PCIE4 @ x8 mode for 2nd GPU?
hrsetrdr
Post by hrsetrdr »
I'm looking to double up my FAH GPUs, 2 in one rig. My X79 board has: 3 x PCI Express 3.0 x16 slots (PCIE1 @ x16 mode; PCIE3 @ x16 mode; PCIE4 @ x8 mode).
Will the PCIE4 @ x8 mode affect PPD for the GPU installed there?
Folding rig:Supermicro X9DRD-7LN4F-JBOD | (2) Xeon E5-2670 | 128GB DDR3 ECC Registered
Install Folding@Home on Linux without Python dependancy issues
MeeLee
Re: PCIE4 @ x8 mode for 2nd GPU?
Post by MeeLee »
hrsetrdr wrote: Thu Apr 28, 2022 4:15 pm I'm looking to double up my FAH GPUs, 2 in one rig. My X79 board has: 3 x PCI Express 3.0 x16 slots (PCIE1 @ x16 mode; PCIE3 @ x16 mode; PCIE4 @ x8 mode).
It will. However, very minor.
Most GPUs will see a degradation at PCIE 3.0 x4, but PCIE 3.0 x8 usually runs fine (without much PPD loss; PCIE 3.0 x8 is about as fast as PCIE 4.0 x4).
So long your GPU accepts the PCIE 4.0 standard, you'll have to get something faster than an RTX 3090, to be bottlenecked by the PCIE 4.0 x8 bandwidth.
bikeaddict
Post by bikeaddict »
Since PCIE4 @ x8 has the same throughput as PCIE3 @ x16 (what my machines and many other folders use) it shouldn't limit the speed at all. My NVIDIA Setting app shows I'm using 1% bandwidth.
kiore
Post by kiore »
bikeaddict wrote: Fri Apr 29, 2022 11:14 pm Since PCIE4 @ x8 has the same throughput as PCIE3 @ x16 (what my machines and many other folders use) it shouldn't limit the speed at all. My NVIDIA Setting app shows I'm using 1% bandwidth.
Thanks for this, was wondering if this would be the case, my experience even on PCIE 3 at 8 the difference is noticeable but not huge, I think it those populating PCIE 3 x2 slots that were used for mining that suddenly see this critical drop.
hrsetrdr
Post by hrsetrdr »
MeeLee wrote: Fri Apr 29, 2022 7:35 pm
OK, thanks for defining this, if there were to be a significant impact on performance I would then have opted to run the GPUs in separate machines.
Post by Neil-B »
The biggest issue you may have is the thermal impact ... with two gpus in case the chances are the air flow will be impacted ... one or both gpus may potentially have thermal issues - either running hot or even getting to the point of thermally throttling.
Good airflow case with lots of fans and relatively low ambient temps you shouldn't have any issues but worth monitoring ... Cluttered case with minimal fans and you may have sub-optimal experiences.
gunnarre
Post by gunnarre »
Yes, so physical spacing between the slots you're going to use on the motherboard may be important too. Even in a good case, if the cards are sandwiched together with millimeter clearance, they may be thermally throttled.
hrsetrdr
Post by hrsetrdr »
Neil-B wrote: Tue May 03, 2022 9:27 am The biggest issue you may have is the thermal impact ... with two gpus in case the chances are the air flow will be impacted ... one or both gpus may potentially have thermal issues - either running hot or even getting to the point of thermally throttling.
I was concerned, even-though my new build has all kinds of air flow the case is a mid-tower, and I'm thinking two fire breathing GPUs running 24/7 would cause an excessive heat build-up all around. So, whenever my new PSU gets here I've decided to put the RTX 3060 in with my GTX 1080, which is housed in a roomier server case.
MeeLee
Post by MeeLee »
A good option is to get a high quality, 1 or 2 inch riser, that will allow the GPU to be mechanically mounted in a slot above or below the standard slot.
hrsetrdr
Post by hrsetrdr »
MeeLee wrote: Wed May 04, 2022 12:22 am
Thanks, addressing the thermal issues is my current undertaking.
