nvidia gt 710 stats not updated any
OZCAN'S Team
Post by OZCAN'S Team »
Thanks for this forum for support
I have an gt 710 graphics with latest drivers installed, although finishing a number of wu's never updated stat's as a work done
I use internet as hotspot and not continuously active . I think there's a problem with it or gpu
Can you understand what happens ?
19:35:08:WU01:FS01:0x22:************************************ System ************************************
19:35:08:WU01:FS01:0x22:        CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
19:35:08:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
19:35:08:WU01:FS01:0x22:       CPUs: 2
19:35:09:WU01:FS01:0x22:     Memory: 4.00GiB
19:35:09:WU01:FS01:0x22:Free Memory: 1.32GiB
19:35:09:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:35:09:WU01:FS01:0x22: OS Version: 6.2
19:35:09:WU01:FS01:0x22:Has Battery: false
19:35:09:WU01:FS01:0x22: On Battery: false
19:35:09:WU01:FS01:0x22: UTC Offset: 3
19:35:09:WU01:FS01:0x22:        PID: 10232
19:35:09:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
19:35:09:WU01:FS01:0x22:************************************ OpenMM ************************************
19:35:09:WU01:FS01:0x22:   Revision: 189320d0
19:35:09:WU01:FS01:0x22:********************************************************************************
19:35:09:WU01:FS01:0x22:Project: 16492 (Run 0, Clone 109, Gen 229)
19:35:09:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
19:35:09:WU01:FS01:0x22:Reading tar file core.xml
19:35:09:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
19:35:09:WU01:FS01:0x22:Reading tar file state.xml.bz2
19:35:09:WU01:FS01:0x22:Reading tar file system.xml.bz2
19:35:09:WU01:FS01:0x22:Digital signatures verified
19:35:09:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:35:09:WU01:FS01:0x22:Version 0.0.13
19:35:09:WU01:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
19:35:09:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
19:35:09:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (10%) [10 total]
19:35:09:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
19:35:09:WU01:FS01:0x22:There are 3 platforms available.
19:35:09:WU01:FS01:0x22:Platform 0: Reference
19:35:09:WU01:FS01:0x22:Platform 1: OpenCL
19:35:09:WU01:FS01:0x22:  opencl-device 0 specified
19:35:09:WU01:FS01:0x22:Platform 2: CUDA
19:35:09:WU01:FS01:0x22:  cuda-device 0 specified
19:35:24:WU01:FS01:0x22:Attempting to create CUDA context:
19:35:24:WU01:FS01:0x22:  Configuring platform CUDA
19:36:00:WU01:FS01:0x22:  Using CUDA and gpu 0
19:36:00:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
19:36:16:WU01:FS01:0x22:Checkpoint completed at step 0
19:36:25:WU01:FS01:0x22:An exception occurred at step 99: Error downloading array energySum: CUDA_ERROR_LAUNCH_TIMEOUT (702)
19:36:25:WU01:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
19:36:25:WU01:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
19:36:29:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:36:29:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
19:36:30:WU01:FS01:Starting
19:36:30:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8076 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:36:30:WU01:FS01:Started FahCore on PID 6044
19:36:31:WU01:FS01:Core PID:9528
19:36:31:WU01:FS01:FahCore 0x22 started
19:36:31:WU01:FS01:0x22:*********************** Log Started 2022-03-16T19:36:31Z ***********************
19:36:31:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:36:31:WU01:FS01:0x22:       Core: Core22
19:36:31:WU01:FS01:0x22:       Type: 0x22
19:36:31:WU01:FS01:0x22:    Version: 0.0.13
19:36:31:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:36:31:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
19:36:31:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
19:36:31:WU01:FS01:0x22:       Date: Sep 19 2020
19:36:31:WU01:FS01:0x22:       Time: 02:35:58
19:36:31:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:36:31:WU01:FS01:0x22:     Branch: core22-0.0.13
19:36:31:WU01:FS01:0x22:   Compiler: Visual C++ 2015
19:36:31:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:36:31:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
19:36:31:WU01:FS01:0x22:   Platform: win32 10
19:36:31:WU01:FS01:0x22:       Bits: 64
19:36:31:WU01:FS01:0x22:       Mode: Release
19:36:31:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:36:31:WU01:FS01:0x22:             <peastman@stanford.edu>
19:36:31:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6044 -checkpoint 15
19:36:31:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:36:31:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
19:36:31:WU01:FS01:0x22:************************************ libFAH ************************************
19:36:31:WU01:FS01:0x22:       Date: Sep 7 2020
19:36:31:WU01:FS01:0x22:       Time: 19:09:56
19:36:31:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:36:31:WU01:FS01:0x22:     Branch: HEAD
19:36:31:WU01:FS01:0x22:************************************ CBang *************************************
19:36:31:WU01:FS01:0x22:       Time: 19:08:30
19:36:31:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:36:31:WU01:FS01:0x22:************************************ System ************************************
19:36:31:WU01:FS01:0x22:        CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
19:36:31:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
19:36:31:WU01:FS01:0x22:       CPUs: 2
19:36:31:WU01:FS01:0x22:     Memory: 4.00GiB
19:36:31:WU01:FS01:0x22:Free Memory: 1.33GiB
19:36:31:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:36:31:WU01:FS01:0x22: OS Version: 6.2
19:36:31:WU01:FS01:0x22:Has Battery: false
19:36:31:WU01:FS01:0x22: On Battery: false
19:36:31:WU01:FS01:0x22: UTC Offset: 3
19:36:31:WU01:FS01:0x22:        PID: 9528
19:36:31:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
19:36:31:WU01:FS01:0x22:************************************ OpenMM ************************************
19:36:31:WU01:FS01:0x22:   Revision: 189320d0
19:36:31:WU01:FS01:0x22:********************************************************************************
19:36:31:WU01:FS01:0x22:Project: 16492 (Run 0, Clone 109, Gen 229)
19:36:31:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
19:36:31:WU01:FS01:0x22:Digital signatures verified
19:36:31:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:36:31:WU01:FS01:0x22:Version 0.0.13
19:36:31:WU01:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
19:36:31:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
19:36:31:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (10%) [10 total]
19:36:31:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
19:36:31:WU01:FS01:0x22:There are 3 platforms available.
19:36:31:WU01:FS01:0x22:Platform 0: Reference
19:36:31:WU01:FS01:0x22:Platform 1: OpenCL
19:36:31:WU01:FS01:0x22:  opencl-device 0 specified
19:36:31:WU01:FS01:0x22:Platform 2: CUDA
19:36:31:WU01:FS01:0x22:  cuda-device 0 specified
19:36:46:WU01:FS01:0x22:Attempting to create CUDA context:
19:36:46:WU01:FS01:0x22:  Configuring platform CUDA
19:37:21:WU01:FS01:0x22:  Using CUDA and gpu 0
19:37:21:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
19:37:32:WU01:FS01:0x22:An exception occurred at step 124: Error downloading array energySum: CUDA_ERROR_LAUNCH_TIMEOUT (702)
19:37:32:WU01:FS01:0x22:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
19:37:32:WU01:FS01:0x22:ERROR:114: Max number of attempts to resume from last checkpoint reached.
19:37:32:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
19:37:32:WU01:FS01:0x22:Saving result file science.log
19:37:32:WU01:FS01:0x22:Saving result file state.xml.bz2
19:37:32:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:37:37:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:37:37:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
19:37:37:WU01:FS01:Starting
19:37:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8076 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:37:37:WU01:FS01:Started FahCore on PID 5152
19:37:38:WU01:FS01:Core PID:2996
19:37:38:WU01:FS01:FahCore 0x22 started
19:37:39:WU01:FS01:0x22:*********************** Log Started 2022-03-16T19:37:38Z ***********************
19:37:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:37:39:WU01:FS01:0x22:       Core: Core22
19:37:39:WU01:FS01:0x22:       Type: 0x22
19:37:39:WU01:FS01:0x22:    Version: 0.0.13
19:37:39:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:37:39:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
19:37:39:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
19:37:39:WU01:FS01:0x22:       Date: Sep 19 2020
19:37:39:WU01:FS01:0x22:       Time: 02:35:58
19:37:39:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:37:39:WU01:FS01:0x22:     Branch: core22-0.0.13
19:37:39:WU01:FS01:0x22:   Compiler: Visual C++ 2015
19:37:39:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:37:39:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
19:37:39:WU01:FS01:0x22:   Platform: win32 10
19:37:39:WU01:FS01:0x22:       Bits: 64
19:37:39:WU01:FS01:0x22:       Mode: Release
19:37:39:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:37:39:WU01:FS01:0x22:             <peastman@stanford.edu>
19:37:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5152 -checkpoint 15
19:37:39:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:37:39:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
19:37:39:WU01:FS01:0x22:************************************ libFAH ************************************
19:37:39:WU01:FS01:0x22:       Date: Sep 7 2020
19:37:39:WU01:FS01:0x22:       Time: 19:09:56
19:37:39:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:37:39:WU01:FS01:0x22:     Branch: HEAD
19:37:39:WU01:FS01:0x22:************************************ CBang *************************************
19:37:39:WU01:FS01:0x22:       Time: 19:08:30
19:37:39:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:37:39:WU01:FS01:0x22:************************************ System ************************************
19:37:39:WU01:FS01:0x22:        CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
19:37:39:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
19:37:39:WU01:FS01:0x22:       CPUs: 2
19:37:39:WU01:FS01:0x22:     Memory: 4.00GiB
19:37:39:WU01:FS01:0x22:Free Memory: 1.32GiB
19:37:39:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:37:39:WU01:FS01:0x22: OS Version: 6.2
19:37:39:WU01:FS01:0x22:Has Battery: false
19:37:39:WU01:FS01:0x22: On Battery: false
19:37:39:WU01:FS01:0x22: UTC Offset: 3
19:37:39:WU01:FS01:0x22:        PID: 2996
19:37:39:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
19:37:39:WU01:FS01:0x22:************************************ OpenMM ************************************
19:37:39:WU01:FS01:0x22:   Revision: 189320d0
19:37:39:WU01:FS01:0x22:********************************************************************************
19:37:39:WU01:FS01:0x22:Project: 16492 (Run 0, Clone 109, Gen 229)
19:37:39:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
19:37:39:WU01:FS01:0x22:Reading tar file core.xml
19:37:39:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
19:37:39:WU01:FS01:0x22:Reading tar file state.xml.bz2
19:37:39:WU01:FS01:0x22:Reading tar file system.xml.bz2
19:37:39:WU01:FS01:0x22:Digital signatures verified
19:37:39:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:37:39:WU01:FS01:0x22:Version 0.0.13
19:37:39:WU01:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
19:37:39:WU01:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
19:37:39:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (10%) [10 total]
19:37:39:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
19:37:39:WU01:FS01:0x22:There are 3 platforms available.
19:37:39:WU01:FS01:0x22:Platform 0: Reference
19:37:39:WU01:FS01:0x22:Platform 1: OpenCL
19:37:39:WU01:FS01:0x22:  opencl-device 0 specified
19:37:39:WU01:FS01:0x22:Platform 2: CUDA
19:37:40:WU01:FS01:0x22:  cuda-device 0 specified
19:37:54:WU01:FS01:0x22:Attempting to create CUDA context:
19:37:54:WU01:FS01:0x22:  Configuring platform CUDA
19:38:29:WU01:FS01:0x22:  Using CUDA and gpu 0
19:38:29:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
19:38:45:WU01:FS01:0x22:Checkpoint completed at step 0
19:39:02:WU01:FS01:0x22:An exception occurred at step 240: Error invoking kernel: CUDA_ERROR_LAUNCH_TIMEOUT (702)
19:39:02:WU01:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
19:39:02:WU01:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
19:39:09:WARNING:WU01:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:39:09:WARNING:WU01:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
19:39:09:WARNING:WU01:FS01:Too many errors, failing
19:39:09:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
19:39:09:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
19:39:09:WU01:FS01:Connecting to 140.163.4.210:8080
19:39:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:39:30:WU01:FS01:Connecting to 140.163.4.210:80
19:39:52:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:39:52:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:39:52:WU01:FS01:Trying to send results to collection server
19:39:52:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
19:39:52:WU01:FS01:Connecting to 128.252.203.13:8080
19:40:13:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:40:13:WU01:FS01:Connecting to 128.252.203.13:80
19:40:34:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:40:34:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:40:34:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
19:40:34:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
19:40:34:WU01:FS01:Connecting to 140.163.4.210:8080
19:40:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:40:55:WU01:FS01:Connecting to 140.163.4.210:80
19:41:17:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:41:17:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:41:17:WU01:FS01:Trying to send results to collection server
19:41:17:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
19:41:17:WU01:FS01:Connecting to 128.252.203.13:8080
19:41:38:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:41:38:WU01:FS01:Connecting to 128.252.203.13:80
19:41:59:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:41:59:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:41:59:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
19:42:00:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
19:42:00:WU01:FS01:Connecting to 140.163.4.210:8080
19:42:21:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:42:21:WU01:FS01:Connecting to 140.163.4.210:80
19:42:42:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:42:42:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:42:42:WU01:FS01:Trying to send results to collection server
19:42:42:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
19:42:42:WU01:FS01:Connecting to 128.252.203.13:8080
19:43:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:43:03:WU01:FS01:Connecting to 128.252.203.13:80
19:43:24:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:43:24:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:43:37:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
19:43:37:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
19:43:37:WU01:FS01:Connecting to 140.163.4.210:8080
19:43:58:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:43:58:WU01:FS01:Connecting to 140.163.4.210:80
19:44:19:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:44:19:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:44:19:WU01:FS01:Trying to send results to collection server
19:44:19:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
19:44:19:WU01:FS01:Connecting to 128.252.203.13:8080
19:44:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:44:40:WU01:FS01:Connecting to 128.252.203.13:80
19:45:02:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:45:02:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:46:14:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
19:46:14:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
19:46:14:WU01:FS01:Connecting to 140.163.4.210:8080
19:46:35:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:46:35:WU01:FS01:Connecting to 140.163.4.210:80
19:46:56:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:46:56:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:46:56:WU01:FS01:Trying to send results to collection server
19:46:57:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
19:46:57:WU01:FS01:Connecting to 128.252.203.13:8080
19:47:18:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:47:18:WU01:FS01:Connecting to 128.252.203.13:80
19:47:39:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:47:39:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:50:28:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
19:50:28:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
19:50:28:WU01:FS01:Connecting to 140.163.4.210:8080
19:50:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:50:49:WU01:FS01:Connecting to 140.163.4.210:80
19:51:11:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:51:11:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:51:11:WU01:FS01:Trying to send results to collection server
19:51:11:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
19:51:11:WU01:FS01:Connecting to 128.252.203.13:8080
19:51:32:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:51:32:WU01:FS01:Connecting to 128.252.203.13:80
19:51:53:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:51:53:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:57:19:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
19:57:20:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
19:57:20:WU01:FS01:Connecting to 140.163.4.210:8080
19:57:41:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:57:41:WU01:FS01:Connecting to 140.163.4.210:80
19:58:02:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:58:02:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
19:58:02:WU01:FS01:Trying to send results to collection server
19:58:02:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
19:58:02:WU01:FS01:Connecting to 128.252.203.13:8080
19:58:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:58:23:WU01:FS01:Connecting to 128.252.203.13:80
19:58:44:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
19:58:44:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
20:01:07:WU00:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
20:08:25:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
20:08:25:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
20:08:25:WU01:FS01:Connecting to 140.163.4.210:8080
20:08:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:08:46:WU01:FS01:Connecting to 140.163.4.210:80
20:09:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
20:09:07:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
20:09:07:WU01:FS01:Trying to send results to collection server
20:09:08:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
20:09:08:WU01:FS01:Connecting to 128.252.203.13:8080
20:09:29:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:09:29:WU01:FS01:Connecting to 128.252.203.13:80
20:09:50:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
20:09:50:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
20:26:22:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
20:26:22:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
20:26:22:WU01:FS01:Connecting to 140.163.4.210:8080
20:26:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:26:43:WU01:FS01:Connecting to 140.163.4.210:80
20:27:04:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
20:27:04:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
20:27:04:WU01:FS01:Trying to send results to collection server
20:27:04:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
20:27:04:WU01:FS01:Connecting to 128.252.203.13:8080
20:27:25:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:27:25:WU01:FS01:Connecting to 128.252.203.13:80
20:27:47:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
20:27:47:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
20:52:25:WU00:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
20:55:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
20:55:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
20:55:24:WU01:FS01:Connecting to 140.163.4.210:8080
20:55:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:55:45:WU01:FS01:Connecting to 140.163.4.210:80
20:56:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
20:56:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
20:56:06:WU01:FS01:Trying to send results to collection server
20:56:07:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
20:56:07:WU01:FS01:Connecting to 128.252.203.13:8080
20:56:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:56:28:WU01:FS01:Connecting to 128.252.203.13:80
20:56:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
20:56:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
21:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
21:42:23:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
21:42:23:WU01:FS01:Connecting to 140.163.4.210:8080
21:42:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:42:44:WU01:FS01:Connecting to 140.163.4.210:80
21:43:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
21:43:05:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
21:43:05:WU01:FS01:Trying to send results to collection server
21:43:05:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
21:43:05:WU01:FS01:Connecting to 128.252.203.13:8080
21:43:26:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:43:26:WU01:FS01:Connecting to 128.252.203.13:80
21:43:46:WU00:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
21:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
21:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
22:35:05:WU00:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
22:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
22:42:23:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
22:42:23:WU01:FS01:Connecting to 140.163.4.210:8080
22:42:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
22:42:44:WU01:FS01:Connecting to 140.163.4.210:80
22:43:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
22:43:05:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
22:43:05:WU01:FS01:Trying to send results to collection server
22:43:05:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
22:43:05:WU01:FS01:Connecting to 128.252.203.13:8080
22:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
22:43:27:WU01:FS01:Connecting to 128.252.203.13:80
22:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
22:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
23:26:23:WU00:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
23:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
23:42:23:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
23:42:23:WU01:FS01:Connecting to 140.163.4.210:8080
23:42:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:42:44:WU01:FS01:Connecting to 140.163.4.210:80
23:43:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
23:43:05:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
23:43:05:WU01:FS01:Trying to send results to collection server
23:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
23:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
23:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:43:27:WU01:FS01:Connecting to 128.252.203.13:80
23:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
23:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
00:17:41:WU00:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
00:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
00:42:23:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
00:42:23:WU01:FS01:Connecting to 140.163.4.210:8080
00:42:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:42:44:WU01:FS01:Connecting to 140.163.4.210:80
00:43:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
00:43:05:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
00:43:05:WU01:FS01:Trying to send results to collection server
00:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
00:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
00:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:43:27:WU01:FS01:Connecting to 128.252.203.13:80
00:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
00:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
01:09:07:WU00:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
******************************* Date: 2022-03-17 *******************************
01:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
01:42:23:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
01:42:23:WU01:FS01:Connecting to 140.163.4.210:8080
01:42:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:42:44:WU01:FS01:Connecting to 140.163.4.210:80
01:43:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
01:43:05:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
01:43:05:WU01:FS01:Trying to send results to collection server
01:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
01:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
01:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:43:27:WU01:FS01:Connecting to 128.252.203.13:80
01:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
01:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
02:00:24:WU00:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
02:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
02:42:23:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
02:42:23:WU01:FS01:Connecting to 140.163.4.210:8080
02:42:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:42:44:WU01:FS01:Connecting to 140.163.4.210:80
02:43:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
02:43:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
02:43:06:WU01:FS01:Trying to send results to collection server
02:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
02:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
02:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:43:27:WU01:FS01:Connecting to 128.252.203.13:80
02:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
02:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
02:51:41:WU00:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
03:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
03:42:23:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
03:42:23:WU01:FS01:Connecting to 140.163.4.210:8080
03:42:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:42:45:WU01:FS01:Connecting to 140.163.4.210:80
03:42:59:WU00:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
03:43:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
03:43:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
03:43:06:WU01:FS01:Trying to send results to collection server
03:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
03:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
03:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:43:27:WU01:FS01:Connecting to 128.252.203.13:80
03:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
03:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
04:34:18:WU00:FS00:0xa8:Completed 600000 out of 5000000 steps (12%)
04:42:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
04:42:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
04:42:24:WU01:FS01:Connecting to 140.163.4.210:8080
04:42:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:42:45:WU01:FS01:Connecting to 140.163.4.210:80
04:43:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
04:43:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
04:43:06:WU01:FS01:Trying to send results to collection server
04:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
04:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
04:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:43:27:WU01:FS01:Connecting to 128.252.203.13:80
04:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
04:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
05:25:37:WU00:FS00:0xa8:Completed 650000 out of 5000000 steps (13%)
05:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
05:42:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
05:42:24:WU01:FS01:Connecting to 140.163.4.210:8080
05:42:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:42:45:WU01:FS01:Connecting to 140.163.4.210:80
05:43:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
05:43:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
05:43:06:WU01:FS01:Trying to send results to collection server
05:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
05:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
05:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:43:27:WU01:FS01:Connecting to 128.252.203.13:80
05:43:48:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
05:43:48:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
06:16:54:WU00:FS00:0xa8:Completed 700000 out of 5000000 steps (14%)
06:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
06:42:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
06:42:24:WU01:FS01:Connecting to 140.163.4.210:8080
06:42:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
06:42:45:WU01:FS01:Connecting to 140.163.4.210:80
06:43:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
06:43:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
06:43:06:WU01:FS01:Trying to send results to collection server
06:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
06:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
06:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
06:43:27:WU01:FS01:Connecting to 128.252.203.13:80
06:43:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
06:43:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
07:08:10:WU00:FS00:0xa8:Completed 750000 out of 5000000 steps (15%)
07:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
07:42:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
07:42:24:WU01:FS01:Connecting to 140.163.4.210:8080
07:42:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:42:45:WU01:FS01:Connecting to 140.163.4.210:80
07:43:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
07:43:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
07:43:06:WU01:FS01:Trying to send results to collection server
07:43:06:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
07:43:06:WU01:FS01:Connecting to 128.252.203.13:8080
07:43:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:43:27:WU01:FS01:Connecting to 128.252.203.13:80
07:43:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
07:43:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
07:59:27:WU00:FS00:0xa8:Completed 800000 out of 5000000 steps (16%)
08:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
08:42:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
08:42:24:WU01:FS01:Connecting to 140.163.4.210:8080
08:42:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:42:46:WU01:FS01:Connecting to 140.163.4.210:80
08:43:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
08:43:07:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
08:43:07:WU01:FS01:Trying to send results to collection server
08:43:07:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
08:43:07:WU01:FS01:Connecting to 128.252.203.13:8080
08:43:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:43:28:WU01:FS01:Connecting to 128.252.203.13:80
08:43:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
08:43:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
08:50:44:WU00:FS00:0xa8:Completed 850000 out of 5000000 steps (17%)
09:42:17:WU00:FS00:0xa8:Completed 900000 out of 5000000 steps (18%)
09:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
09:42:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
09:42:24:WU01:FS01:Connecting to 140.163.4.210:8080
09:42:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:42:45:WU01:FS01:Connecting to 140.163.4.210:80
09:43:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
09:43:06:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
09:43:06:WU01:FS01:Trying to send results to collection server
09:43:07:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
09:43:07:WU01:FS01:Connecting to 128.252.203.13:8080
09:43:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:43:28:WU01:FS01:Connecting to 128.252.203.13:80
09:43:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
09:43:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
10:33:36:WU00:FS00:0xa8:Completed 950000 out of 5000000 steps (19%)
10:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
10:42:24:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
10:42:24:WU01:FS01:Connecting to 140.163.4.210:8080
10:42:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:42:45:WU01:FS01:Connecting to 140.163.4.210:80
10:43:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
10:43:07:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
10:43:07:WU01:FS01:Trying to send results to collection server
10:43:07:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
10:43:07:WU01:FS01:Connecting to 128.252.203.13:8080
10:43:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:43:28:WU01:FS01:Connecting to 128.252.203.13:80
10:43:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
10:43:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
11:24:57:WU00:FS00:0xa8:Completed 1000000 out of 5000000 steps (20%)
11:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
11:42:25:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
11:42:25:WU01:FS01:Connecting to 140.163.4.210:8080
11:42:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:42:46:WU01:FS01:Connecting to 140.163.4.210:80
11:43:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
11:43:07:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
11:43:07:WU01:FS01:Trying to send results to collection server
11:43:07:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
11:43:07:WU01:FS01:Connecting to 128.252.203.13:8080
11:43:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:43:28:WU01:FS01:Connecting to 128.252.203.13:80
11:43:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
11:43:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
12:16:18:WU00:FS00:0xa8:Completed 1050000 out of 5000000 steps (21%)
12:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
12:42:25:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
12:42:25:WU01:FS01:Connecting to 140.163.4.210:8080
12:42:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:42:46:WU01:FS01:Connecting to 140.163.4.210:80
12:43:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
12:43:07:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
12:43:07:WU01:FS01:Trying to send results to collection server
12:43:07:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
12:43:07:WU01:FS01:Connecting to 128.252.203.13:8080
12:43:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:43:28:WU01:FS01:Connecting to 128.252.203.13:80
12:43:49:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
12:43:49:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
13:07:43:WU00:FS00:0xa8:Completed 1100000 out of 5000000 steps (22%)
13:42:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
13:42:25:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
13:42:25:WU01:FS01:Connecting to 140.163.4.210:8080
13:42:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:42:46:WU01:FS01:Connecting to 140.163.4.210:80
13:43:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
13:43:07:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
13:43:07:WU01:FS01:Trying to send results to collection server
13:43:07:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
13:43:07:WU01:FS01:Connecting to 128.252.203.13:8080
13:43:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:43:28:WU01:FS01:Connecting to 128.252.203.13:80
13:43:50:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
13:43:50:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
13:59:11:WU00:FS00:0xa8:Completed 1150000 out of 5000000 steps (23%)
******************************* Date: 2022-03-18 *******************************
11:29:18:WARNING:WU00:FS00:Detected clock skew (21 hours 30 mins), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
11:29:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
11:29:21:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
11:29:25:WU01:FS01:Connecting to 140.163.4.210:8080
11:29:25:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:29:25:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Bir yuva i_lemi eri_ilemeyen bir ana bilgisayar için denendi.
11:29:26:WU01:FS01:Trying to send results to collection server
11:29:26:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
11:29:26:WU01:FS01:Connecting to 128.252.203.13:8080
11:29:26:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:29:27:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Bir yuva i_lemi eri_ilemeyen bir ana bilgisayar için denendi.
12:03:40:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:04:07:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:09:20:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:09:37:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:11:59:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:14:00:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:15:04:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:15:26:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:16:48:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:17:24:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:17:46:ERROR:Receive error: 10053: Kurulan bir balant1, ana makinenizdeki yaz1l1m taraf1ndan iptal edildi.
12:29:18:WU00:FS00:0xa8:Completed 1200000 out of 5000000 steps (24%)
12:29:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
12:29:20:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
12:29:20:WU01:FS01:Connecting to 140.163.4.210:8080
12:29:41:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:29:41:WU01:FS01:Connecting to 140.163.4.210:80
12:30:02:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
12:30:02:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
12:30:02:WU01:FS01:Trying to send results to collection server
12:30:02:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
12:30:02:WU01:FS01:Connecting to 128.252.203.13:8080
12:30:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:30:23:WU01:FS01:Connecting to 128.252.203.13:80
12:30:44:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
12:30:44:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
13:20:40:WU00:FS00:0xa8:Completed 1250000 out of 5000000 steps (25%)
13:29:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
13:29:20:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
13:29:20:WU01:FS01:Connecting to 140.163.4.210:8080
13:29:41:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:29:41:WU01:FS01:Connecting to 140.163.4.210:80
13:30:02:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.210:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
13:30:02:WARNING:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
13:30:02:WU01:FS01:Trying to send results to collection server
13:30:03:WU01:FS01:Uploading 3.98MiB to 128.252.203.13
13:30:03:WU01:FS01:Connecting to 128.252.203.13:8080
13:30:24:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:30:24:WU01:FS01:Connecting to 128.252.203.13:80
13:30:45:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.13:80: Balan1lan uygun olarak belli bir süre içinde yan1t vermediinden veya kurulan
13:30:45:ERROR:WU01:FS01:balant1 balan1lan ana bilgisayar yan1t vermediinden bir balant1 kurulamad1.
14:16:02:WARNING:WU00:FS00:Detected clock skew (16 mins 33 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
14:29:02:WU00:FS00:0xa8:Completed 1300000 out of 5000000 steps (26%)
14:29:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:16492 run:0 clone:109 gen:229 core:0x22 unit:0x0000006d000000e50000406c00000000
14:29:20:WU01:FS01:Uploading 3.98MiB to 140.163.4.210
14:29:20:WU01:FS01:Connecting to 140.163.4.210:8080
14:29:26:WU01:FS01:Upload 39.29%
14:29:32:WU01:FS01:Upload 92.72%
14:29:33:WU01:FS01:Upload complete
14:29:33:WU01:FS01:Server responded WORK_ACK (400)
14:29:33:WU01:FS01:Cleaning up
14:37:03:ERROR:Receive error: 10054: Varolan bir balant1 uzaktaki bir ana bilgisayar taraf1ndan zorla kapat1ld1.
14:40:19:FS00:Paused
14:40:19:FS01:Paused
14:40:19:FS00:Shutting core down
14:40:19:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 8640
14:40:19:WU00:FS00:0xa8:Exiting, please wait. . .
14:40:22:WU00:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
14:40:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:40:25:Saving configuration to config.xml
14:40:25:<config>
14:40:25:  <!-- Folding Slot Configuration -->
14:40:25:  <cause v='HIGH_PRIORITY'/>
14:40:25:
14:40:25:  <!-- User Information -->
14:40:25:  <passkey v='*****'/>
14:40:25:  <team v='1062969'/>
14:40:25:  <user v='Hp_Compaq'/>
14:40:25:
14:40:25:  <!-- Folding Slots -->
14:40:25:  <slot id='0' type='CPU'>
14:40:25:    <paused v='true'/>
14:40:25:  </slot>
14:40:25:  <slot id='1' type='GPU'>
14:40:25:    <pci-bus v='2'/>
14:40:25:    <pci-slot v='0'/>
14:40:25:  </slot>
14:40:25:</config>
14:44:58:51:127.0.0.
OZCAN'S Team
Re: nvidia gt 710 stats not updated any
last attempt also no stats updated
PaulTV
Post by PaulTV »
Both jobs show that your machine failed the job (error: FAILED). Looking at https://apps.foldingathome.org/wu#proje ... 09&gen=229 (PRCG matching the second post), and comparing with the logs, you're folding as Hp_Compaq. Given that this job was assigned to the other folder before your machine returned the result, I think it may have hit the expiration.
A job has a timeout and an expiration. If a job result isn't returned before the timeout, it's assigned to another machine, but the original machine will keep on folding. But when expiration is reached, the client will drop the result and ask for a new job. You'll want to complete jobs before the timeout is reached. If your computer can't make that even when folding 7/24 on most if not all jobs, it'll be too slow.
Folding simulations often are chopped up in workunits. One workunit will then be a continuation from a previous workunit. That's why there are timeouts on those jobs, as not to slow down science that much.
Hi Hp_Compaq (team 1062969), Your WU (P16492 R0 C109 G229) was added to the stats database on Invalid Date for 0 points of credit.
Stats show the return status of the failed WU, 0 credit for a failed WU. The WU itself is good, it has been successfully completed by another folder.
The error code shown may indicate a corrupted checkpoint. This sometimes happens when folding is not shutdown before a reboot or system shutdown, especially on Windows as it often does not wait for the F@h client to complete its shutdown.
You did not show the beginning of the log which shows the hardware and software configuration. You may do better to stick with just CPU folding, the GT 710 is slow and will complete WUs only if running full time. It may not complete some projects before the deadlines even running 24 hours a day.
Welcome to Folding@Home!
I am guessing, as you did not include the configuration portion of your log, usually the first 100 lines. Nvidia labeled many card GT 710, some cannot run at all, others just can't complete on time.
https://www.techpowerup.com/gpu-specs/g ... -710.c1990
This card can run F@H, it has 64 bit floating point math and has a version of OpenCL greater than 1.1
However, even running 24/7 it is unlikely to complete a Work Unit before it is re-assigned. It appears to be 4 times slower than the slowest card that always completes running 24/7.
Something is wrong with the GPU, maybe its drivers ... did you install the latest drivers for it from nVidia website ?
