Project: 2665 (Run 0, Clone 355, Gen 24) Points not awarded?
Great_Gig
Hardware configuration: CPU: Intel Q6600 'GO' @ 2.88GHz (20% Overclock)
Cooling: Thermalright HR-01 Heat Sink + Nexus 120mm Silent Fan
Motherboard: Gigabyte GA-G31M-S2L
RAM: 1GB Kingston HyperX DDR2 800MHz
Disk: 1GB OCZ USB Flash Drive
PSU: Enermax Pro 82+ 385W
O/S: Diskless System - 64bit Linux SMP Client
Monitor: FahMon 2.3.2b
Power Consumption: 84W
Post by Great_Gig »
I wonder if any help can be given for a WU that has been sent successfully to the server, but the points have not yet been awarded?
The WU was completed successfully for Project: 2665 and the results were according to the FAHlog.txt sent to server 171.64.65.64.8080 at 17:17 (GMT) on the 7th July 2008. So far there has been no credit for this completed WU? Does anyone know if there is any reason why this credit has not been awarded due to problems with the server, or have I lost it completely?
I have included the FAHlog.txt showing the progress on the WU and also a screenshot from Kakao showing no credit for this Project: 2665 WU during 7th July 2008. I have just rechecked the Stanford Stats and see that I have been credited today with 1760 points (8th July 08) for a completed Project: 2605 WU, but there is still no credit for yesterdays Project: 2665 WU, which should be a further 1920 points.
Note: The first WU shown in the FAHlog is also for Project: 2665 and the 1920 points were awarded for this at 1900 on 06-07-2008. Any ideas guys or PandeGroup regarding this and if it has been lost, is there anyway I can resend the result, so I don’t lose the 1920 points credit?
Many thanks.
--- Opening Log file [July 5 17:17:12]
# SMP Client ##################################################################
                       Folding@Home Client Version 6.02beta
                          http://folding.stanford.edu
Launch directory: /etc/folding/1
Executable: ./fah6
Arguments: -local -forceasm -verbosity 9 -smp
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[17:17:12] - Ask before connecting: No
[17:17:12] - User name: GreatGig (Team 132987)
[17:17:12] - User ID not found locally
[17:17:12] + Requesting User ID from server
[17:17:12] - Getting ID from AS:
[17:17:12] Connecting to http://assign.stanford.edu:8080/
[17:17:17] Posted data.
[17:17:17] Initial: 064A; - Received User ID = 4A060EE151780CBF
[17:17:17] - Machine ID: 1
[17:17:17]
[17:17:17] Work directory not found. Creating...
[17:17:17] Could not open work queue, generating new queue...
[17:17:17] - Autosending finished units...
[17:17:17] Trying to send all finished work units
[17:17:17] + No unsent completed units remaining.
[17:17:17] - Autosend completed
[17:17:17] - Preparing to get new work unit...
[17:17:17] + Attempting to get work packet
[17:17:17] - Will indicate memory of 998 MB
[17:17:17] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[17:17:17] - Connecting to assignment server
[17:17:17] Connecting to http://assign.stanford.edu:8080/
[17:17:18] Posted data.
[17:17:18] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[17:17:18] + News From Folding@Home: Welcome to Folding@Home
[17:17:18] Loaded queue successfully.
[17:17:18] Connecting to http://171.64.65.64:8080/
[16:16:57] Posted data.
[16:16:57] Initial: 0000; - Receiving payload (expected size: 4738636)
[16:19:14] - Downloaded at ~33 kB/s
[16:19:14] - Averaged speed for that direction ~33 kB/s
[16:19:14] + Received work.
[16:19:14] + Closed connections
[16:19:14]
[16:19:14] + Processing work unit
[16:19:14] Core required: FahCore_a1.exe
[16:19:14] Core not found.
[16:19:14] - Core is not present or corrupted.
[16:19:14] - Attempting to download new core...
[16:19:14] + Downloading new core: FahCore_a1.exe
[16:19:14] Downloading core (/~pande/Linux/x86/Core_a1.fah from www.stanford.edu)
[16:19:15] Initial: AFDE; + 10240 bytes downloaded
 - EDITED to save space -
[16:19:59] Initial: 3A56; + 1484800 bytes downloaded
[16:19:59] Initial: D4FE; + 1490945 bytes downloaded
[16:19:59] Verifying core Core_a1.fah...
[16:19:59] Signature is VALID
[16:19:59]
[16:19:59] Trying to unzip core FahCore_a1.exe
[16:20:00] Decompressed FahCore_a1.exe (3625104 bytes) successfully
[16:20:00] + Core successfully engaged
[16:20:05]
[16:20:05] + Processing work unit
[16:20:05] Core required: FahCore_a1.exe
[16:20:05] Core found.
[16:20:05] Working on Unit 01 [July 5 16:20:05]
[16:20:05] + Working ...
[16:20:05] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 30 -forceasm -verbose -lifeline 524 -version 602'
[16:20:05]
[16:20:05] *------------------------------*
[16:20:05] Folding@Home Gromacs SMP Core
[16:20:05] Version 1.74 (November 27, 2006)
[16:20:05]
[16:20:05] Preparing to commence simulation
[16:20:05] - Ensuring status. Please wait.
[16:20:06] - Starting from initial work packet
[16:20:06]
[16:20:06] Project: 2665 (Run 0, Clone 355, Gen 24)
[16:20:06]
[16:20:06] Assembly optimizations on if available.
[16:20:06] Entering M.D.
[16:20:23]  on if available.
[16:20:23] Entering M.D.
[16:20:30] G in water
[16:20:30] Writing local files
[16:20:30] ocal files
[16:20:30] Extra SSE boost OK.
[16:20:31] al files
[16:20:31] Completed 0 out of 250000 steps  (0 percent)
[16:35:03] Writing local files
[16:35:03] Completed 2500 out of 250000 steps  (1 percent)
[16:49:36] Writing local files
[16:49:36] Completed 5000 out of 250000 steps  (2 percent)
[17:04:09] Writing local files
[17:04:10] Completed 7500 out of 250000 steps  (3 percent)
[17:18:44] Writing local files
[17:18:44] Completed 10000 out of 250000 steps  (4 percent)
[17:33:17] Writing local files
[17:33:18] Completed 12500 out of 250000 steps  (5 percent)
[15:25:17] Completed 237500 out of 250000 steps  (95 percent)
[15:39:54] Writing local files
[15:39:54] Completed 240000 out of 250000 steps  (96 percent)
[15:54:31] Writing local files
[15:54:31] Completed 242500 out of 250000 steps  (97 percent)
[16:09:06] Writing local files
[16:09:06] Completed 245000 out of 250000 steps  (98 percent)
[16:16:51] - Autosending finished units...
[16:16:51] Trying to send all finished work units
[16:16:51] + No unsent completed units remaining.
[16:16:51] - Autosend completed
[16:23:40] Writing local files
[16:23:40] Completed 247500 out of 250000 steps  (99 percent)
[16:38:17] Writing local files
[16:38:17] Completed 250000 out of 250000 steps  (100 percent)
[16:38:17] Writing final coordinates.
[16:38:18] Past main M.D. loop
[16:38:18] Will end MPI now
[16:39:17]
[16:39:17] Finished Work Unit:
[16:39:17] - Reading up to 21310704 from "work/wudata_01.arc": Read 21310704
[16:39:18] - Reading up to 558708 from "work/wudata_01.xtc": Read 558708
[16:39:18] goefile size: 0
[16:39:18] logfile size: 197779
[16:39:18] Leaving Run
[16:39:22] - Writing 22073563 bytes of core data to disk...
[16:39:22]   ... Done.
[16:39:22] - Shutting down core
[16:39:22]
[16:39:22] Folding@home Core Shutdown: FINISHED_UNIT
[16:39:26] CoreStatus = 64 (100)
[16:39:26] Unit 1 finished with 83 percent of time to deadline remaining.
[16:39:26] Updated performance fraction: 0.830995
[16:39:26] Sending work to server
[16:39:26] + Attempting to send results
[16:39:26] - Reading file work/wuresults_01.dat from core
[16:39:26]   (Read 22073563 bytes from disk)
[16:39:26] Connecting to http://171.64.65.64:8080/
[16:39:29] - Couldn't send HTTP request to server
[16:39:29] + Could not connect to Work Server (results)
[16:39:29]     (171.64.65.64:8080)
[16:39:29] - Error: Could not transmit unit 01 (completed July 6) to work server.
[16:39:29] - 1 failed uploads of this unit.
[16:39:29]   Keeping unit 01 in queue.
[16:39:29] Trying to send all finished work units
[16:39:29] + Attempting to send results
[16:39:29] - Reading file work/wuresults_01.dat from core
[16:39:29]   (Read 22073563 bytes from disk)
[16:39:29] Connecting to http://171.64.65.64:8080/
[16:39:32] - Couldn't send HTTP request to server
[16:39:32] + Could not connect to Work Server (results)
[16:39:32]     (171.64.65.64:8080)
[16:39:32] - Error: Could not transmit unit 01 (completed July 6) to work server.
[16:39:32] - 2 failed uploads of this unit.
[16:39:32] + Attempting to send results
[16:39:32] - Reading file work/wuresults_01.dat from core
[16:39:32]   (Read 22073563 bytes from disk)
[16:39:32] Connecting to http://171.64.122.86:8080/
[16:47:14] Posted data.
[16:47:15] Initial: 0000; - Uploaded at ~46 kB/s
[16:47:15] - Averaged speed for that direction ~46 kB/s
[16:47:15] + Results successfully sent
[16:47:15] Thank you for your contribution to Folding@Home.
[16:47:15] + Starting local stats count at 1
[16:47:15]   Successfully sent unit 01 to Collection server.
[16:47:15] + Sent 1 of 1 completed units to the server
[16:47:15] - Preparing to get new work unit...
[16:47:15] + Attempting to get work packet
[16:47:15] - Will indicate memory of 998 MB
[16:47:15] - Connecting to assignment server
[16:47:15] Connecting to http://assign.stanford.edu:8080/
[16:47:15] Posted data.
[16:47:15] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[16:47:15] + News From Folding@Home: Welcome to Folding@Home
[16:47:15] Loaded queue successfully.
[16:47:15] Connecting to http://171.64.65.64:8080/
[16:47:22] Posted data.
[16:47:22] Initial: 0000; - Receiving payload (expected size: 4738636)
[16:49:50] - Downloaded at ~31 kB/s
[16:49:50] - Averaged speed for that direction ~32 kB/s
[16:49:50] + Received work.
[16:49:50] Trying to send all finished work units
[16:49:50] + No unsent completed units remaining.
[16:49:50] + Closed connections
[16:49:50] + Processing work unit
[16:49:50] Core required: FahCore_a1.exe
[16:49:50] Core found.
[16:49:50] Working on Unit 02 [July 6 16:49:50]
[16:49:50] + Working ...
[16:49:50] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 02 -checkpoint 30 -forceasm -verbose -lifeline 524 -version 602'
[16:49:50] *------------------------------*
[16:49:50] Folding@Home Gromacs SMP Core
[16:49:50] Version 1.74 (November 27, 2006)
[16:49:50]
[16:49:50] Preparing to commence simulation
[16:49:50] - Ensuring status. Please wait.
[16:49:51] - Starting from initial work packet
[16:49:51] Project: 2665 (Run 0, Clone 355, Gen 24)
[16:49:51] Assembly optimizations on if available.
[16:49:51] Entering M.D.
[16:50:08]  on if available.
[16:50:08] Entering M.D.
[16:50:15] Protein: HGG in water
[16:50:15] Writing local files
[16:50:15] Extra SSE boost OK.
[16:50:16] al files
[16:50:16] Completed 0 out of 250000 steps  (0 percent)
[17:04:48] Writing local files
[17:04:48] Completed 2500 out of 250000 steps  (1 percent)
[17:19:20] Writing local files
[17:19:20] Completed 5000 out of 250000 steps  (2 percent)
[17:33:53] Writing local files
[17:33:53] Completed 7500 out of 250000 steps  (3 percent)
[17:48:27] Writing local files
[17:48:27] Completed 10000 out of 250000 steps  (4 percent)
[18:03:01] Writing local files
[18:03:02] Completed 12500 out of 250000 steps  (5 percent)
[18:17:36] Writing local files
[18:17:37] Completed 15000 out of 250000 steps  (6 percent)
[18:32:11] Writing local files
[18:32:11] Completed 17500 out of 250000 steps  (7 percent)
[18:46:45] Writing local files
[18:46:45] Completed 20000 out of 250000 steps  (8 percent)
[19:01:19] Writing local files
[19:01:19] Completed 22500 out of 250000 steps  (9 percent)
[19:15:54] Writing local files
[19:15:54] Completed 25000 out of 250000 steps  (10 percent)
[19:30:28] Writing local files
[19:30:28] Completed 27500 out of 250000 steps  (11 percent)
[19:45:03] Writing local files
[19:45:03] Completed 30000 out of 250000 steps  (12 percent)
[19:59:36] Writing local files
[19:59:36] Completed 32500 out of 250000 steps  (13 percent)
[20:14:09] Writing local files
[20:14:09] Completed 35000 out of 250000 steps  (14 percent)
[20:28:43] Writing local files
[20:28:43] Completed 37500 out of 250000 steps  (15 percent)
[20:43:16] Writing local files
[20:43:17] Completed 40000 out of 250000 steps  (16 percent)
[20:57:51] Writing local files
[20:57:51] Completed 42500 out of 250000 steps  (17 percent)
[21:12:26] Writing local files
[21:12:26] Completed 45000 out of 250000 steps  (18 percent)
[21:27:01] Writing local files
[21:27:01] Completed 47500 out of 250000 steps  (19 percent)
[21:41:36] Writing local files
[21:41:36] Completed 50000 out of 250000 steps  (20 percent)
[21:56:10] Writing local files
[21:56:10] Completed 52500 out of 250000 steps  (21 percent)
[22:10:43] Writing local files
[22:10:43] Completed 55000 out of 250000 steps  (22 percent)
[22:16:51] - Autosending finished units...
[22:16:51] Trying to send all finished work units
[22:16:51] + No unsent completed units remaining.
[22:16:51] - Autosend completed
[22:25:16] Writing local files
[22:25:16] Completed 57500 out of 250000 steps  (23 percent)
[22:39:51] Writing local files
[22:39:51] Completed 60000 out of 250000 steps  (24 percent)
[22:54:27] Writing local files
[22:54:27] Completed 62500 out of 250000 steps  (25 percent)
[23:09:01] Writing local files
[23:09:02] Completed 65000 out of 250000 steps  (26 percent)
[23:23:36] Writing local files
[23:23:37] Completed 67500 out of 250000 steps  (27 percent)
[23:38:11] Writing local files
[23:38:11] Completed 70000 out of 250000 steps  (28 percent)
[23:52:45] Writing local files
[23:52:45] Completed 72500 out of 250000 steps  (29 percent)
[00:07:19] Writing local files
[00:07:19] Completed 75000 out of 250000 steps  (30 percent)
[00:21:53] Writing local files
[00:21:53] Completed 77500 out of 250000 steps  (31 percent)
[00:36:27] Writing local files
[00:36:27] Completed 80000 out of 250000 steps  (32 percent)
[00:51:02] Writing local files
[00:51:02] Completed 82500 out of 250000 steps  (33 percent)
[01:05:38] Writing local files
[01:05:38] Completed 85000 out of 250000 steps  (34 percent)
[01:20:15] Writing local files
[01:20:15] Completed 87500 out of 250000 steps  (35 percent)
[01:34:51] Writing local files
[01:34:51] Completed 90000 out of 250000 steps  (36 percent)
[01:49:27] Writing local files
[01:49:27] Completed 92500 out of 250000 steps  (37 percent)
[02:04:02] Writing local files
[02:04:02] Completed 95000 out of 250000 steps  (38 percent)
[02:18:37] Writing local files
[02:18:37] Completed 97500 out of 250000 steps  (39 percent)
[02:33:13] Writing local files
[02:33:13] Completed 100000 out of 250000 steps  (40 percent)
[02:47:49] Writing local files
[02:47:49] Completed 102500 out of 250000 steps  (41 percent)
[03:02:23] Writing local files
[03:02:24] Completed 105000 out of 250000 steps  (42 percent)
[03:16:58] Writing local files
[03:16:58] Completed 107500 out of 250000 steps  (43 percent)
[03:31:32] Writing local files
[03:31:32] Completed 110000 out of 250000 steps  (44 percent)
[03:46:08] Writing local files
[03:46:08] Completed 112500 out of 250000 steps  (45 percent)
[04:00:42] Writing local files
[04:00:42] Completed 115000 out of 250000 steps  (46 percent)
[04:15:17] Writing local files
[04:15:17] Completed 117500 out of 250000 steps  (47 percent)
[04:16:51] - Autosending finished units...
[04:16:51] Trying to send all finished work units
[04:16:51] + No unsent completed units remaining.
[04:16:51] - Autosend completed
[04:29:51] Writing local files
[04:29:52] Completed 120000 out of 250000 steps  (48 percent)
[04:44:25] Writing local files
[04:44:26] Completed 122500 out of 250000 steps  (49 percent)
[04:59:01] Writing local files
[04:59:01] Completed 125000 out of 250000 steps  (50 percent)
[05:13:36] Writing local files
[05:13:36] Completed 127500 out of 250000 steps  (51 percent)
[05:28:11] Writing local files
[05:28:11] Completed 130000 out of 250000 steps  (52 percent)
[05:42:46] Writing local files
[05:42:46] Completed 132500 out of 250000 steps  (53 percent)
[05:57:21] Writing local files
[05:57:21] Completed 135000 out of 250000 steps  (54 percent)
[06:11:55] Writing local files
[06:11:56] Completed 137500 out of 250000 steps  (55 percent)
[06:26:29] Writing local files
[06:26:29] Completed 140000 out of 250000 steps  (56 percent)
[06:41:04] Writing local files
[06:41:04] Completed 142500 out of 250000 steps  (57 percent)
[06:55:39] Writing local files
[06:55:39] Completed 145000 out of 250000 steps  (58 percent)
[07:10:14] Writing local files
[07:10:14] Completed 147500 out of 250000 steps  (59 percent)
[07:24:50] Writing local files
[07:24:50] Completed 150000 out of 250000 steps  (60 percent)
[07:39:27] Writing local files
[07:39:27] Completed 152500 out of 250000 steps  (61 percent)
[07:54:05] Writing local files
[07:54:05] Completed 155000 out of 250000 steps  (62 percent)
[08:08:41] Writing local files
[08:08:41] Completed 157500 out of 250000 steps  (63 percent)
[08:23:18] Writing local files
[08:23:18] Completed 160000 out of 250000 steps  (64 percent)
[08:37:54] Writing local files
[08:37:54] Completed 162500 out of 250000 steps  (65 percent)
[08:52:28] Writing local files
[08:52:28] Completed 165000 out of 250000 steps  (66 percent)
[09:07:04] Writing local files
[09:07:04] Completed 167500 out of 250000 steps  (67 percent)
[09:21:40] Writing local files
[09:21:40] Completed 170000 out of 250000 steps  (68 percent)
[09:36:16] Writing local files
[09:36:16] Completed 172500 out of 250000 steps  (69 percent)
[09:50:51] Writing local files
[09:50:51] Completed 175000 out of 250000 steps  (70 percent)
[10:05:26] Writing local files
[10:05:26] Completed 177500 out of 250000 steps  (71 percent)
[10:16:51] - Autosending finished units...
[10:16:51] Trying to send all finished work units
[10:16:51] + No unsent completed units remaining.
[10:16:51] - Autosend completed
[10:19:59] Writing local files
[10:20:00] Completed 180000 out of 250000 steps  (72 percent)
[10:34:35] Writing local files
[10:34:35] Completed 182500 out of 250000 steps  (73 percent)
[10:49:10] Writing local files
[10:49:10] Completed 185000 out of 250000 steps  (74 percent)
[11:03:45] Writing local files
[11:03:45] Completed 187500 out of 250000 steps  (75 percent)
[11:18:18] Writing local files
[11:18:18] Completed 190000 out of 250000 steps  (76 percent)
[11:32:53] Writing local files
[11:32:53] Completed 192500 out of 250000 steps  (77 percent)
[11:47:27] Writing local files
[11:47:27] Completed 195000 out of 250000 steps  (78 percent)
[12:02:00] Writing local files
[12:02:00] Completed 197500 out of 250000 steps  (79 percent)
[12:16:35] Writing local files
[12:16:35] Completed 200000 out of 250000 steps  (80 percent)
[12:31:09] Writing local files
[12:31:09] Completed 202500 out of 250000 steps  (81 percent)
[12:45:43] Writing local files
[12:45:43] Completed 205000 out of 250000 steps  (82 percent)
[13:00:16] Writing local files
[13:00:17] Completed 207500 out of 250000 steps  (83 percent)
[13:14:51] Writing local files
[13:14:51] Completed 210000 out of 250000 steps  (84 percent)
[13:29:26] Writing local files
[13:29:26] Completed 212500 out of 250000 steps  (85 percent)
[13:44:01] Writing local files
[13:44:01] Completed 215000 out of 250000 steps  (86 percent)
[13:58:37] Writing local files
[13:58:37] Completed 217500 out of 250000 steps  (87 percent)
[14:13:12] Writing local files
[14:13:12] Completed 220000 out of 250000 steps  (88 percent)
[14:27:49] Writing local files
[14:27:49] Completed 222500 out of 250000 steps  (89 percent)
[14:42:26] Writing local files
[14:42:26] Completed 225000 out of 250000 steps  (90 percent)
[14:57:02] Writing local files
[14:57:02] Completed 227500 out of 250000 steps  (91 percent)
[15:11:39] Writing local files
[15:11:39] Completed 230000 out of 250000 steps  (92 percent)
[15:26:16] Writing local files
[15:26:16] Completed 232500 out of 250000 steps  (93 percent)
[15:40:53] Writing local files
[15:40:53] Completed 235000 out of 250000 steps  (94 percent)
[15:55:32] Writing local files
[15:55:32] Completed 237500 out of 250000 steps  (95 percent)
[16:10:09] Writing local files
[16:10:09] Completed 240000 out of 250000 steps  (96 percent)
[16:24:47] Writing local files
[16:24:47] Completed 242500 out of 250000 steps  (97 percent)
[16:39:23] Writing local files
[16:39:23] Completed 245000 out of 250000 steps  (98 percent)
[16:53:59] Writing local files
[16:53:59] Completed 247500 out of 250000 steps  (99 percent)
[17:08:37] Writing local files
[17:08:37] Completed 250000 out of 250000 steps  (100 percent)
[17:08:37] Writing final coordinates.
[17:08:37] Past main M.D. loop
[17:08:37] Will end MPI now
[17:09:37]
[17:09:37] Finished Work Unit:
[17:09:37] - Reading up to 21310704 from "work/wudata_02.arc": Read 21310704
[17:09:37] - Reading up to 558708 from "work/wudata_02.xtc": Read 558708
[17:09:37] goefile size: 0
[17:09:37] logfile size: 197782
[17:09:37] Leaving Run
[17:09:38] - Writing 22073566 bytes of core data to disk...
[17:09:38]   ... Done.
[17:09:38] - Shutting down core
[17:09:38]
[17:09:38] Folding@home Core Shutdown: FINISHED_UNIT
[17:09:42] CoreStatus = 64 (100)
[17:09:42] Unit 2 finished with 83 percent of time to deadline remaining.
[17:09:42] Updated performance fraction: 0.831015
[17:09:42] Sending work to server
[17:09:42] + Attempting to send results
[17:09:42] - Reading file work/wuresults_02.dat from core
[17:09:42]   (Read 22073566 bytes from disk)
[17:09:42] Connecting to http://171.64.65.64:8080/
[17:17:24] Posted data.
[17:17:24] Initial: 0000; - Uploaded at ~46 kB/s
[17:17:24] - Averaged speed for that direction ~46 kB/s
[17:17:24] + Results successfully sent
[17:17:24] Thank you for your contribution to Folding@Home.
[17:17:24] + Number of Units Completed: 2
[17:21:28] - Warning: Could not delete all work unit files (2): Core returned invalid code
[17:21:28] Trying to send all finished work units
[17:21:28] + No unsent completed units remaining.
[17:21:28] - Preparing to get new work unit...
[17:21:28] + Attempting to get work packet
[17:21:28] - Will indicate memory of 998 MB
[17:21:28] - Connecting to assignment server
[17:21:28] Connecting to http://assign.stanford.edu:8080/
[17:21:29] Posted data.
[17:21:29] Initial: 40AB; - Successful: assigned to (171.64.65.56).
[17:21:29] + News From Folding@Home: Welcome to Folding@Home
[17:21:29] Loaded queue successfully.
[17:21:29] Connecting to http://171.64.65.56:8080/
[17:21:32] Posted data.
[17:21:32] Initial: 0000; - Receiving payload (expected size: 2430536)
[17:22:39] - Downloaded at ~35 kB/s
[17:22:39] - Averaged speed for that direction ~33 kB/s
[17:22:39] + Received work.
[17:22:39] Trying to send all finished work units
[17:22:39] + No unsent completed units remaining.
[17:22:39] + Closed connections
[17:22:39]
[17:22:39] + Processing work unit
[17:22:39] Core required: FahCore_a1.exe
[17:22:39] Core found.
[17:22:39] Working on Unit 03 [July 7 17:22:39]
[17:22:39] + Working ...
[17:22:39] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 03 -checkpoint 30 -forceasm -verbose -lifeline 524 -version 602'
[17:22:39] *------------------------------*
[17:22:39] Folding@Home Gromacs SMP Core
[17:22:39] Version 1.74 (November 27, 2006)
[17:22:39]
[17:22:39] Preparing to commence simulation
[17:22:39] - Ensuring status. Please wait.
[17:22:56] - Assembly optimizations manually forced on.
[17:22:56] - Not checking prior termination.
[17:22:56] - Expanded 2430024 -> 12885597 (decompressed 530.2 percent)
[17:22:57] - Starting from initial work packet
[17:22:57]
[17:22:57] Project: 2605 (Run 13, Clone 567, Gen 69)
[17:22:57]
[17:22:57] Assembly optimizations on if available.
[17:22:57] Entering M.D.
[17:23:02] Rejecting checkpoint
[17:23:03] Protein: Protein in POPCExtra SSE boost OK.
[17:23:03]
[17:23:03] Extra SSE boost OK.
[17:23:03] Writing local files
[17:23:04] Completed 0 out of 500000 steps  (0 percent)
[17:32:49] Writing local files
[17:32:49] Completed 5000 out of 500000 steps  (1 percent)
Team: 132987
notaussiefloyd.com F@h Team
Folding: Q6600 @ 2.88GHz | Notfred Diskless Linux 64bit SMP
Re: Project: 2665 (Run 0, Clone 355, Gen 24) Points not awarded?
Apparently, you submitted this WU twice : one with full credit and one with 0 credits (results already sent) ... I don't really know what's going on, so I asked another opinion ;)
Great_Gig
Post by Great_Gig »
How can you tell it was submitted twice - I'm fairly new to Folding and looked at the log but must I have missed that? The log commences with the first WU, which was completed and submitted, then a second for the same project starts and is also completed.
Is this common as I was quite disappointed to be wasting nearly 24 hours of power for no reason :e(
Team: 132987
Great_Gig wrote:How can you tell it was submitted twice - I'm fairly new to Folding and looked at the log but must I have missed that?
You can't tell. The database that he's using is restricted to forum moderators.
It's not common except when there are errors in your setup. Are you running more than one FAH client? If so, what MachineIDs are they set to? Are you moving WUs from one client to another?
Hi GreatGig (team 132987),
Your WU (P2665 R0 C355 G24) was added to the stats database on 2008-07-06 10:50:47 for 1920 points of credit.
Your WU (P2665 R0 C355 G24) was added to the stats database on 2008-07-07 10:54:34 for 0 points of credit.
Great_Gig
Post by Great_Gig »
bruce wrote: It's not common except when there are errors in your setup. Are you running more than one FAH client? If so, what MachineIDs are they set to? Are you moving WUs from one client to another?
Thanks for the reply - I'm not running more than one FAH client on my home rig, but I do have a Windows client running at work on a PC there (that's the 47 point credit you can see in my Kakao stats). The machine ID's as far as I can tell are OK, but I am at home at the moment, so cannot check the work Machine ID until tomorrow. My home rig (see below) is a Diskless one, running Notfreds Linux Folding CD Generator, with nothing being altered, moved or changed at all. I just bought the rig for dedicated Folding and it's worked fine until this problem - which is why I'm a little upset by it, after just spending quite a bit of money! Would appreciate any pointers if you think I'm doing anything wrong? :e?:
Home Setup:
Intel Q6600 'GO' CPU @ stock 2.4 GHz
Thermalright HR-01 HS & Nexus 120mm fan.
GA-G31M-S2L Motherboard
2GB Corsair DDR2 800MHz RAM
Silverstone 460W PSU
Linux Diskless SMP client (1 SMP Instance running on 4 cores)
FahSpy to monitor
If there's anything wrong here or something I should change/add, can you let me know?
Thanks guys.
Team: 132987
Great_Gig
Post by Great_Gig »
I don't know if this is any relevance, but after todays WU was sent and succussfully received (points have been credited), I noticed this in the FAHlog.txt - is this a problem?
[09:43:59] Posted data.
[09:43:59] Initial: 0000; - Uploaded at ~45 kB/s
[09:44:01] - Averaged speed for that direction ~46 kB/s
[09:44:01] + Results successfully sent
[09:44:01] Thank you for your contribution to Folding@Home.
[09:44:01] + Number of Units Completed: 3
[09:48:05] - Warning: Could not delete all work unit files (3): Core returned invalid code
[09:48:05] Trying to send all finished work units
[09:48:05] + No unsent completed units remaining.
[09:48:05] - Preparing to get new work unit...
[09:48:05] + Attempting to get work packet
[09:48:05] - Will indicate memory of 998 MB
Team: 132987
Great_Gig wrote:[09:48:05] - Warning: Could not delete all work unit files (3): Core returned invalid code
It's just a minor cosmetic bug, nothing to worry about ... Known bug #4 in that list : viewtopic.php?f=8&t=50
Your machine is running at stock clocks, so it shouldn't cause any issue ... :)
After a WU is uploaded, the old files are supposed to be deleted. On the list of known bugs for FahCore_a1, you'll note that it doesn't always work correctly. This will be corrected someday, but it's not that critical since you'll eventually get enough WUs to overwrite the detritus of earlier WUs.
If the data that was just uploaded was not deleted but was removed from the queue, it's possible that running qfix again could cause it to be uploded again.
Great_Gig
Post by Great_Gig »
I guess I have lost the 1920 points credit then, which is disappointing. I'm a bit worried again now, as my current WU is another Project 2665, the last was 2605 and the points were credited OK. If it happens again tomorrow (due to finish at 1100), is there anything I should do? Should I halt the client, wipe the USB drive and start the rig again?
Thanks again for the advice.
Team: 132987
But you did get 1920 points for that WU . . . didn't you see my earlier post?
Did you run the same WU twice and finish it on both 07-06 and 07-07? (Times in your log are in GMT/UTC. I'll adjust the times from my earlier post which were PDT to GMT to match your logs.)
Your WU (P2665 R0 C355 G24) was added to the stats database on 2008-07-06 17:50:47 for 1920 points of credit.
Your WU (P2665 R0 C355 G24) was added to the stats database on 2008-07-07 17:54:34 for 0 points of credit.
I have not run notfred's code but if there's something in it that's related to the problem, it would be somehow related to the UserID/MachineID values or to a stop/restart of the WU.
Great_Gig
Post by Great_Gig »
bruce wrote:But you did get 1920 points for that WU . . . didn't you see my earlier post?
Yes I did see your post, but I must admit to being a little confused :e?: (sorry). Basically what happened was the client was started at 17.17 on 5th July 08 (the timing seemed to shift back an hour when it logged to the server?), the WU downloaded was 2665. That WU completed at 16.38 the following day (6th July) and 1920 points were credited. At 16.49 another 2665 WU was started, which completed at 17.08 the next day (7th July). This work unit was not credited and the only points received on 7th July were 47 from a Windows Client at my workplace.
At 17.22 on 7th July a Project 2605 WU was downloaded and commenced, which completed at 09.40 today - 8th July and the 1760 points for this have been credited. At 09.52 today another project 2665 WU was commenced and is due to finish at 11.02 tomorrow.
So basically since the Diskless rig started on 5th July it has completed 2 x 2665 projects and 1 x 2605 project WU's, but only credit has been received for 1 x 2665 and 1 x 2605 WU. All 3 completed WU's according to the FAHlog have been sent to the server successfully. Since the Diskless SMP client started it has run 24/7 with no interuptions of power and is still running, I have not done anything to it since start. I'm not sure if I have missed something and please accept my apologies if I have :oops: I'm a folding newbie and have a lot to learn.......
I have included my entire FAHlog.txt since start on 5th July 2008 if it helps. (Timings are UK). Is there anything I should do in the meantime, or just let the client run and see if the same error occurs again?
Executable: ./fah6
Warning:
 use of the flag.
[17:17:17]
[16:19:14]
[16:19:15] Initial: B54E; + 20480 bytes downloaded
[16:19:16] Initial: D6C2; + 30720 bytes downloaded
[16:19:16] Initial: 9F08; + 40960 bytes downloaded
[16:19:17] Initial: C6C3; + 51200 bytes downloaded
[16:19:17] Initial: EBA8; + 61440 bytes downloaded
[16:19:17] Initial: 3141; + 71680 bytes downloaded
[16:19:17] Initial: D218; + 81920 bytes downloaded
[16:19:18] Initial: F7AC; + 92160 bytes downloaded
[16:19:18] Initial: 820B; + 102400 bytes downloaded
[16:19:18] Initial: 1B1E; + 112640 bytes downloaded
[16:19:19] Initial: C249; + 122880 bytes downloaded
[16:19:19] Initial: 5EBD; + 133120 bytes downloaded
[16:19:19] Initial: CD6C; + 143360 bytes downloaded
[16:19:19] Initial: 221C; + 153600 bytes downloaded
[16:19:19] Initial: DB18; + 163840 bytes downloaded
[16:19:20] Initial: 237E; + 174080 bytes downloaded
[16:19:20] Initial: AEEC; + 184320 bytes downloaded
[16:19:20] Initial: 4C66; + 194560 bytes downloaded
[16:19:21] Initial: AE1E; + 204800 bytes downloaded
[16:19:21] Initial: A37E; + 215040 bytes downloaded
[16:19:21] Initial: 8193; + 225280 bytes downloaded
[16:19:22] Initial: 9F05; + 235520 bytes downloaded
[16:19:22] Initial: AAA5; + 245760 bytes downloaded
[16:19:22] Initial: 6400; + 256000 bytes downloaded
[16:19:23] Initial: 6E3D; + 266240 bytes downloaded
[16:19:23] Initial: EA6B; + 276480 bytes downloaded
[16:19:23] Initial: 820A; + 286720 bytes downloaded
[16:19:24] Initial: DE6D; + 296960 bytes downloaded
[16:19:24] Initial: B97B; + 307200 bytes downloaded
[16:19:24] Initial: 9D5D; + 317440 bytes downloaded
[16:19:24] Initial: 91D7; + 327680 bytes downloaded
[16:19:24] Initial: BB3B; + 337920 bytes downloaded
[16:19:24] Initial: 611B; + 348160 bytes downloaded
[16:19:25] Initial: B290; + 358400 bytes downloaded
[16:19:25] Initial: B0AA; + 368640 bytes downloaded
[16:19:25] Initial: 6A85; + 378880 bytes downloaded
[16:19:25] Initial: BF10; + 389120 bytes downloaded
[16:19:25] Initial: A818; + 399360 bytes downloaded
[16:19:25] Initial: 90E1; + 409600 bytes downloaded
[16:19:26] Initial: 2869; + 419840 bytes downloaded
[16:19:26] Initial: CAFE; + 430080 bytes downloaded
[16:19:26] Initial: 414B; + 440320 bytes downloaded
[16:19:26] Initial: 9B7A; + 450560 bytes downloaded
[16:19:26] Initial: 33AA; + 460800 bytes downloaded
[16:19:27] Initial: B1D5; + 471040 bytes downloaded
[16:19:27] Initial: 0206; + 481280 bytes downloaded
[16:19:27] Initial: 11F4; + 491520 bytes downloaded
[16:19:27] Initial: 31B5; + 501760 bytes downloaded
[16:19:28] Initial: 46B2; + 512000 bytes downloaded
[16:19:28] Initial: 3113; + 522240 bytes downloaded
[16:19:29] Initial: 525A; + 532480 bytes downloaded
[16:19:29] Initial: 66F9; + 542720 bytes downloaded
[16:19:29] Initial: 9672; + 552960 bytes downloaded
[16:19:30] Initial: 9058; + 563200 bytes downloaded
[16:19:30] Initial: 49ED; + 573440 bytes downloaded
[16:19:31] Initial: 515D; + 583680 bytes downloaded
[16:19:31] Initial: CAC0; + 593920 bytes downloaded
[16:19:31] Initial: 0B15; + 604160 bytes downloaded
[16:19:32] Initial: 5A89; + 614400 bytes downloaded
[16:19:32] Initial: 0F31; + 624640 bytes downloaded
[16:19:32] Initial: 2BC3; + 634880 bytes downloaded
[16:19:32] Initial: 3C06; + 645120 bytes downloaded
[16:19:32] Initial: 89C7; + 655360 bytes downloaded
[16:19:33] Initial: 6C54; + 665600 bytes downloaded
[16:19:33] Initial: 8D4D; + 675840 bytes downloaded
[16:19:33] Initial: EA59; + 686080 bytes downloaded
[16:19:33] Initial: C563; + 696320 bytes downloaded
[16:19:33] Initial: 8D45; + 706560 bytes downloaded
[16:19:34] Initial: 9BD0; + 716800 bytes downloaded
[16:19:34] Initial: 130C; + 727040 bytes downloaded
[16:19:34] Initial: CDA1; + 737280 bytes downloaded
[16:19:34] Initial: 7681; + 747520 bytes downloaded
[16:19:35] Initial: 1110; + 757760 bytes downloaded
[16:19:35] Initial: EE35; + 768000 bytes downloaded
[16:19:35] Initial: E5E1; + 778240 bytes downloaded
[16:19:36] Initial: 4B97; + 788480 bytes downloaded
[16:19:36] Initial: 4D75; + 798720 bytes downloaded
[16:19:36] Initial: E268; + 808960 bytes downloaded
[16:19:37] Initial: FAC6; + 819200 bytes downloaded
[16:19:37] Initial: A625; + 829440 bytes downloaded
[16:19:37] Initial: A12A; + 839680 bytes downloaded
[16:19:38] Initial: 83A3; + 849920 bytes downloaded
[16:19:38] Initial: 3BEA; + 860160 bytes downloaded
[16:19:38] Initial: 5298; + 870400 bytes downloaded
[16:19:39] Initial: 4811; + 880640 bytes downloaded
[16:19:39] Initial: EB07; + 890880 bytes downloaded
[16:19:39] Initial: 83FC; + 901120 bytes downloaded
[16:19:39] Initial: FA4E; + 911360 bytes downloaded
[16:19:40] Initial: 2945; + 921600 bytes downloaded
[16:19:40] Initial: 6BC9; + 931840 bytes downloaded
[16:19:40] Initial: E495; + 942080 bytes downloaded
[16:19:40] Initial: 1050; + 952320 bytes downloaded
[16:19:41] Initial: 2070; + 962560 bytes downloaded
[16:19:41] Initial: 1083; + 972800 bytes downloaded
[16:19:41] Initial: 96E5; + 983040 bytes downloaded
[16:19:42] Initial: 3EEE; + 993280 bytes downloaded
[16:19:42] Initial: 84AC; + 1003520 bytes downloaded
[16:19:42] Initial: 3B6B; + 1013760 bytes downloaded
[16:19:43] Initial: 3030; + 1024000 bytes downloaded
[16:19:43] Initial: 4B95; + 1034240 bytes downloaded
[16:19:43] Initial: D9BC; + 1044480 bytes downloaded
[16:19:44] Initial: C5B8; + 1054720 bytes downloaded
[16:19:44] Initial: A5EF; + 1064960 bytes downloaded
[16:19:44] Initial: 28DC; + 1075200 bytes downloaded
[16:19:44] Initial: 0943; + 1085440 bytes downloaded
[16:19:44] Initial: 338A; + 1095680 bytes downloaded
[16:19:45] Initial: ADFC; + 1105920 bytes downloaded
[16:19:45] Initial: ED39; + 1116160 bytes downloaded
[16:19:45] Initial: D284; + 1126400 bytes downloaded
[16:19:45] Initial: 0057; + 1136640 bytes downloaded
[16:19:45] Initial: 3E65; + 1146880 bytes downloaded
[16:19:46] Initial: FCB5; + 1157120 bytes downloaded
[16:19:46] Initial: A7D8; + 1167360 bytes downloaded
[16:19:46] Initial: A564; + 1177600 bytes downloaded
[16:19:47] Initial: 7654; + 1187840 bytes downloaded
[16:19:47] Initial: 0848; + 1198080 bytes downloaded
[16:19:48] Initial: 471E; + 1208320 bytes downloaded
[16:19:49] Initial: A7F3; + 1218560 bytes downloaded
[16:19:49] Initial: FA59; + 1228800 bytes downloaded
[16:19:50] Initial: FBF2; + 1239040 bytes downloaded
[16:19:50] Initial: F54E; + 1249280 bytes downloaded
[16:19:51] Initial: 3023; + 1259520 bytes downloaded
[16:19:51] Initial: AB37; + 1269760 bytes downloaded
[16:19:51] Initial: 0896; + 1280000 bytes downloaded
[16:19:52] Initial: 756D; + 1290240 bytes downloaded
[16:19:52] Initial: C1E7; + 1300480 bytes downloaded
[16:19:53] Initial: 9AAC; + 1310720 bytes downloaded
[16:19:53] Initial: E5AF; + 1320960 bytes downloaded
[16:19:53] Initial: BBE3; + 1331200 bytes downloaded
[16:19:53] Initial: 3596; + 1341440 bytes downloaded
[16:19:54] Initial: 924C; + 1351680 bytes downloaded
[16:19:54] Initial: 30B7; + 1361920 bytes downloaded
[16:19:55] Initial: AEB7; + 1372160 bytes downloaded
[16:19:55] Initial: 7D25; + 1382400 bytes downloaded
[16:19:56] Initial: 0FEB; + 1392640 bytes downloaded
[16:19:56] Initial: 3131; + 1402880 bytes downloaded
[16:19:56] Initial: 755F; + 1413120 bytes downloaded
[16:19:56] Initial: 4800; + 1423360 bytes downloaded
[16:19:56] Initial: 1282; + 1433600 bytes downloaded
[16:19:57] Initial: B2A3; + 1443840 bytes downloaded
[16:19:57] Initial: 21E9; + 1454080 bytes downloaded
[16:19:58] Initial: 789E; + 1464320 bytes downloaded
[16:19:58] Initial: 8542; + 1474560 bytes downloaded
[16:19:59]
[16:20:05]
[16:20:05]
[16:20:05]
[16:20:06]
[16:20:06]
[16:20:31] al files
[17:47:52] Writing local files
[17:47:52] Completed 15000 out of 250000 steps  (6 percent)
[18:02:26] Writing local files
[18:02:26] Completed 17500 out of 250000 steps  (7 percent)
[18:17:00] Writing local files
[18:17:00] Completed 20000 out of 250000 steps  (8 percent)
[18:31:35] Writing local files
[18:31:35] Completed 22500 out of 250000 steps  (9 percent)
[18:46:09] Writing local files
[18:46:09] Completed 25000 out of 250000 steps  (10 percent)
[19:00:43] Writing local files
[19:00:43] Completed 27500 out of 250000 steps  (11 percent)
[19:15:16] Writing local files
[19:15:16] Completed 30000 out of 250000 steps  (12 percent)
[19:29:48] Writing local files
[19:29:48] Completed 32500 out of 250000 steps  (13 percent)
[19:44:22] Writing local files
[19:44:22] Completed 35000 out of 250000 steps  (14 percent)
[19:58:56] Writing local files
[19:58:56] Completed 37500 out of 250000 steps  (15 percent)
[20:13:29] Writing local files
[20:13:29] Completed 40000 out of 250000 steps  (16 percent)
[20:28:03] Writing local files
[20:28:04] Completed 42500 out of 250000 steps  (17 percent)
[20:42:38] Writing local files
[20:42:38] Completed 45000 out of 250000 steps  (18 percent)
[20:57:13] Writing local files
[20:57:13] Completed 47500 out of 250000 steps  (19 percent)
[21:11:47] Writing local files
[21:11:47] Completed 50000 out of 250000 steps  (20 percent)
[21:26:21] Writing local files
[21:26:21] Completed 52500 out of 250000 steps  (21 percent)
[21:40:53] Writing local files
[21:40:53] Completed 55000 out of 250000 steps  (22 percent)
[21:55:26] Writing local files
[21:55:26] Completed 57500 out of 250000 steps  (23 percent)
[22:10:00] Writing local files
[22:10:00] Completed 60000 out of 250000 steps  (24 percent)
[22:24:35] Writing local files
[22:24:35] Completed 62500 out of 250000 steps  (25 percent)
[22:39:09] Writing local files
[22:39:09] Completed 65000 out of 250000 steps  (26 percent)
[22:53:43] Writing local files
[22:53:43] Completed 67500 out of 250000 steps  (27 percent)
[23:08:18] Writing local files
[23:08:18] Completed 70000 out of 250000 steps  (28 percent)
[23:22:51] Writing local files
[23:22:51] Completed 72500 out of 250000 steps  (29 percent)
[23:37:25] Writing local files
[23:37:25] Completed 75000 out of 250000 steps  (30 percent)
[23:51:58] Writing local files
[23:51:58] Completed 77500 out of 250000 steps  (31 percent)
[00:06:33] Writing local files
[00:06:33] Completed 80000 out of 250000 steps  (32 percent)
[00:21:08] Writing local files
[00:21:08] Completed 82500 out of 250000 steps  (33 percent)
[00:35:43] Writing local files
[00:35:43] Completed 85000 out of 250000 steps  (34 percent)
[00:50:19] Writing local files
[00:50:19] Completed 87500 out of 250000 steps  (35 percent)
[01:04:55] Writing local files
[01:04:55] Completed 90000 out of 250000 steps  (36 percent)
[01:19:31] Writing local files
[01:19:31] Completed 92500 out of 250000 steps  (37 percent)
[01:34:07] Writing local files
[01:34:07] Completed 95000 out of 250000 steps  (38 percent)
[01:48:42] Writing local files
[01:48:42] Completed 97500 out of 250000 steps  (39 percent)
[02:03:18] Writing local files
[02:03:18] Completed 100000 out of 250000 steps  (40 percent)
[02:17:53] Writing local files
[02:17:54] Completed 102500 out of 250000 steps  (41 percent)
[02:32:28] Writing local files
[02:32:28] Completed 105000 out of 250000 steps  (42 percent)
[02:47:03] Writing local files
[02:47:03] Completed 107500 out of 250000 steps  (43 percent)
[03:01:37] Writing local files
[03:01:37] Completed 110000 out of 250000 steps  (44 percent)
[03:16:12] Writing local files
[03:16:12] Completed 112500 out of 250000 steps  (45 percent)
[03:30:46] Writing local files
[03:30:46] Completed 115000 out of 250000 steps  (46 percent)
[03:45:20] Writing local files
[03:45:20] Completed 117500 out of 250000 steps  (47 percent)
[03:59:54] Writing local files
[03:59:54] Completed 120000 out of 250000 steps  (48 percent)
[04:14:28] Writing local files
[04:14:28] Completed 122500 out of 250000 steps  (49 percent)
[04:29:02] Writing local files
[04:29:03] Completed 125000 out of 250000 steps  (50 percent)
[04:43:37] Writing local files
[04:43:37] Completed 127500 out of 250000 steps  (51 percent)
[04:58:12] Writing local files
[04:58:12] Completed 130000 out of 250000 steps  (52 percent)
[05:12:47] Writing local files
[05:12:47] Completed 132500 out of 250000 steps  (53 percent)
[05:27:21] Writing local files
[05:27:21] Completed 135000 out of 250000 steps  (54 percent)
[05:41:55] Writing local files
[05:41:55] Completed 137500 out of 250000 steps  (55 percent)
[05:56:28] Writing local files
[05:56:28] Completed 140000 out of 250000 steps  (56 percent)
[06:11:03] Writing local files
[06:11:03] Completed 142500 out of 250000 steps  (57 percent)
[06:25:37] Writing local files
[06:25:37] Completed 145000 out of 250000 steps  (58 percent)
[06:40:12] Writing local files
[06:40:12] Completed 147500 out of 250000 steps  (59 percent)
[06:54:48] Writing local files
[06:54:48] Completed 150000 out of 250000 steps  (60 percent)
[07:09:24] Writing local files
[07:09:24] Completed 152500 out of 250000 steps  (61 percent)
[07:24:01] Writing local files
[07:24:01] Completed 155000 out of 250000 steps  (62 percent)
[07:38:37] Writing local files
[07:38:37] Completed 157500 out of 250000 steps  (63 percent)
[07:53:14] Writing local files
[07:53:14] Completed 160000 out of 250000 steps  (64 percent)
[08:07:50] Writing local files
[08:07:50] Completed 162500 out of 250000 steps  (65 percent)
[08:22:25] Writing local files
[08:22:25] Completed 165000 out of 250000 steps  (66 percent)
[08:37:00] Writing local files
[08:37:00] Completed 167500 out of 250000 steps  (67 percent)
[08:51:36] Writing local files
[08:51:36] Completed 170000 out of 250000 steps  (68 percent)
[09:06:11] Writing local files
[09:06:11] Completed 172500 out of 250000 steps  (69 percent)
[09:20:46] Writing local files
[09:20:46] Completed 175000 out of 250000 steps  (70 percent)
[09:35:21] Writing local files
[09:35:21] Completed 177500 out of 250000 steps  (71 percent)
[09:49:55] Writing local files
[09:49:55] Completed 180000 out of 250000 steps  (72 percent)
[10:04:30] Writing local files
[10:04:31] Completed 182500 out of 250000 steps  (73 percent)
[10:19:05] Writing local files
[10:19:05] Completed 185000 out of 250000 steps  (74 percent)
[10:33:40] Writing local files
[10:33:40] Completed 187500 out of 250000 steps  (75 percent)
[10:48:13] Writing local files
[10:48:13] Completed 190000 out of 250000 steps  (76 percent)
[11:02:47] Writing local files
[11:02:47] Completed 192500 out of 250000 steps  (77 percent)
[11:17:20] Writing local files
[11:17:20] Completed 195000 out of 250000 steps  (78 percent)
[11:31:53] Writing local files
[11:31:53] Completed 197500 out of 250000 steps  (79 percent)
[11:46:26] Writing local files
[11:46:26] Completed 200000 out of 250000 steps  (80 percent)
[12:01:00] Writing local files
[12:01:00] Completed 202500 out of 250000 steps  (81 percent)
[12:15:33] Writing local files
[12:15:34] Completed 205000 out of 250000 steps  (82 percent)
[12:30:06] Writing local files
[12:30:06] Completed 207500 out of 250000 steps  (83 percent)
[12:44:39] Writing local files
[12:44:39] Completed 210000 out of 250000 steps  (84 percent)
[12:59:13] Writing local files
[12:59:14] Completed 212500 out of 250000 steps  (85 percent)
[13:13:48] Writing local files
[13:13:49] Completed 215000 out of 250000 steps  (86 percent)
[13:28:24] Writing local files
[13:28:24] Completed 217500 out of 250000 steps  (87 percent)
[13:42:59] Writing local files
[13:43:00] Completed 220000 out of 250000 steps  (88 percent)
[13:57:36] Writing local files
[13:57:37] Completed 222500 out of 250000 steps  (89 percent)
[14:12:12] Writing local files
[14:12:12] Completed 225000 out of 250000 steps  (90 percent)
[14:26:48] Writing local files
[14:26:48] Completed 227500 out of 250000 steps  (91 percent)
[14:41:24] Writing local files
[14:41:24] Completed 230000 out of 250000 steps  (92 percent)
[14:56:01] Writing local files
[14:56:01] Completed 232500 out of 250000 steps  (93 percent)
[15:10:39] Writing local files
[15:10:39] Completed 235000 out of 250000 steps  (94 percent)
[15:25:17] Writing local files
[16:39:17]
[16:39:22]
[16:49:50]
[16:49:50]
[16:49:50]
[16:49:51]
[16:49:51]
[16:50:16] al files
[17:09:37]
[17:09:38]
[17:22:39]
[17:22:39]
[17:22:39]
[17:22:57]
[17:22:57]
[17:23:03]
[17:42:33] Writing local files
[17:42:33] Completed 10000 out of 500000 steps  (2 percent)
[17:52:17] Writing local files
[17:52:17] Completed 15000 out of 500000 steps  (3 percent)
[18:02:06] Writing local files
[18:02:06] Completed 20000 out of 500000 steps  (4 percent)
[18:11:51] Writing local files
[18:11:51] Completed 25000 out of 500000 steps  (5 percent)
[18:21:34] Writing local files
[18:21:34] Completed 30000 out of 500000 steps  (6 percent)
[18:31:21] Writing local files
[18:31:21] Completed 35000 out of 500000 steps  (7 percent)
[18:41:06] Writing local files
[18:41:06] Completed 40000 out of 500000 steps  (8 percent)
[18:50:51] Writing local files
[18:50:51] Completed 45000 out of 500000 steps  (9 percent)
[19:00:38] Writing local files
[19:00:38] Completed 50000 out of 500000 steps  (10 percent)
[19:10:28] Writing local files
[19:10:28] Completed 55000 out of 500000 steps  (11 percent)
[19:20:11] Writing local files
[19:20:11] Completed 60000 out of 500000 steps  (12 percent)
[19:29:54] Writing local files
[19:29:54] Completed 65000 out of 500000 steps  (13 percent)
[19:39:39] Writing local files
[19:39:39] Completed 70000 out of 500000 steps  (14 percent)
[19:49:28] Writing local files
[19:49:28] Completed 75000 out of 500000 steps  (15 percent)
[19:59:14] Writing local files
[19:59:14] Completed 80000 out of 500000 steps  (16 percent)
[20:08:55] Writing local files
[20:08:55] Completed 85000 out of 500000 steps  (17 percent)
[20:18:35] Writing local files
[20:18:36] Completed 90000 out of 500000 steps  (18 percent)
[20:28:18] Writing local files
[20:28:18] Completed 95000 out of 500000 steps  (19 percent)
[20:37:59] Writing local files
[20:37:59] Completed 100000 out of 500000 steps  (20 percent)
[20:47:41] Writing local files
[20:47:41] Completed 105000 out of 500000 steps  (21 percent)
[20:57:22] Writing local files
[20:57:22] Completed 110000 out of 500000 steps  (22 percent)
[21:07:02] Writing local files
[21:07:02] Completed 115000 out of 500000 steps  (23 percent)
[21:16:49] Writing local files
[21:16:49] Completed 120000 out of 500000 steps  (24 percent)
[21:26:34] Writing local files
[21:26:34] Completed 125000 out of 500000 steps  (25 percent)
[21:36:14] Writing local files
[21:36:15] Completed 130000 out of 500000 steps  (26 percent)
[21:45:55] Writing local files
[21:45:55] Completed 135000 out of 500000 steps  (27 percent)
[21:55:44] Writing local files
[21:55:44] Completed 140000 out of 500000 steps  (28 percent)
[22:05:31] Writing local files
[22:05:31] Completed 145000 out of 500000 steps  (29 percent)
[22:15:17] Writing local files
[22:15:17] Completed 150000 out of 500000 steps  (30 percent)
[22:25:06] Writing local files
[22:25:06] Completed 155000 out of 500000 steps  (31 percent)
[22:34:56] Writing local files
[22:34:56] Completed 160000 out of 500000 steps  (32 percent)
[22:44:44] Writing local files
[22:44:45] Completed 165000 out of 500000 steps  (33 percent)
[22:54:33] Writing local files
[22:54:33] Completed 170000 out of 500000 steps  (34 percent)
[23:04:22] Writing local files
[23:04:22] Completed 175000 out of 500000 steps  (35 percent)
[23:14:07] Writing local files
[23:14:07] Completed 180000 out of 500000 steps  (36 percent)
[23:23:49] Writing local files
[23:23:49] Completed 185000 out of 500000 steps  (37 percent)
[23:33:37] Writing local files
[23:33:37] Completed 190000 out of 500000 steps  (38 percent)
[23:43:26] Writing local files
[23:43:26] Completed 195000 out of 500000 steps  (39 percent)
[23:53:09] Writing local files
[23:53:09] Completed 200000 out of 500000 steps  (40 percent)
[00:02:52] Writing local files
[00:02:52] Completed 205000 out of 500000 steps  (41 percent)
[00:12:34] Writing local files
[00:12:34] Completed 210000 out of 500000 steps  (42 percent)
[00:22:17] Writing local files
[00:22:17] Completed 215000 out of 500000 steps  (43 percent)
[00:32:00] Writing local files
[00:32:00] Completed 220000 out of 500000 steps  (44 percent)
[00:41:47] Writing local files
[00:41:47] Completed 225000 out of 500000 steps  (45 percent)
[00:51:31] Writing local files
[00:51:31] Completed 230000 out of 500000 steps  (46 percent)
[01:01:16] Writing local files
[01:01:16] Completed 235000 out of 500000 steps  (47 percent)
[01:11:01] Writing local files
[01:11:01] Completed 240000 out of 500000 steps  (48 percent)
[01:20:45] Writing local files
[01:20:45] Completed 245000 out of 500000 steps  (49 percent)
[01:30:30] Writing local files
[01:30:30] Completed 250000 out of 500000 steps  (50 percent)
[01:40:16] Writing local files
[01:40:16] Completed 255000 out of 500000 steps  (51 percent)
[01:50:07] Writing local files
[01:50:07] Completed 260000 out of 500000 steps  (52 percent)
[01:59:58] Writing local files
[01:59:58] Completed 265000 out of 500000 steps  (53 percent)
[02:09:49] Writing local files
[02:09:49] Completed 270000 out of 500000 steps  (54 percent)
[02:19:40] Writing local files
[02:19:40] Completed 275000 out of 500000 steps  (55 percent)
[02:29:30] Writing local files
[02:29:30] Completed 280000 out of 500000 steps  (56 percent)
[02:39:20] Writing local files
[02:39:20] Completed 285000 out of 500000 steps  (57 percent)
[02:49:10] Writing local files
[02:49:10] Completed 290000 out of 500000 steps  (58 percent)
[02:59:00] Writing local files
[02:59:00] Completed 295000 out of 500000 steps  (59 percent)
[03:08:50] Writing local files
[03:08:50] Completed 300000 out of 500000 steps  (60 percent)
[03:18:41] Writing local files
[03:18:41] Completed 305000 out of 500000 steps  (61 percent)
[03:28:30] Writing local files
[03:28:30] Completed 310000 out of 500000 steps  (62 percent)
[03:38:12] Writing local files
[03:38:13] Completed 315000 out of 500000 steps  (63 percent)
[03:47:57] Writing local files
[03:47:57] Completed 320000 out of 500000 steps  (64 percent)
[03:57:43] Writing local files
[03:57:43] Completed 325000 out of 500000 steps  (65 percent)
[04:07:27] Writing local files
[04:07:28] Completed 330000 out of 500000 steps  (66 percent)
[04:17:18] Writing local files
[04:17:18] Completed 335000 out of 500000 steps  (67 percent)
[04:27:07] Writing local files
[04:27:07] Completed 340000 out of 500000 steps  (68 percent)
[04:36:50] Writing local files
[04:36:50] Completed 345000 out of 500000 steps  (69 percent)
[04:46:39] Writing local files
[04:46:39] Completed 350000 out of 500000 steps  (70 percent)
[04:56:29] Writing local files
[04:56:29] Completed 355000 out of 500000 steps  (71 percent)
[05:06:12] Writing local files
[05:06:12] Completed 360000 out of 500000 steps  (72 percent)
[05:16:01] Writing local files
[05:16:01] Completed 365000 out of 500000 steps  (73 percent)
[05:25:51] Writing local files
[05:25:51] Completed 370000 out of 500000 steps  (74 percent)
[05:35:40] Writing local files
[05:35:40] Completed 375000 out of 500000 steps  (75 percent)
[05:45:31] Writing local files
[05:45:31] Completed 380000 out of 500000 steps  (76 percent)
[05:55:22] Writing local files
[05:55:22] Completed 385000 out of 500000 steps  (77 percent)
[06:05:13] Writing local files
[06:05:13] Completed 390000 out of 500000 steps  (78 percent)
[06:15:05] Writing local files
[06:15:05] Completed 395000 out of 500000 steps  (79 percent)
[06:24:57] Writing local files
[06:24:57] Completed 400000 out of 500000 steps  (80 percent)
[06:34:42] Writing local files
[06:34:42] Completed 405000 out of 500000 steps  (81 percent)
[06:44:33] Writing local files
[06:44:33] Completed 410000 out of 500000 steps  (82 percent)
[06:54:23] Writing local files
[06:54:24] Completed 415000 out of 500000 steps  (83 percent)
[07:04:14] Writing local files
[07:04:14] Completed 420000 out of 500000 steps  (84 percent)
[07:14:05] Writing local files
[07:14:05] Completed 425000 out of 500000 steps  (85 percent)
[07:23:55] Writing local files
[07:23:55] Completed 430000 out of 500000 steps  (86 percent)
[07:33:41] Writing local files
[07:33:41] Completed 435000 out of 500000 steps  (87 percent)
[07:43:24] Writing local files
[07:43:24] Completed 440000 out of 500000 steps  (88 percent)
[07:53:08] Writing local files
[07:53:08] Completed 445000 out of 500000 steps  (89 percent)
[08:02:52] Writing local files
[08:02:52] Completed 450000 out of 500000 steps  (90 percent)
[08:12:35] Writing local files
[08:12:35] Completed 455000 out of 500000 steps  (91 percent)
[08:22:17] Writing local files
[08:22:17] Completed 460000 out of 500000 steps  (92 percent)
[08:32:05] Writing local files
[08:32:05] Completed 465000 out of 500000 steps  (93 percent)
[08:41:55] Writing local files
[08:41:55] Completed 470000 out of 500000 steps  (94 percent)
[08:51:45] Writing local files
[08:51:45] Completed 475000 out of 500000 steps  (95 percent)
[09:01:35] Writing local files
[09:01:35] Completed 480000 out of 500000 steps  (96 percent)
[09:11:26] Writing local files
[09:11:26] Completed 485000 out of 500000 steps  (97 percent)
[09:21:16] Writing local files
[09:21:16] Completed 490000 out of 500000 steps  (98 percent)
[09:31:06] Writing local files
[09:31:06] Completed 495000 out of 500000 steps  (99 percent)
[09:40:56] Writing local files
[09:40:56] Completed 500000 out of 500000 steps  (100 percent)
[09:40:56] Writing final coordinates.
[09:40:57] Past main M.D. loop
[09:40:57] Will end MPI now
[09:41:57]
[09:41:57] Finished Work Unit:
[09:41:57] - Reading up to 3721056 from "work/wudata_03.arc": Read 3721056
[09:41:57] - Reading up to 1776544 from "work/wudata_03.xtc": Read 1776544
[09:41:57] goefile size: 0
[09:41:57] logfile size: 16912
[09:41:57] Leaving Run
[09:41:59] - Writing 5518912 bytes of core data to disk...
[09:41:59]   ... Done.
[09:41:59] - Shutting down core
[09:41:59]
[09:41:59] Folding@home Core Shutdown: FINISHED_UNIT
[09:42:03] CoreStatus = 64 (100)
[09:42:03] Unit 3 finished with 83 percent of time to deadline remaining.
[09:42:03] Updated performance fraction: 0.830665
[09:42:03] Sending work to server
[09:42:03] + Attempting to send results
[09:42:03] - Reading file work/wuresults_03.dat from core
[09:42:03]   (Read 5518912 bytes from disk)
[09:42:03] Connecting to http://171.64.65.56:8080/
[09:48:05] - Connecting to assignment server
[09:48:05] Connecting to http://assign.stanford.edu:8080/
[09:48:06] Posted data.
[09:48:06] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[09:48:06] + News From Folding@Home: Welcome to Folding@Home
[09:48:06] Loaded queue successfully.
[09:48:06] Connecting to http://171.64.65.64:8080/
[09:48:11] Posted data.
[09:48:11] Initial: 0000; - Receiving payload (expected size: 4738675)
[09:51:45] - Downloaded at ~21 kB/s
[09:51:45] - Averaged speed for that direction ~30 kB/s
[09:51:45] + Received work.
[09:51:45] Trying to send all finished work units
[09:51:45] + No unsent completed units remaining.
[09:51:45] + Closed connections
[09:51:45]
[09:51:45] + Processing work unit
[09:51:45] Core required: FahCore_a1.exe
[09:51:45] Core found.
[09:51:45] Working on Unit 04 [July 8 09:51:45]
[09:51:45] + Working ...
[09:51:45] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 30 -forceasm -verbose -lifeline 524 -version 602'
[09:51:45]
[09:51:45] *------------------------------*
[09:51:45] Folding@Home Gromacs SMP Core
[09:51:45] Version 1.74 (November 27, 2006)
[09:51:45]
[09:51:45] Preparing to commence simulation
[09:51:45] - Ensuring status. Please wait.
[09:52:02] - Assembly optimizations manually forced on.
[09:52:02] - Not checking prior termination.
[09:52:03] - Expanded 4738163 -> 24426905 (decompressed 515.5 percent)
[09:52:03] - Starting from initial work packet
[09:52:03]
[09:52:03] Project: 2665 (Run 3, Clone 521, Gen 24)
[09:52:03]
[09:52:03] Assembly optimizations on if available.
[09:52:03] Entering M.D.
[09:52:09] Rejecting checkpoint
[09:52:10] Protein: HGG in waterExtra SSE boost OK.
[09:52:10]
[09:52:11] Extra SSE boost OK.
[09:52:11] Writing local files
[09:52:11] Completed 0 out of 250000 steps  (0 percent)
[10:06:39] Writing local files
[10:06:39] Completed 2500 out of 250000 steps  (1 percent)
[10:21:07] Writing local files
[10:21:07] Completed 5000 out of 250000 steps  (2 percent)
[10:35:37] Writing local files
[10:35:37] Completed 7500 out of 250000 steps  (3 percent)
[10:50:08] Writing local files
[10:50:08] Completed 10000 out of 250000 steps  (4 percent)
[11:04:38] Writing local files
[11:04:39] Completed 12500 out of 250000 steps  (5 percent)
[11:19:08] Writing local files
[11:19:08] Completed 15000 out of 250000 steps  (6 percent)
[11:33:38] Writing local files
[11:33:38] Completed 17500 out of 250000 steps  (7 percent)
[11:48:09] Writing local files
[11:48:09] Completed 20000 out of 250000 steps  (8 percent)
[12:02:40] Writing local files
[12:02:40] Completed 22500 out of 250000 steps  (9 percent)
[12:17:11] Writing local files
[12:17:11] Completed 25000 out of 250000 steps  (10 percent)
[12:31:40] Writing local files
[12:31:40] Completed 27500 out of 250000 steps  (11 percent)
[12:46:10] Writing local files
[12:46:10] Completed 30000 out of 250000 steps  (12 percent)
[13:00:39] Writing local files
[13:00:39] Completed 32500 out of 250000 steps  (13 percent)
[13:15:08] Writing local files
[13:15:08] Completed 35000 out of 250000 steps  (14 percent)
[13:29:37] Writing local files
[13:29:37] Completed 37500 out of 250000 steps  (15 percent)
[13:44:05] Writing local files
[13:44:05] Completed 40000 out of 250000 steps  (16 percent)
[13:58:35] Writing local files
[13:58:35] Completed 42500 out of 250000 steps  (17 percent)
[14:13:02] Writing local files
[14:13:03] Completed 45000 out of 250000 steps  (18 percent)
[14:27:32] Writing local files
[14:27:32] Completed 47500 out of 250000 steps  (19 percent)
[14:42:01] Writing local files
[14:42:01] Completed 50000 out of 250000 steps  (20 percent)
[14:56:32] Writing local files
[14:56:32] Completed 52500 out of 250000 steps  (21 percent)
[15:11:02] Writing local files
[15:11:02] Completed 55000 out of 250000 steps  (22 percent)
[15:25:33] Writing local files
[15:25:33] Completed 57500 out of 250000 steps  (23 percent)
[15:40:03] Writing local files
[15:40:03] Completed 60000 out of 250000 steps  (24 percent)
[15:54:32] Completed 62500 out of 250000 steps  (25 percent)
[16:09:00] Writing local files
[16:09:01] Completed 65000 out of 250000 steps  (26 percent)
[16:23:30] Writing local files
[16:23:30] Completed 67500 out of 250000 steps  (27 percent)
[16:37:59] Writing local files
[16:37:59] Completed 70000 out of 250000 steps  (28 percent)
[16:52:30] Writing local files
[16:52:30] Completed 72500 out of 250000 steps  (29 percent)
[17:06:58] Writing local files
[17:06:59] Completed 75000 out of 250000 steps  (30 percent)
[17:21:28] Writing local files
[17:21:28] Completed 77500 out of 250000 steps  (31 percent)
[17:35:58] Writing local files
[17:35:59] Completed 80000 out of 250000 steps  (32 percent)
[17:50:29] Writing local files
[17:50:29] Completed 82500 out of 250000 steps  (33 percent)
[18:04:58] Writing local files
[18:04:58] Completed 85000 out of 250000 steps  (34 percent)
[18:19:28] Writing local files
[18:19:28] Completed 87500 out of 250000 steps  (35 percent)
[18:33:57] Writing local files
[18:33:57] Completed 90000 out of 250000 steps  (36 percent)
[18:48:25] Writing local files
[18:48:25] Completed 92500 out of 250000 steps  (37 percent)
[19:02:55] Writing local files
[19:02:55] Completed 95000 out of 250000 steps  (38 percent)
[19:17:24] Writing local files
[19:17:24] Completed 97500 out of 250000 steps  (39 percent)
[19:31:54] Writing local files
[19:31:54] Completed 100000 out of 250000 steps  (40 percent)
[19:46:23] Writing local files
[19:46:24] Completed 102500 out of 250000 steps  (41 percent)
[20:00:53] Writing local files
[20:00:53] Completed 105000 out of 250000 steps  (42 percent)
[20:15:23] Writing local files
[20:15:23] Completed 107500 out of 250000 steps  (43 percent)
[20:29:53] Writing local files
[20:29:53] Completed 110000 out of 250000 steps  (44 percent)
[20:44:25] Writing local files
[20:44:25] Completed 112500 out of 250000 steps  (45 percent)
[20:58:56] Writing local files
[20:58:56] Completed 115000 out of 250000 steps  (46 percent)
[21:13:28] Writing local files
[21:13:28] Completed 117500 out of 250000 steps  (47 percent)
[21:28:00] Writing local files
[21:28:00] Completed 120000 out of 250000 steps  (48 percent)
[21:42:32] Writing local files
[21:42:32] Completed 122500 out of 250000 steps  (49 percent)
[21:57:04] Writing local files
[21:57:04] Completed 125000 out of 250000 steps  (50 percent)
Team: 132987
Great_Gig wrote:(the timing seemed to shift back an hour when it logged to the server?),
. . . (Timings are UK).
UK is on BST which is one hour east of GMT.
When a WU uploads, it often takes an extra hour or so before it's logged in the stats.
I'll need a little while to digest the logs but they'll probably be quite helpful in figuring out what happened.
Great_Gig
Hardware configuration: CPU: Intel Q6600 'GO' @ 2.88GHz (20% Overclock)
Cooling: Thermalright HR-01 Heat Sink + Nexus 120mm Silent Fan
Motherboard: Gigabyte GA-G31M-S2L
RAM: 1GB Kingston HyperX DDR2 800MHz
Disk: 1GB OCZ USB Flash Drive
PSU: Enermax Pro 82+ 385W
O/S: Diskless System - 64bit Linux SMP Client
Monitor: FahMon 2.3.2b
Power Consumption: 84W
Post by Great_Gig »
bruce wrote: When a WU uploads, it often takes an extra hour or so before it's logged in the stats.
Many thanks bruce, your help is really appreciated Image
Team: 132987
Great_Gig
Post by Great_Gig »
I think I have just spotted something in the FAHlog.txt? I am not sure if this could be the problem, as I don't at this stage really understand fully the differences between the WU's etc. Anyway, the WU's I have completed so far are;
1. Project: 2665 (Run 0, Clone 355, Gen 24) 5th to 6th July
2. Project: 2665 (Run 0, Clone 355, Gen 24) 6th to 7th July
3. Project: 2605 (Run 13, Clone 567, Gen 69) 7th to 8th July
4. Project: 2665 (Run 3, Clone 521, Gen 24) still running
Edited summary below of the entires in FAHlog.txt?
--- Opening Log file [July 5 17:17:12]
[16:20:05] Folding@Home Gromacs SMP Core
[16:20:05] Version 1.74 (November 27, 2006)
[16:20:05]
[16:20:05] Preparing to commence simulation
[16:20:05] - Ensuring status. Please wait.
[16:20:06] - Starting from initial work packet
[16:20:06]
[16:20:06] Project: 2665 (Run 0, Clone 355, Gen 24)
[16:20:06]
[16:49:51]
[16:49:51]
[17:22:57]
[17:22:57]
[09:52:03]
Could this be the problem? I don't know the significance of the Run, Clone & Gen numbers, but the first 2 Project 2665 WU's have the same numbers, but the current one is different? Has the client downloaded and processed the same WU and therefore that's why I didn't get any credit, as it was a duplicate?
Please excuse me if you are all laughing and thinking I'm a twit if I have just made a stupid mistake, but I'm a newbie and don't fully understand all this yet :oops:
Team: 132987
ChelseaOilman
Post by ChelseaOilman »
It seems the work server wasn't able to accept the finished WU the first time so it went to the collection server. Then even though you couldn't upload the finised WU to the work server, the same work server was able to send you a new WU. Unfortunately because the first WU went to the collection server, you ended up getting the same WU from the work server again. It's not supposed to work that way.
[16:20:05] Working on Unit 01 [July 5 16:20:05]
[16:20:31] Completed 0 out of 250000 steps (0 percent)
[16:39:17]
[16:39:22]
[16:49:50]
[17:09:37]
[17:09:38]
