Hope these GPU are been added.
0x10de:0x0df4:1:0:0:NVIDIA Corporation:NVIDIA GeForce GT 540M
0x8086:0x0116:0:2:0:Intel Corporation:Intel(R) HD Graphics 3000
GT540M、HD Graphics 3000
Re: GT540M、HD Graphics 3000
The first is already in the list:
It is identified as a different mobile GPU, but that may be from the same chip being used. It is blacklisted, the 3 colons in the middle without numbers between them. It will stay blacklisted as the Fermi (GF106) chipset is too old to be used for folding.
The second is not in the list nd will not be added as it also is too old. It is part of Intel's Gen6 graphics, the earliest generation of iGPU from Intel that is supported is Gen9 as I recall.
0x10de:0x0df4:::GF106 [GeForce GT 555M SDDR3]The second is not in the list nd will not be added as it also is too old. It is part of Intel's Gen6 graphics, the earliest generation of iGPU from Intel that is supported is Gen9 as I recall.
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/g ... -540m.c702
The Core 22 code for GPUs has two prerequisites that it needs: 64 Bit floating Point math and OpenCL 1.2 or higher.
Your GT 540m does have 64 bit Floating Point math (sometimes called Double Precision) but only supports OpenCL 1.1
My understanding is that no Fermi GPU supports OpenCL 1.2 https://en.wikipedia.org/wiki/Fermi_(microarchitecture)
https://www.techpowerup.com/gpu-specs/h ... 3000.c1251
The HD 3000 supports neither 64 bit Floating Point math nor OpenCL 1.2
