Please Add AMD Radeon Graphics (1002 164C - 17AA 3F95)
64bit
Post by 64bit »
Please add the following integrated GPU for AMD Ryzen 3 5300U.
GPU-Z Details
Name: AMD Radeon(TM) Graphics
Device ID: 1002 164C - 17AA 3F95
Log File:
*********************** Log Started 2022-03-17T14:37:19Z ***********************
14:37:19:******************************* libFAH ********************************
14:37:19:           Date: Oct 20 2020
14:37:19:           Time: 13:36:55
14:37:19:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:37:19:         Branch: master
14:37:19:       Compiler: Visual C++ 2015
14:37:19:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:37:19:       Platform: win32 10
14:37:19:           Bits: 32
14:37:19:           Mode: Release
14:37:19:****************************** FAHClient ******************************
14:37:19:        Version: 7.6.21
14:37:19:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:37:19:      Copyright: 2020 foldingathome.org
14:37:19:       Homepage: https://foldingathome.org/
14:37:19:           Time: 13:41:04
14:37:19:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:37:19:           Bits: 32
14:37:19:           Args: --open-web-control
14:37:19:******************************** CBang ********************************
14:37:19:           Time: 11:36:18
14:37:19:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:37:19:           Bits: 32
14:37:19:******************************* System ********************************
14:37:19:            CPU: AMD Ryzen 3 5300U with Radeon Graphics
14:37:19:         CPU ID: AuthenticAMD Family 23 Model 104 Stepping 1
14:37:19:           CPUs: 8
14:37:19:         Memory: 5.87GiB
14:37:19:    Free Memory: 2.09GiB
14:37:19:        Threads: WINDOWS_THREADS
14:37:19:     OS Version: 6.2
14:37:19:    Has Battery: true
14:37:19:     On Battery: false
14:37:19:     UTC Offset: 8
14:37:19:            PID: 8056
14:37:19:            CWD: C:\ProgramData\FAHClient
14:37:19:  Win32 Service: false
14:37:19:             OS: Windows 10 Home
14:37:19:        OS Arch: AMD64
14:37:19:           GPUs: 1
14:37:19:          GPU 0: Bus:3 Slot:0 Func:0 AMD:1
14:37:19:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:37:19:                 specified module could not be found.
14:37:19:
14:37:19:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3224.5
14:37:19:***********************************************************************
14:37:19:<config>
14:37:19:  <!-- Folding Slots -->
14:37:19:</config>
14:37:19:Trying to access database...
14:37:19:Successfully acquired database lock
14:37:19:FS00:Initialized folding slot 00: cpu:4
14:37:19:WARNING:FS01:Disabling beta GPU slot 01: gpu:3:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
14:37:23:17:127.0.0.1:New Web session
14:38:20:Saving configuration to config.xml
14:38:20:<config>
14:38:20:  <!-- Folding Slots -->
14:38:20:  <slot id='0' type='CPU'/>
14:38:20:  <slot id='1' type='GPU'>
14:38:20:    <pci-bus v='3'/>
14:38:20:    <pci-slot v='0'/>
14:38:20:  </slot>
14:38:20:</config>
14:38:20:Set client configured
14:38:20:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:38:21:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:38:22:WU00:FS00:Assigned to work server 129.32.209.202
14:38:22:WU00:FS00:Requesting new work unit for slot 00: cpu:4 from 129.32.209.202
14:38:22:WU00:FS00:Connecting to 129.32.209.202:8080
14:38:23:WU00:FS00:Downloading 833.50KiB
14:38:25:WU00:FS00:Download complete
14:38:25:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16977 run:135 clone:71 gen:65 core:0xa8 unit:0x00000047000000410000425100000087
14:38:25:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
14:38:25:WU00:FS00:Connecting to cores.foldingathome.org:80
14:38:25:WU00:FS00:FahCore a8: Downloading 7.72MiB
14:38:28:WU00:FS00:FahCore a8: Download complete
14:38:29:WU00:FS00:Valid core signature
14:38:29:WU00:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
14:38:29:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
14:38:29:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
14:38:29:WU00:FS00:Starting
14:38:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 8056 -checkpoint 15 -np 4
14:38:29:WU00:FS00:Started FahCore on PID 18752
14:38:30:WU00:FS00:Core PID:17384
14:38:30:WU00:FS00:FahCore 0xa8 started
14:38:30:WU00:FS00:0xa8:*********************** Log Started 2022-03-17T14:38:30Z ***********************
14:38:30:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:38:30:WU00:FS00:0xa8:       Core: Gromacs
14:38:30:WU00:FS00:0xa8:       Type: 0xa8
14:38:30:WU00:FS00:0xa8:    Version: 0.0.12
14:38:30:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:38:30:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
14:38:30:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
14:38:30:WU00:FS00:0xa8:       Date: Jan 16 2021
14:38:30:WU00:FS00:0xa8:       Time: 12:29:40
14:38:30:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
14:38:30:WU00:FS00:0xa8:     Branch: master
14:38:30:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
14:38:30:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:38:30:WU00:FS00:0xa8:   Platform: win32 10
14:38:30:WU00:FS00:0xa8:       Bits: 64
14:38:30:WU00:FS00:0xa8:       Mode: Release
14:38:30:WU00:FS00:0xa8:       SIMD: avx2_256
14:38:30:WU00:FS00:0xa8:     OpenMP: ON
14:38:30:WU00:FS00:0xa8:       CUDA: OFF
14:38:30:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 18752 -checkpoint 15 -np
14:38:30:WU00:FS00:0xa8:             4
14:38:30:WU00:FS00:0xa8:************************************ libFAH ************************************
14:38:30:WU00:FS00:0xa8:       Time: 11:24:13
14:38:30:WU00:FS00:0xa8:************************************ CBang *************************************
14:38:30:WU00:FS00:0xa8:       Time: 11:23:53
14:38:30:WU00:FS00:0xa8:************************************ System ************************************
14:38:30:WU00:FS00:0xa8:        CPU: AMD Ryzen 3 5300U with Radeon Graphics
14:38:30:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 104 Stepping 1
14:38:30:WU00:FS00:0xa8:       CPUs: 8
14:38:30:WU00:FS00:0xa8:     Memory: 5.87GiB
14:38:30:WU00:FS00:0xa8:Free Memory: 1.49GiB
14:38:30:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
14:38:30:WU00:FS00:0xa8: OS Version: 6.2
14:38:30:WU00:FS00:0xa8:Has Battery: true
14:38:30:WU00:FS00:0xa8: On Battery: false
14:38:30:WU00:FS00:0xa8: UTC Offset: 8
14:38:30:WU00:FS00:0xa8:        PID: 17384
14:38:30:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
14:38:30:WU00:FS00:0xa8:********************************************************************************
14:38:30:WU00:FS00:0xa8:Project: 16977 (Run 135, Clone 71, Gen 65)
14:38:30:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
14:38:30:WU00:FS00:0xa8:Reading tar file core.xml
14:38:30:WU00:FS00:0xa8:Reading tar file frame65.tpr
14:38:30:WU00:FS00:0xa8:Digital signatures verified
14:38:30:WU00:FS00:0xa8:Calling: mdrun -c frame65.gro -s frame65.tpr -x frame65.xtc -cpt 15 -nt 4 -ntmpi 1
14:38:30:WU00:FS00:0xa8:Steps: first=162500000 total=165000000
14:38:31:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
14:40:00:FS00:Shutting core down
14:40:00:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 17384
14:40:00:WU00:FS00:0xa8:Exiting, please wait. . .
14:40:00:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:40:01:WU00:FS00:Starting
14:40:01:WARNING:WU00:FS00:Changed SMP threads from 4 to 6 this can cause some work units to fail
14:40:01:WARNING:WU00:FS00:AS lowered CPUs from 6 to 4
14:40:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 8056 -checkpoint 15 -np 4
14:40:01:WU00:FS00:Started FahCore on PID 10780
14:40:01:WU00:FS00:Core PID:14164
14:40:01:WU00:FS00:FahCore 0xa8 started
14:40:01:WU00:FS00:0xa8:*********************** Log Started 2022-03-17T14:40:01Z ***********************
14:40:01:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:40:01:WU00:FS00:0xa8:       Core: Gromacs
14:40:01:WU00:FS00:0xa8:       Type: 0xa8
14:40:01:WU00:FS00:0xa8:    Version: 0.0.12
14:40:01:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:40:01:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
14:40:01:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
14:40:01:WU00:FS00:0xa8:       Date: Jan 16 2021
14:40:01:WU00:FS00:0xa8:       Time: 12:29:40
14:40:01:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
14:40:01:WU00:FS00:0xa8:     Branch: master
14:40:01:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
14:40:01:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:40:01:WU00:FS00:0xa8:   Platform: win32 10
14:40:01:WU00:FS00:0xa8:       Bits: 64
14:40:01:WU00:FS00:0xa8:       Mode: Release
14:40:01:WU00:FS00:0xa8:       SIMD: avx2_256
14:40:01:WU00:FS00:0xa8:     OpenMP: ON
14:40:01:WU00:FS00:0xa8:       CUDA: OFF
14:40:01:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10780 -checkpoint 15 -np
14:40:01:WU00:FS00:0xa8:             4
14:40:01:WU00:FS00:0xa8:************************************ libFAH ************************************
14:40:01:WU00:FS00:0xa8:       Time: 11:24:13
14:40:01:WU00:FS00:0xa8:************************************ CBang *************************************
14:40:01:WU00:FS00:0xa8:       Time: 11:23:53
14:40:01:WU00:FS00:0xa8:************************************ System ************************************
14:40:01:WU00:FS00:0xa8:        CPU: AMD Ryzen 3 5300U with Radeon Graphics
14:40:01:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 104 Stepping 1
14:40:01:WU00:FS00:0xa8:       CPUs: 8
14:40:01:WU00:FS00:0xa8:     Memory: 5.87GiB
14:40:01:WU00:FS00:0xa8:Free Memory: 1.61GiB
14:40:01:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
14:40:01:WU00:FS00:0xa8: OS Version: 6.2
14:40:01:WU00:FS00:0xa8:Has Battery: true
14:40:01:WU00:FS00:0xa8: On Battery: false
14:40:01:WU00:FS00:0xa8: UTC Offset: 8
14:40:01:WU00:FS00:0xa8:        PID: 14164
14:40:01:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
14:40:01:WU00:FS00:0xa8:********************************************************************************
14:40:01:WU00:FS00:0xa8:Project: 16977 (Run 135, Clone 71, Gen 65)
14:40:01:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
14:40:01:WU00:FS00:0xa8:Digital signatures verified
14:40:01:WU00:FS00:0xa8:Calling: mdrun -c frame65.gro -s frame65.tpr -x frame65.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
14:40:01:WU00:FS00:0xa8:Steps: first=162500000 total=165000000
14:40:01:WU00:FS00:0xa8:Completed 9902 out of 2500000 steps (0%)
14:40:04:FS00:Shutting core down
14:40:04:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 14164
14:40:04:WU00:FS00:0xa8:Exiting, please wait. . .
14:40:05:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:40:22:Saving configuration to config.xml
14:40:22:<config>
14:40:22:  <!-- Slot Control -->
14:40:22:  <power v='FULL'/>
14:40:22:
14:40:22:  <!-- User Information -->
14:40:22:  <passkey v='*****'/>
14:40:22:  <team v='2999'/>
14:40:22:  <user v='64bit.MY'/>
14:40:22:
14:40:22:  <!-- Folding Slots -->
14:40:22:  <slot id='0' type='CPU'/>
14:40:22:  <slot id='1' type='GPU'>
14:40:22:    <pci-bus v='3'/>
14:40:22:    <pci-slot v='0'/>
14:40:22:  </slot>
14:40:22:</config>
14:41:01:WU00:FS00:Starting
14:41:01:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
14:41:01:WARNING:WU00:FS00:AS lowered CPUs from 7 to 4
14:41:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 8056 -checkpoint 15 -np 4
14:41:01:WU00:FS00:Started FahCore on PID 10776
14:41:01:WU00:FS00:Core PID:18688
14:41:01:WU00:FS00:FahCore 0xa8 started
14:41:01:WU00:FS00:0xa8:*********************** Log Started 2022-03-17T14:41:01Z ***********************
14:41:01:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:41:01:WU00:FS00:0xa8:       Core: Gromacs
14:41:01:WU00:FS00:0xa8:       Type: 0xa8
14:41:01:WU00:FS00:0xa8:    Version: 0.0.12
14:41:01:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:41:01:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
14:41:01:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
14:41:01:WU00:FS00:0xa8:       Date: Jan 16 2021
14:41:01:WU00:FS00:0xa8:       Time: 12:29:40
14:41:01:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
14:41:01:WU00:FS00:0xa8:     Branch: master
14:41:01:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
14:41:01:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:41:01:WU00:FS00:0xa8:   Platform: win32 10
14:41:01:WU00:FS00:0xa8:       Bits: 64
14:41:01:WU00:FS00:0xa8:       Mode: Release
14:41:01:WU00:FS00:0xa8:       SIMD: avx2_256
14:41:01:WU00:FS00:0xa8:     OpenMP: ON
14:41:01:WU00:FS00:0xa8:       CUDA: OFF
14:41:01:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10776 -checkpoint 15 -np
14:41:01:WU00:FS00:0xa8:             4
14:41:01:WU00:FS00:0xa8:************************************ libFAH ************************************
14:41:01:WU00:FS00:0xa8:       Time: 11:24:13
14:41:01:WU00:FS00:0xa8:************************************ CBang *************************************
14:41:01:WU00:FS00:0xa8:       Time: 11:23:53
14:41:01:WU00:FS00:0xa8:************************************ System ************************************
14:41:01:WU00:FS00:0xa8:        CPU: AMD Ryzen 3 5300U with Radeon Graphics
14:41:01:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 104 Stepping 1
14:41:01:WU00:FS00:0xa8:       CPUs: 8
14:41:01:WU00:FS00:0xa8:     Memory: 5.87GiB
14:41:01:WU00:FS00:0xa8:Free Memory: 1.45GiB
14:41:01:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
14:41:01:WU00:FS00:0xa8: OS Version: 6.2
14:41:01:WU00:FS00:0xa8:Has Battery: true
14:41:01:WU00:FS00:0xa8: On Battery: false
14:41:01:WU00:FS00:0xa8: UTC Offset: 8
14:41:01:WU00:FS00:0xa8:        PID: 18688
14:41:01:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
14:41:01:WU00:FS00:0xa8:********************************************************************************
14:41:01:WU00:FS00:0xa8:Project: 16977 (Run 135, Clone 71, Gen 65)
14:41:01:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
14:41:01:WU00:FS00:0xa8:Digital signatures verified
14:41:01:WU00:FS00:0xa8:Calling: mdrun -c frame65.gro -s frame65.tpr -x frame65.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
14:41:01:WU00:FS00:0xa8:Steps: first=162500000 total=165000000
14:41:02:WU00:FS00:0xa8:Completed 10252 out of 2500000 steps (0%)
14:43:04:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
14:46:32:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
14:49:58:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
14:53:24:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
14:56:49:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
15:00:23:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
15:04:04:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
15:06:36:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
15:07:35:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
15:11:02:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
15:14:30:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
15:17:56:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
15:21:24:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
15:24:52:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
15:28:19:WU00:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
15:31:47:WU00:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
15:35:15:WU00:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
15:38:43:WU00:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
15:42:11:WU00:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
15:45:41:WU00:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
15:47:28:Saving configuration to config.xml
15:47:28:<config>
15:47:28:  <!-- Folding Slot Configuration -->
15:47:28:  <cause v='COVID_19'/>
15:47:28:
15:47:28:  <!-- Network -->
15:47:28:  <proxy v=':8080'/>
15:47:28:
15:47:28:  <!-- Slot Control -->
15:47:28:  <power v='FULL'/>
15:47:28:
15:47:28:  <!-- User Information -->
15:47:28:  <passkey v='*****'/>
15:47:28:  <team v='2999'/>
15:47:28:  <user v='64bit.MY'/>
15:47:28:
15:47:28:  <!-- Folding Slots -->
15:47:28:  <slot id='0' type='CPU'/>
15:47:28:  <slot id='1' type='GPU'>
15:47:28:    <pci-bus v='3'/>
15:47:28:    <pci-slot v='0'/>
15:47:28:  </slot>
15:47:28:</config>
15:49:18:WU00:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
15:53:01:WU00:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
15:56:41:WU00:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
16:00:21:WU00:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
16:03:59:WU00:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
16:07:30:WU00:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
16:11:05:WU00:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
16:14:42:WU00:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
16:18:19:WU00:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
16:21:59:WU00:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
16:25:40:WU00:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
16:29:12:WU00:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
16:32:40:WU00:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
16:36:05:WU00:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
16:39:32:WU00:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
16:43:00:WU00:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
16:46:29:WU00:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
16:49:58:WU00:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
16:53:34:WU00:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
16:57:11:WU00:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
17:00:53:WU00:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
17:04:31:WU00:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
17:08:15:WU00:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
17:11:45:WU00:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
17:15:07:WU00:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
17:18:28:WU00:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
17:21:51:WU00:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
17:25:16:WU00:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
17:28:39:WU00:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
17:32:01:WU00:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
17:35:23:WU00:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
17:38:44:WU00:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
17:42:05:WU00:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
17:45:26:WU00:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
17:48:47:WU00:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
17:52:07:WU00:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
17:55:28:WU00:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
17:58:50:WU00:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
18:02:11:WU00:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
18:05:33:WU00:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
18:08:55:WU00:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
18:12:16:WU00:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
18:15:38:WU00:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
18:18:59:WU00:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
18:22:20:WU00:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
18:25:43:WU00:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
18:29:03:WU00:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
18:32:25:WU00:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
18:35:46:WU00:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
18:39:08:WU00:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
18:42:29:WU00:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
18:45:51:WU00:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
18:49:12:WU00:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
18:52:33:WU00:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
18:55:55:WU00:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
18:59:16:WU00:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
19:02:38:WU00:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
19:05:59:WU00:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
19:09:21:WU00:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
19:12:42:WU00:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
19:16:04:WU00:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
19:19:26:WU00:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
19:22:48:WU00:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
19:26:10:WU00:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
19:29:32:WU00:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
19:32:54:WU00:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
19:36:16:WU00:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
19:39:37:WU00:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
19:42:59:WU00:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
19:46:20:WU00:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
19:49:41:WU00:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
19:53:03:WU00:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
19:56:24:WU00:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
19:59:45:WU00:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
20:03:07:WU00:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
20:06:29:WU00:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
20:09:50:WU00:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
20:13:10:WU00:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
20:16:31:WU00:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
20:19:53:WU00:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
20:19:53:WU01:FS00:Connecting to assign1.foldingathome.org:80
20:19:55:WU01:FS00:Assigned to work server 128.252.203.11
20:19:55:WU01:FS00:Requesting new work unit for slot 00: cpu:7 from 128.252.203.11
20:19:55:WU01:FS00:Connecting to 128.252.203.11:8080
20:19:55:WU01:FS00:Downloading 8.34MiB
20:20:01:WU01:FS00:Download 36.73%
20:20:06:WU01:FS00:Download complete
20:20:06:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18206 run:10998 clone:0 gen:166 core:0xa8 unit:0x00000000000000a60000471e00002af6
20:23:15:WU00:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
20:23:15:WU00:FS00:0xa8:Saving result file ..\logfile_01.txt
20:23:15:WU00:FS00:0xa8:Saving result file frame65.gro
20:23:15:WU00:FS00:0xa8:Saving result file frame65.xtc
20:23:15:WU00:FS00:0xa8:Saving result file md.log
20:23:15:WU00:FS00:0xa8:Saving result file science.log
20:23:15:WU00:FS00:0xa8:Saving result file state.cpt
20:23:15:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
20:23:16:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:23:16:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16977 run:135 clone:71 gen:65 core:0xa8 unit:0x00000047000000410000425100000087
20:23:16:WU00:FS00:Uploading 2.79MiB to 129.32.209.202
20:23:16:WU01:FS00:Starting
20:23:16:WU00:FS00:Connecting to 129.32.209.202:8080
20:23:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 8056 -checkpoint 15 -np 7
20:23:16:WU01:FS00:Started FahCore on PID 3496
20:23:16:WU01:FS00:Core PID:9032
20:23:16:WU01:FS00:FahCore 0xa8 started
20:23:16:WU01:FS00:0xa8:*********************** Log Started 2022-03-17T20:23:16Z ***********************
20:23:16:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
20:23:16:WU01:FS00:0xa8:       Core: Gromacs
20:23:16:WU01:FS00:0xa8:       Type: 0xa8
20:23:16:WU01:FS00:0xa8:    Version: 0.0.12
20:23:16:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:23:16:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
20:23:16:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
20:23:16:WU01:FS00:0xa8:       Date: Jan 16 2021
20:23:16:WU01:FS00:0xa8:       Time: 12:29:40
20:23:16:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
20:23:16:WU01:FS00:0xa8:     Branch: master
20:23:16:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
20:23:16:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:23:16:WU01:FS00:0xa8:   Platform: win32 10
20:23:16:WU01:FS00:0xa8:       Bits: 64
20:23:16:WU01:FS00:0xa8:       Mode: Release
20:23:16:WU01:FS00:0xa8:       SIMD: avx2_256
20:23:16:WU01:FS00:0xa8:     OpenMP: ON
20:23:16:WU01:FS00:0xa8:       CUDA: OFF
20:23:16:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3496 -checkpoint 15 -np 7
20:23:16:WU01:FS00:0xa8:************************************ libFAH ************************************
20:23:16:WU01:FS00:0xa8:       Time: 11:24:13
20:23:16:WU01:FS00:0xa8:************************************ CBang *************************************
20:23:16:WU01:FS00:0xa8:       Time: 11:23:53
20:23:16:WU01:FS00:0xa8:************************************ System ************************************
20:23:16:WU01:FS00:0xa8:        CPU: AMD Ryzen 3 5300U with Radeon Graphics
20:23:16:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 104 Stepping 1
20:23:16:WU01:FS00:0xa8:       CPUs: 8
20:23:16:WU01:FS00:0xa8:     Memory: 5.87GiB
20:23:16:WU01:FS00:0xa8:Free Memory: 2.38GiB
20:23:16:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
20:23:16:WU01:FS00:0xa8: OS Version: 6.2
20:23:16:WU01:FS00:0xa8:Has Battery: true
20:23:16:WU01:FS00:0xa8: On Battery: false
20:23:16:WU01:FS00:0xa8: UTC Offset: 8
20:23:16:WU01:FS00:0xa8:        PID: 9032
20:23:16:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
20:23:16:WU01:FS00:0xa8:********************************************************************************
20:23:16:WU01:FS00:0xa8:Project: 18206 (Run 10998, Clone 0, Gen 166)
20:23:16:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
20:23:16:WU01:FS00:0xa8:Reading tar file core.xml
20:23:16:WU01:FS00:0xa8:Reading tar file frame166.tpr
20:23:16:WU01:FS00:0xa8:Digital signatures verified
20:23:16:WU01:FS00:0xa8:Calling: mdrun -c frame166.gro -s frame166.tpr -x frame166.xtc -cpt 15 -nt 7 -ntmpi 1
20:23:17:WU01:FS00:0xa8:Steps: first=20750000 total=20875000
20:23:21:WU01:FS00:0xa8:Completed 1 out of 125000 steps (0%)
20:23:22:WU00:FS00:Upload 35.87%
20:23:28:WU00:FS00:Upload 60.53%
20:23:34:WU00:FS00:Upload 98.63%
20:23:34:WU00:FS00:Upload complete
20:23:34:WU00:FS00:Server responded WORK_ACK (400)
20:23:34:WU00:FS00:Final credit estimate, 13447.00 points
20:23:34:WU00:FS00:Cleaning up
20:26:08:WU01:FS00:0xa8:Completed 1250 out of 125000 steps (1%)
20:28:55:WU01:FS00:0xa8:Completed 2500 out of 125000 steps (2%)
20:31:41:WU01:FS00:0xa8:Completed 3750 out of 125000 steps (3%)
20:34:28:WU01:FS00:0xa8:Completed 5000 out of 125000 steps (4%)
20:37:14:WU01:FS00:0xa8:Completed 6250 out of 125000 steps (5%)
******************************* Date: 2022-03-17 *******************************
20:40:01:WU01:FS00:0xa8:Completed 7500 out of 125000 steps (6%)
20:42:47:WU01:FS00:0xa8:Completed 8750 out of 125000 steps (7%)
20:45:33:WU01:FS00:0xa8:Completed 10000 out of 125000 steps (8%)
20:48:19:WU01:FS00:0xa8:Completed 11250 out of 125000 steps (9%)
20:51:05:WU01:FS00:0xa8:Completed 12500 out of 125000 steps (10%)
20:53:53:WU01:FS00:0xa8:Completed 13750 out of 125000 steps (11%)
20:56:43:WU01:FS00:0xa8:Completed 15000 out of 125000 steps (12%)
20:59:31:WU01:FS00:0xa8:Completed 16250 out of 125000 steps (13%)
21:02:19:WU01:FS00:0xa8:Completed 17500 out of 125000 steps (14%)
21:05:05:WU01:FS00:0xa8:Completed 18750 out of 125000 steps (15%)
21:07:51:WU01:FS00:0xa8:Completed 20000 out of 125000 steps (16%)
21:10:38:WU01:FS00:0xa8:Completed 21250 out of 125000 steps (17%)
21:13:24:WU01:FS00:0xa8:Completed 22500 out of 125000 steps (18%)
21:16:09:WU01:FS00:0xa8:Completed 23750 out of 125000 steps (19%)
21:18:55:WU01:FS00:0xa8:Completed 25000 out of 125000 steps (20%)
21:21:41:WU01:FS00:0xa8:Completed 26250 out of 125000 steps (21%)
21:24:29:WU01:FS00:0xa8:Completed 27500 out of 125000 steps (22%)
21:27:15:WU01:FS00:0xa8:Completed 28750 out of 125000 steps (23%)
21:30:01:WU01:FS00:0xa8:Completed 30000 out of 125000 steps (24%)
21:32:47:WU01:FS00:0xa8:Completed 31250 out of 125000 steps (25%)
21:35:32:WU01:FS00:0xa8:Completed 32500 out of 125000 steps (26%)
21:38:18:WU01:FS00:0xa8:Completed 33750 out of 125000 steps (27%)
21:41:06:WU01:FS00:0xa8:Completed 35000 out of 125000 steps (28%)
21:43:52:WU01:FS00:0xa8:Completed 36250 out of 125000 steps (29%)
21:46:37:WU01:FS00:0xa8:Completed 37500 out of 125000 steps (30%)
21:49:23:WU01:FS00:0xa8:Completed 38750 out of 125000 steps (31%)
21:52:09:WU01:FS00:0xa8:Completed 40000 out of 125000 steps (32%)
21:54:57:WU01:FS00:0xa8:Completed 41250 out of 125000 steps (33%)
21:57:42:WU01:FS00:0xa8:Completed 42500 out of 125000 steps (34%)
22:00:28:WU01:FS00:0xa8:Completed 43750 out of 125000 steps (35%)
22:03:14:WU01:FS00:0xa8:Completed 45000 out of 125000 steps (36%)
22:05:59:WU01:FS00:0xa8:Completed 46250 out of 125000 steps (37%)
22:08:47:WU01:FS00:0xa8:Completed 47500 out of 125000 steps (38%)
22:11:32:WU01:FS00:0xa8:Completed 48750 out of 125000 steps (39%)
22:14:18:WU01:FS00:0xa8:Completed 50000 out of 125000 steps (40%)
22:17:04:WU01:FS00:0xa8:Completed 51250 out of 125000 steps (41%)
22:19:49:WU01:FS00:0xa8:Completed 52500 out of 125000 steps (42%)
22:22:35:WU01:FS00:0xa8:Completed 53750 out of 125000 steps (43%)
22:25:24:WU01:FS00:0xa8:Completed 55000 out of 125000 steps (44%)
22:28:12:WU01:FS00:0xa8:Completed 56250 out of 125000 steps (45%)
22:30:57:WU01:FS00:0xa8:Completed 57500 out of 125000 steps (46%)
22:33:43:WU01:FS00:0xa8:Completed 58750 out of 125000 steps (47%)
22:36:29:WU01:FS00:0xa8:Completed 60000 out of 125000 steps (48%)
22:39:16:WU01:FS00:0xa8:Completed 61250 out of 125000 steps (49%)
22:42:02:WU01:FS00:0xa8:Completed 62500 out of 125000 steps (50%)
22:44:48:WU01:FS00:0xa8:Completed 63750 out of 125000 steps (51%)
22:47:33:WU01:FS00:0xa8:Completed 65000 out of 125000 steps (52%)
22:50:19:WU01:FS00:0xa8:Completed 66250 out of 125000 steps (53%)
22:53:05:WU01:FS00:0xa8:Completed 67500 out of 125000 steps (54%)
22:55:53:WU01:FS00:0xa8:Completed 68750 out of 125000 steps (55%)
22:58:38:WU01:FS00:0xa8:Completed 70000 out of 125000 steps (56%)
23:01:24:WU01:FS00:0xa8:Completed 71250 out of 125000 steps (57%)
23:04:10:WU01:FS00:0xa8:Completed 72500 out of 125000 steps (58%)
23:06:55:WU01:FS00:0xa8:Completed 73750 out of 125000 steps (59%)
23:09:43:WU01:FS00:0xa8:Completed 75000 out of 125000 steps (60%)
23:12:28:WU01:FS00:0xa8:Completed 76250 out of 125000 steps (61%)
23:15:14:WU01:FS00:0xa8:Completed 77500 out of 125000 steps (62%)
23:18:00:WU01:FS00:0xa8:Completed 78750 out of 125000 steps (63%)
23:20:45:WU01:FS00:0xa8:Completed 80000 out of 125000 steps (64%)
23:23:33:WU01:FS00:0xa8:Completed 81250 out of 125000 steps (65%)
23:26:19:WU01:FS00:0xa8:Completed 82500 out of 125000 steps (66%)
23:29:05:WU01:FS00:0xa8:Completed 83750 out of 125000 steps (67%)
23:31:51:WU01:FS00:0xa8:Completed 85000 out of 125000 steps (68%)
23:34:36:WU01:FS00:0xa8:Completed 86250 out of 125000 steps (69%)
23:37:22:WU01:FS00:0xa8:Completed 87500 out of 125000 steps (70%)
23:40:10:WU01:FS00:0xa8:Completed 88750 out of 125000 steps (71%)
23:42:56:WU01:FS00:0xa8:Completed 90000 out of 125000 steps (72%)
23:45:41:WU01:FS00:0xa8:Completed 91250 out of 125000 steps (73%)
23:48:27:WU01:FS00:0xa8:Completed 92500 out of 125000 steps (74%)
23:51:13:WU01:FS00:0xa8:Completed 93750 out of 125000 steps (75%)
23:54:00:WU01:FS00:0xa8:Completed 95000 out of 125000 steps (76%)
23:56:46:WU01:FS00:0xa8:Completed 96250 out of 125000 steps (77%)
23:59:32:WU01:FS00:0xa8:Completed 97500 out of 125000 steps (78%)
00:02:18:WU01:FS00:0xa8:Completed 98750 out of 125000 steps (79%)
00:05:03:WU01:FS00:0xa8:Completed 100000 out of 125000 steps (80%)
00:07:49:WU01:FS00:0xa8:Completed 101250 out of 125000 steps (81%)
00:10:37:WU01:FS00:0xa8:Completed 102500 out of 125000 steps (82%)
00:13:23:WU01:FS00:0xa8:Completed 103750 out of 125000 steps (83%)
00:16:09:WU01:FS00:0xa8:Completed 105000 out of 125000 steps (84%)
00:19:02:WU01:FS00:0xa8:Completed 106250 out of 125000 steps (85%)
00:22:14:WU01:FS00:0xa8:Completed 107500 out of 125000 steps (86%)
00:25:18:WU01:FS00:0xa8:Completed 108750 out of 125000 steps (87%)
00:28:23:WU01:FS00:0xa8:Completed 110000 out of 125000 steps (88%)
Re: Please Add AMD Radeon Graphics (1002 164C - 17AA 3F95)
Welcome to Folding@Home!
While we wait for someone with the authority to add to the white list, I thought I would bump this to put it back at the top of the list!
Once you can fold with AMD Ryzen 3 5300U graphics, you will find it very slow. You may wish to try CPU only, like now, GPU only, and Both together to find out which produces more Points Per Day. It may well be that Both is not the most productive.
Added 0x164c / Lucienne
I'm not sure it will fold very well ...
