[05:49:35] Completed 247500 out of 250000 steps (99 percent)
[06:01:46] - Autosending finished units...
[06:01:46] Trying to send all finished work units
[06:01:46] + No unsent completed units remaining.
[06:01:46] - Autosend completed
[06:04:48] Timered checkpoint triggered.
[06:19:50] Timered checkpoint triggered.
[06:20:10] Warning: long 1-4 interactions This is within about 1 min from the time I would have expected the sooa\
[06:20:10] Gromacs cannot continue further.
[06:20:10] Going to send back what have done.
[06:20:10] logfile size: 204885
[06:20:10] - Writing 205421 bytes of core data to disk...
[06:20:10] ... Done.
[06:20:11] - Failed to delete work/wudata_02.arc
[06:20:11] Warning: check for stray files
[06:20:11]
[06:20:11] Folding@home Core Shutdown: EARLY_UNIT_END
[06:20:11]
[06:20:29] CoreStatus = 63 (99)
[06:20:29] + Error starting Folding@Home core or unexpected system termination of core.
[06:20:34]
[06:20:34] + Processing work unit
[06:20:34] Core required: FahCore_a1.exe
[06:20:34] Core found.
[06:20:34] Working on Unit 02 [July 8 06:20:34]
[06:20:34] + Working ...
[06:20:34] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 02 -priority 96 -cpu 98 -checkpoint 15 -forceasm -verbose -lifeline 3732 -version 800'
[06:20:39]
[06:20:39] *------------------------------*
[06:20:39] Folding@Home Gromacs SMP Core
[06:20:39] Version 1.76 (February 23, 2008)
[06:20:39]
[06:20:39] Preparing to commence simulation
[06:20:39] - Ensuring status. Please wait.
[06:20:39] Folding@home Core Shutdown: MISSING_WORK_FILES
[06:20:39] Finalizing output
[06:22:56] NG_WORK_FILES
[06:22:56] Finalizing output
[06:23:00] CoreStatus = 1 (1)
[06:23:00] Client-core communications error: ERROR 0x1
[06:23:00] Deleting current work unit & continuing...
Project: 2665 (Run 2, Clone 25, Gen 21)
So near yet so far away. It failed at exactly 100%.
Re: Project: 2665 (Run 2, Clone 25, Gen 21)
Bruce, why didn't you post in the "Issue with specific WU" forum
Edit by -b: Topic moved
Someone else was able to return it for full credit ... it might be a temporary issue with your client/machine.
