Only run at certain times ?
Maple38
Post by Maple38 »
Hello, looking for a solution to only have Folding@home run during the day as my PC fans are very loud when I'm trying to sleep. Is there any software that allows this to be done?
PaulTV
Re: Only run at certain times ?
Post by PaulTV »
Currently that's not a standard functionality of the client, but it can be done using the system's task scheduler. See viewtopic.php?p=356264&hilit=send+pause#p356264
Mxyzptlk
Hardware configuration: Lots... Look at my website: www.mxyzptlk.us
Post by Mxyzptlk »
Install this extension in the chrome browser and you can set the times if day that you want to fold.
https://folding.lar.systems/
