Integrated Mac GPU
Alyx312
Integrated Mac GPU
Post by Alyx312 »
I'm not sure if this is the right place because I'm not used to navigating this sort of forum, but I'm running a 2021 Macbook Pro, and when I try to add a slot for my GPU, I get "No CUDA or OpenCL 1.2+ support detected for GPU slot 03: gpu:-1:-1. Disabling.", is there anything I can do to fix this? Looks like re-installing NVidia drivers worked for someone I found here, but I'm not on a NVidia GPU and I couldn't find any relevant info in that topic, if anyone knows how to fix this, that would be highly appreciated!
Re: Integrated Mac GPU
Currently GPU folding is not supported on the macOS. But the GPU detection code is universal as the code in the client is the same across Windows, Linux, and macOS. However then it can not find either CUDA or OpenCL support which results in that message. You will not be able to enable a GPU slot.
Sometime in the future GP folding on macOS may be possible. But no guarantees or possibly timeline for that to happen. There are multiple items that would need to be developed and tested before this will be possible.
