Suggestion for advanced viewer
Peter_Hucker
Hardware configuration: Ryzen 9 3900XT: 24 cores, 128GB RAM, 1TB NVME, 4TB HDD, R9 Nano (Fiji) GPU.
Ryzen 9 3900X: 24 cores, 64GB RAM, 250GB NVME.
Xeon X5650 dual CPU server: 24 cores, 64GB RAM, 250GB NVME, R9 290(Hawaii) GPU.
Xeon X5650 dual CPU server: 24 cores, 64GB RAM, 250GB NVME.
I3-6100: 4 cores, 32GB RAM, 250GB NVME, 2 of R9 2980X (Tahiti) GPUs.
5 other smaller computers.
Post by Peter_Hucker »
Can't find a suggestion forum, so I'll put it here.
Running several computers is hard work using FAH advanced (so I'm using a 3rd party program HFM which is a bit better).
It would be good if all the computers showed at once, one line per slot. At the moment, I have to select a computer first, and even then its slots are split into three areas of information.
