Buying a Mac Studio. Good Folder?
uclajd
Hardware configuration: Nvidia RTX-2080 with Max-Q (990Mhz)
Post by uclajd »
Just curious if the new Mac Studio with the M1 Ultra will be a decent folder, or is CPU folding just so far behind GPU it isn't significant? My laptop (Alienware i9-9980HK CPU @ 2.40GHz with an RTX 2080) is pooping out about 825,000 PPD, and it would be over a million if I didn't use my laptop 8 hours a day. Pretty darned efficient for under 200 watts.
I'm getting the top of the line Apple M1 Ultra with 20-core CPU, 64-core GPU, 32-core Neural Engine.
Supposedly the Mac Mini M1 does about 69,000 PPD. It has 8-core CPU, 8-core GPU, 16-core Neural Engine.
Which cores does F@H use on a Mac (CPU or GPU)?
Nvidia RTX-2080 with Max-Q (990Mhz) on Alienware 17 i9-9980HK @2.40 GHz 8-core.
Re: Buying a Mac Studio. Good Folder?
For largely historical reasons, only CPU folding is supported on the MacOS.
Post by calxalot »
With cpu:16 and a passkey for bonus points, you should see up to 8x the ppd of an M1 mini.
That will vary a lot.
My M1 mini saw 60 to 120 kppd depending on WU assigned. Usually 83k.
No Mac will ever beat a nVidia GPU in FAH ... :roll:
cdpage
Post by cdpage »
Now that M2 chips are a thing, is there any chance we'll see an update to F@H for Macs in the nearish future?
cdpage wrote: Wed Jun 15, 2022 2:22 pm Now that M2 chips are a thing, is there any chance we'll see an update to F@H for Macs in the nearish future?
Maybe. The current version of the client, 7.6.21, was created before the Apple Silicon based Mac's were widely available. It is the final version 7 client, they are working on a version 8 client at the moment. A Beta version may be out later this year or early next year, and I am assuming they will compile for both versions of Mac hardware then.
However most of the CPU time is spent processing a WU in a folding core. I have no idea when they may release one compiled to use the native ARM instructions of the M1 or M2. Such a release would need to include testing to see that the code created is valid scientifically.
daiko
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Post by daiko »
calxalot wrote: Thu Mar 17, 2022 9:45 pm With cpu:16 and a passkey for bonus points, you should see up to 8x the ppd of an M1 mini.
A late followup to this topic. Following the suggestion above, on a Mac Studio with the 10 core M1 Max:
After folding for months on the default cpu:10 setting, I saw your post and set my cpu:8 to prioritize the performance cores.
(I think that’s how this should work?) I’m currently seeing about 125kppd on the current WU, seems about a 20% boost. 8-)
Overall CPU load hovers around 70-80% at Folding Core Priority: Lowest possible.
Is there any merit in using the "Slightly higher” Priority setting to push CPU use further?
Currently, the fans are inaudible and core temps about 75-80°C.
Post by calxalot »
Do you have a passkey? I think someone reported getting over 220 kppd on an M1 Max.
daiko
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Post by daiko »
calxalot wrote: Sun Jul 31, 2022 8:09 pm Do you have a passkey? I think someone reported getting over 220 kppd on an M1 Max.
Something odd here...
I’ve been folding (off and on) since 2005. If I click on my oldest running machine, it shows a 32 digit INTEGER number in the passkey field, which I had subsequently copied to each new machine. This correctly shows my user and team identities as well as my total points earned. I dug back into my gmail history to find TWO passkey emails from FAH, dated April 2020 and March 2022, showing two different 32 digit HEX numbers. If I enter that 2022 code into my client software I show a grand total of 3400 points under Points Earned in the client, but if I click on 'See Stats' it shows the correct total for my username. It seems I was getting some bonus points with the integer key, as I would occasionally see an unexplained credit, so I assumed the system was working as it should. But now I question that assumption. Any suggestions to resolve this discrepancy? Thanks...
Post by calxalot »
My passkey is a 32 character hex value.
daiko
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Post by daiko »
Thanks for your reply regarding the use of a passkey. I was able to sort this out; I thought I had been receiving bonus points, but now that I am using a proper passkey I have seen a huge uptick in my PPD. Still, 220 kppd seems unlikely for most WUs. The best I’ve seen so far is about 160kppd on one of the cancer projects. https://folding.lar.systems/cpu_ppd/brands/apple/ shows an average of 136kppd in its somewhat limited db for M1 CPUs.
I don’t often use Chrome as a browser on my Mac, but I like the extra info available through the FOLDING AT HOME IN THE DARK extension. Probably old news for most here, but worth a look if you haven’t.
Post by calxalot »
You will need to finish 10 WUs before the bonus kicks in. And maintain an 80% success rate.
dirspb
Post by dirspb »
daiko wrote: Sat Aug 06, 2022 5:48 pm https://folding.lar.systems/cpu_ppd/brands/apple/ shows an average of 136kppd in its somewhat limited db for M1 CPUs.
These stats are very wrong. I'm getting ~100k on MBP M1 Pro 10 core running it all day in background, but it shows 50k for it. Even for standard 8 core it's too low.
daiko
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Post by daiko »
Very late reply, but Yes, you’re right it’s low for some reason. Of course it varies per project. I’ve seen a high of 300kppd on some WUs. Generally closer to 200 on average lately. This is specifying cpu:8 to prioritize the performance cores, as suggested by calxalot above. Running 24/7 here in the background.
send2devnull2
Post by send2devnull2 »
I have a intel 2019 MacPro, with 12core xeon W processor, and I am only seeing ppd of 43044, with the cpu set at 23.
Does is that normal? I have a passkey in the client.
