win10 system clock bonkers
Knish
Post by Knish »
i was messing around in the linux portion of a dual boot for a few hrs, and when I got back into windows and started folding, it took me a while to notice my clock was showing UTC for some reason. I had to manually hit the "update now" to time.msft button in the windows time & date settings even tho I've got it set to local time and have the auto syncing box checked. Seemed to do the trick, but then I noticed FahControl lost connection to local host. Checking the current log file, it seems to be chugging away normally, with the noticeable shift in timestamps of when I made the windows time adjustment. Since it's still folding, I'm reluctant to try anything for fear of some Bad Skew Time...? or something. Luckily I had it already on Finish so I can try a forced end task later (as the menu seems to no longer come up from systray icon nor does web-client connect either)
but if anyone has a solution to restoring my FahControl, or even maybe preventing my win10 Home time from going haywire to begin with, I'm all ears
To add more variables, this is also the system I use as the "Command" controller to monitor 3 other folding systems.
*********************** Log Started 2022-07-27T15:36:32Z ***********************
15:36:32:******************************* libFAH ********************************
15:36:32:           Date: Oct 20 2020
15:36:32:           Time: 13:36:55
15:36:32:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:36:32:         Branch: master
15:36:32:       Compiler: Visual C++ 2015
15:36:32:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:36:32:       Platform: win32 10
15:36:32:           Bits: 32
15:36:32:           Mode: Release
15:36:32:****************************** FAHClient ******************************
15:36:32:        Version: 7.6.21
15:36:32:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:36:32:      Copyright: 2020 foldingathome.org
15:36:32:       Homepage: https://foldingathome.org/
15:36:32:           Time: 13:41:04
15:36:32:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:36:32:           Bits: 32
15:36:32:         Config: C:\ProgramData\FAHClient\config.xml
15:36:32:******************************** CBang ********************************
15:36:32:           Time: 11:36:18
15:36:32:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:36:32:           Bits: 32
15:36:32:******************************* System ********************************
15:36:32:            CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
15:36:32:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:36:32:           CPUs: 4
15:36:32:         Memory: 15.94GiB
15:36:32:    Free Memory: 14.14GiB
15:36:32:        Threads: WINDOWS_THREADS
15:36:32:     OS Version: 6.2
15:36:32:    Has Battery: false
15:36:32:     On Battery: false
15:36:32:     UTC Offset: -7
15:36:32:            PID: 7136
15:36:32:            CWD: C:\ProgramData\FAHClient
15:36:32:  Win32 Service: false
15:36:32:             OS: Windows 10 Home
15:36:32:        OS Arch: AMD64
15:36:32:           GPUs: 1
15:36:32:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
15:36:32:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.7
15:36:32:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:516.59
15:36:32:***********************************************************************
bollix47
Re: win10 system clock bonkers
Post by bollix47 »
The driver you're using (516.59) has a few problems and a hotfix is available:
https://nvidia.custhelp.com/app/answers ... ion-516.79
