Hello,
I have installed folding @ home on a ubuntu server (home server) and I have installed the viewer, but I'm not sure on how to connect to the viewer. For example my servers ip is 192.168.100.110 and I have services like cockpit and apache running (for different reasons). How do I connect to the viewer. My home server does not have a gui due to being headless.
Thanks
Remote computer connection
bikeaddict
Re: Remote computer connection
First, stop the FAHClient service on the server at a root prompt or with sudo:
If the service is still running as it likes to ignore stop signals if it's not paused:
then you can:
Edit /etc/fahclient/config.xml (if it's there on Ubuntu) so it has a line similar to this with the IP address of your desktop viewer:
Add a password for security:
Save config.xml and then restart FAHClient:
You may have to open port 36330 if you're running a firewall on the server.
Then on your desktop viewer, run FAHControl and add a new client with IP address 192.168.100.110 and the password. Once the client is saved, you can configure the server with all the tabs using the Configure button.
service FAHClient stop
or
/etc/init.d/FAHClient stopCode: Select all
ps -ef | grep FAHClientCode: Select all
killall FAHClientCode: Select all
<allow v='127.0.0.1 192.168.100.109'/>Code: Select all
<password v='MyFAHPassword1'/>Code: Select all
service FAHClient start
or
/etc/init.d/FAHClient startThen on your desktop viewer, run FAHControl and add a new client with IP address 192.168.100.110 and the password. Once the client is saved, you can configure the server with all the tabs using the Configure button.
