Please add AMD Rembrandt IGP
jelmeree
Post by jelmeree »
This one is the IGP from the AMD Ryzen 7 6800H.
Name AMD Radeon (TM) Graphics
Device ID 1002 1681 1043 13ED
*********************** Log Started 2022-09-13T08:49:18Z ***********************
08:49:18:******************************* libFAH ********************************
08:49:18:           Date: Oct 20 2020
08:49:18:           Time: 13:36:55
08:49:18:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
08:49:18:         Branch: master
08:49:18:       Compiler: Visual C++ 2015
08:49:18:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
08:49:18:       Platform: win32 10
08:49:18:           Bits: 32
08:49:18:           Mode: Release
08:49:18:****************************** FAHClient ******************************
08:49:18:        Version: 7.6.21
08:49:18:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:49:18:      Copyright: 2020 foldingathome.org
08:49:18:       Homepage: https://foldingathome.org/
08:49:18:           Time: 13:41:04
08:49:18:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
08:49:18:           Bits: 32
08:49:18:           Args: --open-web-control
08:49:18:         Config: C:\ProgramData\FAHClient\config.xml
08:49:18:******************************** CBang ********************************
08:49:18:           Time: 11:36:18
08:49:18:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
08:49:18:           Bits: 32
08:49:18:******************************* System ********************************
08:49:18:            CPU: AMD Ryzen 7 6800H with Radeon Graphics
08:49:18:         CPU ID: AuthenticAMD Family 25 Model 68 Stepping 1
08:49:18:           CPUs: 16
08:49:18:         Memory: 15.25GiB
08:49:18:    Free Memory: 8.74GiB
08:49:18:        Threads: WINDOWS_THREADS
08:49:18:     OS Version: 6.2
08:49:18:    Has Battery: true
08:49:18:     On Battery: true
08:49:18:     UTC Offset: 2
08:49:18:            PID: 12980
08:49:18:            CWD: C:\ProgramData\FAHClient
08:49:18:  Win32 Service: false
08:49:18:             OS: Windows 10 Home
08:49:18:        OS Arch: AMD64
08:49:18:           GPUs: 2
08:49:18:          GPU 0: Bus:5 Slot:0 Func:0 AMD:1
08:49:18:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:8 GA104M [GeForce RTX 3070 Mobile /
08:49:18:                 Max-Q]
08:49:18:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.6
08:49:18:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:512.78
08:49:18:OpenCL Device 1: Platform:1 Device:0 Bus:5 Slot:0 Compute:1.2 Driver:3444.0
08:49:18:***********************************************************************
08:49:18:<config>
08:49:18:  <!-- Folding Core -->
08:49:18:  <checkpoint v='30'/>
08:49:18:
08:49:18:  <!-- Folding Slot Configuration -->
08:49:18:  <gpu-beta v='true'/>
08:49:18:
08:49:18:  <!-- Network -->
08:49:18:  <proxy v=':8080'/>
08:49:18:
08:49:18:  <!-- Slot Control -->
08:49:18:  <pause-on-battery v='false'/>
08:49:18:  <power v='medium'/>
08:49:18:
08:49:18:  <!-- Folding Slots -->
08:49:18:  <slot id='0' type='CPU'>
08:49:18:    <pause-on-start v='true'/>
08:49:18:  </slot>
08:49:18:  <slot id='1' type='GPU'>
08:49:18:    <pause-on-start v='True'/>
08:49:18:    <pci-bus v='5'/>
08:49:18:    <pci-slot v='0'/>
08:49:18:  </slot>
08:49:18:  <slot id='2' type='GPU'>
08:49:18:    <paused v='True'/>
08:49:18:    <pci-bus v='1'/>
08:49:18:  </slot>
08:49:18:</config>
08:49:18:Trying to access database...
08:49:18:Successfully acquired database lock
08:49:18:FS00:Initialized folding slot 00: cpu:13
08:49:18:FS01:Initialized folding slot 01: gpu:5:0
08:49:18:FS02:Initialized folding slot 02: gpu:1:0 GA104M [GeForce RTX 3070 Mobile / Max-Q]
Re: Please add AMD Rembrandt IGP
I have neither the skill nor the authority to add the GPU, but it does support both OpenCL 2.0 and 64 bit floating point math.
https://www.techpowerup.com/gpu-specs/radeon-680m.c3871
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
I'd be very interested in seeing what kind of performance this gives once it's enabled for folding. I suspect units like this might get in the 150-200k PPD range folding on iGPU if not higher.
On the flip side I suspect they might still be subject to the same bottlenecks as the earlier Ryzen chips when folding on both CPU and iGPU at the same time.
Fold them if you get them!
jelmeree
Post by jelmeree »
The performance should be about the same as the RX 6400, but folding isn't enabled yet for this GPU so I haven't been able to test it. When running both the CPU and IGP I think it will hit power limits.
Added 0x1681 / Rembrandt [Radeon 680M] ...
Thank you!
