Project 19002 - turned my 3090Ti into a 1.2M PPD Card
Lazvon
Hardware configuration: 4080 / 12700F, 3090Ti/12900KS, 3090/12900K, 3090/10940X, 3080Ti/12700K, 3080Ti/9900X, 3080Ti/9900X
Post by Lazvon »
Past day or so my 3090Ti has been getting Project 19002. Take the card from normally averaging ~9M PPD down to 1.3M. I take it there is nothing to be done, just accept the workloads it's given. The other two 3090s and two 3080Tis are all still chugging along with 7-9M each.
Folding since Feb 2021. 1) 4090/12900KS, 2) 4080/12700F, 3) 4070Ti/9900X, 4) 3090/12900K, 5) 3090/10940X, 6) 3080Ti/12700K, 7) 3080Ti/9900X
bollix47
Re: Project 19002 - turned my 3090Ti into a 1.2M PPD Card
Post by bollix47 »
A TPF of 19 seconds should result is considerably more PPD than 1.3M ... not sure what's wrong but have you checked the log for errors/restarts?
Have you tried a reboot?
Also, make sure HFM has the latest project data. Tools > Download Projects
bollix47
Post by bollix47 »
According to the DB it took almost 19 hours to complete so that is definitely a sign of a problem.
https://apps.foldingathome.org/wu#proje ... ne=1&gen=9
Lazvon
Post by Lazvon »
Next project shot right back up to 9M PPD. That project doesn’t like the card for some reason.
