Found an old PC with a Quadro P400, but cant get it to work.
iero
Post by iero »
Any help would be appriciated!
*********************** Log Started 2022-03-19T17:02:31Z ***********************
17:02:31:******************************* libFAH ********************************
17:02:31:           Date: Oct 20 2020
17:02:31:           Time: 13:36:55
17:02:31:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
17:02:31:         Branch: master
17:02:31:       Compiler: Visual C++ 2015
17:02:31:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:02:31:       Platform: win32 10
17:02:31:           Bits: 32
17:02:31:           Mode: Release
17:02:31:****************************** FAHClient ******************************
17:02:31:        Version: 7.6.21
17:02:31:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:02:31:      Copyright: 2020 foldingathome.org
17:02:31:       Homepage: https://foldingathome.org/
17:02:31:           Time: 13:41:04
17:02:31:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
17:02:31:           Bits: 32
17:02:31:           Args: --open-web-control
17:02:31:         Config: C:\ProgramData\FAHClient\config.xml
17:02:31:******************************** CBang ********************************
17:02:31:           Time: 11:36:18
17:02:31:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
17:02:31:           Bits: 32
17:02:31:******************************* System ********************************
17:02:31:            CPU: AMD Athlon(tm) Dual Core Processor 4850e
17:02:31:         CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
17:02:31:           CPUs: 2
17:02:31:         Memory: 2.00GiB
17:02:31:    Free Memory: 1.51GiB
17:02:31:        Threads: WINDOWS_THREADS
17:02:31:     OS Version: 6.1
17:02:31:    Has Battery: false
17:02:31:     On Battery: false
17:02:31:     UTC Offset: 2
17:02:31:            PID: 2416
17:02:31:            CWD: C:\ProgramData\FAHClient
17:02:31:  Win32 Service: false
17:02:31:             OS: Windows 7 Home Premium Service Pack 1
17:02:31:        OS Arch: X86
17:02:31:           GPUs: 1
17:02:31:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:5 GP107GL [Quadro P400] 641
17:02:31:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:6.1 Driver:9.1
17:02:31:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:392.37
17:02:31:***********************************************************************
17:02:31:<config>
17:02:31:  <!-- Slot Control -->
17:02:31:  <power v='full'/>
17:02:31:
17:02:31:  <!-- Folding Slots -->
17:02:31:  <slot id='0' type='CPU'/>
17:02:31:  <slot id='1' type='GPU'>
17:02:31:    <pci-bus v='2'/>
17:02:31:    <pci-slot v='0'/>
17:02:31:  </slot>
17:02:31:</config>
17:02:32:Trying to access database...
17:02:32:Successfully acquired database lock
17:02:32:FS00:Initialized folding slot 00: cpu:1
17:02:32:FS01:Initialized folding slot 01: gpu:2:0 GP107GL [Quadro P400] 641
17:02:32:WARNING:WU00:FS00:Past final deadline 2022-03-14T17:50:25Z, dumping
17:02:32:WU00:FS00:Cleaning up
17:02:34:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU00:FS00:Exception: Could not get IP address for assign4.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
17:02:34:ERROR:WU01:FS01:Exception: Could not get IP address for assign1.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU01:FS01:Exception: Could not get IP address for assign2.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU01:FS01:Exception: Could not get IP address for assign3.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU01:FS01:Exception: Could not get IP address for assign4.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:34:ERROR:WU01:FS01:Exception: Failed to find any IP addresses for assignment servers
17:02:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign4.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
17:02:35:ERROR:WU01:FS01:Exception: Could not get IP address for assign1.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU01:FS01:Exception: Could not get IP address for assign2.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU01:FS01:Exception: Could not get IP address for assign3.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU01:FS01:Exception: Could not get IP address for assign4.foldingathome.org: ¢ãíùóôïò êåíôñéêüò õðïëïãéóôÞò.
17:02:35:ERROR:WU01:FS01:Exception: Failed to find any IP addresses for assignment servers
17:02:44:3:127.0.0.1:New Web session
17:03:35:WU00:FS00:Connecting to assign1.foldingathome.org:80
17:03:35:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:03:36:WU00:FS00:Assigned to work server 129.32.209.205
17:03:36:WU00:FS00:Requesting new work unit for slot 00: cpu:1 from 129.32.209.205
17:03:36:WU00:FS00:Connecting to 129.32.209.205:8080
17:03:37:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:03:37:WU01:FS01:Connecting to assign2.foldingathome.org:80
17:03:37:WU00:FS00:Downloading 270.50KiB
17:03:38:WU00:FS00:Download complete
17:03:38:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18435 run:42 clone:23 gen:183 core:0xa8 unit:0x00000017000000b7000048030000002a
17:03:38:WU00:FS00:Starting
17:03:38:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/32bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 2416 -checkpoint 15 -np 1
17:03:38:WU00:FS00:Started FahCore on PID 1848
17:03:42:WU00:FS00:Core PID:3920
17:03:42:WU00:FS00:FahCore 0xa8 started
17:03:43:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:03:43:WU01:FS01:Connecting to assign3.foldingathome.org:80
17:03:44:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:03:44:WU01:FS01:Connecting to assign4.foldingathome.org:80
17:03:45:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:03:45:ERROR:WU01:FS01:Exception: Could not get an assignment
17:03:47:WU00:FS00:0xa8:*********************** Log Started 2022-03-19T17:03:46Z ***********************
17:03:47:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
17:03:47:WU00:FS00:0xa8:       Core: Gromacs
17:03:47:WU00:FS00:0xa8:       Type: 0xa8
17:03:47:WU00:FS00:0xa8:    Version: 0.0.12
17:03:47:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:03:47:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
17:03:47:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
17:03:47:WU00:FS00:0xa8:       Date: Jan 16 2021
17:03:47:WU00:FS00:0xa8:       Time: 13:07:18
17:03:47:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:03:47:WU00:FS00:0xa8:     Branch: master
17:03:47:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
17:03:47:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:03:47:WU00:FS00:0xa8:   Platform: win32 10
17:03:47:WU00:FS00:0xa8:       Bits: 32
17:03:47:WU00:FS00:0xa8:       Mode: Release
17:03:47:WU00:FS00:0xa8:       SIMD: sse2
17:03:47:WU00:FS00:0xa8:     OpenMP: ON
17:03:47:WU00:FS00:0xa8:       CUDA: OFF
17:03:47:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1848 -checkpoint 15 -np 1
17:03:47:WU00:FS00:0xa8:************************************ libFAH ************************************
17:03:47:WU00:FS00:0xa8:       Time: 13:06:07
17:03:47:WU00:FS00:0xa8:************************************ CBang *************************************
17:03:47:WU00:FS00:0xa8:       Time: 13:05:41
17:03:47:WU00:FS00:0xa8:************************************ System ************************************
17:03:47:WU00:FS00:0xa8:        CPU: AMD Athlon(tm) Dual Core Processor 4850e
17:03:47:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
17:03:47:WU00:FS00:0xa8:       CPUs: 2
17:03:47:WU00:FS00:0xa8:     Memory: 2.00GiB
17:03:47:WU00:FS00:0xa8:Free Memory: 1.17GiB
17:03:47:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
17:03:47:WU00:FS00:0xa8: OS Version: 6.1
17:03:47:WU00:FS00:0xa8:Has Battery: false
17:03:47:WU00:FS00:0xa8: On Battery: false
17:03:47:WU00:FS00:0xa8: UTC Offset: 2
17:03:47:WU00:FS00:0xa8:        PID: 3920
17:03:47:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
17:03:47:WU00:FS00:0xa8:********************************************************************************
17:03:47:WU00:FS00:0xa8:Project: 18435 (Run 42, Clone 23, Gen 183)
17:03:47:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
17:03:47:WU00:FS00:0xa8:Reading tar file core.xml
17:03:47:WU00:FS00:0xa8:Reading tar file frame183.tpr
17:03:47:WU00:FS00:0xa8:Digital signatures verified
17:03:48:WU00:FS00:0xa8:Calling: mdrun -c frame183.gro -s frame183.tpr -x frame183.xtc -cpt 15 -nt 1 -ntmpi 1
17:03:52:WU00:FS00:0xa8:Steps: first=915000000 total=920000000
17:03:57:WU00:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
17:05:12:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:05:13:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:05:13:WU01:FS01:Connecting to assign2.foldingathome.org:80
17:05:14:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:05:14:WU01:FS01:Connecting to assign3.foldingathome.org:80
17:05:15:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:05:15:WU01:FS01:Connecting to assign4.foldingathome.org:80
17:05:16:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:05:16:ERROR:WU01:FS01:Exception: Could not get an assignment
17:07:49:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:07:50:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:07:50:WU01:FS01:Connecting to assign2.foldingathome.org:80
17:07:51:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:07:51:WU01:FS01:Connecting to assign3.foldingathome.org:80
17:07:53:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:07:53:WU01:FS01:Connecting to assign4.foldingathome.org:80
17:07:53:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:07:53:ERROR:WU01:FS01:Exception: Could not get an assignment
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
Re: Found an old PC with a Quadro P400, but cat get it to wo
We have issues:
It appears this has a 32 bit OS, Nvidia has dropped support for 32 bit Windows OSes. Here is a 64 bit driver
https://www.nvidia.com/Download/driverR ... 5850/en-us
I am unclear if a 64 bit Windows 10 will run F@H in 2 gig of RAM
Your current 32 bit driver is very old, yet seems to be the last supported 32 bit driver
https://www.techpowerup.com/gpu-specs/quadro-p400.c2934
While it meets all the prerequisites to fold ( OpenCL 1.2 or better and 64 bit floating point math) it may be too slow to complete Work Units even running 24/7.
iero
Re: Found an old PC with a Quadro P400, but cant get it to w
Post by iero »
Yeah, [it's a work PC] the HDD came with an 32bit installation of Windows 7. I downloaded the latest 32bit drivers from Nvidias site. I was hoping to avoid a fresh install of Windows, but is it your opinion that that is the only way forward?
GPU only
The only way to get the P400 to be usable for folding will be to install a 64-bit OS, either Windows or Linux. The 2 GB of RAM will be tight, some WUs can take more than that during various stages of processing. An ample swap file can make up for some of that, but 4 GB of RAM would be better.
The Quadro P400 has about 2/3 of the processing power as the GT 1030. Currently that is about the minimum processor that will process almost all WUs from the various projects within the timeout when run 24 hours a day. So there will be projects the P400 can complete, but others will will take longer.
iero
Post by iero »
Maybe I'll try to salvage some more RAM from another work PC XD. I tried running the latest edition of UBUNTU but I immediately got an error [ kernel bug or something of that sorts] and I have no experience with LINUX.
GPU only
The other choice would be to return it to work and hope someone else had a use for it.
iero
Post by iero »
That ain't an option, the only reason it was still kept around (thrown under a rack of files) is because they do not know if the have any useful files on the second HDD.
They didn't even care that I said, that I'll take it home for a few days.
GPU only
One tool to 'see inside' your PC is called Speccy.
https://www.ccleaner.com/speccy/download
if you keep insisting you want the free version, you can see the specs on the existing RAM, and the number of free slots, without taking it apart.
When you click on RAM, it should show you the number of slots and the number of free slots you could add RAM to.
Lower down under SPD, you may find the technical specs of your existing RAM like Max Bandwidth PC3-12800 (800 MHz) in my system.
Then you would want to make sure the RAM you were looking at was also PC3 and was at least as fast as 12800.
I am not sure what your specs are, but that is a clue for Windows without opening the case.
64 bits OS is mandatory for FAH. Windows 10 64 bits should work with 2 GB of RAM, but the system will struggle with some big work units running on FAH ... I have a system with 4 GB and a GPU, and it is fine as long as it dedicated to FAH.
I consider 4 GB of RAM as a minimum for GPU folding.
The only "interesting" thing in this system is the GPU, so you could also pull the GPU out of this machine and use it in your own one. The CPU won't do anything useful on FAH ...
