18:48:30: Bits: 32
18:48:30:******************************* System ********************************
18:48:30: CPU: AMD Ryzen 7 5800X 8-Core Processor
18:48:30: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
18:48:30: CPUs: 16
18:48:30: Memory: 31.91GiB
18:48:30: Free Memory: 27.87GiB
18:48:30: Threads: WINDOWS_THREADS
18:48:30: OS Version: 6.2
18:48:30: Has Battery: false
18:48:30: On Battery: false
18:48:30: UTC Offset: 3
18:48:30: PID: 12040
18:48:30: CWD: C:\Program Files (x86)\FAHClient\Data
18:48:30: OS: Windows 10 Enterprise
18:48:30: OS Arch: AMD64
18:48:30: GPUs: 2
18:48:30: GPU 0: Bus:9 Slot:0 Func:0 AMD:4 Hawaii PRO [R9 290/390]
18:48:30: GPU 1: Bus:10 Slot:0 Func:0 AMD:4 Hawaii PRO [R9 290/390]
18:48:30: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': 5
18:48:30: =0945= C:070==K9 <>4C;L.
18:48:30:
18:48:30:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3240.7
18:48:30:OpenCL Device 1: Platform:0 Device:1 Bus:10 Slot:0 Compute:1.2 Driver:3240.7
18:48:30: Win32 Service: false
18:48:30:******************************* libFAH ********************************
18:48:30: Date: Apr 15 2020
18:48:30: Time: 14:53:14
18:48:30: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:48:30: Bits: 32
18:48:30:***********************************************************************
18:48:31:<config>
18:48:31: <!-- Network -->
18:48:31: <proxy v=':8080'/>
18:48:31:
18:48:31: <!-- Slot Control -->
18:48:31: <power v='FULL'/>
18:48:31:
18:48:31: <!-- User Information -->
18:48:31: <passkey v='*****'/>
18:48:31: <team v='47191'/>
18:48:31: <user v='Master991'/>
18:48:31:
18:48:31: <!-- Folding Slots -->
18:48:31: <slot id='0' type='GPU'/>
18:48:31:</config>
18:48:31:Trying to access database...
18:48:31:Successfully acquired database lock
18:48:31:Enabled folding slot 00: READY gpu:0:Hawaii PRO [R9 290/390]
18:48:31:WU00:FS00:Connecting to 13.59.134.176:80
18:48:32:WU00:FS00:Assigned to work server 129.32.209.202
18:48:32:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Hawaii PRO [R9 290/390] from 129.32.209.202
18:48:32:WU00:FS00:Connecting to 129.32.209.202:8080
18:48:35:16:127.0.0.1:New Web session
18:48:53:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:48:53:WU00:FS00:Connecting to 129.32.209.202:80
18:49:14:ERROR:WU00:FS00:Exception: Failed to connect to 129.32.209.202:80: >?KB:0 CAB0=>28BL A>548=5=85 1K;0 157CA?5H=>9, B.:. >B 4@C3>3> :><?LNB5@0 70 B@51C5<>5 2@5<O =5 ?>;CG5= =C6=K9 >B:;8:, 8;8 1K;> @07>@20=> C65 CAB0=>2;5==>5 A>548=5=85 87-70 =525@=>3> >B:;8:0 C65 ?>4:;NG5==>3> :><?LNB5@0.
18:49:15:WU00:FS00:Connecting to 13.59.134.176:80
18:49:15:WU00:FS00:Assigned to work server 129.32.209.202
18:49:15:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Hawaii PRO [R9 290/390] from 129.32.209.202
18:49:15:WU00:FS00:Connecting to 129.32.209.202:8080
18:49:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:49:37:WU00:FS00:Connecting to 129.32.209.202:80
18:49:58:ERROR:WU00:FS00:Exception: Failed to connect to 129.32.209.202:80: >?KB:0 CAB0=>28BL A>548=5=85 1K;0 157CA?5H=>9, B.:. >B 4@C3>3> :><?LNB5@0 70 B@51C5<>5 2@5<O =5 ?>;CG5= =C6=K9 >B:;8:, 8;8 1K;> @07>@20=> C65 CAB0=>2;5==>5 A>548=5=85 87-70 =525@=>3> >B:;8:0 C65 ?>4:;NG5==>3> :><?LNB5@0.
18:50:15:WU00:FS00:Connecting to 13.59.134.176:80
18:50:16:WU00:FS00:Assigned to work server 129.32.209.202
18:50:16:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Hawaii PRO [R9 290/390] from 129.32.209.202
18:50:16:WU00:FS00:Connecting to 129.32.209.202:8080
18:50:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:50:37:WU00:FS00:Connecting to 129.32.209.202:80
Re: AMD Cards Failing out
Master991 wrote: Mon Nov 07, 2022 7:55 pm Hello! I've ran into similar problem I guess. PC fails to download WU's and it happened suddenly.
In your case I suspect your connection is bing blocked by the firewall at the institution where the work server is located. Spammers, hackers, and others have resulted in large blocks of IP addresses in your country being blacklisted. I would recommend trying through a VPN connection if have access to one.
