FAHClient --html-help missing some options
lyuvelch
Post by lyuvelch »
Hi,
I've noticed that some of the FAHClient 7.6.21 command options, which are listed in the
FAHClient --help
output are not listed in the
output.
Example:
--send-pause
--send-unpause
,etc.
You may want to fix the FAHClient code in order to keep the two help outputs consistent.
Re: FAHClient --html-help missing some options
This will probably never be fixed since there won't be any new client based on the v7 code ...
