I have two computers, both with AMD 200GE processors with on-processor GPU and the same motherboards. The first computer is folding with the CPU and GPU with good point totals. The second computer is folding with the CPU and with the GPU disabled. Any thoughts on why the second Computer's GPU is disabled? How do I enable the second GPU? Both computers had the folding client installed the same way with no special GPU slot settings. Thanks for your help.
Planorez
Disabled Processor GPU
Re: Disabled Processor GPU
Can you post the first couple of hundred lines of the log from the system with the disabled GPU.
How to post logs
How to post logs
*********************** Log Started 2022-04-22T14:05:05Z ***********************
14:05:05:******************************* libFAH ********************************
14:05:05: Date: Oct 20 2020
14:05:05: Time: 13:36:55
14:05:05: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:05:05: Branch: master
14:05:05: Compiler: Visual C++ 2015
14:05:05: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:05:05: Platform: win32 10
14:05:05: Bits: 32
14:05:05: Mode: Release
14:05:05:****************************** FAHClient ******************************
14:05:05: Version: 7.6.21
14:05:05: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:05:05: Copyright: 2020 foldingathome.org
14:05:05: Homepage: https://foldingathome.org/
14:05:05: Time: 13:41:04
14:05:05: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:05:05: Bits: 32
14:05:05: Args: --open-web-control
14:05:05:******************************** CBang ********************************
14:05:05: Time: 11:36:18
14:05:05: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:05:05: Bits: 32
14:05:05:******************************* System ********************************
14:05:05: CPU: AMD Athlon 200GE with Radeon Vega Graphics
14:05:05: CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
14:05:05: CPUs: 4
14:05:05: Memory: 3.43GiB
14:05:05: Free Memory: 914.31MiB
14:05:05: Threads: WINDOWS_THREADS
14:05:05: OS Version: 6.2
14:05:05: Has Battery: false
14:05:05: On Battery: false
14:05:05: UTC Offset: -5
14:05:05: PID: 980
14:05:05: CWD: C:\ProgramData\FAHClient
14:05:05:Win32 Service: false
14:05:05: OS: Windows 10 Enterprise
14:05:05: OS Arch: AMD64
14:05:05: GPUs: 1
14:05:05: GPU 0: Bus:7 Slot:0 Func:0 AMD:5 Raven Ridge [Radeon Vega Series /
14:05:05: Radeon Vega Mobile Series]
14:05:05: CUDA: Not detected: cuInit() returned 999
14:05:05:***********************************************************************
14:05:05:<config>
14:05:05: <!-- Folding Slots -->
14:05:05:</config>
14:05:05:Trying to access database...
14:05:05:Successfully acquired database lock
14:05:05:FS00:Initialized folding slot 00: cpu:2
14:05:05:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:7:0 Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]. Disabling.
14:05:09:17:127.0.0.1:New Web session
14:05:46:Set client configured
14:05:47:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:05:47:WU00:FS00:Assigned to work server 128.252.203.9
14:05:47:WU00:FS00:Requesting new work unit for slot 00: cpu:2 from 128.252.203.9
14:05:47:WU00:FS00:Connecting to 128.252.203.9:8080
14:05:48:WU00:FS00:Downloading 7.00MiB
14:05:50:WU00:FS00:Download complete
14:05:50:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17445 run:0 clone:2530 gen:23 core:0xa8 unit:0x000009e2000000170000442500000000
14:05:50:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
14:05:50:WU00:FS00:Connecting to cores.foldingathome.org:80
14:05:51:WU00:FS00:FahCore a8: Downloading 7.72MiB
14:05:53:WU00:FS00:FahCore a8: Download complete
14:05:53:WU00:FS00:Valid core signature
14:05:53:WU00:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
14:05:53:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
14:05:53:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
14:05:53:WU00:FS00:Starting
14:05:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 980 -checkpoint 15 -np 2
14:05:54:WU00:FS00:Started FahCore on PID 5328
14:05:54:WU00:FS00:Core PID:5844
14:05:54:WU00:FS00:FahCore 0xa8 started
14:05:54:WU00:FS00:0xa8:*********************** Log Started 2022-04-22T14:05:54Z ***********************
14:05:54:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:05:54:WU00:FS00:0xa8: Core: Gromacs
14:05:54:WU00:FS00:0xa8: Type: 0xa8
14:05:54:WU00:FS00:0xa8: Version: 0.0.12
14:05:54:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:05:54:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
14:05:54:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
14:05:54:WU00:FS00:0xa8: Date: Jan 16 2021
14:05:54:WU00:FS00:0xa8: Time: 12:29:40
14:05:54:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
14:05:54:WU00:FS00:0xa8: Branch: master
14:05:54:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
14:05:54:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:05:54:WU00:FS00:0xa8: Platform: win32 10
14:05:54:WU00:FS00:0xa8: Bits: 64
14:05:54:WU00:FS00:0xa8: Mode: Release
14:05:54:WU00:FS00:0xa8: SIMD: avx2_256
14:05:54:WU00:FS00:0xa8: OpenMP: ON
14:05:54:WU00:FS00:0xa8: CUDA: OFF
14:05:54:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 5328 -checkpoint 15 -np 2
14:05:54:WU00:FS00:0xa8:************************************ libFAH ************************************
14:05:54:WU00:FS00:0xa8: Time: 11:24:13
14:05:54:WU00:FS00:0xa8:************************************ CBang *************************************
14:05:54:WU00:FS00:0xa8: Time: 11:23:53
14:05:54:WU00:FS00:0xa8:************************************ System ************************************
14:05:54:WU00:FS00:0xa8: CPU: AMD Athlon 200GE with Radeon Vega Graphics
14:05:54:WU00:FS00:0xa8: CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
14:05:54:WU00:FS00:0xa8: CPUs: 4
14:05:54:WU00:FS00:0xa8: Memory: 3.43GiB
14:05:54:WU00:FS00:0xa8:Free Memory: 799.84MiB
14:05:54:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
14:05:54:WU00:FS00:0xa8: OS Version: 6.2
14:05:54:WU00:FS00:0xa8:Has Battery: false
14:05:54:WU00:FS00:0xa8: On Battery: false
14:05:54:WU00:FS00:0xa8: UTC Offset: -5
14:05:54:WU00:FS00:0xa8: PID: 5844
14:05:54:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
14:05:54:WU00:FS00:0xa8:********************************************************************************
14:05:54:WU00:FS00:0xa8:Project: 17445 (Run 0, Clone 2530, Gen 23)
14:05:54:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
14:05:54:WU00:FS00:0xa8:Reading tar file core.xml
14:05:54:WU00:FS00:0xa8:Reading tar file frame23.tpr
14:05:54:WU00:FS00:0xa8:Digital signatures verified
14:05:54:WU00:FS00:0xa8:Calling: mdrun -c frame23.gro -s frame23.tpr -x frame23.xtc -cpt 15 -nt 2 -ntmpi 1
14:05:54:WU00:FS00:0xa8:Steps: first=2875000 total=3000000
14:05:56:WU00:FS00:0xa8:Completed 1 out of 125000 steps (0%)
14:06:00:FS00:Shutting core down
14:06:01:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 5844
14:06:01:WU00:FS00:0xa8:Exiting, please wait. . .
14:06:03:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:06:04:WU00:FS00:Starting
14:06:04:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
14:06:04:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
14:06:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 980 -checkpoint 15 -np 2
14:06:04:WU00:FS00:Started FahCore on PID 2732
14:06:04:WU00:FS00:Core PID:8940
14:06:04:WU00:FS00:FahCore 0xa8 started
14:06:04:WU00:FS00:0xa8:*********************** Log Started 2022-04-22T14:06:04Z ***********************
14:06:04:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:06:04:WU00:FS00:0xa8: Core: Gromacs
14:06:04:WU00:FS00:0xa8: Type: 0xa8
14:06:04:WU00:FS00:0xa8: Version: 0.0.12
14:06:04:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:06:04:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
14:06:04:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
14:06:04:WU00:FS00:0xa8: Date: Jan 16 2021
14:06:04:WU00:FS00:0xa8: Time: 12:29:40
14:06:04:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
14:06:04:WU00:FS00:0xa8: Branch: master
14:06:04:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
14:06:04:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:06:04:WU00:FS00:0xa8: Platform: win32 10
14:06:04:WU00:FS00:0xa8: Bits: 64
14:06:04:WU00:FS00:0xa8: Mode: Release
14:06:04:WU00:FS00:0xa8: SIMD: avx2_256
14:06:04:WU00:FS00:0xa8: OpenMP: ON
14:06:04:WU00:FS00:0xa8: CUDA: OFF
14:06:04:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 2732 -checkpoint 15 -np 2
14:06:04:WU00:FS00:0xa8:************************************ libFAH ************************************
14:06:04:WU00:FS00:0xa8: Time: 11:24:13
14:06:04:WU00:FS00:0xa8:************************************ CBang *************************************
14:06:04:WU00:FS00:0xa8: Time: 11:23:53
14:06:04:WU00:FS00:0xa8:************************************ System ************************************
14:06:04:WU00:FS00:0xa8: CPU: AMD Athlon 200GE with Radeon Vega Graphics
14:06:04:WU00:FS00:0xa8: CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
14:06:04:WU00:FS00:0xa8: CPUs: 4
14:06:04:WU00:FS00:0xa8: Memory: 3.43GiB
14:06:04:WU00:FS00:0xa8:Free Memory: 795.54MiB
14:06:04:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
14:06:04:WU00:FS00:0xa8: OS Version: 6.2
14:06:04:WU00:FS00:0xa8:Has Battery: false
14:06:04:WU00:FS00:0xa8: On Battery: false
14:06:04:WU00:FS00:0xa8: UTC Offset: -5
14:06:04:WU00:FS00:0xa8: PID: 8940
14:06:04:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
14:06:04:WU00:FS00:0xa8:********************************************************************************
14:06:04:WU00:FS00:0xa8:Project: 17445 (Run 0, Clone 2530, Gen 23)
14:06:04:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
14:06:04:WU00:FS00:0xa8:Digital signatures verified
14:06:04:WU00:FS00:0xa8:Calling: mdrun -c frame23.gro -s frame23.tpr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 2 -ntmpi 1
14:06:04:WU00:FS00:0xa8:Steps: first=2875000 total=3000000
14:06:06:Saving configuration to config.xml
14:06:06:<config>
14:06:06: <!-- Slot Control -->
14:06:06: <power v='FULL'/>
14:06:06:
14:06:06: <!-- User Information -->
14:06:06: <passkey v='*****'/>
14:06:06: <user v='Planorez'/>
14:06:06:
14:06:06: <!-- Folding Slots -->
14:06:06: <slot id='0' type='CPU'/>
14:06:06: <slot id='1' type='GPU'>
14:06:06: <pci-bus v='7'/>
14:06:06: <pci-slot v='0'/>
14:06:06: </slot>
14:06:06:</config>
14:06:06:WU00:FS00:0xa8:Completed 22 out of 125000 steps (0%)
14:10:48:WU00:FS00:0xa8:Completed 1250 out of 125000 steps (1%)
14:15:45:WU00:FS00:0xa8:Completed 2500 out of 125000 steps (2%)
14:20:23:WU00:FS00:0xa8:Completed 3750 out of 125000 steps (3%)
14:25:10:WU00:FS00:0xa8:Completed 5000 out of 125000 steps (4%)
14:29:52:WU00:FS00:0xa8:Completed 6250 out of 125000 steps (5%)
14:34:34:WU00:FS00:0xa8:Completed 7500 out of 125000 steps (6%)
14:39:19:WU00:FS00:0xa8:Completed 8750 out of 125000 steps (7%)
14:44:05:WU00:FS00:0xa8:Completed 10000 out of 125000 steps (8%)
14:48:48:WU00:FS00:0xa8:Completed 11250 out of 125000 steps (9%)
14:53:30:WU00:FS00:0xa8:Completed 12500 out of 125000 steps (10%)
14:58:13:WU00:FS00:0xa8:Completed 13750 out of 125000 steps (11%)
15:02:54:WU00:FS00:0xa8:Completed 15000 out of 125000 steps (12%)
15:07:40:WU00:FS00:0xa8:Completed 16250 out of 125000 steps (13%)
15:12:27:WU00:FS00:0xa8:Completed 17500 out of 125000 steps (14%)
15:17:11:WU00:FS00:0xa8:Completed 18750 out of 125000 steps (15%)
15:21:51:WU00:FS00:0xa8:Completed 20000 out of 125000 steps (16%)
15:26:28:WU00:FS00:0xa8:Completed 21250 out of 125000 steps (17%)
15:31:05:WU00:FS00:0xa8:Completed 22500 out of 125000 steps (18%)
15:35:41:WU00:FS00:0xa8:Completed 23750 out of 125000 steps (19%)
15:40:19:WU00:FS00:0xa8:Completed 25000 out of 125000 steps (20%)
15:44:57:WU00:FS00:0xa8:Completed 26250 out of 125000 steps (21%)
15:49:35:WU00:FS00:0xa8:Completed 27500 out of 125000 steps (22%)
15:54:15:WU00:FS00:0xa8:Completed 28750 out of 125000 steps (23%)
15:58:55:WU00:FS00:0xa8:Completed 30000 out of 125000 steps (24%)
16:03:33:WU00:FS00:0xa8:Completed 31250 out of 125000 steps (25%)
16:08:14:WU00:FS00:0xa8:Completed 32500 out of 125000 steps (26%)
16:12:52:WU00:FS00:0xa8:Completed 33750 out of 125000 steps (27%)
16:17:31:WU00:FS00:0xa8:Completed 35000 out of 125000 steps (28%)
16:22:10:WU00:FS00:0xa8:Completed 36250 out of 125000 steps (29%)
16:26:48:WU00:FS00:0xa8:Completed 37500 out of 125000 steps (30%)
16:31:25:WU00:FS00:0xa8:Completed 38750 out of 125000 steps (31%)
16:36:03:WU00:FS00:0xa8:Completed 40000 out of 125000 steps (32%)
16:40:43:WU00:FS00:0xa8:Completed 41250 out of 125000 steps (33%)
16:45:23:WU00:FS00:0xa8:Completed 42500 out of 125000 steps (34%)
16:50:01:WU00:FS00:0xa8:Completed 43750 out of 125000 steps (35%)
16:54:42:WU00:FS00:0xa8:Completed 45000 out of 125000 steps (36%)
16:59:20:WU00:FS00:0xa8:Completed 46250 out of 125000 steps (37%)
17:03:58:WU00:FS00:0xa8:Completed 47500 out of 125000 steps (38%)
17:08:39:WU00:FS00:0xa8:Completed 48750 out of 125000 steps (39%)
17:13:16:WU00:FS00:0xa8:Completed 50000 out of 125000 steps (40%)
17:17:54:WU00:FS00:0xa8:Completed 51250 out of 125000 steps (41%)
17:22:33:WU00:FS00:0xa8:Completed 52500 out of 125000 steps (42%)
17:27:12:WU00:FS00:0xa8:Completed 53750 out of 125000 steps (43%)
17:31:49:WU00:FS00:0xa8:Completed 55000 out of 125000 steps (44%)
17:36:29:WU00:FS00:0xa8:Completed 56250 out of 125000 steps (45%)
17:41:08:WU00:FS00:0xa8:Completed 57500 out of 125000 steps (46%)
17:45:46:WU00:FS00:0xa8:Completed 58750 out of 125000 steps (47%)
17:50:24:WU00:FS00:0xa8:Completed 60000 out of 125000 steps (48%)
17:55:03:WU00:FS00:0xa8:Completed 61250 out of 125000 steps (49%)
17:59:41:WU00:FS00:0xa8:Completed 62500 out of 125000 steps (50%)
18:04:19:WU00:FS00:0xa8:Completed 63750 out of 125000 steps (51%)
18:08:59:WU00:FS00:0xa8:Completed 65000 out of 125000 steps (52%)
18:13:39:WU00:FS00:0xa8:Completed 66250 out of 125000 steps (53%)
18:18:18:WU00:FS00:0xa8:Completed 67500 out of 125000 steps (54%)
18:22:58:WU00:FS00:0xa8:Completed 68750 out of 125000 steps (55%)
18:27:37:WU00:FS00:0xa8:Completed 70000 out of 125000 steps (56%)
18:32:14:WU00:FS00:0xa8:Completed 71250 out of 125000 steps (57%)
18:36:53:WU00:FS00:0xa8:Completed 72500 out of 125000 steps (58%)
18:41:31:WU00:FS00:0xa8:Completed 73750 out of 125000 steps (59%)
18:46:11:WU00:FS00:0xa8:Completed 75000 out of 125000 steps (60%)
18:50:49:WU00:FS00:0xa8:Completed 76250 out of 125000 steps (61%)
18:55:30:WU00:FS00:0xa8:Completed 77500 out of 125000 steps (62%)
19:00:08:WU00:FS00:0xa8:Completed 78750 out of 125000 steps (63%)
19:04:46:WU00:FS00:0xa8:Completed 80000 out of 125000 steps (64%)
19:09:27:WU00:FS00:0xa8:Completed 81250 out of 125000 steps (65%)
19:14:07:WU00:FS00:0xa8:Completed 82500 out of 125000 steps (66%)
19:18:45:WU00:FS00:0xa8:Completed 83750 out of 125000 steps (67%)
19:23:25:WU00:FS00:0xa8:Completed 85000 out of 125000 steps (68%)
19:28:06:WU00:FS00:0xa8:Completed 86250 out of 125000 steps (69%)
19:33:03:WU00:FS00:0xa8:Completed 87500 out of 125000 steps (70%)
19:37:39:WU00:FS00:0xa8:Completed 88750 out of 125000 steps (71%)
19:42:12:WU00:FS00:0xa8:Completed 90000 out of 125000 steps (72%)
19:46:46:WU00:FS00:0xa8:Completed 91250 out of 125000 steps (73%)
19:51:19:WU00:FS00:0xa8:Completed 92500 out of 125000 steps (74%)
19:55:51:WU00:FS00:0xa8:Completed 93750 out of 125000 steps (75%)
20:00:23:WU00:FS00:0xa8:Completed 95000 out of 125000 steps (76%)
******************************* Date: 2022-04-22 *******************************
20:05:09:WU00:FS00:0xa8:Completed 96250 out of 125000 steps (77%)
20:09:47:WU00:FS00:0xa8:Completed 97500 out of 125000 steps (78%)
20:14:29:WU00:FS00:0xa8:Completed 98750 out of 125000 steps (79%)
20:19:11:WU00:FS00:0xa8:Completed 100000 out of 125000 steps (80%)
20:24:05:WU00:FS00:0xa8:Completed 101250 out of 125000 steps (81%)
20:28:59:WU00:FS00:0xa8:Completed 102500 out of 125000 steps (82%)
20:33:50:WU00:FS00:0xa8:Completed 103750 out of 125000 steps (83%)
20:38:34:WU00:FS00:0xa8:Completed 105000 out of 125000 steps (84%)
20:43:07:WU00:FS00:0xa8:Completed 106250 out of 125000 steps (85%)
20:47:45:WU00:FS00:0xa8:Completed 107500 out of 125000 steps (86%)
20:52:33:WU00:FS00:0xa8:Completed 108750 out of 125000 steps (87%)
20:57:19:WU00:FS00:0xa8:Completed 110000 out of 125000 steps (88%)
21:01:54:WU00:FS00:0xa8:Completed 111250 out of 125000 steps (89%)
21:06:30:WU00:FS00:0xa8:Completed 112500 out of 125000 steps (90%)
21:11:25:WU00:FS00:0xa8:Completed 113750 out of 125000 steps (91%)
21:16:30:WU00:FS00:0xa8:Completed 115000 out of 125000 steps (92%)
Very little is known about this GPU
https://www.techpowerup.com/gpu-specs/amd-raven-2.g888
the output of GPU-Z may help F@H configure what it can do.
https://www.techpowerup.com/download/techpowerup-gpu-z/
This thread probably should be in the whitelist forum
viewforum.php?f=83
viewforum.php?f=83
This is the link to the Technical Information from the AMD® site: https://www.amd.com/en/product/8206
This is the link for the latest Windows 10 Drivers Page: https://www.amd.com/en/support/apu/amd- ... amd-athlon
I would recommend getting the WHQL certified (stable) drivers/Adrenalin Software package, released on 3/17/2022 before attempting to use the more recent and un-certified release (dated 4/5/2022).
I hope this gives you a few tidbits of information to help.
Paul
Paul
It looks like your GPU has already been whitelisted as the client has recognised it and assigned it as a species 5 card (the species is the first number after the manufacturers name), so that's not your issue.
I'm with psaam001, I think your driver needs updated.
When Windows is installed it installs a driver that works, this is rarely the newest and it's not always fully functional but it is functional enough for most uses.
Folding is not a normal use.
In this case the important warning is the OpenCL one.
The CUDA warning can be ignored as it is an NVidia exclusive feature and is not available on AMD cards.
