Please Add Radeon Pro W6600 GPU
Christine_the_Foxy
Hardware configuration: Ryzen 7 5700X, 32GB (2x16) 2666Mhz ECC, Radeon Pro W6600
Post by Christine_the_Foxy »
I see that the gaming cards that use the same core (6600XT) are provisioned, and that the bigger brother to this Radeon pro (W6800) are also provisioned.
Details From GPUZ:
Name: AMD Radeon PRO W6600
Device ID: 1002 73e3 - 1002 0e0c
Details from FAHClient.exe
C:\Program Files (x86)\FAHClient>fahclient --lspci
0x1002:0x73e3:9:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:AMD Radeon PRO W6600
Log From F@H
*********************** Log Started 2022-03-04T16:46:58Z ***********************
16:46:58:******************************* libFAH ********************************
16:46:58:           Date: Oct 20 2020
16:46:58:           Time: 13:36:55
16:46:58:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
16:46:58:         Branch: master
16:46:58:       Compiler: Visual C++ 2015
16:46:58:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:46:58:       Platform: win32 10
16:46:58:           Bits: 32
16:46:58:           Mode: Release
16:46:58:****************************** FAHClient ******************************
16:46:58:        Version: 7.6.21
16:46:58:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:46:58:      Copyright: 2020 foldingathome.org
16:46:58:       Homepage: https://foldingathome.org/
16:46:58:           Time: 13:41:04
16:46:58:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
16:46:58:           Bits: 32
16:46:58:         Config: C:\Users\Christine\AppData\Roaming\FAHClient\config.xml
16:46:58:******************************** CBang ********************************
16:46:58:           Time: 11:36:18
16:46:58:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
16:46:58:           Bits: 32
16:46:58:******************************* System ********************************
16:46:58:            CPU: AMD Ryzen 5 3600 6-Core Processor
16:46:58:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
16:46:58:           CPUs: 12
16:46:58:         Memory: 31.91GiB
16:46:58:    Free Memory: 23.38GiB
16:46:58:        Threads: WINDOWS_THREADS
16:46:58:     OS Version: 6.2
16:46:58:    Has Battery: false
16:46:58:     On Battery: false
16:46:58:     UTC Offset: -5
16:46:58:            PID: 15268
16:46:58:            CWD: C:\Users\Christine\AppData\Roaming\FAHClient
16:46:58:  Win32 Service: false
16:46:58:             OS: Windows 10 Enterprise
16:46:58:        OS Arch: AMD64
16:46:58:           GPUs: 1
16:46:58:          GPU 0: Bus:9 Slot:0 Func:0 AMD:1
16:46:58:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
16:46:58:                 specified module could not be found.
16:46:58:
16:46:58:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3276.6
16:46:58:***********************************************************************
16:46:58:<config>
16:46:58:  <!-- Folding Slot Configuration -->
16:46:58:  <cause v='COVID_19'/>
16:46:58:
16:46:58:  <!-- Network -->
16:46:58:  <proxy v=':8080'/>
16:46:58:
16:46:58:  <!-- Slot Control -->
16:46:58:  <power v='full'/>
16:46:58:
16:46:58:  <!-- User Information -->
16:46:58:  <team v='50717'/>
16:46:58:  <user v='Christine_The_Foxy'/>
16:46:58:
16:46:58:  <!-- Folding Slots -->
16:46:58:  <slot id='0' type='CPU'>
16:46:58:    <cpus v='6'/>
16:46:58:  </slot>
16:46:58:  <slot id='1' type='GPU'>
16:46:58:    <pci-bus v='9'/>
16:46:58:    <pci-slot v='0'/>
16:46:58:  </slot>
16:46:58:</config>
16:46:58:Trying to access database...
16:46:58:Successfully acquired database lock
16:46:58:FS00:Initialized folding slot 00: cpu:6
16:46:58:WARNING:FS01:Disabling beta GPU slot 01: gpu:9:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
16:46:58:WU00:FS00:Starting
16:46:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Christine\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 15268 -checkpoint 15 -np 6
16:46:58:WU00:FS00:Started FahCore on PID 17628
16:46:58:WU00:FS00:Core PID:10352
16:46:58:WU00:FS00:FahCore 0xa8 started
16:46:59:WU00:FS00:0xa8:*********************** Log Started 2022-03-04T16:46:58Z ***********************
16:46:59:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
16:46:59:WU00:FS00:0xa8:       Core: Gromacs
16:46:59:WU00:FS00:0xa8:       Type: 0xa8
16:46:59:WU00:FS00:0xa8:    Version: 0.0.12
16:46:59:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:46:59:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
16:46:59:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
16:46:59:WU00:FS00:0xa8:       Date: Jan 16 2021
16:46:59:WU00:FS00:0xa8:       Time: 12:29:40
16:46:59:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
16:46:59:WU00:FS00:0xa8:     Branch: master
16:46:59:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
16:46:59:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:46:59:WU00:FS00:0xa8:   Platform: win32 10
16:46:59:WU00:FS00:0xa8:       Bits: 64
16:46:59:WU00:FS00:0xa8:       Mode: Release
16:46:59:WU00:FS00:0xa8:       SIMD: avx2_256
16:46:59:WU00:FS00:0xa8:     OpenMP: ON
16:46:59:WU00:FS00:0xa8:       CUDA: OFF
16:46:59:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17628 -checkpoint 15 -np
16:46:59:WU00:FS00:0xa8:             6
16:46:59:WU00:FS00:0xa8:************************************ libFAH ************************************
16:46:59:WU00:FS00:0xa8:       Time: 11:24:13
16:46:59:WU00:FS00:0xa8:************************************ CBang *************************************
16:46:59:WU00:FS00:0xa8:       Time: 11:23:53
16:46:59:WU00:FS00:0xa8:************************************ System ************************************
16:46:59:WU00:FS00:0xa8:        CPU: AMD Ryzen 5 3600 6-Core Processor
16:46:59:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
16:46:59:WU00:FS00:0xa8:       CPUs: 12
16:46:59:WU00:FS00:0xa8:     Memory: 31.91GiB
16:46:59:WU00:FS00:0xa8:Free Memory: 23.36GiB
16:46:59:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
16:46:59:WU00:FS00:0xa8: OS Version: 6.2
16:46:59:WU00:FS00:0xa8:Has Battery: false
16:46:59:WU00:FS00:0xa8: On Battery: false
16:46:59:WU00:FS00:0xa8: UTC Offset: -5
16:46:59:WU00:FS00:0xa8:        PID: 10352
16:46:59:WU00:FS00:0xa8:        CWD: C:\Users\Christine\AppData\Roaming\FAHClient\work
16:46:59:WU00:FS00:0xa8:********************************************************************************
16:46:59:WU00:FS00:0xa8:Project: 18206 (Run 15346, Clone 0, Gen 159)
16:46:59:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
16:46:59:WU00:FS00:0xa8:Digital signatures verified
16:46:59:WU00:FS00:0xa8:Calling: mdrun -c frame159.gro -s frame159.tpr -x frame159.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
16:46:59:WU00:FS00:0xa8:Steps: first=19875000 total=20000000
16:47:01:WU00:FS00:0xa8:Completed 74442 out of 125000 steps (59%)
Re: Please Add Radeon Pro W6600 GPU
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/r ... 6600.c3818
Your GPU should fold nicely. it meets both prerequisites 64 bit Floating Point math and OpenCL 1.2 (or greater) support.
I hope the database is updated.
0x73e3 / Navi 23 WKS-XL [Radeon PRO W6600] has been added to the list of supported GPUs.
Christine_the_Foxy
Thank you for the quick action.
We grabbed the first WU for the card here a few minutes ago. Sitting stead at 100watts consumed, 98% load, and 2.588Ghz core clock ~74C.
Current estimated PPD is 252,300 which I am honestly impressed with for a single slot card.
Christine_the_Foxy
Following up now that Driver 22.7.1 is out just in the event anyone searches for this card and its performance.
Driver pack 22.Q2 from the pro side kept PPD to 230k-270k depending on what project was assigning WU.
Driver Pack 22.7.1 from the mainline consumer drivers has increased my estimated PPD to ~700,000 PPD on a single card. This is a pretty drastic increase from a driver update.
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
That's quite the bump from a driver alone. Well worth the update it seems!
Fold them if you get them!
Christine_the_Foxy
as a further Follow up with mainline Adrenalin Driver 22.8.2
running at 100%, sitting at about 72C on the core. right at the 100watt TDP
Running for the last 4 hours has me up to 1,406,710 PPD per Card. I have installed folding at home in the dark, and finally passkeyed my folding account so it should eventually be externally verifiable on folding.lar.systems. Time per fold is at 3min 02sec and decreasing, where it was around 5min per fold before.
