Out of nowhere my cpu says disabled.
nerd
Post by nerd »
I was gonna start folding and when I looked above the button, disabled showed up and said get help at foldingforum.org. Logs are here.
*********************** Log Started 2022-08-23T18:32:18Z ***********************
18:32:18:******************************* libFAH ********************************
18:32:18:         Date: Oct 20 2020
18:32:18:         Time: 13:36:55
18:32:18:     Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
18:32:18:       Branch: master
18:32:18:     Compiler: Visual C++ 2015
18:32:18:      Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:32:18:     Platform: win32 10
18:32:18:         Bits: 32
18:32:18:         Mode: Release
18:32:18:****************************** FAHClient ******************************
18:32:18:      Version: 7.6.21
18:32:18:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:32:18:    Copyright: 2020 foldingathome.org
18:32:18:     Homepage: https://foldingathome.org/
18:32:18:         Time: 13:41:04
18:32:18:     Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
18:32:18:         Bits: 32
18:32:18:         Args: --open-web-control
18:32:18:******************************** CBang ********************************
18:32:18:         Time: 11:36:18
18:32:18:     Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
18:32:18:         Bits: 32
18:32:18:******************************* System ********************************
18:32:18:          CPU: AMD A8-6500 APU with Radeon(tm) HD Graphics
18:32:18:       CPU ID: AuthenticAMD Family 21 Model 19 Stepping 1
18:32:18:         CPUs: 4
18:32:18:       Memory: 7.19GiB
18:32:18:  Free Memory: 1.83GiB
18:32:18:      Threads: WINDOWS_THREADS
18:32:18:   OS Version: 6.2
18:32:18:  Has Battery: false
18:32:18:   On Battery: false
18:32:18:   UTC Offset: -7
18:32:18:          PID: 10832
18:32:18:          CWD: C:\ProgramData\FAHClient
18:32:18:Win32 Service: false
18:32:18:           OS: Windows 10 Home
18:32:18:      OS Arch: AMD64
18:32:18:         GPUs: 1
18:32:18:        GPU 0: Bus:0 Slot:1 Func:0 AMD:2 Oland [Radeon HD 8570D] 432
18:32:18:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:32:18:               specified module could not be found.
18:32:18:
18:32:18:***********************************************************************
18:32:18:<config>
18:32:18:  <!-- Folding Slots -->
18:32:18:</config>
18:32:18:Trying to access database...
18:32:21:Successfully acquired database lock
18:32:21:FS00:Initialized folding slot 00: cpu:2
18:32:21:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:0:1 Oland [Radeon HD 8570D] 432.  Disabling.
18:33:20:20:127.0.0.1:New Web session
18:33:22:Saving configuration to config.xml
18:33:22:<config>
18:33:22:  <!-- Folding Slots -->
18:33:22:  <slot id='0' type='CPU'/>
18:33:22:  <slot id='1' type='GPU'>
18:33:22:    <pci-bus v='0'/>
18:33:22:    <pci-slot v='1'/>
18:33:22:  </slot>
18:33:22:</config>
18:33:24:Set client configured
18:33:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:33:26:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:33:27:WU00:FS00:Assigned to work server 128.252.203.12
18:33:27:WU00:FS00:Requesting new work unit for slot 00: cpu:2 from 128.252.203.12
18:33:27:WU00:FS00:Connecting to 128.252.203.12:8080
18:33:28:WU00:FS00:Downloading 2.57MiB
18:33:28:WU00:FS00:Download complete
18:33:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18322 run:5 clone:351 gen:239 core:0xa8 unit:0x0000015f000000ef0000479200000005
18:33:31:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah
18:33:31:WU00:FS00:Connecting to cores.foldingathome.org:80
18:33:32:WU00:FS00:FahCore a8: Downloading 7.72MiB
18:33:35:WU00:FS00:FahCore a8: Download complete
18:33:35:WU00:FS00:Valid core signature
18:33:35:WU00:FS00:Unpacked 21.01MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
18:33:35:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
18:33:36:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
18:33:36:WU00:FS00:Starting
18:33:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10832 -checkpoint 15 -np 2
18:33:37:WU00:FS00:Started FahCore on PID 9428
18:33:39:WU00:FS00:Core PID:3988
18:33:39:WU00:FS00:FahCore 0xa8 started
18:33:39:WU00:FS00:0xa8:*********************** Log Started 2022-08-23T18:33:39Z ***********************
18:33:39:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
18:33:39:WU00:FS00:0xa8:       Core: Gromacs
18:33:39:WU00:FS00:0xa8:       Type: 0xa8
18:33:39:WU00:FS00:0xa8:    Version: 0.0.12
18:33:39:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:33:39:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
18:33:39:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
18:33:39:WU00:FS00:0xa8:       Date: Jan 16 2021
18:33:39:WU00:FS00:0xa8:       Time: 11:56:07
18:33:39:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:33:39:WU00:FS00:0xa8:     Branch: master
18:33:39:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
18:33:39:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:33:39:WU00:FS00:0xa8:   Platform: win32 10
18:33:39:WU00:FS00:0xa8:       Bits: 64
18:33:39:WU00:FS00:0xa8:       Mode: Release
18:33:39:WU00:FS00:0xa8:       SIMD: avx_256
18:33:39:WU00:FS00:0xa8:     OpenMP: ON
18:33:39:WU00:FS00:0xa8:       CUDA: OFF
18:33:39:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9428 -checkpoint 15 -np 2
18:33:39:WU00:FS00:0xa8:************************************ libFAH ************************************
18:33:39:WU00:FS00:0xa8:       Time: 11:24:13
18:33:39:WU00:FS00:0xa8:************************************ CBang *************************************
18:33:40:WU00:FS00:0xa8:       Date: Jan 16 2021
18:33:40:WU00:FS00:0xa8:       Time: 11:23:53
18:33:40:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:33:40:WU00:FS00:0xa8:     Branch: master
18:33:40:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
18:33:40:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:33:40:WU00:FS00:0xa8:   Platform: win32 10
18:33:40:WU00:FS00:0xa8:       Bits: 64
18:33:40:WU00:FS00:0xa8:       Mode: Release
18:33:40:WU00:FS00:0xa8:************************************ System ************************************
18:33:40:WU00:FS00:0xa8:        CPU: AMD A8-6500 APU with Radeon(tm) HD Graphics
18:33:40:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 19 Stepping 1
18:33:40:WU00:FS00:0xa8:       CPUs: 4
18:33:40:WU00:FS00:0xa8:     Memory: 7.19GiB
18:33:40:WU00:FS00:0xa8:Free Memory: 1.89GiB
18:33:40:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
18:33:40:WU00:FS00:0xa8: OS Version: 6.2
18:33:40:WU00:FS00:0xa8:Has Battery: false
18:33:40:WU00:FS00:0xa8: On Battery: false
18:33:40:WU00:FS00:0xa8: UTC Offset: -7
18:33:40:WU00:FS00:0xa8:        PID: 3988
18:33:40:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
18:33:40:WU00:FS00:0xa8:********************************************************************************
18:33:40:WU00:FS00:0xa8:Project: 18322 (Run 5, Clone 351, Gen 239)
18:33:40:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
18:33:40:WU00:FS00:0xa8:Reading tar file core.xml
18:33:40:WU00:FS00:0xa8:Reading tar file frame239.tpr
18:33:40:WU00:FS00:0xa8:Digital signatures verified
18:33:40:WU00:FS00:0xa8:Calling: mdrun -c frame239.gro -s frame239.tpr -x frame239.xtc -cpt 15 -nt 2 -ntmpi 1
18:33:40:WU00:FS00:0xa8:Steps: first=119500000 total=120000000
18:34:09:WU00:FS00:0xa8:Completed 1 out of 500000 steps (0%)
18:35:24:Saving configuration to config.xml
18:35:24:<config>
18:35:24:  <!-- Folding Slot Configuration -->
18:35:24:  <cause v='COVID_19'/>
18:35:24:
18:35:24:  <!-- Folding Slots -->
18:35:24:  <slot id='0' type='CPU'/>
18:35:24:  <slot id='1' type='GPU'>
18:35:24:    <pci-bus v='0'/>
18:35:24:    <pci-slot v='1'/>
18:35:24:  </slot>
18:35:24:</config>
18:36:25:Saving configuration to config.xml
18:36:25:<config>
18:36:25:  <!-- Folding Slot Configuration -->
18:36:25:  <cause v='COVID_19'/>
18:36:25:
18:36:25:  <!-- User Information -->
18:36:25:  <user v='Jeffrey'/>
18:36:25:
18:36:25:  <!-- Folding Slots -->
18:36:25:  <slot id='0' type='CPU'/>
18:36:25:  <slot id='1' type='GPU'>
18:36:25:    <pci-bus v='0'/>
18:36:25:    <pci-slot v='1'/>
18:36:25:  </slot>
18:36:25:</config>
18:57:39:WU00:FS00:0xa8:Completed 5000 out of 500000 steps (1%)
19:06:36:FS00:Shutting core down
19:06:36:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 3988
19:06:36:WU00:FS00:0xa8:Exiting, please wait. . .
19:06:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:06:48:WU00:FS00:Starting
19:06:48:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
19:06:48:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
19:06:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10832 -checkpoint 15 -np 2
19:06:48:WU00:FS00:Started FahCore on PID 10024
19:06:52:WU00:FS00:Core PID:10680
19:06:52:WU00:FS00:FahCore 0xa8 started
19:06:53:WU00:FS00:0xa8:*********************** Log Started 2022-08-23T19:06:52Z ***********************
19:06:53:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:06:53:WU00:FS00:0xa8:       Core: Gromacs
19:06:53:WU00:FS00:0xa8:       Type: 0xa8
19:06:53:WU00:FS00:0xa8:    Version: 0.0.12
19:06:53:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:06:53:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:06:53:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:06:53:WU00:FS00:0xa8:       Date: Jan 16 2021
19:06:53:WU00:FS00:0xa8:       Time: 11:56:07
19:06:53:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:06:53:WU00:FS00:0xa8:     Branch: master
19:06:53:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:06:53:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:06:53:WU00:FS00:0xa8:   Platform: win32 10
19:06:53:WU00:FS00:0xa8:       Bits: 64
19:06:53:WU00:FS00:0xa8:       Mode: Release
19:06:53:WU00:FS00:0xa8:       SIMD: avx_256
19:06:53:WU00:FS00:0xa8:     OpenMP: ON
19:06:53:WU00:FS00:0xa8:       CUDA: OFF
19:06:53:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10024 -checkpoint 15 -np
19:06:53:WU00:FS00:0xa8:             2
19:06:53:WU00:FS00:0xa8:************************************ libFAH ************************************
19:06:53:WU00:FS00:0xa8:       Time: 11:24:13
19:06:53:WU00:FS00:0xa8:************************************ CBang *************************************
19:06:53:WU00:FS00:0xa8:       Time: 11:23:53
19:06:54:WU00:FS00:0xa8:   Platform: win32 10
19:06:54:WU00:FS00:0xa8:       Bits: 64
19:06:54:WU00:FS00:0xa8:       Mode: Release
19:06:54:WU00:FS00:0xa8:************************************ System ************************************
19:06:54:WU00:FS00:0xa8:        CPU: AMD A8-6500 APU with Radeon(tm) HD Graphics
19:06:54:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 19 Stepping 1
19:06:54:WU00:FS00:0xa8:       CPUs: 4
19:06:54:WU00:FS00:0xa8:     Memory: 7.19GiB
19:06:54:WU00:FS00:0xa8:Free Memory: 3.26GiB
19:06:54:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:06:54:WU00:FS00:0xa8: OS Version: 6.2
19:06:54:WU00:FS00:0xa8:Has Battery: false
19:06:54:WU00:FS00:0xa8: On Battery: false
19:06:54:WU00:FS00:0xa8: UTC Offset: -7
19:06:54:WU00:FS00:0xa8:        PID: 10680
19:06:54:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
19:06:54:WU00:FS00:0xa8:********************************************************************************
19:06:54:WU00:FS00:0xa8:Project: 18322 (Run 5, Clone 351, Gen 239)
19:06:54:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:06:54:WU00:FS00:0xa8:Digital signatures verified
19:06:54:WU00:FS00:0xa8:Calling: mdrun -c frame239.gro -s frame239.tpr -x frame239.xtc -cpi state.cpt -cpt 15 -nt 2 -ntmpi 1
19:06:54:WU00:FS00:0xa8:Steps: first=119500000 total=120000000
19:06:55:Saving configuration to config.xml
19:06:55:<config>
19:06:55:  <!-- Folding Slot Configuration -->
19:06:55:  <cause v='COVID_19'/>
19:06:55:
19:06:55:  <!-- Slot Control -->
19:06:55:  <power v='FULL'/>
19:06:55:
19:06:55:  <!-- User Information -->
19:06:55:  <user v='Jeffrey'/>
19:06:55:
19:06:55:  <!-- Folding Slots -->
19:06:55:  <slot id='0' type='CPU'/>
19:06:55:  <slot id='1' type='GPU'>
19:06:55:    <pci-bus v='0'/>
19:06:55:    <pci-slot v='1'/>
19:06:55:  </slot>
19:06:55:</config>
19:07:14:WU00:FS00:0xa8:Completed 8602 out of 500000 steps (1%)
19:12:45:WU00:FS00:0xa8:Completed 10000 out of 500000 steps (2%)
19:26:33:WU00:FS00:0xa8:Completed 15000 out of 500000 steps (3%)
19:40:31:WU00:FS00:0xa8:Completed 20000 out of 500000 steps (4%)
19:55:37:WU00:FS00:0xa8:Completed 25000 out of 500000 steps (5%)
20:08:21:WU00:FS00:0xa8:Completed 30000 out of 500000 steps (6%)
20:11:27:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
20:11:59:Saving configuration to config.xml
20:11:59:<config>
20:11:59:  <!-- Folding Slot Configuration -->
20:11:59:  <cause v='COVID_19'/>
20:11:59:
20:11:59:  <!-- Network -->
20:11:59:  <proxy v=':8080'/>
20:11:59:
20:11:59:  <!-- Slot Control -->
20:11:59:  <power v='FULL'/>
20:11:59:
20:11:59:  <!-- User Information -->
20:11:59:  <user v='Jeffrey'/>
20:11:59:
20:11:59:  <!-- Folding Slots -->
20:11:59:  <slot id='0' type='CPU'/>
20:11:59:  <slot id='1' type='GPU'>
20:11:59:    <pci-bus v='0'/>
20:11:59:    <pci-slot v='1'/>
20:11:59:  </slot>
20:11:59:</config>
20:15:02:Saving configuration to config.xml
20:15:02:<config>
20:15:02:  <!-- Folding Slot Configuration -->
20:15:02:  <cause v='COVID_19'/>
20:15:02:
20:15:02:  <!-- Network -->
20:15:02:  <proxy v=':8080'/>
20:15:02:
20:15:02:  <!-- Slot Control -->
20:15:02:  <power v='FULL'/>
20:15:02:
20:15:02:  <!-- User Information -->
20:15:02:  <team v='54345'/>
20:15:02:  <user v='Jeffrey'/>
20:15:02:
20:15:02:  <!-- Folding Slots -->
20:15:02:  <slot id='0' type='CPU'/>
20:15:02:  <slot id='1' type='GPU'>
20:15:02:    <pci-bus v='0'/>
20:15:02:    <pci-slot v='1'/>
20:15:02:  </slot>
20:15:02:</config>
20:15:30:WARNING:FS00:No CUDA or OpenCL 1.2+ support detected for GPU slot 00: gpu:-1:-1.  Disabling.
20:15:30:FS00:Converted slot from CPU to 00: gpu:-1:-1
20:15:30:Saving configuration to config.xml
20:15:30:<config>
20:15:30:  <!-- Folding Slot Configuration -->
20:15:30:  <cause v='COVID_19'/>
20:15:30:
20:15:30:  <!-- Network -->
20:15:30:  <proxy v=':8080'/>
20:15:30:
20:15:30:  <!-- Slot Control -->
20:15:30:  <power v='FULL'/>
20:15:30:
20:15:30:  <!-- User Information -->
20:15:30:  <team v='54345'/>
20:15:30:  <user v='Jeffrey'/>
20:15:30:
20:15:30:  <!-- Folding Slots -->
20:15:30:  <slot id='0' type='GPU'/>
20:15:30:  <slot id='1' type='GPU'>
20:15:30:    <pci-bus v='0'/>
20:15:30:    <pci-slot v='1'/>
20:15:30:  </slot>
20:15:30:</config>
20:15:53:FS00:Initialized folding slot 00: cpu:3
20:15:53:FS00:Converted slot from GPU to 00: cpu:3
20:15:53:FS01:Initialized folding slot 01: cpu:2
20:15:53:FS01:Converted slot from GPU to 01: cpu:2
20:15:53:Saving configuration to config.xml
20:15:53:<config>
20:15:53:  <!-- Folding Slot Configuration -->
20:15:53:  <cause v='COVID_19'/>
20:15:53:
20:15:53:  <!-- Network -->
20:15:53:  <proxy v=':8080'/>
20:15:53:
20:15:53:  <!-- Slot Control -->
20:15:53:  <power v='FULL'/>
20:15:53:
20:15:53:  <!-- User Information -->
20:15:53:  <team v='54345'/>
20:15:53:  <user v='Jeffrey'/>
20:15:53:
20:15:53:  <!-- Folding Slots -->
20:15:53:  <slot id='0' type='CPU'/>
20:15:53:  <slot id='1' type='CPU'/>
20:15:53:</config>
20:16:03:Saving configuration to config.xml
20:16:03:<config>
20:16:03:  <!-- Folding Slot Configuration -->
20:16:03:  <cause v='COVID_19'/>
20:16:03:
20:16:03:  <!-- Network -->
20:16:03:  <proxy v=':8080'/>
20:16:03:
20:16:03:  <!-- Slot Control -->
20:16:03:  <power v='FULL'/>
20:16:03:
20:16:03:  <!-- User Information -->
20:16:03:  <team v='54345'/>
20:16:03:  <user v='Jeffrey'/>
20:16:03:
20:16:03:  <!-- Folding Slots -->
20:16:03:  <slot id='0' type='CPU'/>
20:16:03:  <slot id='1' type='CPU'/>
20:16:03:</config>
20:16:24:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:0:1 Oland [Radeon HD 8570D] 432.  Disabling.
20:16:24:FS01:Converted slot from CPU to 01: gpu:0:1 Oland [Radeon HD 8570D] 432
20:16:24:Saving configuration to config.xml
20:16:24:<config>
20:16:24:  <!-- Folding Slot Configuration -->
20:16:24:  <cause v='COVID_19'/>
20:16:24:
20:16:24:  <!-- Network -->
20:16:24:  <proxy v=':8080'/>
20:16:24:
20:16:24:  <!-- Slot Control -->
20:16:24:  <power v='FULL'/>
20:16:24:
20:16:24:  <!-- User Information -->
20:16:24:  <team v='54345'/>
20:16:24:  <user v='Jeffrey'/>
20:16:24:
20:16:24:  <!-- Folding Slots -->
20:16:24:  <slot id='0' type='CPU'/>
20:16:24:  <slot id='1' type='GPU'/>
20:16:24:</config>
20:16:39:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
20:16:59:61:127.0.0.1:New Web session
20:17:04:Saving configuration to config.xml
20:17:04:<config>
20:17:04:  <!-- Folding Slot Configuration -->
20:17:04:  <cause v='COVID_19'/>
20:17:04:
20:17:04:  <!-- Network -->
20:17:04:  <proxy v=':8080'/>
20:17:04:
20:17:04:  <!-- Slot Control -->
20:17:04:  <power v='FULL'/>
20:17:04:
20:17:04:  <!-- User Information -->
20:17:04:  <team v='54345'/>
20:17:04:  <user v='Jeffrey'/>
20:17:04:
20:17:04:  <!-- Folding Slots -->
20:17:04:  <slot id='0' type='CPU'/>
20:17:04:  <slot id='1' type='GPU'/>
20:17:04:</config>
20:17:12:FS00:Paused
20:17:12:FS01:Paused
20:17:20:FS00:Unpaused
20:17:20:FS01:Unpaused
20:17:58:Saving configuration to config.xml
20:17:58:<config>
20:17:58:  <!-- Folding Slot Configuration -->
20:17:58:  <cause v='COVID_19'/>
20:17:58:
20:17:58:  <!-- Network -->
20:17:58:  <proxy v=':8080'/>
20:17:58:
20:17:58:  <!-- Slot Control -->
20:17:58:  <power v='FULL'/>
20:17:58:
20:17:58:  <!-- User Information -->
20:17:58:  <team v='54345'/>
20:17:58:  <user v='Jeffrey'/>
20:17:58:
20:17:58:  <!-- Folding Slots -->
20:17:58:  <slot id='0' type='CPU'/>
20:17:58:  <slot id='1' type='GPU'/>
20:17:58:</config>
20:22:51:FS00:Finishing
20:22:51:FS01:Finishing
20:23:29:Saving configuration to config.xml
20:23:29:<config>
20:23:29:  <!-- Folding Slot Configuration -->
20:23:29:  <cause v='COVID_19'/>
20:23:29:
20:23:29:  <!-- Network -->
20:23:29:  <proxy v=':8080'/>
20:23:29:
20:23:29:  <!-- Slot Control -->
20:23:29:  <power v='FULL'/>
20:23:29:
20:23:29:  <!-- User Information -->
20:23:29:  <team v='54345'/>
20:23:29:  <user v='Jeffrey'/>
20:23:29:
20:23:29:  <!-- Folding Slots -->
20:23:29:  <slot id='0' type='CPU'/>
20:23:29:</config>
20:23:42:WU00:FS00:0xa8:Completed 35000 out of 500000 steps (7%)
20:23:42:76:127.0.0.1:New Web session
20:24:11:Saving configuration to config.xml
20:24:11:<config>
20:24:11:  <!-- Folding Slot Configuration -->
20:24:11:  <cause v='COVID_19'/>
20:24:11:
20:24:11:  <!-- Network -->
20:24:11:  <proxy v=':8080'/>
20:24:11:
20:24:11:  <!-- Slot Control -->
20:24:11:  <power v='FULL'/>
20:24:11:
20:24:11:  <!-- User Information -->
20:24:11:  <team v='54345'/>
20:24:11:  <user v='Jeffrey'/>
20:24:11:
20:24:11:  <!-- Folding Slots -->
20:24:11:  <slot id='0' type='CPU'/>
20:24:11:</config>
Re: Out of nowhere my cpu says disabled.
Everything looks okay in the log until about 20:11, the configuration saves in the log indicate something was done through FAHControl or the Web Control to change settings. At 20:15 the client appears to have misidentified Slot 00 as being for the GPU instead of the CPU:
Or was that from checking off the GPU radio button for Slot 00 in FAHControl inadvertently? I have done that before on Windows systems, the default Windows theme makes the contrast very poor for that button.
The GPU slot is never going to function, the iGPU in the AMD A8-6500 APU while detected does not have the necessary support to be used for folding anymore. It does not support 64-bit processing which is now required. You can delete that slot, and to keep it from being detected and configured again, go to the Expert section of Configure on FAHControl and add an Extra client option. The name to enter is gpu and the value is set as false.
nerd
Post by nerd »
I deleted the GPU slot in the settings, and I just realized, it says disabled but it is still folding and making progress?
During the time it was set to GPU the slot may have stored GPU specific data connected to the slot. It appears to not have gone away, but at least the CPU WU is folding. My suggestion is to set the processing to Finish, then delete the slot after the WU is completed and results uploaded. The client will recreate a CPU slot, that should no longer have the GPU specific settings stored in the client.
This a rather old GPU, and the driver package you use doesn't install OpenCL which is required to run FAH.
Did you install the drivers from AMD website ?
