i have a mac mini m1 (base model), and while the installation of f@h 7.6.21 went well, i have a problem with f@h control.
it stops every some seconds, then starts after somes seconds while the status shows it's updating/connecting.
what's the source of the problem???
thanks!!!
F@H Control problem.
Re: F@H Control problem.
See this post and let us know if it helps - viewtopic.php?p=353629#p353629. There have been some changes in macOS since the installer was created, the suggested changes should help.
seems to work!!! thanks Joe!!!Joe_H wrote: ↑Fri Sep 23, 2022 2:34 pm See this post and let us know if it helps - viewtopic.php?p=353629#p353629. There have been some changes in macOS since the installer was created, the suggested changes should help.
(i put the commands in terminal).
i am new to macs (2 years now)...with windows (contrary to the linux os) i had no problem overall!!!
thanks again!!!
