EUE: GPU2 WU Project: 5010 (Run 8, Clone 22, Gen 1)
MDCRL
Post by MDCRL »
New WU 5010 (Run 8, Clone 22, Gen 1) having some problems- this is the first I have seen w/ this WU
--- Opening Log file [July 7 23:57:15]
# Windows Console GPU Edition #################################################
                       Folding@Home Client Version 6.12beta8
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\RL\Application Data\Folding@home-gpu
[23:57:15] - Ask before connecting: No
[23:57:15] - User name: MDCRL (Team 35275)
[23:57:15] - User ID: 5C7A79536B104CCD
[23:57:15] - Machine ID: 2
[23:57:15]
[23:57:16] Loaded queue successfully.
[23:57:16] Initialization complete
[23:57:16] + Benchmarking ...
[23:57:19]
[23:57:19] + Processing work unit
[23:57:19] Core required: FahCore_11.exe
[23:57:19] Core found.
[23:57:19] Working on queue slot 06 [July 7 23:57:19]
[23:57:19] + Working ...
[23:57:21]
[23:57:21] *------------------------------*
[23:57:21] Folding@Home GPU Core - Beta
[23:57:21] Version 1.06 (Mon Jun 23 10:53:13 PDT 2008)
[23:57:21]
[23:57:21] Compiler  :
[23:57:21] Build host: amoeba
[23:57:21] Preparing to commence simulation
[23:57:21] - Looking at optimizations...
[23:57:21] - Files status OK
[23:57:21] - Expanded 40533 -> 245182 (decompressed 604.8 percent)
[23:57:21] Called DecompressByteArray: compressed_data_size=40533 data_size=245182, decompressed_data_size=245182 diff=0
[23:57:21] - Digital signature verified
[23:57:21]
[23:57:21] Project: 5010 (Run 8, Clone 22, Gen 1)
[23:57:21]
[23:57:21] Assembly optimizations on if available.
[23:57:21] Entering M.D.
[23:57:28] Will resume from checkpoint file
[23:58:03] Working on 576 p5005_supervillin_e1
[23:58:05] Client config found, loading data.
[23:58:06] Starting GUI Server
[23:58:06] Resuming from checkpoint
[23:58:06] Verified work/wudata_06.log
[23:58:06] Verified work/wudata_06.edr
[23:58:06] Verified work/wudata_06.trr
[23:58:06] Verified work/wudata_06.xtc
[23:58:06] Completed 1%
[00:03:43] Completed 2%
[00:08:34] Completed 3%
[00:13:21] Completed 4%
[00:18:09] Completed 5%
[00:23:04] Completed 6%
[00:28:09] Completed 7%
[00:33:09] Completed 8%
[00:37:57] Completed 9%
[00:44:03] Completed 10%
[00:49:39]
[00:49:39] Done: 23179 -> 5367 (compressed to 23.1 percent)
[00:49:39]   ... Done.
[00:49:39]
[00:49:39] Folding@home Core Shutdown: EARLY_UNIT_END
I shut down client for a bit to make sure everything was OK on the machine
- on restart it went right into a new WU and is running ok so far - I'll update if repeated...
--- Opening Log file [July 8 01:16:56]
[01:16:56] - Ask before connecting: No
[01:16:56] - User name: MDCRL (Team 35275)
[01:16:56] - User ID: 5C7A79536B104CCD
[01:16:56] - Machine ID: 2
[01:16:56]
[01:16:56] Loaded queue successfully.
[01:16:56] Initialization complete
[01:16:56] + Benchmarking ...
[01:16:56]
[01:16:56] + Processing work unit
[01:16:56] Core required: FahCore_11.exe
[01:16:56] Core found.
[01:16:57] Working on queue slot 07 [July 8 01:16:57]
[01:16:57] + Working ...
[01:16:58]
[01:16:58] *------------------------------*
[01:16:58] Folding@Home GPU Core - Beta
[01:16:58] Version 1.06 (Mon Jun 23 10:53:13 PDT 2008)
[01:16:58]
[01:16:58] Compiler  :
[01:16:58] Build host: amoeba
[01:16:58] Preparing to commence simulation
[01:16:58] - Looking at optimizations...
[01:16:58] - Files status OK
[01:16:58] - Expanded 43692 -> 244433 (decompressed 559.4 percent)
[01:16:58] Called DecompressByteArray: compressed_data_size=43692 data_size=244433, decompressed_data_size=244433 diff=0
[01:16:58] - Digital signature verified
[01:16:58]
[01:16:58] Project: 5008 (Run 3, Clone 5, Gen 3)
[01:16:58]
[01:16:58] Assembly optimizations on if available.
[01:16:58] Entering M.D.
[01:17:04] Will resume from checkpoint file
[01:17:05] Working on 576 p5005_supervillin_e1
[01:17:07] Client config found, loading data.
[01:17:07] Starting GUI Server
[01:17:08] Resuming from checkpoint
[01:17:08] Verified work/wudata_07.log
[01:17:08] Verified work/wudata_07.edr
[01:17:08] Verified work/wudata_07.trr
[01:17:08] Verified work/wudata_07.xtc
[01:22:47] Completed 1%
Re: EUE: GPU2 WU Project: 5010 (Run 8, Clone 22, Gen 1)
This WU has been completed successfully by someone else ...
