Weizenleiche
Posts: 2 Joined: Fri Jul 15, 2022 11:19 am
Post
by Weizenleiche » Fri Jul 15, 2022 11:35 am
Dear F@H Team,
since yesterday I've been having problems with the bonus points and the statistics at foldingathome.org
yesterday I had to switch from wlan to lan. Since then I have not received any more bonus points. I haven't changed anything else on the pc. switching back to wifi didn't help either
First wu without Bonus Points 07.14, 3pm
Before ~500.000pts, After ~67.000pts
https://folding.extremeoverclocking.com ... ?u=1299962
even stranger is the display on stats.foldingathome.org - here shortly after finalize the wu it says "My work unit was last recorded 10 Minutes ago“ and After an hour „ My work unit was last recorded 23 days ago„ - why?
https://stats.foldingathome.org/donor/id/620816653
i Need help …
My System:
Ubuntu 18.04 LTS, RTX3080, i3 10100f
Only GPU is folding
Posts: 8352 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Fri Jul 15, 2022 3:37 pm
There are two separate issues here. One is fairly simple to check out, your bonus status. From this app -
https://apps.foldingathome.org/bonus - looking up your username shows that you have dropped below the 80% return rate required to receive the Quick Return Bonus -
https://foldingathome.org/support/faq/points/?lng=en . If you recently had a number of WUs that were downloaded but not completed and returned, that would be the cause.
For the other, it appears to be some sort of problem on the stats front end displaying your points information. It does not appear to be affecting everyone's stats reports as I get the correct information when I look up my username on the site. You can check when individual WUs were submitted to the stats database here -
https://apps.foldingathome.org/wu .
Weizenleiche
Post
by Weizenleiche » Fri Jul 15, 2022 8:28 pm
thanks! that explains a lot. here is my log. apparently every 2nd wu breaks. is it possible to determine the error?
18:58:56:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080] from 206.223.170.146
18:58:56:WU01:FS01:Connecting to 206.223.170.146:8080
18:59:07:WU01:FS01:downloading 26.58MiB
18:59:13:WU01:FS01:download 19.05%
18:59:19:WU01:FS01:download 33.86%
18:59:25:WU01:FS01:download 44.44%
18:59:31:WU01:FS01:download 53.14%
18:59:37:WU01:FS01:download 62.08%
18:59:43:WU01:FS01:download 69.84%
18:59:49:WU01:FS01:download 79.48%
18:59:54:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
18:59:54:WU00:FS01:0x22:Average performance: 36.3025 ns/day
18:59:55:WU00:FS01:0x22:Checkpoint completed at step 1250000
18:59:55:WU01:FS01:download 88.65%
18:59:58:WU00:FS01:0x22:Saving result file ../logfile_01.txt
18:59:58:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
18:59:58:WU00:FS01:0x22:Saving result file checkpointState.xml
19:00:01:WU01:FS01:download 92.65%
19:00:01:WU00:FS01:0x22:Saving result file positions.xtc
19:00:01:WU00:FS01:0x22:Saving result file science.log
19:00:01:WU00:FS01:0x22:Saving result file xtcAtoms.csv.bz2
19:00:01:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:00:02:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:00:02:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18213 run:26757 clone:0 gen:29 core:0x22 unit:0x000000000000001d0000472500006885
19:00:02:WU00:FS01:Uploading 27.50MiB to 206.223.170.146
19:00:02:WU00:FS01:Connecting to 206.223.170.146:8080
19:00:07:WU01:FS01:download 96.88%
19:00:08:WU00:FS01:Upload 11.14%
19:00:10:WU01:FS01:download complete
19:00:10:WU01:FS01:Received Unit: id:01 state:dOWNLOAD error:NO_ERROR project:18213 run:28363 clone:0 gen:29 core:0x22 unit:0x000000000000001d0000472500006ecb
19:00:10:WU01:FS01:Starting
19:00:10:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.20/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1675 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:00:10:WU01:FS01:Started FahCore on PID 3697
19:00:10:WU01:FS01:Core PID:3701
19:00:10:WU01:FS01:FahCore 0x22 started
19:00:11:WU01:FS01:0x22:*********************** Log Started 2022-07-15T19:00:10Z ***********************
19:00:11:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:00:11:WU01:FS01:0x22: Core: Core22
19:00:11:WU01:FS01:0x22: Type: 0x22
19:00:11:WU01:FS01:0x22: Version: 0.0.20
19:00:11:WU01:FS01:0x22: Author: Joseph Coffland <[EMAIL]joseph@cauldrondevelopment.com[/EMAIL]>
19:00:11:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
19:00:11:WU01:FS01:0x22: Homepage: [URL]https://foldingathome.org/[/URL]
19:00:11:WU01:FS01:0x22: Date: Jan 20 2022
19:00:11:WU01:FS01:0x22: Time: 00:57:52
19:00:11:WU01:FS01:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
19:00:11:WU01:FS01:0x22: Branch: HEAD
19:00:11:WU01:FS01:0x22: Compiler: GNU 9.4.0
19:00:11:WU01:FS01:0x22: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
19:00:11:WU01:FS01:0x22: -fdata-sections -O3 -funroll-loops -fno-pie
19:00:11:WU01:FS01:0x22: -DOPENMM_VERSION="\"7.7.0\""
19:00:11:WU01:FS01:0x22: Platform: linux 5.11.0-1025-azure
19:00:11:WU01:FS01:0x22: Bits: 64
19:00:11:WU01:FS01:0x22: Mode: Release
19:00:11:WU01:FS01:0x22:Maintainers: John Chodera <[EMAIL]john.chodera@choderalab.org[/EMAIL]> and Peter Eastman
19:00:11:WU01:FS01:0x22: <[EMAIL]peastman@stanford.edu[/EMAIL]>
19:00:11:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 3697 -checkpoint 15
19:00:11:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:00:11:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
19:00:11:WU01:FS01:0x22:************************************ libFAH ************************************
19:00:11:WU01:FS01:0x22: Time: 00:57:22
19:00:11:WU01:FS01:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
19:00:11:WU01:FS01:0x22:************************************ CBang *************************************
19:00:11:WU01:FS01:0x22: Time: 00:57:00
19:00:11:WU01:FS01:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
19:00:11:WU01:FS01:0x22: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
19:00:11:WU01:FS01:0x22:************************************ System ************************************
19:00:11:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i3-10100F CPU @ 3.60GHz
19:00:11:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 165 Stepping 3
19:00:11:WU01:FS01:0x22: CPUs: 8
19:00:11:WU01:FS01:0x22: Memory: 7.64GiB
19:00:11:WU01:FS01:0x22:Free Memory: 4.29GiB
19:00:11:WU01:FS01:0x22: Threads: POSIX_THREADS
19:00:11:WU01:FS01:0x22: OS Version: 5.4
19:00:11:WU01:FS01:0x22:Has Battery: false
19:00:11:WU01:FS01:0x22: On Battery: false
19:00:11:WU01:FS01:0x22: UTC Offset: 2
19:00:11:WU01:FS01:0x22: PID: 3701
19:00:11:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
19:00:11:WU01:FS01:0x22:************************************ OpenMM ************************************
19:00:11:WU01:FS01:0x22: Version: 7.7.0
19:00:11:WU01:FS01:0x22:********************************************************************************
19:00:11:WU01:FS01:0x22:Project: 18213 (Run 28363, Clone 0, Gen 29)
19:00:11:WU01:FS01:0x22:Reading tar file core.xml
19:00:11:WU01:FS01:0x22:Reading tar file integrator.xml
19:00:11:WU01:FS01:0x22:Reading tar file state.xml
19:00:11:WU01:FS01:0x22:Reading tar file system.xml
19:00:11:WU01:FS01:0x22:digital signatures verified
19:00:11:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:00:11:WU01:FS01:0x22:Version 0.0.20
19:00:11:WU01:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
19:00:11:WU01:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:00:11:WU01:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
19:00:11:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
19:00:11:WU01:FS01:0x22:There are 4 platforms available.
19:00:11:WU01:FS01:0x22:Platform 0: Reference
19:00:11:WU01:FS01:0x22:Platform 1: CPU
19:00:11:WU01:FS01:0x22:Platform 2: OpenCL
19:00:11:WU01:FS01:0x22: opencl-device 0 specified
19:00:11:WU01:FS01:0x22:Platform 3: CUDA
19:00:11:WU01:FS01:0x22: cuda-device 0 specified
19:00:14:WU00:FS01:Upload 19.54%
19:00:17:WU01:FS01:0x22:Attempting to create CUDA context:
19:00:17:WU01:FS01:0x22: Configuring platform CUDA
19:00:20:WU00:FS01:Upload 30.00%
19:00:22:WU01:FS01:0x22: Using CUDA and gpu 0
19:00:22:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
19:00:23:WU01:FS01:0x22:Checkpoint completed at step 0
19:00:26:WU00:FS01:Upload 40.22%
19:00:32:WU00:FS01:Upload 50.68%
19:00:38:WU00:FS01:Upload 60.68%
19:00:44:WU00:FS01:Upload 71.13%
19:00:50:WU00:FS01:Upload 81.36%
19:00:56:WU00:FS01:Upload 91.59%
19:01:04:WU00:FS01:Upload complete
19:01:04:WU00:FS01:Server responded WORK_ACK (400)
19:01:04:WU00:FS01:Final credit estimate, 510410.00 points
19:01:04:WU00:FS01:Cleaning up
19:01:21:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
19:02:20:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
19:02:21:WU01:FS01:0x22:Checkpoint completed at step 25000
19:03:19:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
19:04:18:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
19:04:18:WU01:FS01:0x22:Checkpoint completed at step 50000
19:05:17:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
19:06:16:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
19:06:16:WU01:FS01:0x22:Checkpoint completed at step 75000
19:07:15:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
19:08:13:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
19:08:14:WU01:FS01:0x22:Checkpoint completed at step 100000
19:09:13:WU01:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
19:10:11:WU01:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
19:10:12:WU01:FS01:0x22:Checkpoint completed at step 125000
19:11:10:WU01:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
19:12:09:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
19:12:09:WU01:FS01:0x22:Checkpoint completed at step 150000
19:13:08:WU01:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
19:14:07:WU01:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
19:14:07:WU01:FS01:0x22:Checkpoint completed at step 175000
19:15:06:WU01:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
19:16:04:WU01:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
19:16:05:WU01:FS01:0x22:Checkpoint completed at step 200000
19:17:04:WU01:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
19:18:02:WU01:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
19:18:03:WU01:FS01:0x22:Checkpoint completed at step 225000
19:19:02:WU01:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
19:20:00:WU01:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
19:20:01:WU01:FS01:0x22:Checkpoint completed at step 250000
19:20:59:WU01:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
19:21:58:WU01:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
19:21:59:WU01:FS01:0x22:Checkpoint completed at step 275000
20:17:12:ERROR:Receive error: 4: Interrupted system call
20:17:12:WARNING:WU01:FS01:detected clock skew (55 mins 11 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
20:17:13:WU01:FS01:0x22:An exception occurred at step 275470: Error invoking kernel: CUDA_ERROR_LAUNCH_FAILED (719)
20:17:13:WU01:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
20:17:13:WU01:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
20:17:14:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
Posts: 6545 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Sat Jul 16, 2022 5:35 pm
What happened at 20H17 ? Did you close the laptop ? Did it go to sleep ?
John_CMAC
Posts: 1 Joined: Sat Sep 17, 2022 1:35 pm
Post
by John_CMAC » Sat Sep 17, 2022 1:45 pm
Hi, I have recently completed 4 tasks and received only 12,810 points. I don't appear to receive any bonus points and this has been the case all through August. I have a passkey...Any suggestions? Thanks, John
Post
by Joe_H » Sat Sep 17, 2022 2:12 pm
John_CMAC wrote: ↑ Sat Sep 17, 2022 1:45 pm
Have you completed at least 10 WUs? The bonus points are not awarded until after that happens. You also need to maintain at least an 80% return rate to get the bonus. From the Points FAQ -
https://foldingathome.org/support/faq/points :
The bonus is applied for users who use a passkey, have successfully returned at least 10 bonus-eligible WUs, have successfully returned 80% or more of assigned WUs, and returned the unit before its Timeout (formerly Preferred Deadline). Bonus points do not apply to partial returns.
My earlier reply in this topic includes links to apps you can use to check your bonus status and individual WU returns.
